- What is the rattle can prodcedure for my targa top?
- Factory Paint failure on my 90 ZR-1
- sanding off clear coat
- Emblem Backing
- prep
- interior dye on metal
- Base and clear paint quantity to purchase
- Question about using epoxy primers
- Color Sand and Buff
- Buffing Out New Paint Job. What's Needed?
- Oil and Water separator
- Body repair
- redo splice repair using Vette Panel Adhesive?
- what do you guys use to fix paint chips (specifically on hood)
- Garage Paint Job
- Paint shop needed in Houston, texas
- 50th Anniversary Red Complete DIY Repaint Project Advice? PIX
- I got a nice surprise on my 69
- Bumper + Pipe + Cracks!!
- Off Topic Paint Question (Wood Finish)
- Remove c6 corvette rear quarter panels
- powder coating help
- Inner fender skirt question
- Seeking Paint Advice
- Roof Panels (Removable Top) C5/C6
- Help! Need details on matching Laguna Blue paint formula for a '66
- Car was repainted can I cover it?
- Painting that bumper to match
- paint experts needed
- Matrix Paint System???
- 1976 door problem
- Dub........Tire Shine
- Orange peel ?
- What to material to put on stripped '60?
- any painters in CT
- exhaust being close to the body
- paint problems
- Duct tape will fix it...
- Scraped rocker panel... "Options" please.. pic's.
- Wrecked!
- Clay bar ?
- Car is in the shop about to be painted and I don't understand anything.
- wet sand and buff 4r old paint
- Need To locate custom Paint shop for new wheel set
- West System 407 Low Density Filler?
- Paint Shop Needed Raleigh NC
- Targa Band removal?
- White C6 with GM mudguards pics???
- Documented my paint prep in C4 General
- Need help buying a spray gun???
- PPG color for 68 Lemans blue?
- Paint Quality
- C4 Targa help
- spider cracks in old paint
- Paint Chip Repair
- Racing Stripe Decals - install experience?
- swirl marks????
- hole in floor board
- Welding Safety: Dont do this
- How to remove paint.
- Paint Code Needed for C5 Z06 10-spoke wheel
- Paint Problem help needed
- flat,Matte,or Satin paint!
- any tips would help. black 88 drop top
- Corvette Front inner fenders/Install??
- Soda Blasting
- Murdered out my 2004 with flat black paint flat black powder coated rims etc
- replacing front fenders
- 1980 Corvette, what's wrong with my paint?
- Inexpensive Blackout Kit from RPI Designs?
- Painting fuel rail covers
- clear on emblems?
- Dings/Touchups
- C6 Rocker Needed
- Question for Painters
- Paint shop in Chicago
- Icing Pourable Brushable Polyester Finishing Putty
- Partial repaint?
- Clear bra material for other areas
- tip size
- What color Yellow to shoot ???
- c5 hood/headlight alignment
- painting glass bumpers
- Help with convertable top rear window attachement
- Filling holes from tonneau cover snaps
- I want to start prepping this 90 for paint so let me hear your tips
- My 08 Z06 paint correction with Adams products
- Advice needed - I think I messed up
- How soon after paint can you polish
- Epoxy Primer as a Sealer & Primer for Lacquer?
- wetsand
- (C4) Tiny Bubbles, old paint? (1990 coupe)
- Overspray
- Primer / Sealer Color
- C4 product advise
- C5 Dreaded rocker panel issue
- 1977 Rear Impact Bar
- Fish Eye
- have a question
- 02 Z06 body work estimate
- refresh my memory please
- BC/CC sanded through to base?
- Bumper cover suppliers
- 66 Grill attachment
- Cracks in firewall
- Side scoops and other gen features on other gens?
- New emblem install
- Does Color Influence Resale Appeal ?
- Wax on new paint
- C6 Paint?
- A/C compressor hood damage
- Soda Blasting ?
- Good place online to shop for supplies?
- Touch-Up Paint??
- Body work mistakes and a ton of little questions
- ghost line at bonding seam
- Time for a professional??
- Rustoleum $50 paint job question
- Questions about installing a Cowl Scoop
- porchdog is right
- New paint job
- Rear Valance Question - Is it salvageable?
- Sanding Base Before Clear?
- What's the deal with lacquer?
