- Engine Rebuild, Before, During , After (pics)
- what color are our wheels?
- How Do You Repair Stripped Trim Screw Holes
- getting rid of antenna
- Quadrajet date help????
- Black egg crate grills on a yellow car (pics.)
- Tranny Mount th400
- Which water pump am I supposed to have?
- A story of one '68 (PICS)
- Remove headligh housing
- Seat belt position
- Fat Mat Installed - Pics
- 427 hood template needed
- Wimpy seat belts
- weird vibration at 70mph 1976
- Jegs Sport star wheels.. will they fit? anyone running them?
- Odd request; measurement on 68-73 r. bumper
- My Patriot Lake Sidepipe install, pics
- cruise control
- Power steering control valve removal
- Week one of body work
- Header Coatings
- best rivets?
- wiring tubing?
- White Interior '71
- Date of manufacture
- Looking for previous owner of my car
- Using this site
- New Seats in. First decent day and a cruise.
- How rare is elkhart green on 73 vert??
- Might Trade My Truck For A 79 Vette, Need Guidance
- quick carb question
- The $6.95 Carpet redo!-PICS
- Marking under car on body
- what seat belts fit??
- Tranny ID and partial Vin
- Middle Console
- coil wire grounded
- shoulder belt thru seat?
- Show me your L88 hood- need paint ideas
- Nead help on WIERD audio problem
- Weird wiper actuator conversion...
- The Use of "I" in Date Codes (Alan??)
- pedal pieces?
- Zip Coupon Code???
- Hooker side pipe inserts
- 80/82reardifsucks
- Turbo 350.......200 4R swap questions
- Front end Shutter
- 78 Build sheet, what the heck ?
- front spindle question
- Need help picking a "white" for my stripe!! Somebody??
- Your thoughts or suggestions welcomed on my frame-on
- Engines Back
- GM Performance Crate motor question.
- Looking for previous Owner 1970 LT1 coupe
- Clips that hold the vents to the center bezel
- Seat Buckets
- Looking for a decent Corvette mechanic/shop in Tulsa
- Saving Gm {Video}
- Is this place reputable???
- 72 long hood
- black side pipes?
- Power windows
- ram's horn exhaust manifold
- What's the connector by the gas pedal in 75 Coupe for?
- are all front windshields the same?
- Yet another YOM question.
- Fan Shrould
- Help decipher trim code?
- new to the site... got some questions
- Clutch pedal bumper-stop?
- Throaty Cam Sound (Exhaust)
- New chrome parts with pics!
- Vette Names
- 9 leaf rear spring
- Chassis mesure
- Hood Emblem
- Finalllyyyy got vette out!!!
- Moroso or MrGasket plug wire separators - photos?
- Jack stand locations for 4 point lift.
- '69 coupe buying questions
- What Engine do you have?
- Clean/flush fuel tank, lines?
- Removing kick panels to access body mounts
- M-20 Value
- New to the C3s and what I should know about
- 72 LS5 With Unusual Mod
- t-tops refurbished for 69
- Alternator Date
- Plastic trim redye question
- back spacing of rims?
- In Australia and broke my #@$%# windscreen
- 69 Speed Warning Indicator ??
- C3 caliper question
- 68-73 Rear fiberglass bumpers?
- Cheap replacement mirror for C3's?
- car/color combanat
- stripping door jams
- Couple 200-4R questions
- Rear steel spring question
- PPG and House of Colors on 69 t-top?
- Replacing rear bumper on my 75'
- Musty Smell
- window switch options
- Turn a Coupe into a Vert???
- silicone brake fluid
- carburetor threaded fitting
- Torco mach accelerator?
- Shift Boot
- Car Painting
- Crazy California
- What this hobby is about
- NOOB question: Trailing Arms?
- Two-tone paint jobs
- safety neutral switch
- which engines came with 2 fuel lines?
- can anyone answer this?
- Baby's got some new shoes
- Want new paint job
- Started the Vette today, What a great day!
- new shocks for 78 corvette
- correct rounting of the tranny cooling lines
- How rare is a 69 3 speed vert?
- Is upgrading the carb on my '70 vert worth it?
- Door handle troubleshooting ???
- Model year update gone bad...
- Anybody deal with CNC Motorsports?
