View Full Version : C6 Scan & Tune
Pages : 1 2 3 4 5 [6] 7 8 9 10 11
  1. Free-Air Calibration for wide-band O2 sensor?
  2. Wideband O2 in Stock Exhaust?
  3. Mail order tunes
  4. socal tuner for turboed escalade
  5. The Tuning School Live Seminar HP Tuners Beginners June 27-28th Tampa, Fl
  6. Shift Pattern selection on a T43 TCM - 6L80 Trans
  7. Car throwing codes!
  8. Tune for a 09 C6 A6 with G6X3 cam and 3.42 rear
  9. hp tuners VE tune
  10. Any tuners on Oahu?
  11. 2008 ECM swap??? for the tuners
  12. hp tuners newbie
  13. intake air temp ignition retard
  14. where to put WB Bung ???
  15. DIY tunes
  16. Trans not shifting right
  17. looking for a good tuner
  18. tuner ?
  19. HP tuners cable getting in the way?
  20. Chuck Cow Tune
  21. LTFT and WB O2 MAF settings
  22. went to the dyno today
  23. 2008 coupe basic tuning questions
  24. Worth getting a retune??
  25. The Tuning School Home Study Course
  26. 421 HP with just an intake, thanks Shawn!!
  27. TPS issues
  28. Iat
  29. Tuner Question - Please Help!
  30. Stock Timing Advance
  31. Chuck tuned my C6 at BG...WOW!!
  32. How much TM did you remove?
  33. competitive mode
  34. Tuners help plz.
  35. Jeremy Formato Tuning and Porting in Gettysburg PA June 13-20th
  36. Need a tune for a 2007 z06 hptuners..
  37. i need help in LS3 tune
  38. Drag launch technique for HPTuners
  39. Help!!
  40. Cartek cam only new best 11.1 @123.7
  41. Cartek cam only new best 11.1 @123.7
  42. 08 C6 throwing codes after track weekend. Please help.
  43. Do i need a tune?
  44. Degrees Of Tune?
  45. I'm Looking for an experienced tuner in the Pensacola Florida area
  46. Procharged Z06 Code help!
  47. predator update
  48. *** Unlimited HPTuners Pro Box *** See Inside!
  49. 2009 Z06 PCM code
  50. Got the Tuners...
  51. 06 A6 shift question
  52. Why does timing fluctuate between 4000-5000 RPMS?
  53. Any Horsepower Tuners going to be at the Cruise IN?
  54. good price? dyno tune
  55. Formato tuning and porting in S FL (Davie) May 15-16
  56. Tune & Warranty
  57. Please help with these CEL codes.
  58. HP tuners for an 06 c6 coupe
  59. Hp tuners Pro vs normal for the newbie
  60. Can the HPTuner VCM Editor do the following?
  61. HP tuners
  62. Few questions about my FlashScan V2
  63. '06 Trunk Leakage
  64. looking for a good tuner
  65. c6z06 shifter
  66. Help
  67. Newest Stock GM Tune for 08 C6 MN6 LS3
  68. Jeremy Formato tuning in Gainseville FL 5/7
  69. G5X3 cam install question
  70. Can launch control like the 2010 Corvettes be added to LS3 corvettes via a tune?
  71. HPtuner logging distance or accelerometer
  72. Is 3 bills a good deal?
  73. IAT mod?
  74. Cold/Warm Start Issues...
  75. Leaving a WB O2 sensor installed
  76. HPtuner training classes
  77. LC-1 install troubles
  78. IFR's for mototron 60# injectors??
  79. Do I need a 2 Bar sensor to tune for 14 psi?
  80. Tune??
  81. ANyone done a dyno pull before and after a diablo predator install?
  82. Check up after a dyno tune shows car running richer
  83. Another tuning option; many have asked for it!!!
  84. Battery discharges rappidly
  85. Adjusted PE table to get richer mix but now I run too rich between shifts
  86. PM-FL Tuning Package Sale!!!!
  87. Fuel Injector Technical Article
  88. Plese explain....
  89. I need a tune. Software info needed. Headers, high flow cats & Z06 mufflers.
  90. Can you access C6 codes the same way as on a C5?
  91. Those with Z06's and Diablo Predators come in!
  92. TT Performance Parts Inc. the good the bad the ugly ????
  93. Which transmission tables match D and S?
  94. eliminate rear O2's completely?
  95. Wiring help
  96. CEL with SLP Blackwing
  97. HPT file error
  98. HP Tuners and mail order tunes
  99. ~~~~ St Jude Auction #34 mail order tune for C5 / C6 from Chuck Cow ~~~~
  100. Opinion on PLX sm-afr and dm5 gauge?
  101. I need a new or used 05 C6 PCM/ECM TODAY!
  102. Knock Retard..
  103. LG G5X3 tune
  104. Best F/I tuner in N.E. area?
  105. Mucho Help PLEASE!
  106. Best shop in miami for a dyno tune???
  107. Diff. bet. 08 and 09 ECM software?
  108. Locked PCM Issues
  109. Diablo Predator and Aftermarket Amp
  110. What should AFR be with Meth/Water mix?
  111. Driving A6 with gear change without tune questions?
  112. Tuners or Perfomance Mechanics Near Kansas City
  113. IDC's on stock Z06?
  114. Do I need to retune after installing a Vararam Intke?
  115. SUV Tuning (Tahoe/Suburban)
  116. Will LM-1 bosch sensor fit NGK AFX?
  117. Where are the tunes stored on the c6 ?
  118. Innovate Wideband Gauges/Controllers On Sale!!!
  119. •• Purchase HP Tuners Pro and get an Innovate LC1 for $139 or NGK AFX for $239!!! ••
