View Full Version : C3 General
  1. Sad Day
  2. horns on a 1982 ce
  3. Are these guys flippin nuts?
  4. Show off your speakers 78-82
  5. Compact Scissor Jack?
  6. Seatbelt buckle question
  7. Radio Power Wire 1979
  8. Need a pic of a 68 antenna ground plate and strap
  9. Any source for the oem fuse box?
  10. rebuild 74 factory a/c control
  11. Missing Alternator Wire?
  12. Probably a Stupid '80 Question
  13. new guy seeking wisdom.
  14. Air Filter Vacuum Diaphragm
  15. jumping into the restoration again, insight please
  16. What's the proper name for the screens beneath the windshield?
  17. Engine pics, (new at pics)
  18. 1970 Lap belt repair
  19. Corvette promos 4 sale
  20. Current state of interior - how does it look? + couple of ext. shots + video
  21. 70 Parking Light Lens.
  22. Are the L/R seats interchangeable?
  23. New paint, first time for pics
  24. Finally moved the Mako
  25. A few pics of my new paint & first time to post pics
  26. Flag holders for t top holes
  27. Some 'How To' Editorials require Username/Passcode
  28. Remove Valve Cover From a 79 Coupe
  29. One year ago
  30. 73 Vert
  31. Cruz'in Pics,Wheels on the Water,Crisfield, MD. 7/26/09
  32. What Cragars fit my '74
  33. Pic of cables on heater control needed
  34. smooth firewall
  35. OK, enough of engine pads, lets look at TRIM TAGS...
  36. 77-82 steering wheel question
  37. 82 Problem
  38. glass on the grass
  39. Power Window Problems
  40. Carlisle is Soon! What's your wish list?
  41. hood adjustment question
  42. garage make over
  43. Good Guys Show disaster
  44. Another Cracked Windshield
  45. Auto Ancestry
  46. Leaky caliper...but is this brake fluid
  47. design influence
  48. 75 Vert resto 6 months progress (Pics)
  49. question about weatherstriping
  50. Anyone going to Carlisle from near Iowa?
  51. Need Car Cover
  52. Hello All
  53. engine identification from door plate
  54. Clock repairs - who can fix it if I can't?
  55. PO2 Wheel Covers ?'s
  56. Fixing post mirror
  57. 76 Funnycar Vette
  58. Help With Door Handle Pulls
  59. Three Wide in the Front Yard
  60. Bondo for fiberglass
  61. Looking for seatbelts???
  62. Soft Curing - Fiberglass Resin
  63. Need Help replacing Door Handle Pulls
  64. new Dewitts on the way!
  65. Latest bill board ads from Gm, NICE!
  66. May I ask if any one here knows what this 650DP I traded for is.
  67. Save this Vette!
  68. Anyone tried C.C. Off Road/N11 exhaust?
  69. My '81 Repairs UPDATE! (And advice needed)
  70. Hard Liners for Glass T-Tops
  71. Windshield wippers
  72. Grundy over the other Guy
  73. 1971 L-48, worth what...?
  74. Stainless or Steel
  75. Can I use newer C3 or C4 jack on 72?
  76. Mechanical Restoration Help Needed
  77. Perf Mod Info for C3 82 Owner
  78. help please! new here, tire size
  79. Look what i found!!!!!!!
  80. Need a timing light
  81. Eastwood Ceramic Chassis Paint
  82. t-top repair
  83. Don't buy a car without seeing it in person.
  84. Who Rebuilds / Restores Fuel Injectors and Throttle Bodies?
  85. What's this 73 worth?
  86. Moroso Customer Service Contact Info
  87. Today's progress...front grills and polished wheels. PICTURES
  88. With out a doubt, the rims im getting
  89. ***St Jude Auction #54 A Day at the Track *****
  90. Anyone do a vb&p suspension kit and save original parts? I need one of those parts.
  91. Cash For Clunkers - LS swap guys beware.
  92. test
  93. Horn install..PICTURES
  94. corvette show sat the 25th pottsboro tx
  95. test
  96. Rear Fascia Paint fade/swirls
  97. specs on 81 motor ?
  98. Black Rocker Panels
  99. CF Garage - Posting pictures issue
  100. project(?) spotted in NC, by semi driver.Greenboro
  101. Move a thread
  102. rebuild or replace q-jet
  103. Decoding trim tags.................
  104. 1978 corvette no trim tag.
  105. F.A.S.T. EZ-EFI; is anyone using this yet?
  106. NCM Bench Drive In Memory Of IrishMac
  107. new member from Ohio
  108. Steering Column Lock & Hood Release Cable help
  109. Newbie in Texas
  110. Rear Window Difference
  111. T10?? Transmission Identification
  112. A/c blower motor question
  113. HEI Distrbutors
  114. Getting My 74 Painted NE Area
  115. '68 Dealer Code?
