View Full Version : C6 Scan & Tune
Pages : 1 2 3 [4] 5 6 7 8 9 10 11
  1. Help: My xm1 and xm2 disappeared
  2. before and after dyno results with ported TB and IM on an LS3
  3. 2011 Corvette support is here!
  4. Procharger Tensioner Pulley 1/4 Mile Pulls Video
  5. ><>< St Jude Auction #46 "The Man Knob Exhaust Switch" ><><
  6. 2010 grand sprot, blower/cam/tune, stutters at 2000rpm after new tune
  7. HP Tuners & Innovate Sale!!!
  8. I need some help on HP Tuners and General questions...
  9. Need a Tuners Expertise
  10. Innovate LM1 Overstock Sale!!!
  11. Of the shelf tuning solutions?
  12. Quick question
  13. Formato's Florida Tuning Schedule for July:
  14. Can you feel the difference with a tune?
  15. With Speed Density, is it mandatory to get a re-tune when swapping S.C.'r pulleys ?
  16. 02 sensor possible issue?
  17. Looking for tuner in Tulsa/OKC area
  18. Do Knock Sensors throw codes?
  19. Question for those that tune...
  20. Confused about "Tune" for 08 C6 A6
  21. Tuner in Washington State
  22. ls1 to ls2 conversion Knock sensors...???
  23. *** St Jude Auction #40 Custom Dyno Tune C5 and C6 ***
  24. *** LAST CHANCE!! Get a Cam ....
  25. tune for a D1 procharged Z06
  26. Any experiance with this tuner?
  27. how to tune for fuel trims z06?
  28. ~~~ St Jude Auction # 39 "Get your motor runnin' ! " Cam Auction ~~
  29. Xtreme News. Must Read!
  30. Finally! COMPLETE HUD KIT - www.PartsTaxi.com
  31. Exhaust leak?
  32. *** How to make your A6 Corvette AMAZING! ***
  33. Knock Sensor ?
  34. Permanent Tuner in South Florida Breathless Performance tuning for over 10years ONSIT
  35. P0030 and P0135 Error Codes
  36. Data logger to measure shift times.
  37. best way to install innovate lc1 for mobility?
  38. Dyno tuning up to the 2010 Vettes. All our tuning is done onsite on our Mustang Dyno
  39. Dyno tune vs mail order
  40. ReTune previous owner
  41. Need 2008 A6 Transmission Tune - PA or NJ
  42. Diablo Trinity
  43. skip shift
  44. Has anyone used a Predator on 07 z06 ?
  45. how much does dyno tuning on warm, rainy day affect HP?
  46. scan codes PO700 and TCM P1825
  47. Tuning in South Florida
  48. Yeah for me!
  49. Idle Issue
  50. Anybody ever brick an ECU doing a full flash?
  51. Tuner in california for driveability
  52. KY region TUNER needed for 1000HP????????
  53. Help reading HP tune
  54. Do I need to retune when I install a new Torque Converter?
  55. Trouble Codes P0171 & P0174
  56. Code P0808 1-4 UPSHIFT (SKIP SHIFT)
  57. HP Tuner in Las Vegas area?
  58. Northern California Tuner Needed
  59. 160 Thermo setting help
  60. rs4 performance chip
  61. Anyone have a innovate tail pipe sniffer for sale
  62. Throwing code P0108 at track (road course)
  63. GM Accessory Splash Guards $90.95 - www.PartsTaxi.com
  64. HP Tuners Tech Support Question
  65. The Tuning School Products Instock and Free Shipping
  66. May C6 Specials - www.PartsTaxi.com
  67. HP Tuners In Stock & FREE SHIPPING!
  68. SCT SF3 Programmer
  69. LS3 MAP Sensor Question
  70. Ported Throttle Body --> More Timing?
  71. The 6-Speed Tuning Guide and The Advanced Learn at Home Course
  72. Gurgling/Popping on Decel
  73. Help. I am locked out of my Vette in Houston (Right Now)
  74. Supercharged how many degrees???
  75. Winaldl - how is it possible to read the BLM and INT when driving
  76. LM 1 wideband RPM converter
  77. BIG THANKS - Charlie @ RPM Motors
  78. Range of knock retard?
  79. Houston dyno day/Car show - May 22nd
  80. dyno tune
  81. Z-box for sale
  82. retune/supertune obc?
