View Full Version : C7 Z06 Discussion
- C7 Equipment list?
- Apsis: A Very Special C7 Armrest w/Neon Green Lettering
- Anyone have tire friendly alignment specs to share.
- 2016 coolant change
- Brake Rotor (Non-Z07) Part Numbers???
- Is 2016 Z06 known for bad wiring?
- Magnuson's 2650 tune
- Drivers Side cylinder head threaded size
- Fueling Upgrad
- 4th gear squeak under load
- How loud is the Corsa Xtreme?
- Benefit of reduced wheel and tires
- Z06 Emblems on front fender Vents
- creaky driver seat back
- Any ideas to make exhaust sound louder inside the cabin?
- Red Light Bandit Throttles Booster problems.
- C7 z06 water pump replacement
- Got my Chromies powder coated
- Question about performance mods
- Anyone have a raceseng front row hook?
- V8 Engine Sounds l Corvette Z06 Z07 Pack l 4K Video
- Red Light Bandit Throttle Booster
- OEM Z06 wheel weight? How much do they weigh?
- Brembo Carbon Ceramic Decal
- 2017 Z06 coolant sensor location
- New owner, feel in over my head
- Jake Air Intake System by Jake Racing
- What do I do with my Ivan Tampi Customs order?
- Driver's side mirror vandelized....:(
- Nowicki Visible Carbon Fiber Rear Spolier w/ Matching GM Weave/Tint
- Callaway short shifter
- 2016 C7 Z06 with A8 Transmission
- C7 ZO6 hatch won’t stay closed
- Need advice/insight, replacing High Pressure Fuel Pump HPFP replacement
- C7 Z06 X PIPE... Which is best?
- Car running bad after CAI install?
- 2650 with no other mods
- Apsis: This C7 Armrest in Ebony Nappa w/Titanium Stitching is Available
- Need Help With Rear Offsets
- ***need front bumper cover***
- Pinging or supercharger rattle ?
- Pulling Intercooler Bricks Out
- Girodisc iron rotor conversion
- Apsis: Anyone has C7 Airbag for sale?
- TB upgrade question
- Ported Throttle Body - whats the latest & greatest?
- C7 Z06 alternator getting very HOT
- Brake squeal
- DIY brake pad swap - electronic parking brake
- Disparity in indicated coolant temp
- Kong X Port or Magnuson 2650 in Manual Convertible Z
- Long time member, just bought a C7 Z06
- C7z06 supercharger belt advice
- Stingray turned Zo6 question
- Torque converter replacement
- Apsis: This C7 UltraSport PLUS w/Flat Top Carbon Steering Wheel Is Available
- 19x11 and 19x12 Z06 Wheel options
- oil cooler leak
- Does anyone have the part number for the thermostat?
- Help Kentucky resident looking at C7 ZO6 in Florida
- Anyone using these Signature "One" wheels?
- Apsis: These C7 Armrest Are Available for Immediate Delivery
- Lt4 10k miles
- 20% Back On Corsa Exhaust! Get Up To $668.79 Back On Corsa For C7 Models
- How loud is this car ?
- Shorai lithium battery ?
- Replace Fuel Rail Covers
- Does the ZR1 Muffler fit on the Z06?
- Michelin Pilot Sport 4 S Tire size question
- Arh longtubes does the clearance look right for the motor mounts
- Android auto
- I shouldn't need a Tune should I?
- Lug nuts for weld wheels ?
- EOS or ACS Composites stage 3 winglets?
- Car transport
- I just bought a cooler bleeder
- Yet Another Alignment Question
- Anybody in Phoenix area with a Cooler Bleeder?
- Do the 2017 and Later Changes To C7 Z Solve All The Cooling System Issues?
- Questions After 2nd Track Event
- New 2025 ZR1 design Wheels Now in stock for your C6/C7 Z06 and Grandsport | MRR wheel
- NPP Valves - Nuclear Propulsion Package
- Apsis: Just finish this cool C7 Armrest in Tension Blue Nappa...
- PB MIR - Stock A8
- Does this make my strange??
