View Full Version : C6 Scan & Tune
Pages : 1 [2] 3 4 5 6 7 8 9 10 11
  1. •► ► HOLY CoW!!! CoW BOOSTER for FREE ?!?!?! @ CARLISLE!!! ◄ ◄•
  2. •► ► CHUCK CoW AutoCal SUPER DEAL @ CARLISLE!!! ◄ ◄•
  3. wtb used diablo tuner for 05 c6
  4. Looking for a tuner in Jacksonville, NC
  5. •► ► THE OFFICIAL TUNER OF 2011 CORVETTES @ CARLISLE is CORVETTES OF WESTCHESTER ◄ ◄•
  6. #### St Jude Auction #77 LG Motorsports 'Zipper Door' Car Cover ###
  7. can an air intake cause an AH warning?
  8. F/S Calibrated success DVD vol-2, greg banish
  9. 08 Won't start
  10. Predator tuned odd 'dead spot' around 1500rpm
  11. @@@ St Jude Auction #76 Case of Royal Purple and a K&N Filter @@@
  12. >> St Jude Auction #75 C6 Corvette ZR1 Style Carbon Fiber Side Skirts <<
  13. A6 Tune help
  14. ~~~ St Jude Auction #74 "The Man Knob" from LG ~~~~
  15. •► ► CoW BOOSTER - THE MOST AMAZING C6 PRODUCT EVER OFFERED - GUARANTEED! ◄ ◄•
  16. edcmat-l1 tuning in Pittsburgh Aug 29th til?
  17. SLP/Predator programer Q can you tune out rear 02's
  18. >*>*> St Jude Auction #73 "Stop Draggin' your car around"...Frame Savers C5/C6 <*<*<*
  19. Code PO442
  20. ~*~* St Jude Auction #72 Stainless Steel Brake Lines for C5/C6 ~*~*~
  21. Recommendation
  22. Fast Advanced Race Control & Self Tuning XFI 2.0
  23. Ambient Air Temp sensor?
  24. Tech 1 data advice needed on listed settings
  25. Recommed a tuner for the SCT handheld system.
  26. Predator Tuner question
  27. Help with c6
  28. Need Help With Diagnosing A Problem C6Z06
  29. Spark knock under light throttle
  30. 1153 code
  31. TCM: Normal, Default, Sport and Hot Mode
  32. Tuners and 160 degree stats.
  33. Question.
  34. does this sound right for mods.05 ls2 dyno
  35. Place your order pickup at Corvettes of Carlisle
  36. Help!!!!!!!!!!!!!!!! With after tune issues
  37. Advice Needed: Cats or no cats
  38. Industry Leading Tuning Servies!
  39. Rear Wide Body Kit Blow Out Sale - www.PartsTaxi.com
  40. Car recently Tuned...need info on results.
  41. EFI Live & HP Tuners on Sale plus LC1 for $129shipped
  42. >*< St Jude Auction # 66 HID Kit C5 or C6 Winners Choice >*<
  43. Help with Engine codes
  44. what is this computer pin used for
  45. 08 Trouble Code CO450
  46. received great tuning service!!
  47. Hp tuners supercharger file
  48. Car Running Badly After Tune Courtesy of Bad Plugs (Maybe)
  49. DiabloSport and Torque Management
  50. Awesome mileage
  51. Logging knock through SCT/LiveLink
  52. FAST Intake, TB & Tunes Results!
  53. Seimens 46# injector characterization info
  54. HP tuners 72 lb injector question
  55. ECS coming to Chicago
  56. Will a new tune help with emissions and inspection?
  57. Slighty rough idle after installing Airaid CAI
  58. diablosport predator tune questions
  59. Long term Bank 1 and Bank 2 trim don't match
  60. Random Check Engine Light
  61. Master efi tuner - gm efi book available!!
  62. Check in w/dealer for a brief "Service Active Handling" error?
  63. good tuner wanted in bahrain
  64. About to send my PCM off to get tuned by ECS, have a few questions.
  65. Actual Octane HP Differences on a Dyno
  66. Rear wheel roll out
  67. *~*~* St Jude Auction # 62 LS3, LS7 Attack Blue High Flow O.E Replacement Air Filter
