- 2003 ZO6. Do any of the computer functions run through the head unit?
- Please help pick out my cd/mp3 player
- Best place to buy GM10-AUX
- Will a factory C5 Bose CD player fit into a C4?
- first the 12, now the amp
- New HU in 94 non-Bose coupe
- question on c5 radio
- C4 aftermarket HU power
- Where to tap speed sensor wire for navigation
- Question for C4 Guys
- Alpine MP3 Head
- UNCLE ! ! I give up !! Need help before torching the car !
- anyone install a sony plug-and-play xm radio in their C5?
- Another C5 stereo input question
- My cheap stereo parts for Suburban.
- Help, remote cd magizine will not eject..is there a manual way to get it out.
- Which 3.5" tweeters & 8" woofer should I go with for my 98 C5 coupe with stock BOSE HU?
- ALpine XM units
- How bad woud this sound?
- C5 Bose Amp
- My lil' TV
- My ears need help???
- New Bose for 04? Or just the same?
- Proposed Cerwin Vega Setup, for a C4...With Stock Bose.
- Need c5 speaker choice help...
- Looking to buy some tunes, need advice on woofers and door speakers...
- Kick Panels
- Self dimming rearview mirror
- Bose: Does it have RCA inputs?
- Will a CD/radio unit from 2000 work in a 1999 model??
- Crossover install location
- Looking for metal dash bezel
- C3 factory stereo radio
- Im new to all this Audio Stuff can someone help me out with my new system...?
- Stealth Sub Box
- Headunit options-90 Vette
- Experience with XTANT?
- Moved the tweets into the door panels on a C5
- CDT CL61 Mounting Help
- Adding an amp to the stock head unit in C5?
- Kicker solobaric question
- Is it easy to fix a blew sub
- Alright, I finally blew a 12"
- FM RECEPTION
- New Clarion DXZ835MP AM/FM/CD/MP3/WMA PLAYER
- Paging VRUMVRUM
- Speaker wire calculator...
- Rear Speaker Replacement
- C5 Rear Speaker Removal
- 1990 headunit install question
- C5 HVAC Controls... Single DIN?
- IPOD & Fm Modulator
- Looking for a 7" or 8" screen for dash-not motorized
- After market CD changer installation
- C5 Amp, Amp Rack, and Stealthbox-style sub for sale
- has anyone replced only HU and kept factory speakers?
- anyone have documented steps with pics how to install HU IN C5????
- head unit mounting???
- Can this alarm be installed in a '92?
- Info wanted on wiring plug for bose in 86
- NE 1 know of a good place to buy a JL 1000/1?
- 94 Coupe System questions...
- Where can I learn about amps and such?
- Please post pics of your head units....Thanks
- Data acquisition/accelerometers
- For those with XM - A question if I may
- Ok you audio gurus..I need suggestions on a GOOD amp that wont break the bank.
- C4 center console bezel w/LCD
- stock CD changer replacement...
- c5 install- metal tab behind HU
- HU install = pita
- speaker level inputs?
- Need help with radar detector hardwire.....
- Best C5 dash kit
- Alternator Recommendations
- Best Tweeter/Front Speaker location in my 92?
- Need an access point thru firewall
- Bose replacement options?
- Bose Repair Recommendation
- Weaterhead C5 Project Car - What Happened?
- Power antenna hookup for C4 aftermarket system.
- Bose problem, i think.
- panasonic "ghost" touchscreen HU
- C5 altenator enough for JL 300/2 & JL 1000/1
- adding alpine 7878 do i need bose adaptor?
- WTF?
- stereo install 79 vette
- Ohio and Maryland Cops... running speed traps no radar signal on V1 unit
- C4 Delphi XM modulator installation?
- Clicking static only, 91 ZR1
- Speakers mounted in aftermarket rear compartment devider?
- Last Minute Advice
- CD Changer Re-Location
- Where do I wire in a CD Changer - 95 Gold Bose
- Best Adapter for replacement HU w/Bose
- Help me pick black headunit (mp3 is a must!)
- Looking to replace Bose in 91
- It began easy enough...new speakers in C4
- C5 Window Valet on after market HU - coming around Xmas
- How to clean the C5's CD changer heads?
- OEM speaker locations and size in 2002 Z06?
- Amp ground location in C5
- PhatNoise Digital Media Players - works with Corvettes????
- Question for a C4 Bose expert
- Is there a good info site on car audio ?
- How to remove radio???
- Rear speakers in C5 Coupe necessary or not?
- Help please !!
- [CD-RW Playback Trouble MP3 Format]
- Planning a C5 stereo and would appreciate your help
- finding 3 pin connector
- C5 Coupes with an aftermarket Head Unit.
- stereo troubles 79vette
- Satellite radio recommendation for Z06
- Good multi channel amp?
- Bose Wiring Harness Color Codes 1994 C4 ??
- re-arrange the stereo field - calling all experts, advice please
- Alarm problems
- Has anyone installed one of these into their C5?
- How do you calculate your necessary wattage?
- Here goes nothing- sub enclosure build
- Aftermarket radio in 96
- JL sub question. 10W3 vs 10W6
- Got my Cd player and amp installed - thanks Kale
- Mounting kit for c5?
- FOR SALE: 12" custom fiberglass sub enclosure.
