- Spring Carlisle
- Fiero Seat Install,, 2 options.
- ZL-1 INFO What is it Worth $$$$$$ ??????
- Another "What is it worth" 71 Lt1 M-22 numbers matching
- Heppy Easter Dear Vette Brothers & Sisters!
- My first longer road trip in my C3 (Estonia, Europe) PICS
- Added a C4 to my C3 this weekend
- 1970 454 correct spark plug
- San Francisco Bay Area guys... Know of any local cruise coming up?
- New to Vettes
- Tip - Remove grease from interior carpet!
- Props for GTR1999
- BBC pulley clearance on frame question
- Use old engine oil?
- Under hood paint
- do you do this?
- headlight door adjustment
- Just wanted to day thanks
- coil condensor
- BJ 78 Pacecar with no VIN
- Seat adjuster knob
- stupid door spring ?
- New set of pipes or not ?
- 74 needing advice on tranny...
- 3/8-18 thread temp sending unit
- 1971 Won't Start
- wiper arms
- Belt Squeal - 79 vette
- Rear seat bolts
- Rear seat bolts
- Remove seats
- Car history
- posting pics
- Leak down test
- Actuator problems?
- What method of paint stripping?
- Valve Cover Label
- Driving / operating tips for this car?
- $10,000 for a 74 vette?
- 79 hood will it fit???
- Removed timing chain cover on my 402, arent these 2 holes supposed to be closed off ?
- Bellhousing
- Failed..........motor install attempt
- Which bellhousing # fits a 11" clutch?
- Exhaust trim help
- How to test for exhaust leaks?
- PA Antique tag question
- Differential Gasket
- AutoBuffs / Engraving :)
- Follow along as I rebuild my 69 350 Coupe
- Rear Window Molding
- AHH what did they do! i think it used to be a vette
- Removing part of ventilation in 76 - please help
- Part Number Help
- GMpartshouse.com?
- Almost ready for the road! butttt... 3 questions
- w/s wipers only work with door/hood open
- Assembly Instruction Manual for 1974 vette
- carb numbers on horn 9895-1 and 2086 what model? 4175?
- Will this GM aluminum manifold improve performance over stock manifold?
- ride height
- Is it a bulb or the flasher
- Anybody buy or sell their vette lately?Prices?
- 68 car Muncie casting numbers controversy
- If Urethane bumper is too small..
- Bigger wheels on 1982
- New Wheels
- Window won't go all the way up
- What is this component attached to the Heater Hose?
- 75 seat belt problrms
- side exhaust covers
- Ethanol in the gas -- problems?
- new billet specialties 18" rims came in today
- Tyres/Tires 80 Vet
- blower motor help please
- Front Shock Spreader Bar ?
- Not so fast BJ and GM
- Survivor
- What is this?
- '75 with an 8point luggage rack?
- Radio?
- I Picked up an old Friend Today...
- 74 ignition weak links?
- Guys get a load of this...
- question on dist. vacuum advance
- Wiper Door Questions
- Should I be Ticked Off!?
- block # question
- can i buy this bushing anyplace?
- 68 headlight switch???
- Factory Sticker on Inside of Door says Nothing?
- General advice on replacing weatherstripping on 79?
- Barret Jackson 1994 C4 Dark Blue Vin 00001
- Restorivets
- What is it worth
- rear spring arch
- clay bar
- C3 battery problems (from Spain)
- 73 Spare tire (Wheel) color???
- pics of the steering connection
- Outer Door Handle Replacement
- LT1 pictures
- 72 stolen in Rhode Island
- 78' Droopy A/C Duct
- Australian C3 owners - please step in.
- Help with Horn Contact
- What did you pay for your exhaust
- Big Block Regrets
- Where can I buy a TCC Harness for a TH350C
- Tips For Cleaning Sidepipes
- What's this worth?
- 200-4R pressure switch on valve body?
- VIN Lookup
- 70 LT-1, $32K on Craigslist
- Are these what is known as L88 Flares?
- Removing rear window trim
- Cost me $48
- What exactly do you need for a rebuild.
- Exhaust paint
- fuel tank removal
- Need lift recommendations
- One Piece Replacement Fiberglass Roof
- Window Sticker Reprint
- 78 Need help on Clock and Center Gauge Cluster.
- Adhesive on Pillar Weatherstrip?
