View Full Version : Audio/Electronics
  1. Escort 9500ix for sale
  2. Woofersetc Bad Experience
  3. Bose fading out.
  4. FS: AudioLink PowerLink II High level to Low level converter for adding an amp
  5. FS: Pyramid NS-90 Smart Remote Turn On Adapter for adding an amp to stock system
  6. Toss 2008 Bose Amp?
  7. metra antenna adapter
  8. Help Required - Kenwood Install - C5
  9. C5 Factory HU & some upgraded toys...
  10. C5: Help with switched power source
  11. need help mounting amp rack/sub
  12. how to mount a IPhone and Sportster sirius radio in a C5?
  13. sub question
  14. Where to buy a quality speaker terminal, RCA terminal, etc?
  15. Metra VT-GMOS-04 or Peripheral GMAH24B
  16. Pioneer AvicF90BT
  17. Adding amp/sub to Kenwood deck; question
  18. C6 Power Wire Routing Question
  19. a couple of questions on wiring a custom vette system?
  20. C5 door styrofoam and sound deadening
  21. Anyone in KC good at C6 stereo stuff?
  22. Kenwood DNX7120 bypass?
  23. Question about the auto stay on feature
  24. c4 wiring harness?
  25. Suggestions for 3.5" front speaker replacement
  26. Simple And Quick
  27. Speaker choices
  28. What amp to get?
  29. FS: C4 Aftermarket Audio System, Alpine/Memphis Speakers, Alpine HU
  30. Record Internet Radio
  31. wire routing - C5
  32. Well this bites
  33. AVIC Z1 installed on my 07 1Lt Vert
  34. Need some quick help
  35. Onlinecarstereo.com
  36. Amp Selection Decision
  37. Basic question regarding RCA outputs(non-amplified)
  38. My proposed setup
  39. What deck to get? (2003 Z06)
  40. C5 coupe terrible reception.
  41. Upgrade
  42. pioneer 900
  43. C6 with Kenwood DDX-712 - "Pop" when powering down?
  44. Wiring Kenwood H/U
  45. Anyone use "Shallow" 10" woofers in a C6 door?
  46. 6 x 9 Component
  47. c6 radio static issues!
  48. 2008 'Vert, where to mount 2 PDX amps...?
  49. New ?? about hissing.
  50. Want to add sat radio to 07 C6 LT1 need advice
  51. Stereo Removal
  52. Passport 9500 ix ( HELP )
  53. Where to run wires through the firewall on a C6
  54. 2009 Coupe rear 6 disk changer help needed.
  55. Ideas for mounting aftermarket front and rear speakers on 94 Corvette.
  56. Help. Trying to build my own box.
  57. Help- no sound
  58. Popping sound in speaker
  59. need help wiring gods on head unit dvd player
  60. iPod on a 6-CD Changer
  61. Any suggestions on where to put the Kenwood Nav Antenna?
  62. Single DIN HU into 98 to satisfy DD needs
  63. Columbus Sound system installer in Central Ohio needed...
  64. Quality of Ipod through cassette player?
  65. VrumVrums contact info
  66. Touch Screen sensitivity on AVIC-F900BT?
  67. FS: Jl 500.1, 300.4, 300.2 (5 amps total)
  68. Electronic Device to get speed data
  69. Sirius antenna.
  70. Need Bose Amps
  71. FS: Car Audio Stuff
  72. Okay to drive C6 with radio removed?
  73. Need advice: Best aftermarket HEAD unit for 08 C6 ????
  74. You might be an audiophile if.... (humor)
  75. MVM Sale: 20% to 50% off all items!!!
  76. stereo wiring
  77. I took the plunge...
  78. Does any-one have a CDA-9885 Alpine stereo and a Ipod 3G ?
  79. Ipods on factory Nav unit
  80. Kenwood, Pioneer or Eclipse?
  81. Bad AM Reception ?
  82. Some Advice and Opinions
  83. FS: (2) Peerless SLS 6.5" Midbass woofers. (#830946)
  84. Need Suggestions on HU for 95 C4
  85. Beltronics Pro GX65 or Valentine 1 ?????
  86. Power wire to amp - firewall location?
  87. C6 auto volume feature
  88. Any phots of how to wire AOEM-1 and speaker wires for C5 sub box install?
  89. ehhh think i blew my speakers =(
  90. Stock 12 disc changer mounting nuts...size
  91. need a bit of help with my set up.