- M7 Launch Mode
- Best mods to build a wheel stander.
- 2016 Z with original battery
- Water temp low
- 2019 M7 Z06 Problematic First Impressions
- New zo6 owner
- Why no decent tires in our size?
- Any Reason not to Top Off the S/C IC Circuit?
- Best tires for grip?
- CCW Classics clone wheels 18x10 18x12.5 for c7z what offset?
- Z06 Splitter Options
- C7 Z06 stage 3 splitter spoiler help
- Camber kits - What are they and do you need one? Plus C8 Install video
- AWE Tuning Exhausts - 15% OFF!
- C7 Z06 Z07 CCB Brake Caliper Measurements Needed
- Blown shocks ?
- Vibration!
- steering wheel shake at speed.
- Will changing my battery reset my ecm?
- New owner, questions about brake life and exhaust
- Oil level check
- C8Z wheels on C7Z?
- Strange Noise in Z06
- Jokerz Porting vs the competition
- Apsis: Anyone wants to take these two C7 Floor Tunnel Panel? No Waiting
- Intercooler and catch can combination for Z
- Popping Out of Gear & Grinding in 1st - Roast Me!
- Very hard to get into 1st
- Need tire advice
- Buy back my c7 z06 from insurance?
- New Now Available Only at MLA | VOSSEN HF-5 19x10/20x12 Gloss Black - C7 Z06/GS
- Magnuson 2650 installation question
- 3 Piece Wheels Offsets for Z07
- C7 Z06 Dyno #’s/trap speed questions
- Huge Inventory Clearance on DBA rotors and pads!
- 2016 z06 X-pipe question AWE or ARH
- Z06 weird power/shifting issue
- CPR C7 Radiator tank's in stock!
- 19x10 295 30 19x12 345 30 r888
- C8 Stingray rims on a C7 Z06
- MSRC leak
- Thinking about buying a Z06, what's it worth? 2016, 7MT, 3LZ, Z07, DSOM, 18K miles
- Engine Squeak/Rattle any Idea
- My new to me Vette.
- What to spec for resale?
- Does this look normal?
- I'll Have Corsa Send You Up To $400 - Here's How!
- Apsis: These C7 UltraSport Steering Wheel Are Available. Anyone wants to go for it?
- Powerstop or hawk brake pads????
- Apsis: Anyone wants to take this C7 UltraSport PLUS w/Full Flat Top Steering Wheel?
- Whine noise by serpentine belt pulleys
- Code p0446
- Apsis: Just Finish this Unique C7 UltraSport PLUS w/Semi Flat Top Steering Wheel
- Loud inconsistent ticking sound :(
- Coolant, Engine Oil, Trans Oil & Intercooler Temperatures
- Cabin lights and trunk lights don't work
- C7 Zo6 to C8 and Back?
- Front clearance going to 18" rims
- This should add 30-40 RWHP
- Replacement for cracked C7 Z06 wheels
- Private joke 😱🤣🤣🤮🤮😡😡🤬🤬🤬🤬
- KnightDriveTV first SNEAK PEAK at the carbon navi/infotainment display upgrade
- oil filter
- Tax Season Sale Now until 3/1/2024 - GS01 ZE11 ZR01 C8Z C8E Monoblock for C6/C7/C8
- Recent deals on AS3/AS4 Michellin all seasons
- Halltech says "The Early Bee gets the Honey"
- Supercharger Sale! A&A, Magnuson,ECS, Procharger, Edelbrock.. 2YR 0% Financing!
- Interchiller vs. Chordes LVL 1 Cooling Package - C7 Z06
- Intercooler System Dilemma
- C7 Z06 v. C8 Z06 - Both Stock
- P0089, P0300, and Fuel out of exhaust
- Welcome Feb With Special Sale from RPI - upto 10% off & free shipping - Feb24 Code
- arh vs kooks cost
- 2024 Forgeline and CW4L TAX/Spring Sale!!!
