- how much will heavy wheels hurt at the track?
- shock absorbers
- Where do you mount race transponder??
- mounting question for Sparco Roadster owners
- Was anyone else confused watching the F1 race?
- Feedback from owners of LG coil-overs
- Sparco Milano?
- Things that make you go Hmmmmm
- Proposal for Cone Redesign Shows Promise for Autocrossers
- SPEED GT Aston Martin DBRS9 Pics
- fs: penske shocks cheap
- G force during braking (F1)
- Ferrari on POLE 1 & 2
- Brake pads -only auto-x-
- HELP brey-krause harness bar install trouble
- Reinvent the wheel?
- New F1 V8s
- Safe Motorsports waives membership fee for Homestead Event 4-15-06
- can C5 calipers fit a 1.38 inch rotor?
- Who posted Shock dyno chart.
- oil cooler/radiator combo drm or lg?
- MFBA@RA Invite!!
- GTO is not dead
- Best value for wheel bearings
- SPEED Top 10 Moments #4: Mercedes Le Mans Flip
- Sebring Tire Consumption
- Stock C5 Seatbelt Q? (Cinching?)
- What brake fluid to use?
- Aftermarket Mascer Cylinder brake lines
- NVCC host HPDE event at Summit Point Main track April 10th
- Toyo RA1s or Nitto NT-555RIIs?
- Brake ducts for c4
- UN-NASCAR TV This Weekend, March 10-12
- Coilover spring rates
- Who is going to Sebring Next Week??
- Max width on 17" wheel/tire combo
- Help with decision on rotors please
- C6 Calipers - Fixed piston problem?
- Corvette driving school
- Prospeed Gs610
- c5 coil packs, how long do they last?
- Is the C6 Z06 brake pkg the "way to go" C5 brake upgrade or not?
- Penske shocks for sale
- Team PSI's new C5-R and C6-R plus new Z06.R GT3
- Auto-Crossing
- Video at CMP with PCA....
- Physical Damage Insurance is Available for your Track Car ... but not Liability
- Kumho C4 Auto-X tire grip question
- Trans fixes?
- 305/35/18 RA-1's on Wagon Wheels - Advise please
- Airborne Enzo and the Swedish Mob?
- Pacific Northwest Track Days!
- On bumpy uneven surfaces do your cars tend to skip?
- Accident at Cresson MSR
- four post lift f/s
- A weekend at the California Speedway; April 1st & 2nd, 2006
- SV at Laguna Seca - Only $290 with free timing! 3/21/06
- Kotzian kicks at San Diego Tour
- boiled the brakes? so soon!? (C4)
- Roach motels in Kershaw
- c5 plug wire heat-socks/wrap, where to buy? size?
- C6 Z06s now at Spring Mountain Advanced Driving School
- 9.5% off HANS Device
- Corvettes represented well at CMP with the Porsches....
- Sound limits at Tracks
- Got to test Yesterday
- Sound Limit at Tracks
- T1 season is starting for me!!
- Open Trackers with brand name headers, please chime in.
- L angle exhaust--D. Popp or other, help !
- C6 Airducts
- Spring Mountain 3 day level 1 overview
- Need to reduce body roll
- Bendix Rotors zinc plated
- Need information on pour foam for custom seat insert.
- c6 z51 brakes
- Audi Diesel - First run?
- Open Road Racing For '06
- HANS Device Size?
- Tow Vehicle 93 International Aluminum Roll Back (19ft)
- FS: Tow Vehicle - Silverado 3500 4WD Crew Cab
- Check out this working model car!
- F-1 split possible?
- Prodrive Plans F1 Factory
- Sun Strip across Visor??
- Steering wheel removal
- Oil block adaptor and Canton Thermostat FS
- Best wheel/tire combo for racing/autocross
- Steel Braided Brake Lines
- Stiffer springs, Stiffer sway bars = Less traction?
- Question for Randy at DRM
- simple ? re: c6
- How to get there?
- C4: Rear axle ratio
- Question about RA1's and size diff F to R
- CHEAP!Used Hoosier A3S05's: season offer for all of my used tires- about 10 sets
- New Hoosier R6s and A6s Announced
- All that hype about turbo engines, now they're finally seeing the light.
- Instructor personal liability for track events
- Sebring 21-23 Apr with SVTOA
- C4: 335/35R17 Rears?
- oil filter 4 track events?
- Koni Adjustables - Setup Recommendations?
- C5 suspension compression issue rubbing rear liners
- ALMS - GT1 Adjustments
- Four 18 inchers?
- 1999 Corvette FRC T1 for sale
- C5 Owners - What Fluids Do You Use For The track
- fs: penske shocks
- **3 car LG Motorsports team for World Challenge**
- Tire concerns?
- 174mph run
- How much steering wheel play is normal? Anyone wear their steering rack?
- FS: Dart Little M 400 block, Forged Stroker Crank and Rods, Roller Cam
- Need ideas to temporarily reduce exhaust noise
- Getting psyched about track time! How do I know when my Hoosiers are dead?
- racing vendor experience
- UN-NASCAR (& NASCAR) TV This Weekend, Mar. 4-5
- BMW introduces Z4M Coupe
- Karting on MArch 8th at Mid-Atlantic-an invitation
- need help
- A bent '06 Z/06 for Randy@DRM
- In-car Video of Putnam Park needed...
- Help with Camber
- More camber
- Any potential Corvette racecars for rent in Northern California?
- A question about track tires
- Performance Driving School @ Michigan International Speedway
- where can I get resonable 18"x12" wheels?