  92. Can an Aftermarket Nav sync with a radar?
  93. replacing o5 c6 factory nav head unit?
  94. Grounding Questions
  95. Door panel clips?
  96. Key Fob not detected after Parrot install in 08 Z
  97. Finally Happy With Stereo!
  98. Help with audio power wires
  99. stereo experts
  100. How to get speaker wire to door speakers in C6
  101. Stupid Questions?
  102. Engine Noise after Big 3
  103. Burned Cd's
  104. Amp under center trunk compartment in a C5
  105. Any one know the +/- color code on the speakers
  106. (PICS) Double Din Install and Nitrous Relocation!
  107. dyno mat question
  108. Problem loading backround pics on DNX5120
  109. 1LT C6 without Bose- I should have known!
  110. C5 sub/amp question
  111. Thank You CF Audio Forum
  112. Bass Improvement Question
  113. DNX 5120- bluetooth problem
  114. Few Questions After Install of F900BT in C^
  115. 2008 Factory Nav Install in 3LT C6?
  116. Double DIN in early C4
  117. Alpine Blackbird and Daylight savings time ?
  118. Factory Stereo Question
  119. Another advancement in sound deadening and heat C5
  120. o8 A6 stereo head replacement
  121. recommendation for Atlanta sound shop?
  122. Help Design My Stereo
  123. remote wire for c6 rehash...
  124. Pics of black carbon fiber double din bezel installed
  125. ipod adapter question
  126. '93 C4 - 6.5" speakers in front?
  127. need help building boxes...
  128. Just installed Avic Z3 & JL HD amps, sub & speakers
  129. Toasted IPOD - Coincidence??
  130. Need help hooking up my sven2
  131. New XM / Sirrus Offer
  132. Amp Board+Sub -Need safe places to Bolt Down in a '92 coupe C4
  133. For the experts..JL audio c6 install
  134. kenwood nav vs avic fb90t
  135. problem with my passenger door speaker.