  68. >>> St Jude Auction #61 CNC Ported LS2, LS3 & LS7 Throttle Bodies<<<<
  69. Rev Limiter A6
  70. Question about best iPad app obd2
  71. Dyno results similar cars
  72. Jeremy Formato tuning & porting in Gettysburg PA August 24-29
  73. emission fail
  74. EFI live & HP tuner special
  75. July 2011 Aftermarket Specails at GMPARTSHOUSE.COM
  76. First time tuner-want to get my feet wet-HP tuners the best?
  77. Check engine light after removal of skip-shift fuse
  78. edcmat-l1 tuning in Germany/Austria
  79. Questions for ECS, re: handheld and mail order tune
  80. Help with idle issue
  81. I want to run straight pipes w/o CE Codes 08 z06
  82. low dyno numbers after mods
  83. Map scaling help please!
  84. Greg Banish's Next DVD
  85. How do you log injector duty cycle in EFI Live? Anyway to log fuel pressure too?
  86. How much RWHP before maxing out LS7 injectors?
  87. Dyno Guru's
  88. What causes Gurgle on Decel? What could cause it to be reduced? Disappear?
  89. Tune in Indianapolis, Indiana
  90. Punisher Cam on Z06- tune?
  91. Looking for a tuner in Damascus MD area
  92. Hand held tuners???
  93. Data logging - Sampling Rate
  94. Ragin Racin's June Specials
  95. timing retard
  96. Between LS2-LS3
  97. 15-25 HP Plug in Horsepower avaialble at GMPARTSHOUSE.COM for 289.99!!
  98. Tuning - Lessons Learned
  99. The Vette Doctors presents their Fathers Day Supercharger special of $5,595!!!!!!!
  100. Which flash programmer? (newbie here)
  101. LC 1 to HP Tuners interface??
  102. Emissions Evap issues... EFI Live, HP tuners the answer?
  103. Hesitation, Misfire? Tune problem???
  104. Trifecta Performance Tune! Anyone Use it?
  105. Texas Speed & Performance NEW WEBSITE!
  106. TUNE and Emissions
  107. Anyone successfully used Gopoint Technologies' GL1 OBD-II iPhone/iPad Interface?
  108. Just email speed inc for appointment :)
  109. Diagnostic advice needed!
  110. What might work for swap?
  111. Issue with tune?
  112. Are all the A6 automatic transmission tunes from various tuners created equal??
  113. Rain Racin June Specials
  114. June aftermarket specials list GMPARTSHOUSE.COM
  115. Need some help with my tune
  116. HyperTech III Help
  117. Confused bewildered.need assistance
  118. Dyno Battle, low dyno numbers interesting story :)
  119. Getting a Tune for my 05, 6sp. Need info..
  120. Looking 4 Tuner c6 RI,MA. AREA
  121. Low Octane table
  122. Help?? I need to use my laptop with AutoCal to program a tune into my car
  123. P0208 Injector 8 Control Circuit ECM
  124. Possible starter/ground issue?
  125. Looking for Tuner/DYNO near St.Louis MO
  126. Ok with out a tune for a road trip?
  127. First tune install attempt - car won't start!
  128. $50 Dyno Pulls w/ $50 Gift Certificate
  129. >>>> St Jude Auction #42 C6 Mobil 1 Corvette Racing Oil Cap <<<<
  130. Speed Density Question
  131. C6 AirTemps with IntakeAiraid/K&N or engine bay CAI
  132. Jeremy Formato tuning & porting in Gettysburg PA June 11-17
  133. Ragin racin may specials
  134. GMlan problem
  135. which tunner?
  136. STD vs SAE
  137. Tuner in IL(chicago) wanted
  138. DiabloSport Trinity On Sale with FREE UPS NEXT DAY Delivery!
  139. Diablosport Predator Flash Tuners - ON SALE FOR $279.95 SHIPPED!
  140. need a tuner
  141. Torq is headed to Stockholm!
  142. ★ Custom Wide Band Street Tune!
  143. [Results]: Tune by Torq
  144. Ls3 handheld tun
  145. RPM surge on start up
  146. May 2011 C6 Specials - www.PartsTaxi.com
  147. Predator 7194 Failure?
  148. Is this a technical warranty violation?
  149. Wheel calibration
  150. tune needed ?
