- Major build by: Lg motorsports
- Running Meth
- Question On FI?
- How many people run the FAST 85 lb/hr injectors?
- My C6 Z06 build is coming to a close...
- * Injector SPECIAL *
- New Look of AtomicFusion
- Zex Wet Nitrous System
- Thanks to Modern Muscle, Oswego IL
- Big thanks to A&A Corvette
- A&A C6 Z06 what whp to expect ?
- 'stock' LS3 w/ Procharger D-1SC - 604whp/542wtq
- ECS' Project ZR1 Gets A few more Upgrades :) 820+ hp/870 + tq RW!!!
- Considering going TT …. Need advice
- LS2 with L92 Heads and Boost
- Cooling Lesson Learned
- Finally took some pics of the weld Wheels
- dimond pistons and stock rods vs power
- FI C6Z vs CCXR in Mile Race
- Going FI?
- Can a 24 reluctor 6.0 engine work in a 06-09 c6
- C6 LS3 Whipple Superchargers - NOW AVAILABLE!!!
- Nitrous guys... few questions about Nano!
- 10's, Barely...
- Dedicated fuel system for nitrous?
- Anyone running A&A or ECS with 4psi?
- Has anyone used or mounted an ADM gauge???
- APS Twin Turbo on GS or Z06?
- Whats my FI vette worth IYO?
- American Racing Headers Sale w/Free Shipping @ Ragin Racin
- Ragin Racin's June Specials
- Stock ls2 shortblock hp record??
- TVS2300 With a Twist! Flywheel dyno results attached.
- base circle of LS9 cam shaft
- What thermostat Procharged Z?
- ECS Stage 1 Fuel System, help!
- Noisy E-Force Blower
- Any recomendation for a 750hp short block?
- Champion motors ttix 1021 rwhp
- Champion motors a&a dyno 616
- Any FAST 1/4 mile nitrous guys?
- IAT's and the E-Force
- A6 and FI
- Low Fuel Pressure?
- Fuel Pressure Question
- Cam specs for
- The Vette Doctors presents their Fathers Day Supercharger special of $5,595!!!!!!!
- Complete system with 8 rib, 80# injectors, fuel system etc.
- RPM Transmissions Fathers Day Sale!!! Amazing deals Look inside!
- ZIP Products 2 Edelbrock LS3 Superchargers must go.
- Whipple Camaro vs my car?
- ***ETMCs LINE OF FI CAMS, WITH IDLE CLIPS***
- LS2 with A&A at 5psi which cam?
- Level 6 TR6060 ZR1 ratio transmission for sale
- Picked Up My TTix Z06 from Race Proven Motor Sports Today
- My 91mm C6 Build thread!
- Anyone using an SCT programmer to store and swap 91/100oct. tunes?
- vibration damper
- ***MONSTER CLUTCHES $150 OFF*** Super Summer Specials!!! Limited To 20 Members ONLY!!
- dealer installed magnuson by gmpartshouse
- Helical vs. Straight Cut gears in D-1SC
- Lowering compression ratio?
- Forged pistons...stock rods/crank?
- Need a starter
- Thank you Speed Inc. & ECS
- instructions for Procharger install
- How much RWHP can be expected?
- Breather Filter
- E-force install on LS2, need help with tmap wiring
- OE zr1 fuel pump in base c6?
- please help with overheating issue
- Need Help ECS Alky kit wiring...
- Brand new ZR1 TR6060
- Can to much power hurt your in engine with stock exhaust
- 850 cc injector dynamics for TT vette question?
- TVS2300 Superchargers bolt on kits available at GMPARTSHOUSE.com
- Race Proven Motorsports TTIX C6Z "Sleeper" Package
- ****A&A SUPERCHARGER kits INSTALLED AND TUNED FOR $6399.99 JUNE ONLY SALE!!!*****
- SI-Trim Capable of 190mph? Need suggestions
- Need help reguarding Vette Doctors blower cam
- 800+HP C6 Z06 w/Nitrous Outlet Direct Port Nitrous System & Nano
- Z06 exhaust on my 07 A6
- Rain Racin June Specials
- June aftermarket specials list GMPARTSHOUSE.COM
- Blitz SBC ID 3 boost controller, fuel pressure & boost gauge
- Need some info on Prochargers
- Procharger kit for zo6
- Info on Lignefelter SC package.
- air filter
- Cooling mist methanol injection kit
- Small Oil Leak???
- Watch this guys...
- A&A Supercharger Installed for 6,499
- How Efficient is an A&A SC Kit – take a Look
- Anyone with e-force on LS3??? Need MPG differences!
- What is the target AFR at WOT with FI?
- Need some help on my Tune
- YSi or TTix .. Street Car??
- New Z06 troubles
- Thanks ECS
- gmpp lsx 376
- 7.88@183 at Milan last night
- F1R + Tial 50Q is insanely loud at idle and cruise
- A6: while stopping from about about 5 to 0 mph the car jumps forward, like a hiccup!
- Limits imposed by smog test on FI configuration? (sniffer test, NOT visual)
- My new Ride
- Edelbrock E-Force Car in the FS section
- Thought you guys would like this one!!!
- E-Force vs 92mm SpinFAST/BPP Vortex CAI
- FPG Heat Soak
- **Late Model Racecraft on TOP GEAR**
- VMAX throttle body after install
- installed e-force S/C--now have "perceived"oil usage issues
- A&A 8-rib setup, I need help.
- Planning to Race at Milan 6/3/2011 Head Up Series
- **LMR TT Corvette 231mph Video inside**
- APS Twins,Procharger,Maggie???On C6Z06
- Meth for naturally aspirated engines?