  136. Anyone Here using Trapster?
  137. c4 1992 bose cd
  138. HUD Compatible Aftermarket Head Unit?
  139. Amp mounting
  140. iphone apps and nav systems
  141. Kenwood Double DIN 7" Indash DVD/Navi F/S
  142. F/s old school PPi amp 2300m
  143. c6 rear speakers
  144. which brand is best
  145. burning cds
  146. CACorvetteCustoms Z06 Sound System Install **** PICS****
  147. C6 Center Speaker Bose Amp Question
  148. Any experience with Pioneer head unit?
  149. No dimmer control - DNX5120
  150. Hands Free Mic on A-pillar (C6)
  151. Best Head Unit
  152. No AM Reception
  153. a few questions
  154. Double Din Install Pics C5 - Gary Grunz
  155. my320paid4byme C5 Install Pics
  156. Alpine components question
  157. Just Want To Give A Big Thanks!!
  158. C6 door woofer question ?
  159. Time to replace the stock headunit in my 98
  160. My fellow Audiophiles
  161. WTB: Stock Head Unit 02 Z06
  162. Changing over from Bose
  163. Auto-Dimming Mirror Light Sensor
  164. F/S New and Used Alpine Equipment
  165. Vegas and Southern California Audio Shops
  166. Question on factory radios
  167. Amp mounting area.
  168. DNX 5120 install-no sound
  169. Pics of Sirius Starbase hidden in ashtray area
  170. Problems solved with Alpine HU.
  171. ** NEW Kenwood Excelon KVT-915DVD-TV **
  172. Opinions of c6 sound
  173. Polk SR questions
  174. 2008 Factory NAV Manual
  175. curious about others experience with powerfull audio setups
  176. 4/s pioneer premier head unit& 5.25 components
  177. Newbie here. Need to ask some questions
  178. New Blaupunkt 350 watt amp and 6x9 Speakers - $150
  179. AVIC F 900BT Owners- What other parts did you buy??
  180. Power antenna question.
  181. C6's with amps in cubby or oem location
  182. Do any NAVIs display bouncing equalizer screens or cool graphics with music?
  183. Stereo won't play anymore???????
  184. Navi recommendation for someone who does not care about Navi
  185. Nav + changer 6-disc
  186. Amp guidance for front components
  187. Center Speaker poll - speaker upgrade
  188. AVIC F 900BT- Multiple cameras Q's??
  189. 6CD radio
  190. Audison Bit 1 In C6 (PIX)
  191. Which NAV Do you guys recommend?
  192. New amp installed now whining noise in system
  193. New amp installed now whining noise i system
  194. Need help w/Kenwood DX5120
  195. Sound System setup w/o sub
  196. 6.5" components???
  197. NEW Vette Owner Needs SOUND Advice
  198. oem nav voice prompt
  199. F/S Butler TD475 amplifier and JL 8W7 sub in an NVTHIS box
  200. Totally bummed... Kenwood dropped backward compatibility
  201. Some SQ amps for sale
  202. XM Removal question
  203. need help installing an avic d1
  204. BOSE: 1/8 in stereo input?
  205. Stereo help (head unit)
  206. F/S Sound System - JL Audio Fosgate Infinity
  207. Stealth box help
  208. Need New Speakers/ Sound System - Help?
  209. C5 Truck CD Changer question....
  210. Upgrade rear - C5 Speakers on Bose system
  211. '05 Nav Screen w/o XM Firmware Question
  212. Tweeters on C5 A-pillar...
  213. ipod2car installation info
  214. Help on C5 DD Nav Selection (Milwaukee Area Qs)
  215. DNX5120 screen washed out during day
  216. 2008 Nav Download for Eclipse AVN 5510
  217. Kimber Kable Step Inside
  218. Radar Safety Warning System?
  219. Can i Remove my factory cd changer and add a sub & amp to the factory connection???
  220. needs some suggestions on new speakers
  221. Adding Sub Amp to Bose Headunit?
  222. new stereo
  223. Any GPS system do trip logging?
  224. Pioneer Double Din in a 93 C4? Help!
  225. Better C6 ACC solution
  226. 92 Hi-Mid soundstage sucks- What to do next?
  227. C4 Aftermarket Setup for Sale
  228. head unit
  229. Laser Jammer Group Buy
  230. C5 / Adding an amp Question
  231. Help Remote Turn On Lead for Amp ?
  232. help stock CD changer ?
  233. Wiring/Fade control interface to and add on powered/sub
  234. Passive/Active Crossover ???
  235. PAC SW1 controller
  236. RMS vs Maximum Watts vs Nominal Watts
  237. video for ken 8120
  238. C5 Sub Box PLans
  239. C6 Door Speakers
  240. dnx 7120 start up screen change
  241. C5-What I Have, What I Want, What I'm thinking. Help Please
  242. F/S Custom Front console Alpine tv and alpine head unit
  243. Any South Florida Installers Posting Here?
  244. CA Corvette Customs cranks out more double din bezels for the C5
  245. 08-09 Coupe Rear Speaker Size Step In Please
  246. Kenwood DNX5120 Install - Sanity Check ?s
  247. Bose door-driver blown?
  248. After Markert Front Speaker - Advise please
  249. Replacement speakers for C5
  250. C5 Looking to paint my speaker grills
