View Full Version : C3 General
  1. 1972 Front Spring Stagger
  2. '74 Manual...rebuilding and need some help
  3. Really bad C3 replica
  4. Early 1979 corvette question
  5. Alloy wheel setup for C3.
  6. What does it cost to paint a hood?
  7. Help removing rear brakes/disc on '82
  8. CRC Freeze-Off Highly Recommended Product
  9. How to remove?
  10. Looking for 17" slotted alloy wheels
  11. Help needed in Houston
  12. What C3 Projects Are Scheduled For This Weekend?
  13. Making progress '69 frame off
  14. Wiper Troubleshooting Help
  15. Any Black/Silver Cars with this style of wheel?
  16. interior data plates.........
  17. Can you make $$$ on a wreaked Vette?
  18. VIN and tag info ??
  19. RetroSound - What it Looks Like
  20. A/C help
  21. Transmission Code
  22. Whatcha think about them lights?
  23. radiator removal
  24. Musclepalooza
  25. Trim tag rivets
  26. So I'm driving along...
  27. Sway Bar Link Opinions
  28. decode engine
  29. Removed AIR pump
  30. Value of 1969 vette?
  31. Anyone know what happened to the McSpeed site?
  32. Hey DB
  33. "Cutesy" location info
  34. Newbie Intro
  35. 81 pulling after new brake job!!
  36. 01 value?
  37. purtronix electronic ignition
  38. Gauge cluster noise question ?
  39. Any c3 owners have LED tail lights?
  40. Helping Other Members
  41. Lets see your sidepipes!
  42. 1969 LO Code 427 L88, value opinions?
  43. 69 owners, what is this?
  44. Finished the interior!
  45. Alarm recomendations
  46. Making a noisy interior a quiet interior
  47. Quadrajet manifold bolt length?
  48. Cost to flare?
  49. Need help w/ power antenna wiring
  50. This must be a SCAM!
  51. engine pics with dress up kit
  52. 78 PC 112 Miles
  53. Battery Charger - Tender
  54. POP for VIN#194679S734613 on eBay 69 BB vert
  55. GM To Stop Corvette Production
  56. Steering pulling to the right
  57. Need Parts
  58. Wood shift knob?
  59. Looking for a picture of a corvette with these wheels
  60. Houston & Surrounding Areas..Will work on your vette for $$$
  61. Carb mounting...studs or bolts??
  62. Interior instrument panel work
  63. Engine Leveler
  64. 69 convertible roller cost?
  65. Vbp pre-summer sale 15% off through may
  66. 69 Without Power Steering
  67. Oil Filter HELP !!
  68. '71 Tach Went Inop
  69. Cleaning rubber/plastic in the engine bay
  70. Rear Sway bar mount for an 82
  71. NJ Registration - QQ or not to QQ?
  72. Anyone have a 69 Coupe VIN# 716267?
  73. Good things from East Coast Corvettes llc?
  74. Corvette 'Cheetah'
  75. I have been weighed and measured.... :(
  76. It's finally running
  77. Por 15 Engine paint kit?
  78. A few pics from STL C3 Sharks Car Show
  79. Ralley Wheel polishing help
  80. Looking to find a good body shop in Madison WI
  81. Mako Shark
  82. 1971, passenger side blinkers
  83. my first corvette only show(lots of pics)
  84. 1980 Duntov Convertible
  85. Custom shift ball
  86. Starting my Corvette
  87. Faded Fox Raincoat top
  88. ** DFW ** Hooters Fun Run, Sat, June 13th
  89. New Dash Problems
  90. glove box latch question, 81
  91. Astro top
  92. Ncrs c3 cars in attendance
  93. how can I get a bodyshop to repair abad paint job
  94. 79 Project Update Thread
  95. Winner....Coolest American Car contest
  96. Check out ABC News.com for Route 66 in a 59 Corvette
  97. T-Top Adjustment w/ Pic
  98. Anyone Running N50's, 295/50-15 or 325/50-15 Tires?
  99. Oil Pan (Wot do I have) HELP?
  100. Question on changing to an electronic distributor & keeping original tach....
  101. New Brakes + New Rims = Hours Polishing
  102. L-88 Hood
  103. Here's what Corvette Mag says our Vettes are worth
  104. A question for those with FIA headlights
  105. '77 Seats
  106. Cooling question on an '81....
  107. Looking at a 72 vette...
  108. Convertible Pillar Post Weatherstripping Installation
  109. radiator install problem
  110. Original Convertible Top info needed for my 74
  111. My 68's story - tribute to my Dad
  112. Rocket science question of the day!
  113. Going to try a t5 swap, have a question or 2. Thanks
  114. Best Place to Buy A Front Clip?
  115. Weatherstrip adhesive removal -- way too difficult
  116. Question, about my friends vette
  117. OK, You asked for Pics when the motor went in...
  118. Will this carb fit under an L88 hood ?
  119. 77 Vette: What Radio Should I USE?
  120. Birdcage / Interior Pictures
  121. Headlamp Bezels for 69 coupe
  122. Stereo Problems pointed to a bigger issue.....
  123. I think I fixed my starting problem
  124. New Stripes
  125. Body repair - tab on upper door skin near pillar
  126. P/S belt for 72 BB with air
  127. how many dark brown 78 still out there??
