- BF Goodrich G-Force any good?
- Vettes and Jets registration form issue?
- pulled the trigger
- 1982 Collectors Editon Corvette
- Gotta love this all purpose cruiser!
- could i hear some sound clips/videos of some sidepipes?
- Firestone Firehawk Indy 500 vs. Goodyear Eagle GT II
- How do I check the vin on a 73 coupe?
- 69 Rear Wire Harness Short
- Horn Rebuild Question
- Metal headlight bezel repair (pics)
- engine id number
- Battery Ground cable?
- side pipes
- Seat belts
- Anybody know this dealer in Cincinnati?
- Clubs?
- Need 1972 seats recovered
- Battery Operated Impact Driver
- need a side garnish molding 72 coupe advice
- 1971 Corvette
- Anybody running 295/50-15s?
- Connecting sidepipe tubes to headers, what sealer/lube to use?
- Lets see your chrome wheels! Looking for future ideas!
- The Worlds Ugliest Corvette [Poll]
- Hydroboost manual brake adapter plate
- Paint Pulley V-Grooves?
- headlight door adjustment
- 71 emblem
- Coupe or T-Top?
- Neat billet wire looms I found on line.....
- Help me identify this car C3 guys.
- Do I put clear coat over my Can-am white 1969BB?
- Distributor ID band colors??
- TA shims cotter key location
- wow, now this is a custom....
- I need Hydroboost m.c. studs
- fiber optic part needed
- Valve Cover Bolt Questions
- EBC Brakes Opinions Needed
- 71 or 72...any real differences? Which is a better buy?
- Exhaust popping, not good
- C3 owners who have a C4 also
- 69 Big Block A/C Help
- Floor pan replacement
- Coolest American Car contest
- valve cover gasket
- The '79 I was thinking about got inspected. {40 Pics}
- Wanted Steward Warner Oil Pressure Gauge
- The quintessential stock C3 is....
- is the Zr1 doomed
- Need Someone to Look at 81 Vet In Little Rock, Arkansas
- New 2010 Grand Sport To Premiere At Cruise-In X!!!
- rattle can undercoating ?
- Seeking Advice on Ramps
- Absence of Eastwood at Spring Carlisle
- Vaccum System Hose Replacement
- PRICE ON 1970 Lt1 Convertible
- Return of steel cities gray........
- Lube For Starter Gears - ?
- Starter/Ignition??
- debate ender needed - 1978 "anniversary"
- Painting/chroming side and front grills...question?
- 1968 Frame questions with pics
- '80 door latches out and cleaned. Anyone need a pic or help before I put them in?
- decals
- Remember when you bought your first vette??
- "Creaking" from rear when taking off
- Where is this forum member
- A/C repair cost rising like the temp.
- Problems with Vintage Air
- 79 Turn signal problem
- 72 Vette, whats it worth....
- Anyone heard of Vellios Machine Shop - Lawndale, CA?
- Stalled....Help.....
- Joe Boghosian
- one wire alternators
- MPG help for a C3 please. THX
- Body filler in door jambs
- C3 guys in Detroit area?
- Muffler tips for FLOWMASTERS....
- How To Identify a TCI Trans?
- Where do i get the GM manuals ?
- running hot,or not?
- 1969 Vette - Color of Choice.
- Power steering fluid milky?
- Looking for a rough estimate for this work
- What's it worth?
- Painter recommendation in Birmingham
- Cruise-In Badge Reminder...
- Who here follows the custom of..
- Any ideas on tire & wheel combinations?
- Premium Membership....benefits?
- Extra Heater Hose
- $8 shipping for a $2.50 part?!?!
- Gray Corvettes... look awsome..
- Any local people for cruising?
- Replace double-snorkel with K&N on my '70?? Advice please.
- rear end swap ??????
- Any recommendations on a vendor for Torque Thrust IIs?
- Replacement tire decision question?
- Stock Radio Antenna Question
- Good words to Holley
- '74 Convertible Silver Leather Interior
- Pillar Gauge Pod Group?
- Alternator Rebuild Paper- Anyone???
- Another bumper question
- Door Panel Repair
- Tubular A arm on 69
- Never mind.....I found my old post.....
- Factory radio wiring Q......
- Is gas hose the same as tranmission fluid hose?
- Strictly Corvette..Thank You!!
- 77 rear emblem glued or screwed on....?
- Chrome shifter ball for a muncie 4spd?
- first time out
- 1969 gunmetal interior color code??
