View Full Version : Audio/Electronics
  1. all early C4 Guys with Cd players Step in.....I GOT a few questions for you...
  2. How to combine Visualizations and MP3's on Video DVD??
  3. DIY Sirius Satellite Radio install in 2003 C5 via CD Changer
  4. 7 in screen install in a c4.
  5. factory nav disc
  6. Help with '08 C6 Rear Speaker Replacement
  7. 88 stereo aftermarket install problems
  8. Focal 165 KP vs Alpine SPX-17PRO
  9. GPS/CD player for C5
  10. Question on install cost for my setup
  11. new Isimple
  12. Good Or Bad Idea?
  13. c4 stereo questions
  14. Weak link alternator.
  15. HELP! VSS (speed sensor) for KD-NX5000
  16. Cable type?
  17. Budget C3 System.
  18. Orlando In-dash Nav Install?
  19. Avic F###BT with USB external hard drive?
  20. Avic F###BT with USB external hard drive?
  21. Polk db351 twiddler swap: use bass blockers, or no?
  22. Anyone Know Blaupunkt Sor29 ??
  23. Pioneer F90BT
  24. Who is doing the Digital converter TV mod?
  25. Sirius install tip
  26. Which wire to tap into for amp turn on signal
  27. AVIC F700BT Installed!
  28. Can someone recommend a good 3.5" speaker?
  29. 86 radio failure
  30. stupid question again (grounding)
  31. no bass in the car at all
  32. c6 Coupe Stealthbox woofer question
  33. Can anyone show me how to configure my amp
  34. [C6] Door Panel re-installation
  35. Alpine IVA-D105 any feedback?
  36. '85 Replacement 6 X 9 Question
  37. Sat in the C5
  38. IPod hook up??
  39. I've been waiting on the AVIC-F90BT, but the reviews are horrible
  40. Motorola Bluetooth Accessories, anyone have any of these?
  41. Fs Cdt Eurosports 3 way components cheap
  42. Changing audio system in my 2002, head unit, speaker selections, many questions
  43. infinity basslink t for sale
  44. Bass loss with aftermarket deck??
  45. IPOD Conncection to a 2003 Bose System?
  46. Starting on my audio system, few questions
  47. AVIC F900BT Qusetion???
  48. Bose amp replacement for C6?
  49. F/S C5 Sub Box With JL Audio 12" Sub Installed.
  50. new sub and box advice
  51. Can I use Metra wiring on Non-Bose and Non-OnStar Toronto HELP
  52. Removing the CD Changer Brackets
  53. subwoofer
  54. Pics of new fiberglass sub box C5
  55. Follow directions
  56. Perfect ending, got a free AVIC F90
  57. Need quick help with sven2, I'm lost!
  58. Amp install question w/ stock Nav deck
  59. Where to buy Carpet?
  60. co-worker
  61. Any good installers in northern KY or Cincinnati area???
  62. CHEAP, but good DD H/U recommendation
  63. C6 Ipod Cable Install W/ Sirius Sat. Tuner
  64. Got Tuned.... Ohhh Yeah.
  65. AVIC D3 INSTALL Wiring Help
  66. help getting better sound in c5 with stock hu
  67. How to deaden C6 doors?
  68. Green parking brake wire for D3?
  69. How high is your extended antenna?
  70. pics of my Setup
  71. radio reception is like crap....
  72. Need help with VSS wire for 99' C5
  73. Seeking advice on 6.5 componet set
  74. '96 Full Stereo Re-do, Part I (no 56k)
  75. Can't stop need help
  76. Help removing rear speakers from C6 07 vette?
  77. Are you SIRIUS???
  78. JL Audio 500/5 won't turn on???
  79. DNX8120 Write-Up
  80. Upgrade the NAV in your Z06
  81. Wheres the bose amp?
  82. Avic-f900bt
  83. Component Speakers vs Just speakers
  84. Questions about replacing C5 HU
  85. Fake Focals?
  86. photos of custom 10" pods for a C5
  87. C5 Bose CD won't work
  88. C6 Coupe NAV swap with Z06 6 CD
  89. C4 Stereo Questions
  90. Insane Work In Progress Sq Build
  91. I want R.A.P.
  92. Thinking of swapping Amps...thoughts?
  93. Bose/Delco Radio DIY
  94. New to systems..Hertz?
  95. C4 - What needs to be modified?
  96. Changed the Bose speakers in the doors
  97. 4Ohms & 2Ohms on same amp?