- WANT TO TRADE: My Alpine for your stock CD
- I Pod Users; help
- Shop replaced amp, fuses BLOWN AGAIN!!!!!
- ('89 C4) Noise from Bose system - any thoughts?
- amp location????
- Help with Bose system please
- Looking for some JL 10W0s...
- Are Jensen Amps even ACCEPTABLE?
- Finally got my JL equipment installed
- How to: remove shifter knob/boot and...
- Us Acoustics Amp going into protection mode??
- F/S Eclipse 55060 head unit, EQ ect..
- 1000 + watt guys check in- alternator issue
- Half a Sterio in my '91?
- Sub Box
- F/S Dell C/Port2 v3 Docking Stations
- been awhile.... lets see some system pics...
- can I just put a sub in my rear storage area??
- Use Aux10 from PIE for C5. May need COR-HAR also from PIE. AUX GM9 is for F bodies.
- Garmin Street Pilot III mounting ideas
- Equalizer Installation
- Looking for Bose Speaker Relay in my 85
- monster cable 50% off
- C5 Amp. wiring questions
- BEST PRICES ON CAR AUDIO?
- Stereo install help for a '91
- GM Pie Corr Harness install ?'s for a C5
- Bear tracker? What have we got here?
- Help with C3 Stereo Install
- Took First Place
- New Alpine DVD IV-9000
- Has anyone tried the AUX GM9 Digital input converter in their C5?
- [F/S] PNI Sensoro Traveller radar detector
- Power Antenna Relay
- Alternator Noise
- My CD player skips is there anything to do other than throw it away?
- Still looking for some advice.
- F/S JL Audio + Alpine Changer
- Best stereo installer on Long Island? (NY)
- heads up on a good deal
- 3rd brake light is rattling
- Crutchfield has outstanding customer service
- Best tweeter for a smooth, non-harsh sound?
- Monster Cable
- Check out this monster amp
- Where to buy JL and CDT audio components on the net?
- Want to upgrade, need help!
- And so it begins.... (XM, new tuner, Changer..)
- SPEAKER POPING
- Bose Speaker System Poll
- recommendation for Audio shop in DC/MD?VA area
- Looking for Great Stereo Deals!
- [FS] Bass Blockers shipped cheap
- Need some suggestions on sub choice....
- F/S JL Audio 250/1 $230 shipped
- Sub for a C-3, I am so stoked
- New mids or new components?
- C4 Rear Speaker Template 4U
- [On Topic] Corvette Video Game
- Replacement speakers in a C-5?
- Amp/Sub install in Zidanes 88 coupe (lots of pics)
- C5 tweeter installs
- Mids stop work...How should I start to trouble shoot?
- sub-$200 speakers for a 93 C4?
- Pop when amps shut down.
- XM Antenna Location on a C5
- Is it better to use front or rear outputs for a sub?
- System Complete - louder than the voice of GOD! Can you name my speakers?
- Woofers under rear compartment doors
- Why wont anyone install a radio in a C5?
- PLEASE CONFIRM SUB WIRING ON BOSE????
- Suggest a subwoofer & amp(s) for me!
- Subwoofer in an FRC w/partion
- The system is finally done
- Some speakers for a C5 FOR SALE
- Anyone Familiar with the Garman Street Pilot III? A Memory Question
- [Bose Gold '90-'96] Is there a "c" cable connection in the back for direct cd changer connection?
- Where is the Audio Relay.....
- JL Audio 500/5 vs Kicker 700.5
- CDT CL6X ?
- sound shorting out?
- Antenna Help
- How is everyone attaching their amp rack in C5?
- Thoughts on Eclipse CD 8443
- Door project almost complete...
- What is the Best Car Alarm on the Market?
- Be-Quet insulation; which type, how much?
- My HU has a set of Pre-Outs specifically for a Subwoofer. Exactly how do I set them up?
- Call me f'd up, but I think this would work! (maybe)
- Help with AMP (adapter)
- What 5.25" speakers do you like ??
- Easiest way to limit power to cigarette lighter?
- Wiring an amp to SUB
- Bose wouldnt turn off
- Any good stereo system installer in the Los Angeles area?
- C4 Bose Gold CD for 90-96 Corvettes
- 96 C4 Upgrade, why bother with rear speakers, just use components in the frt?
- 87 Bose System - Blows Fuse when I turn on the radio
- stealth C4 sub install
- firewall ?
- Fuel door rattle..
- How/Where do you guys mount amps and crossovers networks
- How do you know if you blow your speakers?
- Any Return To Changing The Bose Drivers?
- Will they fit? - 6x9's in the back of a C5!
- My version
- WTB: 25x2 amp
- Amp Ground '79
- Problem with USX-4085 amp, WTF....
- Bose problem
- 12" sub in my 98 c5
- How strong is the glass hatch on my C4?
- would 6.5" components be a direct fit for non bose hardtop?
- Testing for short circuits (repost from C3 Forum)
- Are these speakers any good?
- Amp/Sub Wiring Question: Do I still wire the sub in parallel if the amp is?
- Help choosing amp...
- Rewiring of blower fan, radio, & lighter.
- Tweeters- argh
- SCORE! Just picked up MTX Thunder4250D for $125!!!
- adding a dvd player to a stock system
- Audio expertise needed!!
- couple sub questions...
- need sub enclosure for FRC