  120. Anyone have the Predator Performance Tune in their C6 ?
  121. Perfect Laptop for tuning $350
  122. Predator tune with wider tires?
  123. Tuner in Wisconsin
  124. speaker noise
  125. The Tuning School Live Beginners HP Tuners Class Dallas April 19-20th
  126. Tire Sensors
  127. A6 Won't Shift @ WOT after 3.42 install
  128. Clutch Pedal Position Relearn?
  129. Tune Question ??
  130. Check engine lite - reduced power
  131. 100mm LPE mass air meter questions
  132. HP Tuners - No LS3 Tunes?
  133. locked tune
  134. $$ NEW FAST 92mm Intake Manifold $799 $$
  135. Tuning the LS2 with HP and Wideband
  136. RPM diff install and calibration
  137. Tuner near South West PA......A really good one is needed.....HELP ME!!!!!!
  138. SCT tuner?
  139. shift points for A4 with 3.42's
  140. Tune Needed in Scottsdale, AZ
  141. MTI of GA Dyno Tune
  142. Need a Good Dyno Tuner in Alabama
  143. LC1 users: where do you stow it?
  144. Stock LS3 is it worth it?
  145. Which wideband?
  146. What am I missing here?
  147. Need a tuner near Richmond VA
  148. Tuner near central PA
  149. Will i have to Re-tune if i punch out my Cats ???
  150. Clutch breakin
  151. C6 ZO6 - 558 RWHP daily driver - Katech
  152. Air/Fuel Ratio
  153. chuck cow
  154. Tune Results! [dyno/pics/video]
  155. will a tune be needed after someone installs the VR-TBS1?
  156. tuner for the TCM?
  157. exhaust gasket
  158. How do i hook up a PLX WO2?
  159. Vengeance Tune in Hawaii
  160. 6 spd owners, did you know??
  161. ******Gettysburg Tuning and Porting March 27- April 4******
  162. Need Slow Hawks number
  163. Formato tuning and porting 3/6 in Gville
  164. Tuner in Orange County, CA
  165. predator and longtubes
  166. Can you alter the threshhold for the low tire pressure DIC error msg with HP Tuners?
  167. F/S LS2 edit
  168. Rev up at start?
  169. Slicks or drag radials?
  170. NIB EFI Live V2 for sale
  171. In Alaska need tune for 2009 C6
  172. Fan spd vs vehicle spd?
  173. Thanks to slowhawk
  174. HP Tuners Sale @ KY Speed
  175. Tuning procedures-please help
  176. Chuck COW tune on an MN6
  177. Different Tune vs Warranty Question
  178. IAT Relocation cause detonation?
  179. Tuning, How to's
  180. A6
  181. 08 VE Table Tuning
  182. Torque Management quirk in tune during powershifting
  183. Code scanner
  184. Tuning software?
  185. Wide Band
  186. Chuck cow tune
  187. Do I need a tune?
  188. Need to clear Diag Code
  189. LQQKING for a good tuner in Ohio
  190. Diablosport Predator
  191. EFIlive Cable
  192. Fuel Economy off. Can this be modified within HP Tuners?
  193. Speedometer change from 3:42 to 3:90
  194. How do you turn off Adaptive Idle for tuning?
  195. Free Shipping + on HP Tuners
  196. diablosport help
  197. SD Enhancement?
  198. Some help please.
  199. IAT not dropping with 50 shot of NOS
  200. Need input before purchase of tuning software
  201. Tune...
  202. Finally a great tune!!!
  203. Need a Great Tuner in Raleigh/Durham/Cary NC Area
  204. A/F ratios with E10
  205. Dayton, OH area tuners/installers
  206. Only a week left on our great introductory offer!
  207. Questions on GM's ECM tuning?
  208. Halltech CAI & Tune???
  209. Tuner in massachusetts
  210. Should I throw my Diablo Predator away?
  211. 2005 pcm in a 2006-2007
  212. Tuner in New Orleans Area?
  213. Anyone have their 08 vette ECM upgraded by GM?
  214. Air/Fuel review please!...>>
  215. Air/Fuel review please!...>>
  216. Reprogram BCM
  217. got efi live need tune
  218. Car is getting richer as speed increases....a few questions
  219. FREE SHIPPING & MORE on HP TUNERS
  220. Dyno
  221. Tuner needed in Knoxville, TN
  222. replace 06 pcm with 07 pcm?
  223. Dyno machines????
  224. cold weather running lean
  225. Stock Tune Question
  226. LPE CAI vs Bee Hive
  227. Is fuel pressure shown in the C6 OBD-II data
  228. 08 Software Update - Locked ECM?
  229. Mods just beginning, when to tune?
  230. Programming the DIC... Is it possible?
  231. Is any tuning needed for a dry 50 shot?
  232. Kudos to Mike Norris
  233. The Tuning School Live seminar class January 17-18th Tampa, FL
  234. Is there a programmer/scanner that will cover GM 3800 V6 as well as '07 Vette?
  235. Professional Tuners in Kansas City???
  236. EGR pin for '08 corvette
  237. Why would my TPS only read 88% at WOT?
  238. Chuck cow tune
  239. **** St Jude Auction # 7 C5 / C6 Tuning from ECS******
  240. TPMS Warning Light
  241. Just learning how to tune. Need suggestions.
  242. hi guys, Need Big Help Here :-(
  243. Chuck Cow to S. florida?????
  244. What's Involved??
  245. tuner?
  246. Help on tunning an 09 c6 zo6!!
  247. Where is the ECM plug on a 2009 C06?
  248. Tune HP?
  249. 05 z51 A4 3.15
  250. used 07 and predator
