- clear coat runs
- Removing paint
- Fillers over Epoxy Primer ???
- Wax & Degreaser concerns
- Emblem
- Wanting to paint small parts myself
- 10 psi at the cap?
- Trim paint
- Can i use brake cleaner.
- Paint pickled on me!
- New bumper
- How to remove clear coat from stock 87 wheels
- Wet/dry sand and buff
- '72 Door Gap & T-Top Gap
- Want to test out the Ventureshield Clear-bra CHEAP?
- Replacing Outer Door Handle (C4)
- **Help** paint scratch...need opinions
- C3 Door Adjustment
- 78 is stripped, What next?
- Need help to fix a dumb paint fix attempt.
- badge removal
- Exposed Fiberglass????
- PPG and Lemans Blue
- Mask advice
- after the paint is off
- Red paint variance
- Polyurethane Clear
- PAint off body or on
- time to clear coat after base
- AutoBuffs ~Feb Only~Repaint Special
- Macco Paint Job
- C5 Frame Damge - What to look for?
- Painting around the hatch on C4
- Any Dupont paint code/formula gurus?
- How to fix this?
- prep before primer
- Painting 1967 hood stripe question
- Painting rear bumper
- what paint manufacturer ??
- Cost of painting a C4-factory quality...
- Iwata LPH 400
- clear coat over black
- Putting clearcoat on my C5 clear roof - Prep?
- Front licenes plate cover
- Urathane Bumpers
- should I wet sand
- Painting Sequence
- Epoxy question
- Ready to start priming
- urethane bumpers
- how to measure the frame? to see if it is bent !!
- D/A sander
- Another primer question
- Paint removal nightmare!!!
- Body Fillers
- NewB Vette 101 painting questions
- C-4 painting
- 72 surround install
- base coat clear coat
- Hoodliner paint
- C4 front bumper
- Gouged my Rear Bumper
- Epoxy Primer over Lacquer Primer???
- Your thoughts on tinting primers
- Will Epoxy Resin and Mat stick to...
- PhotoFinish of Tucson unfairly attacked by member.
- Please help!!! What kind of hood is this?????
- Bug in clear
- air gun
- Paint ID
- Newb painting question..
- Candy Paint on a C3
- Could someone give me an opinion on how to fix this?
- Matte paint
- Removing covers from taillights
- Need to paint front license plate cover.
- C4 - removing and trying to save rear clip/quarters
- EastWood Now Selling Epoxy Primer
- Converting '69 to side exhaust
- Could someone help me with a little body work?
- Hood help
- 1987 Corvette
- D/A Sander
- Paint prep work
- Body panel color 65 C2/sanding advice
- Custom auto painter in Orange County, New York area?
- ~AutoBuffs Paintwork Christmas Special~
- Sanding questions
- 81-82 Vette Paint Job Pics?
- Never did this before
- economical paint system supplier?
- 78 C3 T top adjustment
- Trying to black out the vette
- soda blasting?
- What is the best body filler to use
- Fiberglass Hairs on Surface
- HELP ! - Removing Foreign Liquids from fiberglass
- Suggestions for painter Ft Pierce FL area
- Looking for two paint items
- What is the best brand and type of paint to use?(Will try here now)
- Sealcoat, black and clear are next!
- Correct Body Filler
- Can I paint on Rubber mats?
- clearcoat peeling
- Rear bumper cover not lining up
- Any Corvette vendors running any promos at this time? Need pans!!
- Need instructions on painting.....
- --Iforged Daytona's Ready To Ship!--
- Photoshopping color of car
- Gas mask as a paint respirator
- NAPA (Martin Senour) version of Sherwin Williams
- Shelf Life for Paint
- how to prep for paint
- Door jamb prep
- Instrument can questions?
- Mixing C3 doors?
- SMC prep om fresh panel
- How Much Paint Needed
- Paint job?
- Best technique for installing a hood
- 99frc clear coat peeling
- sanding
- Paint Prep For Pot Metal Parts
- Dummy needs help on deck replacement
- Auto painting software.
- sandpaper grit before primer
- Fiberglass hairs coming through my epoxy!