- Plugs and pulley selection
- Narrowing down Drag radial setup
- What parts are needed to cam a c7 zo6
- Rehash question: C7 A8 transmission problems
- Transmission and axle upgrade advice needed
- Replacing instrument cluster
- C6zr1 vs c7z06
- Check Engine Light Turns Off, On It's Own...
- Tpms sensor compatibility 2017 vs 2019
- Engine and Gearbox Tuning Questions
- Looking for this gasket
- 700whp Build - Need Advice on Fuel System!
- C7 Z06 Z07 Front Tire Size
- 2018 Z06 overheat on the track
- C7z06 prices are sky rocketing!
- Tuners/performance shops tampabay area
- Barrett Jackson 2019 Z06 sold for $150K ???
- No Tuning Mods -
- Michelin or Continental All Seasons
- Z07 M7 Clutch Bleeding Problem. PLEASE HELP
- Corvette C7 Powder Coated & Rebuilt Calipers-Free Shipping!
- Catted Headers - Unsafe for Z06?
- Huge Savings from RPI Designs - up to 10% off and free shipping on most items
- Max Power With Stock Cam & Exhaust
- Will 2019 ZR1 transmission fit in 2017 Z06?
- Headlights
- 17" Rear Drag Wheels
- Resale Question?????
- Help on c6 z06 or c7 z06 manual
- Tampa Fl Diagnostic Shop Recommendation?
- Is that mess of a Z06 Convertible still in the shop, or did Christmas Miracle happen?
- Question about torque numbers
- LT4 injector part number question?
- Howe Racing Ball Joint Seperator Tool
- Well, she’s done. I think?
- Damage to R888Rs?
- Who makes the best cold air intake for 2019 06
- Have more than 7 months looking for this part number... :(
- C7 Z06/Z07 upsizing tires, Forgestar D5, any possible abs sts issues?
- 2016 zo6 zo7 price?
- What can I do for more power? Current Mods below.
- Water from front bumper area? Splashing on windshield.
- 2014-2019 C7 Corvette Billet Aluminum Chrome Painted Engine Dipstick Handle
- 2019 ZO6 front seal only leaks when I get on it
- EOS ZR1 Bumper Installed
- Z06 Usable Power
- C7 Z06 two piece brake rotor bolts torque.
- Z06 Exhaust Manifold Differences
- Headlights go out while driving
- Basic track mods for C7 Z06
- Happy New Year my Corvette friends
- Remote tuner for port/e85
- Small oil leak under on passenger side under the car.
- Issues with DSC Sport V4 Suspension Controller
- CEL From Cats - Factory Replacement VS. Alternatives
- M7 clutch
- Soft Brake Pedal
- looking for a part #
- Cold Weather Operating Temps
- Z06/Z07 Ground Effects Question - Canards + Wicker
- Cat delete X pipe
- Considering C6 Z06 Upgrade to C7 Z06
- Reminder on why to not trust everything you read in a dealers listing
- C7 51 clearence vs c7 z06 vs c7z06 with z07
- wheel offset question
- LG drag racing coil overs 8 sec pass full weight!
- Wheel Offsets
- Ticking sound when idling/driving
- Bought C7Z And Will Be Selling My C8Z
- Spooky handling on wet roads; PS All Season 4ZP?
- C7 Z06 Pulley and Tune help
- C7 Z06 Prices
- Has anyone had this C7Z Shock problem?
- Corsa 15% Back Ends TODAY On Corvetteexhaustsystems.com
- C7 Z06/Z07 3LZ Baterry replacement.
- GM Extended Warranty
- Rear Shocks
- Small radiator fluid leak
- Anyone out there 1st hand comparision on an Audi SQ8?
- C7Z vs C8Z - Weekend driver question
- FE6 Rear shocks
- Should I do it?
- 2017 z06 entry exit comfort
- Weld Racing and M/T Drag Pack For Sale
- Transmission maintenance
- TPS End of Year Sale-Headers, Superchargers, Coilovers, Rollbar, Seats, & much more..
- magnson 3100
- ceramic Brake vs no ceramic brake
- Put the 2017 Z06 on the dyno
- C7 Z06 Convertible with APSIS Interior - Review
- 2019 Z06 with every bolt on
