- fuses/relays
- Stereo Replacement
- New C5 system installed [Lots of Pics]
- Looking for reputable in Arizona
- Rear speaker wires-What color is + for the rear speakers?
- ?? removing console in 2009 coupe?
- Dr Don MP3 Radio Modification
- anyone tried tapping into the bose harness to avoid an adapter?
- bose amp, uninstalling?
- C5 coupe - How to cover the stealth subwoofer?
- C5 coupe - How do you cover the stealth subwoofer?
- Help - where exactly is cd changer connector
- install pics, non-corvette
- Checklist for C6/BOSE Replacement
- questions - ipod to stock radio
- Anyone running a 2nd battery for their audio system?
- Pioneer Avic F90BT
- JL Audio 300/4 amplifier
- DDX512 random reboots
- Door Subs only engage when in Tuner/ Radio Mode...
- Amp rack for C5 - 2 Amp's help please
- Single DIN install kit for 03 Z06?
- indash dvd player question
- Want XM Radio in 2003 convertible
- DNX5120 Bluetooth issue
- Component Speakers For Sale Cheap
- FS: (2) Alpine SPX 177r Crossover networks
- C5 Z06 Sub only install
- bose CD player question
- WTB Bose AMP For a C6
- Antenna Adapter?
- Round 2 Help Me Spend Some Cash
- portable xm in 2008 corvette
- c6 what if: reuse my amp, replace 5.25 rears and 3.5 doors???
- AVIC-N5 installed, pictures please
- SPECIAL: Pioneer ND-BT1 Bluetooth Adapter
- C5 coupe - where to run the power leads for sub amp?
- Radio works But No Sound
- Please help with install
- How to get the cd changer cartridge out?
- Radio problems
- What speakers would you buy within limits?
- HIDs and radio interference
- Double din head unit with speed sensitive volume?
- 1994 stereo
- speakers not fitting?
- PDX-5 dimming?
- Need radio suggestions--must have audio in
- double din radio C5
- HELP!! DNX8120 OWNERS - Where is your Bluetooth mic?
- c6 application: best way to RE-USE my 4/3/2 ch amp (subwoofer? power other speakers?)
- C5 Aftermarket Hookup Help
- F/S Alpine SPS-17C2
- Antenna comes up after a few minutes, CD's skip,....
- 2005 bose interface
- Will 5X7's fit in the front of a 92 Coupe?
- Completely confused.
- HOLY HELL!! I Did It! DNX8120 Install. PHOTO HEAVY
- 95 C4 with New Pioneer HU
- 95 C4 with Satellite Question
- '09 Aftermarket Update & Question....
- Sirius Radio Broke, where to repair?
- Worth losing XM for new head unit?
- C5 - adding amp to stock system (i've looked)
- Quick: Are XM and Sirius antennas interchangeable?
- iPod kits?
- Is This a Good Deal or Not So Much?
- Pioneer AVIC-F90BT
- Odd Illumination issue with Kenwood 6140
- GMCO / Pioneer F700 help needed
- Question about stealth sub
- Amp, speakers for Convertible
- Radar Detector, which one?
- Sir-gm1
- Kenwood DNX5120 question
- C4 sub question
- Difference between U3U and 2LZ Head Unit
- Help...C6 with 300 w amp and 2 10" kickers
- 2 10's or one 12 subwoofer?
- Mounting Options for a GXM30 antenna
- need help with audio please
- Upgrading '03 stereo
- VCIM wire
- Double Din Install Suggestions
- AVIC Dimming?
- Searched for this but....
- Alpine PDX 5 - Questions
- Hooking up my Blackberry
- Help Please
- Question regarding port placement for a reflex bandpass system.
- C6 right rear storage cubby
- Need Advice - C5 Bose Upgrade
- Looking for input on non nav double din units
- New System installed in C6 (56k beware)
- Forum Failure, Radio question
- FS: New DA 150F 10" Sub
- Help in buying an amp
- Portable GPS antenna question
- Kenwood DNX 7140 Now available at Double D Mods
- c5 install
- Kenwood Bluetooth issues
- Head Unit Is Installed !!
- Help Head unit
- Easy speaker wire question
- Does Anyone Know Where to Locate TPM?
- C6 sub setup for you guys (pics)
- Has anyone used this device for a C6 and does it work ?
- HELP ME PLEASE! - Aftermarket Amp - Hiss with Factory HU
- FS: 10in JL Audio Sub (10W3V2) and/or Sealed Enclosure
- Poor reception C5 coupe!
- Need help selling my Bose Stock unit to a fellow CF member
- Satisfied with Woofersetc
- 06 premium bose fit in an o5
- Frustrated - Assembling a Kenwood System in my C6
- 94 C4 Radio Questions
- FS C5 sub box and amp rack cover
- whats a good rca cable to run??
- C5 z door subs not working with aftermarked H/U
- Searching for the CD changer connector
- Opinion On Sub Set-Up
- '09 C6 Coupe Nav/6 CD Changer Install Question
- Kenwood System Question
- Complete C5 1999 Vert Bose system stock for sale
- Bose Radio Repair?