  151. EFIlive help
  152. diablosport tune question
  153. Huge power gains - z06 tune results
  154. Best SoCal Dyno Tune?
  155. Predator Unlock
  156. Need Non-Beta Version of HPTuners Pro...
  157. EFI Live AutoCal downloading problems?
  158. Chuck Cow or ECS Auto hand held tuners?
  159. Playing with fire?
  160. Uncharted Waters/LCD screen
  161. Whatever happened to Ed Wright (pioneer LS1 tuner)
  162. ~~~ St Jude Auction #37 Get your SHIFT Together MGW shifter package~~~
  163. Thanks chuck cow and crew
  164. Halltech's Honeycomb Laminar Flow Straightener
  165. Occasional Hard Start
  166. The Tuning School Advanced Seminar May 14th - 15th Tampa,FL
  167. Where Do You Find That Table?
  168. ECS Handheld problems. Please help!!!
  169. No more Rev Matching on 08 A6
  170. Speed Inc.- C6 cam/arh/ A&A SC RESULTS
  171. ***RSD Snap Shifter $200***
  172. 160 stat... New plugs?
  173. Tuners in CNY?
  174. Need tune input!!! Please...
  175. Super rich smell at idle, killing everyone!
  176. EFI Live
  177. Need an HP tuner format start up tune PLEEEZZZSE
  178. Programmers for 2008
  179. Where to flash my PCM after mods in AZ?
  180. HP Tuner help, please
  181. Diablo Predator not working with 2005
  182. EFI Live torgue control parameters?
  183. Anyone have a good tune for FIC Injector 108's?
  184. Tune Necessary?
  185. We can now post .hpt files
  186. ecm/pcm descriptions
  187. April 2011 C6 Specials - www.PartsTaxi.com
  188. Tuning the Active Suspension parameters?
  189. Diablo Tuner 95 Octane
  190. >>>> St Jude Auction #29 MSD 8.5mm Superconductor wires w/ NGK Plugs <<<<
  191. my budget and wat should I do?
  192. Predator U7194 - '93 Octane Tune (Review)
  193. Idle issue after cam
  194. Can't get past emissions...
  195. 2005 ECM removal
  196. Why are GM OEM tunes so pig rich?
  197. Two tunes on stock computer?
  198. Wondering if my LC-1 just died...
  199. Tuning
  200. A special Spring message from the crew at The Vette Doctors
  201. HPTuners start up???
  202. Bought a car that was HP tuned
  203. Predator U7194 - Help
  204. Tuning impact on traction control?
  205. Anyone have a stock 09 ZR1 tuning file?
  206. Why should I, or should I change my stock tune?
  207. C6 stock tune
  208. 342's won't auto ****
  209. Zo6 hp
  210. Innovate LC-1 Wideband Emulating Narrowband
  211. Used 2008 low gas mileage, loping idle
  212. Does anyone have actual dyno numbers for a diablo tuner?
  213. We're Baaaack! - March 2011 C6 Specials - www.PartsTaxi.com
  214. A&A Vortech Superchargers!-$6599.99 INSTALLED!
  215. LG Motorsports Long Tube Headers-$1999 Installed & Tuned!
  216. c6 with cam and will not half the time
  217. Check Engine Light AGAIN!!!!
  218. 91 & 92 Octane Vs 93
  219. Great service from Ragin Racin
  220. LS3 Predator tune?
  221. Just Tuned At "ECS" in New Jersey
  222. Headers and a tune in New Orleans
  223. 05 not responding to commanded a/f ratio (long post)
  224. ls3 42 lb injector duty cycles and power
  225. The Tuning School Beginners Live Seminar Twinsburg, OH April 16th-17th
  226. Wideband ? for tuners
  227. Got my 08 C6 A6 Tuned By Mike Norris
  228. Old or new Nick Williams 102 TB
  229. Surge in Open Loop when Cold
  230. Passing Emissions
  231. Tuning A6/3600 stall- drag radials for track
  232. huge power loss,need advice please
  233. 05 Z51 dyno numbers
  234. Got Tips? (For someone getting a dyno tune, that is)
  235. 2008 Dyno Tune numbers.
  236. Tune from ECS
  237. Finally Got my car on the dyno!
  238. Check engine light!
  239. OBD2 Problem
  240. We need a tuner list!!!
  241. Fasterprom's Gettysburg PA Tuning Session April 1-9
  242. **LMR LSX 451 Dyno Vid**
  243. Hand held from ecs
  244. •► ► CHUCK CoW TUNING @ VARARAM in TEXAS - MARCH 24-27 - SIGN UP NOW !!! ◄ ◄•
  245. Tuner qualifications
  246. Chuck Cow in Houston March 2011
  247. Stage 1
  248. hand held or ecm tune from ecs
  249. LS2 to LS3 maf swap
  250. Predator 7194 help please