- Hooters Girls Choice award.....Winner
- lights on, buzzer on need it off
- Clutch return spring
- Torque spec for rocker studs
- 78 pace car
- TH400 to 200r4 walk through,,
- 74 vette for newbie, should I buy it?
- Luv my rubber bumper
- Is this Radiator ok? [pics]
- Gasoline Smell Gone With Vapor Canister Change
- 4-Speed sticking in gear
- Tips for installing AN style fittings?
- Bumper help
- Replacing the Driver side Window Motor
- Life is good!
- My 68 hardtop
- Why the hell can't i get the door handle linkage off!?!?
- Whats it worth - 69 Corvette
- ElChopperhead (or anyone) Help me put these wheels on my car please!
- Paint for birdcage/windshield frame
- lower radiator hose, fan clutch removal
- Clutch Fork Boot Replacement - ?
- Side mirror removal problems
- rear gears??? what do they mean?
- '69 Console question-'69 guys, please respond
- To Paint Aluminum Heads or not
- 1980, side pipes stay or go (Massachusetts residents only please)
- tach problem
- New Corvette Vehicle Line Executive
- Matching spinners for my spoke wheels
- Gas Tank restoration?
- new rims and tires
- Tire question
- New Oil Pressure Gauge in the '71 - What A PITA!
- Adhesive question
- What size bolts go into the trans mounts?
- Trailing arm rebuild/ emergency brake
- Need freeze plug advice Bad!!!!
- Convertible Cabin Cover
- Where can I find 71 radio/speaker connectors?
- Who sells Captain Lee's stripper?
- Is it a "tempature sending unit"
- May need carburetor for 78 l48 corvette.
- Distributor Question
- anyone near newnan georgia ?
- Bumper replating question
- Side Pipes or True Dual out the Rear?
- Some new pictures of my car...
- Instrument Panel Help!
- Should i buy this?
- Looking for a trusted shop in Minneapolis area
- 69' stingray, what you think of the price for it?
- c3's in vancouver, wa
- 1981 Side Mirrors electric Motors
- Gas Tank repair.
- 2010 Vette
- Pics of my 73 454 when it was brand new!
- Newbie Needs Info Help With A 69
- Original pics of my 73 454 coupe!
- Time For A Survey
- In need of bumper suggestions
- car cover
- Few Interior Pics
- in need of intake vacuum 78 L48 corvette 3 port
- Update Shots - Pipes are on!!
- 10% off Speed Direct, Steeroids, etc.
- C3's to the crusher
- Thinking about building a website of my resto..suggestions/interest??
- Seen this show? "My Car Is My Lover"
- Lake Tahoe Corvette meet
- House down the block changed hands....
- Return to "original"
- Nose Emblem
- Side Windows on a 1972
- Finally getting to work on the '77
- Odd Problem, 1970 L46
- 1969 Restoration Pix-Continued
- new paint soon --bolt on spoiler pic request
- Mirrors for 75
- Ecklers feedback
- Blown Turn Signal Fuse
- First Vette?s
- new to the group
- Sweet Surprise
- gas tank removal
- electric fan joy
- gas tank removal
- Avoid having this painter do any work...
- 79 Choke Pipe
- Dash lights
- Pulling engine
- Lord what have I done?
- Finished my Trailing Arms
- Black heat shields on shiny side pipes?
- transmission fluid in the engine?
- What happened to the photohost website??
- Posting pictures on the forum
- Bloomington Gold Certification Help
- Fun with Auto trans?
- 81 Vette Help!
- $3000 in Gift Certificates
- New Product!
- Wanted Body Kit Options for 76 Vette
- new to the group
- Chrome ...my favorite color
- Traction bars
- header touching upper arm
- I am about to buy this. What do ya think
- Where is LittleJake?
- Anyone tried this in dash STEREO set up?
- New Guy With ????
- Jack Stand Pad
- Chuck Pelton - Nice Job!
- Getting closer
- Classic Chevrolet Sugar Land Grand Opening!!!
- looking for silver paint options
- A NOT SO funny story about last night
- Some Bling For My Engine
- Any pictures of the "lt" hood from ecklers???
- suspension help
- Tale of the Tremac-Happy Ending!
- Ecklers is too slow!
- Tire help/suggestions:
- Quick question
- Question on L-88
- Anyone in the NCR area willingly to give me a hand with my vette?
- Photo of throttle spring location on Tri-Pwr
- Rear Bumper Install Questions
- Polish aluminum wheels...what do I use?
- Opinions needed
- Stance of this car