  83. Stock Tune Altered 'Stamp' left behind voids warranty???
  84. Results from Gettysburg Tuning Trip - Dyno Results Inside
  85. laptop software
  86. Part throttle timing adjustments
  87. 08 C6 w/ "Reduced Engine Power" Message
  88. LS2, part throttle knock / ping around 3000 rpm
  89. 10 Akrapovic Titanium Exhausts on the way
  90. The Tuning School Advanced Live Seminar May 15th-16th in Tampa FL
  91. Dallas Beginners Live Seminar
  92. Need help with my HP Pro Suite Tuner
  93. WTB C6 LS2 Tune in Massachusetts
  94. Infernal Flappy Plastic Shifters
  95. Corsa Exhaust Discount 33% off MSRP
  96. Ported intake manifold question
  97. C6 Ignition Button question
  98. Pro Vs Standard?
  99. Coolant Table?? Air/Fuel Start up? Other Start up Tables AHHHHHHH FRUSTRATING!!!
  100. Eastcoast Performance Has You Covered>>>Supercharger Kits/Axles/Clutches/Couplers!!!
  101. Tune kills Power to Fuel Pump?
  102. ~~~~St Jude Auction #34 mail order tune for C5 or C6 from Chuck COW ~~~~~
  103. Tuning dilemna in C6
  104. Anyone with a katech torquer cam?
  105. Need help TPMS
  106. Please help with an 2005 tt.
  107. Swapping ECM's in an '09 base
  108. tune
  109. Key Phob losing signal (even with new battery)
  110. smells like sulfur 2009 C6 only 15,000 miles
  111. What is the opt Air fuel radio for TT 9psi for max HP
  112. Davie / South Florida - Formato Fasterproms Tuning April 12th and 13th
  113. Just installed a FAST 92 intake. Tune?
  114. F/s brand new hp tuner suite2.2
  115. Retarding Degrees of Timing
  116. HELP please with electrical problems(MAF related?)
  117. The Tuning School Beginners Live Seminar June 26-27 Tampa FL
  118. 2 1/16" AFR that reads lambda?
  119. Chuck Cow in Raleigh
  120. Need help!!! O2 errors
  121. Tune today
  122. New intake and exhaust, should I get it tuned?
  123. Needing help deciding
  124. ****TUNING SALE AT East Texas MUscle Cars****
  125. Mti Racing Open House Dyno Day Saturday April 3
  126. NGK AFX Wideband Kit - Now comes with upgraded NTK sensor at no additional cost!
  127. view HPT log w/out HPT???
  128. EFI econd vehicle (Vette) help needed, maybe missing something with the truck setup?
  129. HOW TO, Ign on mode, EFI stock tune download???
  130. Differences between SAE Correction Factor & STD Correction Factor
  131. Tuner in South Florida
  132. Dyno Tuning
  133. Replace LS2 MAF with LS3 MAS
  134. Good Conditions For Tuning (Weather)?
  135. 08 zo6
  136. Tunner in DFW
  137. Just met with Jeremy Formato of fasterproms
  138. Diablo Predator Air/Fuel reading
  139. ••••Formato Fasterproms Gettysburg PA April 16th Through April 24th••••
  140. SP Motorsports Mail order tune - $140
  141. Pre-Race Season Tuning Special
  142. Can't Wait till April!!
  143. WTB Stock LS2 Throttle Body
  144. #### Gainesville - March 19th - Formato Fasterproms Tune Session ####
  145. Stock C6 Z06 dyno tune gains?
  146. EFILive & HPTuners on sale+ LC1 For $129shipped
  147. HP Tuners In Stock, Ready to Ship!!!
  148. Trying to find the primary volumetric efficiency table for 08 C6?
  149. GM Performance Cams Now Available! - www.PartsTaxi.com
  150. Anyone with tuning contacts in Israel?
  151. Need tune in Phoenix - any reccommended shops?
  152. Any advantage to the NW TB Here.......
  153. Super noob questions
  154. t56 6 speed shifter upgrade
  155. Recommended tuners in St. Louis
  156. GAINESVILLE AREA Formato Fasterproms Tuning and Porting March 9th
  157. •► ► TUNE YOUR CORVETTE @ HOME with EFI LIVE and CHUCK CoW ◄ ◄•
  158. *** S. Florida - Formato Fasterproms Tuning and Porting March 11th through 13th***
  159. How to Setup Your Wideband in HP Tuners
  160. Predator 91 Octane tune LTFT's/gas mileage?
  161. The Tuning Schools Beginners Live Seminar Dallas TX April 17-18
  162. Removing the cats. What changes do I need to make?
  163. Why does my EFI live unit keep failing?
  164. Code po420
  165. "Normal" Parasitic Loss: Flywheel HP to RWHP
  166. New Tune
  167. 2010 Support added!!