  98. double din install question
  99. Crossovers near the speakers or at the amp? (C4)
  100. Double Din Help
  101. FS: brand new Avic blue tooth adapter CD-BTB200
  102. Oiy! Need some advice/help...
  103. FS: (2) 300/4 & (1) 500/1 JL Audio amps
  104. soundproofing material HELP?
  105. POLL: Which component system for under $200?
  106. XM to Sirius ?'s
  107. iPod2car problems with iPod touch
  108. 1990 Bose - Displays Code SCV?
  109. 2008 C6 reception problems with aftermarket HU
  110. Amp recommendations?
  111. Mounting kit needed for 2-DIN nav install in a '96 w/ Bose?
  112. Clif Designs eqs
  113. pics of most of my stereo install
  114. 1991 Bose problem/question
  115. Infinity Kappas in C6 front and rear??
  116. Help pick speakers for my C5 (FRC)
  117. Anyone used hifisoundconnection.com?
  118. Any experiences (good or bad) w/ www.onlinecarstereo.com?
  119. LF audio install in Victorville/Apple Valley
  120. C6 install question
  121. [C4] AVH-P4000DVD installed today
  122. first pic of the prototype car pc interface
  123. Do I have to use a Pioneer Rear View Camera with D3?
  124. C6 Vert JL Stealthbox vs. mad vettes box
  125. Which Ipod adapter c5 2000
  126. C4 Headunit install -- Unit keeps shutting off?
  127. Escort 9500i gps vs Vette Navigation Help!!
  128. Stock Radio + IPOD in a C3?
  129. Rear speaker size in c5 convertible
  130. C5 Double Din Install questions
  131. Who has the C5 sub-box diagram?
  132. After market deck in 01 with bose
  133. question for the audio gurus! class 2 gm HU in C5?
  134. Any problems with buying components on-line
  135. Need Help, System for a 93 Corvette.
  136. Give me some ideas for an amp rack in my C5 Z06 (want to build tmrw)
  137. 5.25" and 6.5" rear speakers in C5??
  138. fronts only or fronts and rear in C6?
  139. Downloading Pics/Wallpaper
  140. Power to Aftermarket Head Unit
  141. Can you get a CD out of a stock HU w/o it being hooked up???
  142. 08 2LT Non Bose Bass and Treble Resetting
  143. sub killed???????
  144. programing bose radio
  145. Starting my stereo install tomorrow. Any tips?
  146. Pic of C5 dash without radio installed
  147. dumb thought of the day...glassing in the outer cubbys in a C5
  148. What Dash Kit for C6?
  149. Free fix :)
  150. C5: Infinity Basslink II
  151. iPhone and Motorola HF850 bluetooth kit
  152. need a stereo that is almost invisible like my old one
  153. grounding on a C6?
  154. need help on bose system no bass
  155. F/S or F/T: Alpine PDX 2.150 and JLAudio 250/1 -- Houston/Spring Tx --
  156. Subwoofer Boxes
  157. Subwoofer question 2 8w7`s or 1 10w7
  158. WTB: JL Audio amp...1 or 2 channel CHROME finish only
  159. Help me diagnose the noise coming from my right door speaker...
  160. Install question for the gurus....
  161. For Sale: Cerwin Vega speakers
  162. 1987 Radio tuner,sometimes yes,sometimes not !
  163. Radio tuner,sometimes yes,sometimes not !
  164. Best speakers for stock C4 enclosures
  165. customized box and cover for my amp
  166. capacitor choices?
