- Onstar issue with avic f-700bt
- C6 CD Changer steering wheel controls
- L.E.D. license plate light
- upac-GMC2
- Will this setup work?
- Paging those using Apline PXA-700 signal processor
- Need help with subs
- Grounding 03' Z06
- About to setup my system, need some Install help
- I need one s35 Boston Acoustic Speaker
- power antenna problems
- C5 door speaker hole diameter.
- What size speakers in 08 coupe
- Help me select an amp please,,,,,,,
- Easy Question
- equalizer booster
- Doing a Little Upgrade.
- C6 XM question
- FS black 10" Hangover Sub Box **Local In NJ**
- C6 with Nav MP3 playback cuts short
- Door insulation
- Anyone replacing C5 front speakers, i need a measurement
- The PXA-Y701 and Ai-NET Devices - A Learning Experience
- Do you trim your RCA cables?
- Can I just add a sub to a 2008 with bose?
- GMCO and my aftermarket head unit .need some help.
- Extra speakers
- Car Audio Clearence Sale!!!
- Creating your own MP3 CDs with iTunes. . Step by Step instructions!
- C4 Full Audio Install ** PICS **
- Anyone have a set of 5.25 rear speakers they want to sell??
- Got my JL audio 12w6v2 in hangover box in
- Instal of Factory Nav Unit In C6 w/Bose
- Need help with a Kenwood 8120 in C6
- Anyone's experience with the Sony XAVW1??
- FS: JL 500/1, Premier components, Escort X50, IDQ10v3
- Corvette GTP (push button)
- Sir-gmi harness location
- Info needed for C5 aftermarket alarms
- STOP! Read this before you use: Fatmat, PeelSeel, and other ASPHALT products...
- Pioneer AVIC-D3.....WTF
- Which bass to get in a 1980?
- Any other uses for the Navigation screen in the C6?
- Fitting multiple mid-bass drivers in a C5 door
- lucky me, I smoked a focal midrange
- DD Bezel Mod
- Audio Dave is a vendor now!!! Labor Day Sale!!!
- kinda screwed up my previous thread, so lets try again.... buzz from amp
- Please help, can't get onstar to work with aftermarket stereo
- Alpine SPX 3-way and other install items very CHEAP!!
- Holy Roller pulls off the impossible. 12w7 in a C6 Z06
- What battery & charger are you running?
- Can I REMOVE C6 Non-Bose Amplifier?
- Stereo upgrade
- sub wiring problem
- dnx8120 boot up time
- anyone have any electrical schematics?
- Pioneer door tweeters
- My 02 C5 key FOB won't unlock passenger?
- 12v switched and constant?
- I have a Crossover ? for any Guru's
- i have a hiss or buzz in my new system
- Avic Z3 w Bose Install
- C5 SUB setup: JL Stealthbox & NEW JL 250/1v2 amp!
- PAC-ADD-GM24 Connector in '09 C6 ??
- need help from GPS (Garmen nuvi 350) wizzard
- Sirius instead of XM
- The Kicker L7 15" sub is in my C5. WOW
- 1.5 DIN with Nav
- Anyone using Kicker 8" Mid Bass in a C5? Questions..
- what is this connector and red wires for?
- eratic radio
- Do I need to connect F/R low level outs together?
- Sirius SIR-GM1 and the Y Cable?
- Cooling the amp down
- Where is this plug located?
- Pioneer AVIC 700BT in C5?
- Largest speaker that will fit in OEM C6 door opening?
- f/s pioneer avic d3 cd,navigation ,dvd ,sat
- ADVICE WANTED: Adding speakers and amp(s) to non-Bose C6
- Pics of black stealth box with amp!
- AVIC-Z3 in C6
- F/S OEM Nav unit C6
- Ready, Set, WOW!
- Bose amps not working in hot car
- Connect interface to 8inch sub?
- Amp in place of the factor amp in the same location?
- F/S: JL 450/4 Black
- Alternator whine
- Speakers in C5 Vert
- F/S Kenwood back up camera
- Replacing speaker need Bose adapter to Fac. wire
- another upgrade
- FS: Alpine SPX 177r Passive crossovers
- Anyone pull line-level outputs from stock amp location?
- Rockford Fosgate Power Series Amplifiers
- Looking for old school crossover....
- Aftermarket Nav
- C6 Base radio/ Aftermarket head unit swap
- Quick question does a cd changer out of 2001 work in a 1998 Corvette
- 95 C4 Front speaker question
- What Amp Size Noise Suppressor To Use?
- AVIC F series
- Subwoofer wattage and wiring question
- GMOS-04 Interface for Aftermarket Head Unit FS
- FS: Cadence TXA-3004 Amp - Needs Repair
- Any interest in buying my stock GM 2 DIN radio/CD?
- tuning between stations?
- FS: Alpine SPX 177r Passive crossovers (pair)
- Help with GMAH24 speaker wiring...
- Problem with AVIC-D2 illumination
- What is the best Audio system to get???
- Cable lengths for C5?
- Kenwood 8120 - blinking light when off?
- C4 '96 Full Install Part IV
- (Tulsa, OK) Watch a C4 take on 49 other top SQ cars!!!
- C4 '96 Full Install Part III
- How much should I spend $$$$$$$$$$
- Putting in a nav. system, need help finding the speed sensor/detector/signal wire
- C6 Amp Install
- Radioflyer's ***Warp Drive***
- which to go with 1 15" L7 or 2 12" L7's
- C6 Vert is back from the SQ store
- For Sale: SIR-GM1 Sirus Connect Tuner for C6 Factory Systems
- Need Help with External CB Speaker
- 96 bose problems
- Technical advice needed. Anyone now how to hardwire a Alpine AI-net connection?