  168. Tune the A6 or leave Stock?
  169. z06 corvette efi wirinh diagrams
  170. I need HELP! I have installed a A&A SC but I am having major issues.
  171. Tuning for injectors help.
  172. cadillac ctsv swap
  173. Adding mods w/ no tune... watching A/F on dyno, but curious about timing advance
  174. 2005 c6 ecu
  175. Rev Limits ... Basic Questions
  176. Clearing codes without scan tool?
  177. NEED Tech 2 tool in GA/Al
  178. The Tuning School Advanced Live Seminar March 20th-21st Tampa FL
  179. moving to Houston TX - emissions testing question
  180. The Beginners Learn at Home Course Review
  181. 1999-2008 Corvette Superchips Cortex Programmer
  182. Stock Ignition Timing?
  183. Why am I back firing (through exhaust) when I hit rev limiter
  184. Modified parameters, diablo predator tune
  185. Ported Intake / Throttle Body and Tuning Special
  186. Speed Density tuning for the ZO6 LS7 E38 PCM...anyone done it?
  187. Hp Tuners Pro In Stock
  188. 08 Z06 Misfire Issue
  189. Mike Norris Motorsports Tuning In Central & SE FL Feb 17-19
  190. C6 M6 to the dyno for Predator tune
  191. Heads Up Display Kits In Stock - www.PartsTaxi.com
  192. February 2010 C6 Specials - www.PartsTaxi.com
  193. Question on a/f ratio
  194. Tech2 problem: PC can´t connect to Tech2 - NEED HELP!
  195. Can anyone recommend a C6 tuner in Orlando?
  196. I have rev matching back!!!
  197. Diablo Trinity....
  198. Best Tuner in Raleigh, NC Area ???
  199. NEED HELP! Anybody with TECH 2 Scanner (Tampa)??
  200. C5 Throttle Body Tuning Tips
  201. Ft Myers - Formato Fasterproms Tuning on Feb 3rd
  202. MAP readings - please explain
  203. Speed density vs MAF tune
  204. Looking at EFI Live..got offered a TechII.
  205. Gainesville - Formato Fasterproms Tuning Jan 28th and 29th
  206. *** FS: *** U7191 DiabloSport Predator...
  207. Which Diablo Predator Tune to Use?
  208. The Tuning School 2010 Live Seminars Schedule!!
  209. Midwest & Great Lakes LSX Winter Dyno Tuning Specials Starting @ $250
  210. The Tuning School Live Seminar Beginners February 27th-28th Tampa, FL
  211. I need help, just got my ecm back from chuck cow and my car does not crank
  212. FINALLY! ECS is offering A6 trans tuning via a handheld programmer!!
  213. Is there a difference in tune.
  214. New cam causing "bucking" how do I tune this out?
  215. Awesome Special on Diablosport Predators!
  216. Best tuner in southern CA.
  217. South Florida - Formato Fasterproms Tuning Jan 19th and 20th
  218. C6 Heated Seats problem
  219. How do I know I have enough air to make power?
  220. Help answer needed !
  221. Running out of fuel with 60# injectors...what next?
  222. RPM, YANK,SUBFLOOR, Thanks again.
  223. RPM, YANK,SUBFLOOR, Thanks again.
  224. What throws a bigger flag to a tech about a tuned ECU? (reflash vs. swap)
  225. WO2 stuck reading 10.64, does that mean the sensor is bad?
  226. Can GM detect a tune. I need to keep warranty
  227. Question about O2 sensors
  228. efi live or hp tuners, which is best?
  229. C6 Tuning Question
  230. Stage 2 Intake and Tuning Results
  231. The Tuning school Tuning Packages
  232. Chuck Cow Dyno Day in Southeast:
  233. Happy Holidays From Xtreme Motorsports
  234. BPP 11th Hour Sale Xmas Free Shipping Plus 10%
  235. **etune wanted for z06**
  236. RWHP to Flywheel HP calculator?
  237. Mustang MD-1750 Above Ground Chassis Dyno and Four Post Lift For Sale
  238. Scary tuning session
  239. I tune my car with HP Tuners normally but for some reason now EFI Live can't connect
  240. Crank position relearn after installing shortblock
  241. Tuning using Dyno Pak or Track?
  242. Master efi tuner - gm efi - available now!
  243. Parameters for RC 71lb injectors
  244. CAR IS AT RPM, need there trans tuner.
  245. DynoJet 248x Dyno w/ 4 Post Lift-$9000
  246. Formato Fasterproms Tuning and Porting S Florida Dec 21/22 and Gainesville 12/30/09
  247. Chuck Cow =Corvette Performance
  248. Anyone have a tune for 402 with a cam? HP Tuners?
  249. P0354 Ignition Control #4 Circuit
  250. Any Good Tuners in SE Wisconsin or Illinois??
