View Full Version : C7 Tech/Performance
- Poor man’s Apple car play
- Are these noises normal?
- 2016 Z06 Headers No Tune?
- Check MT 7 transmission oil
- Seat adjustment
- Fuses boxes
- C7 Battery Torque Specs
- simple question about AFM failures
- Coolant replacement
- Fresh out of Storage
- restore cruise control c7
- Mobil 1 75000 oil v Mobil 1 standard oil
- Electronic parking brake diagram help
- C7 Z06 shock absorbers
- Click When Pressing Brakes - Steering Wheel
- Front camera
- Side mirror glass replacement
- What else can I do to make my c7 louder?
- C7 Z51 HP problem..
- Supposed to look like this?
- C7 subwoofer with factory head unit
- tire center in Broward county FL
- Any ideas on what this leaking fluid could be?
- 1160 WHP D1x
- C7 z06 p0033 p0034
- Questions on fueling
- ticking sound in the back
- Torque to Yield Bolts
- DSX flex fuel line - did I get the right one?
- What would be the stiffest Urethane sway bar bushing replacements?
- Speaker recommendations
- while im in there question
- Driver front left wheel noise ZO6, *Advice needed*
- 2015 Sting Ray Drivers Door Window Mystery...
- AMT Chamber Kit and Alignment Settings
- warning lights activate for no reason
- Quick/easy question Should I wrap coolant hose under fuse box?
- Rough start when engine is warm
- Triple Pump, which options?
- New Member
- Coilovers or stiffer shocks?
- BIG POWER Trans OPTIONS
- Got a P0068 and ses blinking light along with some other codes. Any help appreciated!
- C7 Base + Z51 Swaybar inquiry
- Mechanic said they can not fix.
- C7 Header Install Cost
- Aftermarket Exhaust w/ NPP
- C7 Release/Clunk noise on shut off?
- 2016 z06 HUD and steering wheel buttons
- OEM Brake pads
- Anyone familiar with GDS2 logs?
- Seat removal
- BC Forged HCA1625 set C7Z or GS- 19x10.5, 20x12.5
- Is there a way to log TC events in HP TUners?
- High pressure fuel pump install after A&A kit
- Valve guides springs replacement? And power bump
- Performance Shop in Tampa/St. Pete Area
- Air filter question
- Dyno Tune inquiry - minimal mods
- Ring clearance
- redline stutter
- Z06 A8 trans life?
- No info on gauges
- Corvette Overheat/ Electrical problem
- Radio display under the audio icon turns orange?
- C7 stingray drag pack?!
- 20% Back On Corsa Exhaust! Get Up To $668.79 Back On Corsa For C7 Models
- Help with fusebox wiring diagram
- C7 Grand Sport Iron Rotor Minimum Thickness
- Dsx fuel kit question.. again
- Question about a flex fuel kit
- LT 2 manifold on the C7
- New MRR Design Forged Wheels Are On The Way!
- Android auto help
- C7 Z06 Top Speed Run Prep Checklist
- KOOKs Header CLEARANCE 2170H420
- Aftermarket ignition coil packs
- Restoring my corvette,and need some dimensions to align
- Rock auto scam
- Steering off after A&A Install
- Front and Rear Wheel Gap
- LG drop spindle install help
- 2017 grand sport
- Check engine after winter storage P0171, P0174 plz halp
- lower bumper with diffusers
- Baseline Dyno for C7
- St Patrick's Day Sale at RPI Designs - Save 10% on Most Products!
- should I replace coil packs
- Stability control module
- Spiegler SS brake line angle on AP 9668
- Shaking and rough idling and struggles to accelerate
- DEXRON Vl
- Afe/ Attack blue
- Remote and Bench tuning by Tampa Tuning
- stored car fluid changes
- Car wom't start after battery change
- Lock and unlock
- Horn
- 2015 Z51 Stingray overheating and oil life issue
- Supercharger install
- Dex Coolant Question
- Any Reputable Shops in Central Florida?
- Does anyone make billet 6l80 output shafts
- 2015 Stingray Trans Problem
- 2015 HVAC mode actuator test
- 4L80 swap Has it been done?
- Tire Fitment Question
- Corvette Camaro tuner in Tampa
- C7 no sound from speakers, sizzling noise and now completely quiet
- Camber kits - What are they and do you need one? Plus C8 Install video
- LT4 Supercharger PCV Seal part number
- AWE Tuning Exhausts - 15% OFF!
- Bolt ons expected HP
- 17 GS - Question about Rotors & Pads
- 2016 misfire problems and other
- 3 year Tpms issues
- Increase HP from 465 to 501. What mods>
- p0001 code
- Engine Light
- JBA Header Flanges?
- LME timing gear vvt delete
- Stingray 305/25/20 Tires
- Billy Boat X-Pipe w/ Cats
- Is Torch Red Wrap Available?
- C7 Zo7 Carbon Ceramic Rotor Switch-Out
- transmission issue
- clock spring
- Help please…
- Underdrive pulleys for water pump, alternator
- C7 rattle
- Headers w/ Stock NPP Mufflers
- Power steering rack squaling noise
- Diablo or Range.