  128. Car cover - outside
  129. Thermal Heat Sleeving Deal
  130. 78 cigarette lighter assembly - need help quick!
  131. Door Skin Replacement
  132. Simply ...wow! I got Velcro eyes!
  133. Long Shot - Looking for Pic's of Tan C3's with chrome wheels
  134. Need 1977 Corvette L-48 Expert / Reference Pictures
  135. Question ref. steel fuel line.
  136. Starter wiring question…Where does the ground go?
  137. 15 or 16 psi cap for radiator?
  138. 69 hood question
  139. Your Vette.. Before and after Pics
  140. Rubber door seal question
  141. HELP Please electrical on a 79
  142. Need advice for '77 L82!!
  143. Before and after pics
  144. Sequence of Re-Installing Interior
  145. Vader Vette
  146. 69 is almost stripped, need advice.
  147. Mecum In Indy
  148. M/C or proportioning valve
  149. 82 Mako Shark Corvette - $5000
  150. Front Bumper Options
  151. '80 rear defogger switch removal
  152. Rash of headlight problems ..
  153. COMPLETED: Long Overdue Interior Repairs
  154. Need Advice on repairing or repainting
  155. slight engine knock when cold....
  156. keisler vs 700 r4 ???
  157. Seat covers
  158. Fan Shroud Usage
  159. Need Rear Compartment Insulation Pics
  160. Owner of 69 vert #194679S708049 ??
  161. Questions w/ photos - speedo gear and transmission
  162. GM Documentation rumors... True?
  163. Is anyone going to the Tahoe Regional NCRS meet?
  164. Car and Truck Show in Vegas
  165. temp sending unit question
  166. Final vote....Coolest American Car contest
  167. center console question
  168. 1978 Blue
  169. Difference between 78 & 79
  170. C3 Section People Going To Bowling Green - Corvette Forum Cruise In
  171. just got a 79!!!
  172. STS baffles how do you get a set?
  173. leaded head conversion?
  174. car show tragedy here in pa. video
  175. Wheels from House of Wheels
  176. Car Cover
  177. charging problem
  178. Should I drop this TPI in my 72 or should I hold out for a stroker?
  179. Value of '72 Distributor
  180. St. Louis C3 Corvette poster now available in 8 sizes starting from $29.95
  181. Brake System (Kits)
  182. Mecum Spring Classic
  183. Radio Ground problem?
  184. belts, chains, and gears!!!(cams) what kind to use
  185. Need help/advice for a new radio...
  186. Advice on 75 vette vert.
  187. Red 1972 Corvette LS-5 454
  188. paint ideas for my '79
  189. Any members wanna loan me law school tuition?
  190. Repairing Cibie peeling relfector
  191. Paint flexibility additive?
  192. Paint flexibility additive?
  193. Lost a bolt, but can't find a part# anywhere
  194. OK I'm 4 out of 4 for car show wins :)
  195. Strange Custom...
  196. Is E85 (85% ethanol) Safe To Use...?
  197. fiber optic order
  198. Help with lars tuning paper
  199. sun visor question
  200. I need help
  201. Fair cost to Mount/Ballance 4 tires
  202. what happened to the gf/wife picture thread
  203. Who else has a C-3 only show?
  204. Fun with Photoshop
  205. "help" with oil temp gauge
  206. steering links
  207. brake bleeder
  208. Lone Star Classic-This Weekend-Corvettes of Dallas wants to know who's coming?
  209. 74 Rear Deck Grills
  210. Help from Tucson
  211. stripped fender louvres on a '71
  212. where to find door handles?
  213. making c3 as quick as c5
  214. Brake boost removal - tip and pics
  215. Trying to set valves with motor out of car, 4 rockers always come up loose.
  216. A few questions about trading a 2000 frc for C3
  217. ~~St Jude Auction #40 The Need for Speed *2 days* at for 10/10ths Motorsports~~
  218. paint & int. codes
  219. 81 Dash Pad Problems
  220. wiper motor parts numbers....
  221. Where can I buy Orr-Lac paint?
  222. AR Custom not making any 18 x 10 anymore
  223. AC shield question
  224. Looky what I got Saturday...
  225. Making some progress, she's on the rack
  226. Greetigns from Italy!!! Corvette Italia her I come!
  227. Does anyone make a repro door panel with the right pocket? (78)
  228. Aftermarket 80' Dash Pad?
  229. Hi Rise Hood on 78
  230. C3 Newbie
  231. Vader Vette
  232. Build sheets??
  233. trying to find new fuel system (tank, sending, pads ect..)
  234. Repainting Frame Question
  235. Class Winner 2nd Year Running
  236. Stripping metal parts
  237. wiper door closes on wiper arms
  238. Interior restoration almost done! Lots of pics!
  239. Bubba'd Wiring
  240. Weird Noise
  241. Cross country transport
  242. new stainless hookers on the way
  243. Auction! 1978 Pace Car...with only 7miles!! Shreveport
  244. Want to join a Corvette Club close to Wakefield, MA
  245. Tranny pan leak (Pic)
  246. Sent the car out for paint and interior!
  247. Another T-Top W/S Question
  248. Is this gap for the flywheel cover a problem? (Pic)
  249. Looking for a 9 to 12 inch peice of 12 gauge fusible link wire
  250. A/C Issues