  167. Alpine 9886 Satellite Radio Problems
  168. 81 speaker wires dash
  169. What are my options? Multi-line data from Sirius
  170. TAKE It ALL for $1000 !!!!!
  171. 6 inch subs
  172. Base Radio Pioneer swap
  173. Need Some Advice From the Audio Experts
  174. Alpine PDX or Jl audio Amps?
  175. CD ejects every time I power on the radio
  176. New system done... 2 pics..
  177. c6 nav in other gm car?
  178. SBH Corp RIPOFF
  179. C5 System Questions - Amp choices
  180. JL 8" subs for sale in C5 parts
  181. Speaker sizes
  182. Differences between Focal 165 KF and 165 KP?
  183. Pos Gmso4.....need Help!
  184. What do you guys think of the JL C5-650s?
  185. Ordered all parts for my system except wiring. Suggestions?
  186. AVIC dimmer interface to a C5
  187. Looking for a Stealth Box for a 06Z
  188. Dave at Corvette Audio rocks
  189. Who does custom amp racks?
  190. WTB double din touchscreen any1 seling?
  191. one side went out but....
  192. AVIC-N4 in my C5 Z06
  193. FS: Speakers & Xovers
  194. After upgrading your headunit....AM reception bad?
  195. C5 front speakers
  196. Subwoofer...should I use a single 12" or 2 X 10"
  197. ~ ~ 4 Ohms Vs 2 Ohms ~ ~
  198. XM...Fine Tuning
  199. C5 related looking for an interface that does IPod and provides RCA outputs
  200. Building my new system, '08 coupe
  201. Music... Reus Audio Systems At Coh
  202. Factory Head Unit
  203. wiring diagram for "08" 3LT
  204. wtb gm delco cd
  205. Is my ED amp dead?
  206. Anyone use the RF Power-1000?
  207. FS Pioneer D1 system
  208. C6 Stereo stuff For Sale
  209. Noise in system is making me crazy
  210. Using PDX 4.150 for Sub and 6.5 Components
  211. Almost there, sub/amp suggestions???
  212. Front Speaker Choices?
  213. Robls6 C5 Z stereo Install
  214. PAC aoem-vet1...If You've installed one, step inside.
  215. Installing Pioneer Z2 in 2008 coupe?
  216. C6 rip n replace options
  217. '94 C4 Wiring Problem
  218. ipod2car noise - video with sound
  219. The perfect no drill solution for an amp/cap in my C6 Z06
  220. I ordered it all...
  221. C6 Coupe Basic Swap Out
  222. Advice on rear speakers choice..
  223. Where to install Sirius unit help.
  224. Best Price on JL Audio Stealthbox
  225. DETACHABLE FRONT PANEL navigation unit
  226. Peripheral GMAH24B Wiring Diagram
  227. Anyone know the difference in JL speakers?
  228. Installing New Pioneer HU & Keeping Bose
  229. Antenna Wire Q
  230. Re-gluing Dynamat
  231. C5 Factory Bose HU
  232. Somebody told me this sub won't work with my box
  233. Audio Equipment.. multiple items.
  234. Good installer in Albuquerque, NM?
  235. Best Sound Quality CD/Mp3/Flashdrive/Ipod
  236. Replacing Pioneer P4000UB
  237. New DNX7120 install
  238. Anyone running a system with an under drive pulley?
  239. C6 Speaker Aim..Pics
  240. Phase Check
  241. AVIC D3 Problems: Please Help
  242. Looking for Custom woofer mounts (pref C5)
  243. Car PC guys, let me know what you woudl do differently.
  244. FS: Peripheral GM24B adapter
  245. Retained Accessory Power problem
  246. Advice needed ASAP! Just came up on a great deal on JL 10W7
  247. My ENTIRE SYSTEM, AMPS, SPEAKERS, ETC, except the sub.. $1500
  248. New sound system question
  249. JL Audio 13-W7 ... In a C5
  250. cd player reading all errors????