- PIE GM10-AUX problems
- C6 Factory Radio/AC control finish
- FS: Complete Bose Gold system $200 - spkrs, amps, head, CDM
- 2005 XM install issues
- Will a C6 radio work and FIT in my C5 car ??
- Best HD radio to replace Bose C5 with
- Jzubik C5 Stereo Install (pics)
- Guys w/ aftermarket HUs w/ satellite radio... where to stuff sat box?
- antenna booster power control terminal???
- C6 speaker replacement threads gone???
- Installer rates
- FS: anyone need some bose speakers?
- iPod2Car and aux cable
- ADD an Ipod and Aux to ANY system
- GMCO and Onstar Vehicles
- 8" and 5.25" in C5 Door?
- Installing OEM Nav in a Bose Equipped C6
- C5 door speaker replacement warning.
- Soundgate GMCVR2 question
- Intrest in old bose?
- replace the 10w1 in stealth box?
- New system is IN!!!!!
- Help me build a sub box for my c3
- FS: Kenwood MP-4032 CD player and Ipod Adapter IP500
- Sound Deadening Question
- Unveiled: Pioneer AVIC F-Series Car Navigation [PICS]
- Escort Passport 8500 X50 Radar/Laser Detector + INVISI Cord + Visor Mount
- Better signal for the SIR-GM1?
- Needed Specs on 2008 door speaker Ohms
- What do you use when painting interior plastic trim?
- Wiring stock speakers with non-bose amp help
- Help / advice request for C6 upgrade, keeping stock 10 inch woofers
- C6 amp/sub installed - start button issues
- Need help wiring JL Audio 300/4 for Components
- Navigation Systems????
- C5 woofers: ever power them with aftermarket amp?
- help with a nice portable GPS unit???
- Center Channel disconnect is not a good idea.
- Brassy sounding in a c5 z06 new guy asks
- c3 owner looking to upgrade audio
- Need electonics help (farads/caps and LEDs)
- Bose Radio
- Ipod2Car Problem - Anyone see this before
- Look what NVTHIS made me!!
- Finally a Stealth box with a built in amp!!
- I finally got off my butt.... (Sub Pix)
- New Custom Z06 Sub-Amp Box Pics
- c4 audio/electronic
- WTB: C5 Bose speaker (passenger side)
- Need this relay to complete HID project
- Tweeter Recommendation Please!
- Looking for Complete Amp install for C5
- 85 - how to route ipod cable from alpine unit
- What Texture and Paint are you guys using on your modded radio bezels? Anyone Vinyl
- F700BT owners - step in, please
- illumanation wire
- Newbie Need Help
- my 12 disc cd changer is not working right
- Help!! squealing sound from the radio
- Soundstream Car Audio..Need Your Help/Opinions????
- Ipod to amp
- Avic D3
- C4 '96 Full install (lotsa pics!) Part I
- HELP !!!! easiest way to hook up an MP3 player
- Want to have up to 3 AUX inputs that are selectable for your Bose HU ?
- avic d1 owners... need calibration?
- C6 stock head unit question ?
- NE1 know how to remove jammed CD from C5 BOSE radio?
- Focal Blowout Sale!!!!!!!!
- FS: behringer dcx2496 with envision electronics psu, id12v.3 sub and crystal dac
- definite downer today
- 1984 C4 BOSE Radio Question??
- HELP! What to get for AVIC d3 install C6 W/ Bose
- Sudden dramatic volume change
- Lets hear your speaker recommendations for my C5
- Time it takes to replace power antenna in C4
- Do Not Get The Jvc Kd-nx5000!!!!!
- MB Quart, what are these QM-R's worth???
- Is aftermarket stereo only on Fuse #5??
- Auto Buffs......Is Back
- flip out eclipse headunit with separate brain. where to mount in a C5?
- C5 Front speaker wiring???
- Parrot CK3100 bluetooth, mechanical installation (photos)
- C2 Stereo Ideas??
- Need Some Help and Thoughts!!
- F/s Alpine Pxa-h701 Surrond 5.1
- JL HD600/4 & 250/1v2
- WTB Pioneer 12 CD Changer M2016
- New speaker question: Alpine w/Soundgate & Bose
- Clarion max685bt
- Scosche Bluetooth Module for GMLan coming
- A/C upgrade question
- Question for AVIC D3 Owners...
- Anyone with Focal Subs on a C6 (on the door)?
- Bass Levels on an 08
- My 89 install
- Alternative to 2008 Factory Navigation Sound Sysyem.
- 2006 Z06 FM Reception
- Panasonic Touch Screen DVD Player For Sale
- D3 Unit Won't Play Sound (HELP!!!)
- I want to thank everyone here for their advice. I love my new setup.
- For Sale: Pioneer AVIC Units Updated and In Stock!!!!
- WTB Leftover Dynamat/FrostKing/Deadening
- How to take of C5 Door speaker grill?
- Finally started my stereo install
- FS: JL C5/Z06 Corvette Stealth Box w/Sub and Black Cover Panel
- C5 Line Level + Retaining factory subs
- C5 Sirius question
- A few questions about the C6 stereo/nav system
- Alpine Installation Issue
- Complete system for any car $550 NEW
- JVC KD-NX5000 Single Din
- C6 Z06 audio questions
- hks camp 2 and navigation
- Removing Bose amp in C6Z06 any problems?
- stereo for c6 convertible
- Where to get 3.5" installed in orlando?
- quick C5 stock stereo ?
- Looking for a Good Double Din Unit
- Question For Those Who Know.....
- alpine component help
- Bose Speaker/Amplifer Problem C5