- am i doing this correctly???
- Underhood Paint
- suggestions on Daytona Blue paint
- Wet Sanding
- How much is a first class paint job ?
- What gun....
- paint
- Something is not right...water coming in
- Paint chip repair
- 1980 vette, laquer or enamel when original
- Isolation blocks under compressor?
- Spray gun spattering, need help
- Need to paint my International blue 68
- Applicator gun info?
- 1993 corvette touch ups
- Should I have my primer tinted?
- My C4 Got Rearended
- Must you remove the factory primer before epoxy priming?
- Undercoating removal
- Touch Up 123?
- Have I made a mistake??
- Bubbles after repainting
- 68 restoration
- Door gap fix question
- Sanded thru primer, what to do next
- Found some cracks in my Door
- Questions about glassing in the rear (pics)
- Mildew on paint (nose/rear)
- paint imperfections
- I got a booboo!
- Epoxy Primer/Fiberglass Adhesive
- 85 new paint
- Question about painting in the colder mo's.
- Static-cling Lighting Blackouts and High pressure washing
- Attention painters!
- Need help from SFL/WPB vet owners body shop
- Going Bra-less
- 2005 Door Ding
- C4 luggage rack plastic inserts
- Black inserts for Corvette Logo
- Best Way To Prepare BC/CC For Reclear
- Noob to fiberglass repair
- Hood loovers
- Small paint blisters
- 1956 Corvette Restoration question
- vinyl decal on new SPI clear
- Need help....dolley for body-off
- Here are pics of what I've been up to . . .
- Good Urethane Bumper Filler?
- epoxy and polyester
- How Do I Fix Nasty Chip On My '65
- New LVLP gun
- Just Bought a Sharpe FX3000 1.4 Spray Gun
- Painting 00 C-5
- Clear Top Coat in a can to cover Rustoleum or DupliColor
- Did I use the wrong Resin?
- C3 Engine compartment paint
- Basecoat/clear question?
- Body Shop in NC
- Source for Capt Lee's
- Can Emblems be polished back to original look?
- Removal of doorsills?
- Pics~AutoBuffs Gallery~Pics
- Aerosol primer are they worth the effort?
- Crack in paint
- Painted my mufflers
- 72 vet body alignment major issues
- What White??
- 600 grit scratches through basecoat
- A little body trivia.
- Approximate paint volume needed for undercarriage?
- C60 ram air hood
- how can you get spray paint off your cars paint?
- Painting with air gun vs. brush on
- Paint type for C4
- Opinions on Feather Fill Generation 2?
- bumper warping
- Need advice with door gaps
- Clearcoat - How to tell if you go through it.
- anyone used ppg 2060 matte clear?
- Wet Sanding/Leveling Small Areas
- Remove and leave off Hood Liner???
- New paint and Rejex
- Glass, SMC, Poly or no poly...WTF?
- Painters on this side vs. Pro Shops (Tx.)
- Finished Black Hood
- Painted Pinstripe Removal
- pictures of cracks and plans to repair
- c6 inner fender wheel replacement?
- (not vette) hey Porch Dog
- Paint Guns and Sanders For Sale
- Ecklers front surround received
- Body Shop in Tampa FL Area
- question of craking paint on my other car
- etches in the paint on a 97
- Need help on buying body panels...
- gel coat? under body
- want a stripe
- Best Random Orbital Buffer?
- Looking for info on a paint code please
- Repainting a '90, need some advice
- Hood surround rivets on early C3's
- Auto Body shop recommendation
- 72 Sunflower Yellow progress
- Bubbles forming on hood
- seriously,need help
- Dealing with orange peel
- Little help with Paint please
- Who makes a decent C5 cowl hood?
- Is this gun OK for "today" paint and clears?
- Types of fiberglass
- Metallic Topcoat over gloss color?
- 01 Z06 right rear fender the same as 03 Coupe
- Too Cool...
- Need Some Advise
- polish or wax
- Another Painting Tip "lights"
- Satin Black paint job
- Could use some help here??
- need help fiberglass resin
- fiberglass repair
- fiberglass
- Painting advice