- How would you do this repair?
- Who Restores Gas Pumps
- Eastwood 25% off everything today only
- Wax and Grease Removers
- Horizon Blue
- 98 painted due to accident couple questions
- ??? - chemical stripper on SMC
- cracks in clearcoat on C5 front fascia
- FPR-8 Furnace filters
- Bonding front bumper
- which Iwata ?
- Sears Craftsman Orbital Buffer
- Minor Clearbra damage
- PPG Concept SS 9300
- Help please with a paint problem
- faint scratches, what to do when hand wax/buff doesnt work?
- Bird droppings etched clearcoat
- Paint guru needed
- Not sure why it happened but how do I fix this?
- Touch up paint!!!!
- Need matching chassis paint for C5
- Factory paint Vs. Body shop Paint???'s
- ***a few pics of a 2010 GS we just finished up**
- Paint Shop Northern NJ?
- Fenders flares
- Repainting C6
- Looking for a color sheet
- Is body repair work on a C3 corvette is more labor intensive than on a metal car?
- Any pics of work on C5 rear brake ducts molded in?
- Fixing Large Crack Between Headlights
- Good Paint Shop in Metro Detroit?
- Body panel alignment
- Lenses
- door lock hole repair
- Painting license cover
- Chemical Strippers
- Need advice - Aerosal spray paint
- What actually determines the cost of painting a Corvette
- Looking for painter in Western North Carolina
- repaint on a budget in VA
- paint and body work in Dayton, OH
- Soda balster in Maryland
- Worry about bare fiberglass?
- what do you think of this repair job
- What is under the primer?
- Dealer Damaged Rocker Panel - where should I take it in East PA?
- 06 machine silver Vert, wide body repaint help needed
- I need some sanding advice-please
- Thinning Rage Extreme???
- 60 vette honduras maroon paint code??
- Inner fender paint problems
- 68 Vette Repaint
- C4 Body Repair Help (Pics)
- How to correct the alignment?
- Door lock plate chalk?
- Repaint
- What glazing putty with epoxy primer?
- Is this paint restorable?
- Paint Manufacturers
- Very deep scratches
- Primer/Paint Question
- 2 tone c5 thoughts... need opinions please
- Repair or Replace Fenders
- modify hood cost..
- Stalker Wide Body Kit
- Rear deck panel for 68 vert ?
- glass patch not "sticking" to doors
- Rear spoiler
- Help Recommendation for body shop in or near Greenville SC
- Paint Problem need opinions
- Need a paint booth in northeast NJ
- washing filler and spot putty and general prep
- Getting lines back on 1970 taillights
- painting headlights on a c6?
- Krome Kote
- any solution besides repainting
- C4 hood problems
- Recommended Body Shop in the East Bay Ca?
- Firewall Re Surface
- Today's off the wall question
- Paint prep question
- tint?
- electric car buffer?
- Sealer Quistion 4 porchdog or anyone
- Refinished my quarter panel this weekend
- SPI universal cear over PPG SS
- Armor Coat protection for Vette Paint
- rear quarter fender body line
- Fiberglass Roller question
- What primer/sealer for my raw glass C-1
- Help With Black Paint Job
- Interior paint
- removing paint spatters from 3M clearbra
- Sandblasting in Texas
- what resin to use
- Yet another Chemical Strip Question
- Black or grey epoxy primer?
- Painting new interior pieces
- Needing quotes in Tampa area
- Dr. Color Chip
- A painting newb
- Sealing old paint?
- Clear Bra - How long to wait on new paint?
- Porchdog was right
- I scraped the roof of my 08Z
- Whats the best thing to use to strip the paint off the hood of a C4.
- Some questions on blending
- Body seams
- Tips on how to paint this...
- i hope chevys quality is better now than back in 1980,(pictures)
- insurance appraisal
- Spots in sealer
- front clip attachment
- Removing Wax on rear defuser
- Which Harbor Freight HVLP paint gun for SPI Epoxy Primer?
- Painting a C4
- 78 Pace Car
- sherman williams paints
- Advice on best prep before painting
- Las vegas Body Shop
- DIY Scratch removal
- Flo-Coating
- Are C5 Door Handles Painted Differently?
- Rear fender repair
- Power window ?