- C5 Bose CD Head Unit Problem
- Need radio help on c4
- Dream System in your C6?
- relay question
- DNX 5120 issue
- C6 sound upgrade....keeping the factory Nav.
- Vert owners...Where did you mount your amp?
- What happen to the new C6 sub boxes I saw????
- WTB JL Stealth boxe for C6 Convert
- 2001 C5 Coupe Very Limited Sound From Rear Speakers
- Good Radio to Install in C5?
- anyone use factory mic for aftermarket bluetooth?
- C6 - adding amp and replace speakers
- OnStar Adapter
- Where to find / buy matching carpet?
- Want to update my C6
- IPOD / Kenwood 5120 compatiblity question
- Anyone have knowledge of amp in marine environment?
- Pioneer AVIC RCA Fuse Fix Tutorial
- check this build out
- c4 ground location besides battery
- POP noise when power up/down
- 8" sub for C6?
- [C6 Answers] What do I need to install an amplifier?
- New System Install Problems
- Need 12V Ignition source for relay...
- 200 coupe. Installed new Eclipse head unit, lost heads up display??
- How to buy the correct watt speakers for my car.. HELP!
- really need some audio help
- Newbe Long post - Help and Questions
- Static go away please
- Broken Radio in a C5. PLEASE HELP!!!
- iPod charging question
- C4 1990 Convertible Audio Question
- Sirius in a C5...what is best way to go?
- Anyone have a Kenwood Excelon DNX8120?
- Stealth sub setup with new system
- Simple install going bad
- FS: Boxology Box with JL 10W3V2
- C6 door panel fastener question
- installing a C6 stock nav system in a C5
- What is the best "cheap" speakers under $100
- Old School Power
- '08 C6 Vert, bose replacement amp turn on wire?
- Audio Gear Dilema (Audiophiles Assemble!)
- Rate my C6 Nav System Choice
- Need source for dash light on 99
- Installing AVIC or Kenwood In Dash GPS on C6 Bose - How Hard?
- Kenwood DNX8120 Install
- Bluetooth Unit on Kenwood DNX 7120
- Ground in a C5
- Memphis Audio
- Pic of new custom NVTHIS subbox with the new e5.12 12" ED SUB
- Pioneer for sale
- Anyone in Central jersey area get a radio/speakers install in their Vette?
- [C6 Answers] What do I need to install a head?
- GMRAP install question
- Solid State Drives
- Sound Deadening advice
- After market speakers using Bose wiring on 89
- sub
- Amp wiring kits
- Help with speaker choice.
- WTB 2008 or 2009 Navigation Manual
- Kenwood DNX7120 vs 7140 Firmware
- A Complete Review and Comparison of Ipod Adapters for the C6 Corvette
- 2007 ZO6 w/ factory nav...big question
- c4 sub enclosure?
- Anyone Switched Factory Head Unit Only?
- Weird Request
- Are these MB Quart RTC19 tweet's worth anything????
- Sub Box Construction
- double din in c3?
- pic request of c5 hu installs
- c4 kick panels
- Questions about installing Nav in a C5
- C5 & MP3 questions
- is the 08 1lt stock unit a BOSE??
- Stock C5 CD player wont...any suggestions?
- Need some encouragement, gonna install a nav unit
- Any use the Peripheral IPOD Interface
- Radar detector, worth it? never had one
- Escort 9500ix for sale
- Woofersetc Bad Experience
- Bose fading out.
- FS: AudioLink PowerLink II High level to Low level converter for adding an amp
- FS: Pyramid NS-90 Smart Remote Turn On Adapter for adding an amp to stock system
- Toss 2008 Bose Amp?
- metra antenna adapter
- Help Required - Kenwood Install - C5
- C5 Factory HU & some upgraded toys...
- C5: Help with switched power source
- need help mounting amp rack/sub
- how to mount a IPhone and Sportster sirius radio in a C5?
- sub question
- Where to buy a quality speaker terminal, RCA terminal, etc?
- Metra VT-GMOS-04 or Peripheral GMAH24B
- Pioneer AvicF90BT
- Adding amp/sub to Kenwood deck; question
- C6 Power Wire Routing Question
- a couple of questions on wiring a custom vette system?
- C5 door styrofoam and sound deadening
- Anyone in KC good at C6 stereo stuff?
- Kenwood DNX7120 bypass?
- Question about the auto stay on feature
- c4 wiring harness?
- Suggestions for 3.5" front speaker replacement
- Simple And Quick
- Speaker choices
- What amp to get?
- FS: C4 Aftermarket Audio System, Alpine/Memphis Speakers, Alpine HU
- Record Internet Radio
- wire routing - C5
- Well this bites
- AVIC Z1 installed on my 07 1Lt Vert
- Need some quick help
- Onlinecarstereo.com
- Amp Selection Decision
- Basic question regarding RCA outputs(non-amplified)
- My proposed setup
- What deck to get? (2003 Z06)
- C5 coupe terrible reception.
- Upgrade
- pioneer 900
- C6 with Kenwood DDX-712 - "Pop" when powering down?
- Wiring Kenwood H/U