- FYI C6-R News
- T1 Suspension Kit Parts for Sale
- MagnaCharger for Autox?
- QTY 2 17X11.5 Rear CCW wheels for Sale
- c6 tire choices
- What price for Late C4 Konis?
- Test And Tune Grissom Afb Peru In April 8-9
- Ride height/ shock question
- Cobalt Spec VRs?
- Any T1 drivers have any video of Road America?
- DeWitt's EOC hose kit for C5
- Temps Too Hot !! Need Help From Cooler Guys
- Crew help needed for SCCA Roebling Road National - T1 March 10-12
- Should I consider changing my stock valve springs?
- Brake control module with aftermarket brakes
- Need help, front end "clunk"
- Track Day Tires For Sale---Hoosier and Kumho
- street/track car weights? thought mine would be less
- Skip Thomas is coming to Atlanta March 24th
- Two (2) upcoming HPDE events
- Coilovers with T1 bars
- Best RR tires for Wagon Wheels?
- Will 3 tires fit inside a C5 Z06?
- Super Blue Brake Fluid
- C5 engine oil adapter with headers
- BK Harness Bar and Sub-Mount Install
- Autocrosser Goes for Olympic Gold!
- Cheap track support
- Helmet help
- 255-40-17 or 255-45-17 Front tires for Stock '98 Z-51 Coupe
- FS: Used 2004 LS6 Crate Engine
- FS: GM GrandSport Wheels
- Penske Shocks F/s
- FS: Used GM C5 Z06 Clutches- Excellent Condition
- FS: Used GM T1 C5 Control Arms- Need Bushings
- FS: Used GM T1 Sachs shocks
- FS: Used Hawk DTC-70 Brake Pads
- FS: Hoosier Racing Rain Tires 315/35-17 and 275/40-17
- FS: GM Grand Sport Wheels
- Track Day C5 Set Up...
- Can C6 compete for real in autox?
- Ohio's nelsonledges fun days worlds cheapest track time
- Motorsport Ranch Event March 3 & 4
- Penske Coilover reservoir mounting Location
- seat help?
- So What's the Deal with Brake Fluid?
- MSR Cresson new section open yet
- Wiring harness for C4 trailer?
- Anyone use the GY Eagle RS?
- Need Pic's of Sparco Evo 2 Installed
- column lock fix? I don't want them to re-flash my pcm.
- Finally decided to get the expensive AMW catch can and it's $200 now!
- Where to buy: Wilwood Pads
- Name and bloodtype info?
- M2005 Class Helmet?
- Good place to mount tow hook???
- More helmet talk - PICS!
- F1 teams and Race Calander
- Hooiser's f/s
- Hotel for THSCC North Course event???
- LS2 oil pan on LS6> Pics
- Time to buy another set of race pads... which ones? Wilwood H or Carbotech?
- 2006 Norcal AutoX School: March 25th
- Prepping a Zo6 for Solo1..Suggestions please!!
- Watkins Glen August 2nd & 3rd
- Tow Hooks for C4's
- Opinions/Experiences With MSR Houston
- Son Needs Cochlear Implant Surgery ...
- Helmet clearance problem
- LGM spindle duct additions
- NORCAL - Want 60-90 minutes of Auto-X seat time for $50?
- Increasing towing capacity w/Tahoe
- Transponder questions???????
- Watkins Glen Video
- GTO now cancelled!
- C6 Z51 2 piece rotors
- PCA Event @ VIR May 19-21
- 24 hour Le Mans Entry list anounced
- Hey Too Tall - SM times?
- Window nets for C5 racecars, any preferences ??
- Auto-X Test & Tune March 4th at Marina - Vettes ONLY
- 19" race rubber
- FS Brand new CCWs in stock C5 Z06 sizes
- If you drive your car to the track when are you swapping pads?
- FS: Kumho Tires: 1 V710 (315); full set of Victoracers (full tread)
- All Corvette Autocross 03/05/06 Marina (Monterey), CA
- Track day numbers
- Just Put on the Hawk HP + Pads
- NE1 run 17's front and rear?
- HELP WANTED - Alignment Specs, Tire Wear Pics Included, How Far Can I Go?
- Hallett Motor Racing Circuit - Anyone Driven This Track?
- anyone here doing Spring Mountain level one Feb 28th?
- R-racing 1992 Lt1 Mech Or Electric Wp
- R-D Cross Bar F/S - fits late 90 to 96 coupe
- CMP race results - Team TrackTapes.com finishes 1-2
- C6, Z51, Z06 2pc & 1pc rotors
- DRM spy photo
- Pair of Brand new Hoosier Wet racing tires.
- Wanted - Helmet with good ventilation
- Wonder how much trouble I just started...
- Power steering mods
- Official NASA-SE Track Side Tire Service - Sasco Sports
- Tow Starps/ Pic of yours on traler....
- New helment
- The ITCHY BALL REPORT
- Back in the day!
- Track pressures for Supercar Tires
- looking for a different steering wheel
- Mid-Ohio with BMW on Memorial Day weekend????
- DRM C5/C6 Modified Master Cylinder for sale
- Rental Cost
- Open Track Day at the new MSR Houston
- 1 run, the best wins
- Harness Question
- News Flash-Ft. Myers: AARP Card Carrying Old Geezer in SS Z06 beats Lehman in ASP Z06
- Spring Mt. Level II mid Feb. fantastic !
- Vettes invited to NFME event. Road race, auto-x and DR
- Porsche rotors on c5/C6-Electro-dynamics??
- Hoosier Track Day Tires... For Sale
- I need a Race Prepped C5