- **LMR TX Mile 244mph Video**
- FI with A6: not shifting properly at WOT
- Header size for centri
- Thanks TRIZ for helping me out with SC
- ■ LS7 Z06 E-Force Build ■
- Stall converters?
- ***Late Model Racecraft now Hold New TX Mile Record***
- Wat type of power can be made on stock bottom en (C6 Z06)
- How to get more torque?
- New 1500sl Novi and new A&A bracket!
- E boost 2 mount
- ECS Auxiliary Washer Tank Systems Now Available OTC!
- Step up ratio SL 2200
- Retune necessary on blown car when removing cats?
- Our New Boost Referenced FPR!!
- Whats involved going from P-SC1 to a F-R1
- **Late Model Racecraft's TX Mile Entry**
- Dallas Performance 'Big Mouth' intake gains on moderate setup?
- Any one interested in used M/T 345-35-18's??
- Whats the stickiest street tire 345-35-18 ?
- No Key No FOB, What Can I do ?
- Lets see your Nitrous Bottle Mounts
- Another ETMC stg 5 out the door.
- ~~~ St Jude Auction #43 Piloti Driving Shoes ~~~
- ***RSD Has Pfadt Coilovers in Stock and Ready to Ship***
- How much should a base ECS kit be making @ 11lbs
- Looking to supercharge my 07 z06. How well does stock block hold up?
- E-Force + what clutch?
- My review of the Eliminator In-tank Stealth Kit
- how much boost on ecs kit ls2?
- Procharger or NA
- P0300?
- 3" mandrel bent stainless
- A&A V3 Funny Squeel?
- My LS7 roll racer 86 coupe,LME LSX 440,Twin billet 71's and a t56 magnum
- Boosted C6Z advise requested
- Let me tell you guys something about RPM Transmissions
- Nitrous Refill Costs?
- Time to turn up the boost...
- ECS Novi 2200, ECS Small Blower Cam, ECS Methanol = :)
- Meth Injection
- Odd piece on drain plug
- Hoosiers slicks 28x10x17 ?
- Max nitrous shot on RHS454??
- FI build on 05. What is the weak link in the rear?
- 2010 A6 max TQ at low rpms
- a few tire questions
- Supercharger gear drives by Chris Alston
- Stock LS2 TTiX 1/4 mile Full street trim results
- Cam - Procharger Grandsport problem!
- Billet valve covers < made in usa
- Has anyone done "just nos" on an mn6 ls3?
- WTT Pulley
- Gauges
- Autometer Gauge Problem
- fi tune help
- Fuel System Upgrade
- APS actuators and blow off valves
- Ragin Racin's May Specials
- ULTIMATE turbo build?
- Very happy with ECS
- I made up my mind on a SC.
- after 1.5 yrs it finally complete!
- Calif legal long tube headers?
- Fuel Pump Fuse With BAP
- looking for measurements but someone may adust my thinking
- House of Boost Fuel System UPDATE!
- (One) House of Boost / Aeromotive Eliminator Fuel System ON SALE
- *****upp twin turbo- new upgrades, new results******
- TTIX 3 Inch Down Pipes!!!
- LS3 Solenoid Brackets
- Boost by gear sensor
- **Another 1000hp Corvette from Late Model Racecraft**
- M/T et streets question
- A&A kit in Miami???
- Anyone Procharge a GS....problems!!
- Gas Gauge
- A&A Corvette Brings You: A Discussion About Belt Wear
- **A&A kits INSTALLED AND TUNED $$6499.99*
- 7.75 @ 183 Record Vids (Stands and Go-Pro)
- How to measure 60-130
- 65lb injector rwhp limits???
- building for sc have questions.
- FI traction! How to get 15" front wheels to clear?
- low 8 sec guys... whatcha runnin?
- Quit it with your Centri more hp videos
- Supercharge in Miami???
- Vortech Vs ProCharger
- Need help, HSW interface maf connection
- Supercharging a stock 05 c6
- A&A Corvette's Newest Design Supercharger Kits Available NOW!!
- New Blower New Pulley
- I guess i need a clutch!
- May 2011 C6 Specials - www.PartsTaxi.com
- headers sizing warhawk F1R
- Injector size for 800-1000wheel on E85.
- My new A&A dongle with filter won't fit, ideas?
- Pro charger installers in KC or STL??
- how many lbs ?
- Pinning the Crank
- Magnuson Supercharger
- Centri Belt Recommendations
- Gates Green Fleet Runner HD Belt
- Wtb: ysi or d1sc
- Speed Inc./ C6 A&A SC Results
- Anyone turbo or supercharge your gs near daytona beach?
- What is a "Flip Drive"
- New Procharger installed - Very Satisified
- FS Polished Intercooled Maggie Kit
- Friendly reminder from an A&A Dealer!
- New custom TT setup - Power?
- *****summertime blowout****
- FI guys. HOW ARE U HOOKIN?
- *Driveshaft Shop* 3.5" vs *Pfadt Racing* Carbon vs *PST* Carbon vs *GM* Stock
- Almost Done
- LS3 heads?
- F1r on ls2???
- Dewitt Installation Temp Reduction
- Fans Wont turn On
- Oil Leak!!!
- Eforce vs Maggie TVS 2300
- Keeping down the heat
- Dental nitrous oxide systems?
- Is there a better air filter and bridge for my Procharger?
- Pushing a Little Water - Best Head Gasket for LS2?
- Best 19" rear tires
- What Are Typica SC Engine Oil Pressures?
- Heads/intake question
- Questions about my setup
- 50 state legal FI options
- Centri in black
- Champion 09 c6 a&a dyno 610 rwhp