- Stabilitrak came on while driving what's up???
- C6 GS and C7 GS have same wheel offsets?
- U0421 Invalid Data Received Ride height Control Module
- LT4 exhaust Valves
- Save my rear end
- Pops and Bang (burbles) problem. Cruise control problem.
- Recommend a degreaser that's safe on gaskets and seals.
- CPR C7 Radiator tank's in stock!
- Comfort Control Electrical Grimlins
- Computer upgrade/ autop tranny
- C6 vs c7 rear offset
- 2017 LT2 No Sound Change
- 2 piece brakes on C7 Grand Sport
- 2015 Stingray LT2 ZF1
- Left Rear Tail light flashes when I apply brakes.
- Brake Fluid
- Happy President's Day With A Special Sale from RPI - upto 12% off & free shipping
- Forgeline Racing and Performance Wheels
- Corvette c7 touchscreen & no audio help
- Torque tube problem?????
- Revesol Steering Wheel
- Can someone help me out with these codes
- 2015 corvette sounds funny
- C7 fan running
- Antitheft deterrant/starting problems
- Looking for best California smog friendly super/procharger for stingray
- I'll Have Corsa Send You Up To $400 - Here's How!
- Wheel Spacers
- Huge Savings at RPI w/code APR13 - 13% on Selected APR Carbon Fiber Items
- C7 Shift Cable
- 2014 c7 m7 noise..
- Powder coating Z06 rotor caps
- 2019 LT 1 Corvette
- NPP Exhaust Valve Flutter
- Flat Bottoming the C7
- 3D Printed Cold Air Intake
- AEM X-series Boost Gauge issues
- Clunky shifting manual
- Hp boost to what?
- zo6 pcv system part numbers
- fender repair
- Girodisc Conversion
- Brake pads and rotors
- Headlight Wiring Harness for RGB lighted emblem
- New battery and now no A/C, running fan and several service messages
- '19 Z06 LT4 Injector "cleaning"
- Ported tb question.
- 2015 Z06 Won't recognize key after 15mo sitting - c8 Key fob
- Went into limp mode and check engine light on
- New to me, bought used 2016 stingray 13k 7 speed.
- Torque Converter and cam vs A&A SC and headers vs. Lingenfelter kit
- Cooling fans wont shut off and coolant temp not showing on 2016 C7 stingray
- 3:42 in an A8 diff?
- Broken exhaust valve and failed factory lifters in LT4 motor
- Halltech says "The Early Bee gets the Honey"
- Anti-freeze loss thermostat change
- 19 Z51 A8 Cam
- Supercharger Sale! ECS, A&A, Edelbrock, Procharger, Magnuson! Free Shipping
- Removing Front Cameras
- Welcome Feb With Special Sale from RPI - upto 10% off & free shipping - Feb24 Code
- Totally Dead!!
- 2024 Forgeline and CW4L TAX/Spring Sale!!!
- Speaker upgrade
- Can I Replace a C7 MSRC Shock with a Non-MSRC?
- advice/ guidance on upgrades happening this month
- Exterior light issue
- Aerospace components rear brake
- Is this supercharger still good?
- Fuse blowing repeatedly
- C7 ground points
- Performance shop- Bluffton/Hilton head/ Savannah area
- Driver Demand Editor: free tool for tuning DBW throttle response with HP Tuners
- Tuning and performance shops in tampabay area?
- Anyone know the name of this tube?
- Where to place tie down straps
- Will this front plate work on a stingray w/ z06 grill?
- Highway feeling a skip like at 70
- Added some more RED
- Corvette C7 Powder Coated & Rebuilt Calipers-Free Shipping
- Debating change in exhaust - AWE to corsa or ???- thoughts?
- Vacuum line relocation?
- Build sheet
- Check engine
- TOO Lean Bank 1 & Bank 2 CEL's
- OEM or Ceramic Spark Plug Wires with Headers?
- C7 Shrill brake noise only when applied in reverse
- Huge Savings from RPI Designs - up to 10% off and free shipping on most items
- Part ID
- Where do you get your track day tires? And which ones are you getting?
- Dtc b3123
- North Carolina Tuners
- Z06/z07 vs gs/z07 suspensions
- X Pipe Fitment Question
- LT1 Valve drop?
- J56 brakes on C7 Grand Sport
- Weld Wheel Question (Fronts)
- Track set up recommendations
- Clutch Accessories
- Parasite Battery Drain
- Front suspension noise—where to start
- New YSI build
- Which CAI is better Roto bug gulp or Corsa for a modded ZO6
- engine cradle
- GS Alignment
- Surge tank overflow to radiator hose issue. Please help!
- Nitto 305 front with 345 rear?
- Aftermarket Exhaust Control
- To much oil
- Installed new cat / new NTK o2 sensors...now it's running poorly.
- Who makes the best cold air intake for the ZO6’s
- Tire Size Help
- Separating the two pieces of the steering wheel bezel
- Poll on brakes
- C7 2015 I need to adjust to door sensor ????
- Cabin air filter replacement
- Fluids need to be replaced