- rear main seal how to replace
- Chambered Exhaust Info
- Thumbs up for auto transporter...
- Front Main Seal Leak Question
- Leaking like a Porsche
- Corvette Forum
- 75 paint code 74L
- Wiper Soleniod Making Hissing Noise
- Help with filling in luggage rack holes
- What would a 427/435 hp run?
- Mr. Wiillllcox!
- Where should I buy new T Tops?
- Anybody heard from 2th Farmer?
- T-top Luggage Rack Straps and New Paint
- Color Mis-Match
- Build Sheet/Tank Sticker - it's there!!!! [pic]
- only hot air...
- Best nose mask?
- Glass Packs ???
- Trouble Insuring My Corvette
- 69 louvers: need a pic of the door close insert
- 1980 body mounts
- Front rear end seal
- C5 rims on a C3
- What brand elec fan?
- Where to '69 shoulder straps attach?
- Good all-around air compressor
- It's hot in the car
- Empty Trailer,need load to Fla.
- Craziest Vette Ive Ever Seen Thread
- 69 Corvette radio help
- Supplier recommendation?
- Engine options
- Proportioning valve
- Hot feet in 79 Vette
- Door Glass outer seal
- lifting body with straps ?
- Simple Green cleaner for your Cooling System, before flushing ?
- Vettes and Jets on the Lex INFO!!!
- Assembly markings?
- Hot Stuff Manifold Dressing
- Steering wheel dye/paint
- wheels on '82
- How do you paint that part right above the back window
- I believe I found a 1969 427 motor?
- prying minds must know
- Air Compressor setup
- 78-82 Vette Double Din Stereo
- 76 frame replacement
- Should i have this repaired or replaced?
- Paint COlors - There's another color besides black????
- 1969 coupe test picture
- need pics of custom installed gauges
- Suggestion on interior purchases please.
- 74-82 Stock Exhaust (muffler) Position
- parts help
- Any experience with hideaway or windshield mount antennas?
- Steering wheel replacements - photos please
- starter question
- 1970 Motion? - Round 2
- Hurst VS Stock
- some neat modifications on my 69
- A few more stereo Qs......
- Halo projection headlamp conversion
- Need Help Pleae!!- Bad backfire and missing
- Question????????????????????
- Rear leaf spring replacement.
- '72 wiper problem
- Question - Broken Starter Clip w/ Pic
- Seat Covers
- rear steel spring
- wiring/whats needed and not
- Center Console Trouble
- My responce by republican John Evens Hb471
- Custom Interior
- Yet another update with pictures, very close now
- How in the world do i get this out!??!!?
- E Brake assembly
- Problem with 10" Bolts
- Nice SIRIUS Sportster5 for gift....
- QUICK help! dash pad removal
- Please Help Get Right Info
- Underhood wiring harness ?
- How to attach fender corner moldings?
- Are C3 rocker interchangable?
- Please help get OEM parts
- Body Wire Harness
- corvette shop in montgomery ny
- chrome or stainless rocker molding screws
- Can any forum member use a free rear spring, pick up in New Jersey
- headlight problem
- I Need Help From Someone Going To A Swap Meet Or Show
- Electric Cooling Fans - What Alternator Amperage?
- Vented or non vented gas cap
- Sidepipes opinion please
- 1981 Corvette low idle then Dies Please Help!!!
- My car is in Corvette Fever this month!
- Patriot Lake sidepipes
- How many front emblem (68-72) Choices are There??
- I know Im going to catch a lot of crap fir this but....
- Rebuilding the brake booster? Is there a kit?
- Removing Rear Rotors
- AC Fan not working
- Heater core source experience 78-82 Need a quality product.
- '72 horn relay
- stereo cables...best placement???
- radio wiring
- Tach/Speedometer access
- stripping paint off the motor
- Electric Fans - What Temp Should They Kick In?
- Re-wiring Project
- brake booster decal
- short vid of 68 4 speed with sidepipes
- **YIKES** had two really close calls
- Opinions please?
- Lug nuts for aluminum wheels
- floor mats for a 82 CE
- 78 Carpet put down
- '68 Antenna plate contraption....
- Differential identification codes
- Need Advise on Wheels and tires
- Oil pressure problem