- Lap belt wont roll up??
- Pillar mounted gauges, anyone?
- Door hinge spring replacement procedure?
- Steering Column
- madrid v comfort-weave sun-visors: difference?
- Has anyone their C-3 on a cross country trip?
- Door won't stay open
- Carb rebuilt by Lars needs to look better
- Zora's White ZL1
- Poll: Which Steering wheel
- 78 questions --help?????
- 2 1/4 primaries lemon header / a/c issue
- Would these work for a 79?
- Barrett Jackson restamp car
- What did you use to glue the tunnel collar on to the bellhousing?
- disassembly of t-tops and weatherstrip
- Age of vette owners
- Plating Shop in Florida
- speakers???????????????????????????????
- C3 Corvette Sub Enclosure
- Summit Black Cherry Pearl
- Finally got my first vette...
- Interior Question
- Last big $$$ item today. A trip to the chromer!
- Any new toys?
- Hey there...new to Forum
- tool for antenna removal
- Recommendation for sandable, high build RATTLE CAN primer?
- Frame Rust, How Hard to Treat?
- Rear suspension parts
- Any of you 78-82 owners running Fiske wheels?
- Bad news - good news update
- Removable Hardtop Storage
- possible 200 4r swap
- Fixed Headlights Pricing
- Replacing Speedo Cable
- stock 76 performance
- Short little video. Nothing Earth shattering!
- 350K 71 Vette
- Rechrome Plastic (Killer Chrome)
- How can you get over-spray off your frame
- After car shut off ???
- Question about windshield SS trim??
- exhaust question
- 1978 exterior paint colors
- 1968 Corvette door key
- Were does this hose go?
- First Fire Up!!!!
- double din in c3?
- C3 Stinger hood pic?
- Build date
- Celica Headlights
- Paint and Interior Code Nos. for 74 Corvette
- Here's a few pics from Raceway Park ...
- Chrome bumper or C5
- Powered by Corvette
- Number of Views???
- PCV Hose
- Rear Clunking sound fixed! I hope
- Newbie with a question??
- Tips for carpet install on compartment doors
- Underhood insulation options?
- Sacramento Hooter's Run (pics)
- Spare Tire Lock and Key
- new lug question and floormats
- Reinstall Interior
- Int. Color Change w/Vinyl - PICS
- before ordering wheels want to know some stuff!
- pic of busted composite spring
- Looking for Fiberglass repair shop in Las vegas?
- paint stripper from home depot
- Motive Speed Bleeder
- 78-82 glove box lock removal???????
- 1973 454, is it an LS4 or LS5
- Won Best of Show for our club at AutoFair
- General 'Hot Air in the Car" question.
- Attaching .pdf? GM Letter about '69 L71/TH400
- Lifter roller squeel
- Hooters all Corvette Show~n~Shine
- Front bumper removal
- My NEW Project Car!!
- anybody have picture of hood cable/latch
- Lambo Kit
- Gas door/bezel compatability question
- 79 L-82 valve covers
- Headlight Actuators
- What should I use here?
- GM to sell origional '78 Indy Pace Car
- Witch mouldings/trimmings
- New steering wheel
- 1st car show for 09 we entered & we won
- My turn to be the........
- 350 sb Brass Fitting - Question
- Making a compilation. need your pics and vids!
- '78 Pace Car
- dying interior
- 79 electrical problem
- headlight washers
- Early C3's for skinny guys ?
- drove to the beach saturday :) [pics]
- In case you missed this Vette joke...
- 1978 Silver Ann Orginal Owner
- Vented battery?
- Weir Bellhousing on LT1 T56 gearbox
- Car Painting Tools
- Draw on Battery??? 69'-427
- 76 vette
- L88 hood cracks at cowl
- 68 small block guy, I need a picture.
- Artifacts from previous Corvettes that I have owned
- Which wheel do you like better?
- Stainless Steel Hooker Sidepipes (pic request)
- Felt washer on Cross shaft?
- Borg warner from camaro-will it fit 81 vett?
- 1973 project car
- Corvette Seat Installation
- Best way to repair a hole in heater box?
- Rain Coat
- 1969 Corvette Question
- Rim Size
- Vintge Air?
- luggage rack on 1969 BB, to be or not to be
- Buying Vette from Canada- process???
- What's wrong with the C3's