  116. Test at Tune at Summit Raceway Park Videos(Norwalk)
  117. selling your vette, hold out, you will get the $$
  118. Trim tag?
  119. 74 horn problem
  120. MY first Vette
  121. Cleaning 79 Vette wheels
  122. I dig customs but....
  123. Battery Tender for 1981
  124. Using R134 fittings but running Freeze 12
  125. Sidepipe baffles
  126. Vettes in japan
  127. Kids these days-not interested in cars?
  128. Astronauts Vettes
  129. Stripping Paint
  130. Fuel filter
  131. Weatherstrip lubricant
  132. C4 A/C Heater Blower in a C3 Conversion
  133. Best place to buy LED dash lights?
  134. heat issue, please help
  135. 1982 Corvette Spark Plug Gaps
  136. How to remove Radiator? HELP!
  137. bumper quality and fit ?
  138. All of a sudden the Vette isnt so important...
  139. Lights In Back of Speedo & Tach
  140. Lifting the body
  141. Opps....no matching numbers!
  142. What would you do in this C3 situation??
  143. New member and vette owner
  144. My Missing Spare Tire...
  145. Corvette Forum Garage!
  146. 1974 Silver Aerosol Dye
  147. Anyone Using An Adjustable Proportioning Valve and Distribution Block???
  148. What's my car worth?
  149. Horn note recommendations, I'm tone deaf!! Help please...
  150. What about this one?
  151. inline fuel filter necessary on my 76?
  152. Need VIN help / title?
  153. Sharkfin Antenna?
  154. helli coil
  155. Look-see Help in GA?
  156. Gauging interest in C3 Body Color Painted Engine Covers Kit
  157. Correct position for '76 oil pressure sender?
  158. Dirty Steering box
  159. Help ID this old Smog Pump...PICS
  160. carpet glue removal
  161. a/c repair while I'm here...
  162. rust!
  163. My first vette
  164. HELP!!! Paint Experts
  165. seat belts
  166. Did they make a 76 die cast model?
  167. Dash Speaker
  168. 76 Corvette...Anyone know what this wire is for?
  169. 76 Corvette 1/2 of my dashlights are out
  170. gotta question about my seat in my 78
  171. what is worth?
  172. Lots of pics
  173. Edelbrock Endurashine
  174. Cover up vin?
  175. Question on rear stamp
  176. I realy need your advice, what to do.
  177. Convertible carpet
  178. '75 Speedo cable
  179. Corvette Homecoming in Bowling Green
  180. What do you guys think?
  181. VIN number help!!!!!!!
  182. All original 1979 L48 Corvette ...honest opinions, please...
  183. Bubble Back Window
  184. Which order would you suggest for a frame off rebuild
  185. separator assembly......yes or no?
  186. Anyone seen these flares?
  187. finally some pics of the c3 on its comming home
  188. Wheels I'm thinking about getting - like paul 74's
  189. Need a Forwarder
  190. 78-82 rear curtain/privacy shade
  191. A/C question/idea
  192. Seat replacement
  193. 80 rain coats
  194. C3 Parking Brake Parts Identification
  195. Best place to advertise Corvette For Sale?
  196. Oil Changing instructions for Women vs. Men
  197. American Airpower show pics
  198. C3 in Movies or on TV game
  199. A few interior resto questions.
  200. Need Some Pics of a 68-73 Rear Clip
  201. A deer hit me
  202. like to know your thoughts on the Astro tops!!
  203. Side mirror removal 79'
  204. Hope I don't have to sell mine
  205. like to change my original 76 mirrors, any suggestions?
  206. Pictures from the monterey cruise in the original post
  207. Question About 1976 Corvette Interiors
  208. Clock repair procedures - where is the link?
  209. What is this
  210. Need 1979 History
  211. E brake cable rubs
  212. New Speakers w/ Stock Radio..
  213. Is there a trick to getting the speedo cable..
  214. got new wheels, need suggestions on tire size
  215. Bubba visits the rear of the car.
  216. Lookie Here! MORE PICTURES after one week at home!!!
  217. light scratches on window remedy?
  218. Anyone Live Near a Corvette Parts Supplier?
  219. question on thermostats
  220. Side gill color ?
  221. 1974 drivers door VIN and GVWR sticker
  222. 69 SB Right Spring out of Pocket
  223. It just won't start
  224. Where is #500,000?
  225. Longest Shark Owner
  226. All-Corvette show [a LOT of pics]
  227. B&M Mega Shifter in a 77 Vette
  228. My Heart is Broken
  229. Need a little date help on this rear end...
  230. 73 front grill question
  231. Professional Detailers Sampler Kit $25.95
  232. 68-72 front end on 73
  233. Anyone got a discount code for Rock Auto or Corvette Vendor?
  234. Where to get C5 or C6 seats
  235. Survey says, what else is needed???
  236. Finally made the decision
  237. Paragon
  238. How much can you make by parting out a vette
  239. Need help
  240. Seatbelts for my 77
  241. 79 Rear body mount fiberglass cracked
  242. Grey Power Rocks
  243. Anyone have a picture of a 70-76 dash removed?
  244. Dual Quads
  245. First 350 Chevy engine built?
  246. 1968 corvette? need help, PLEASE!!
  247. Lancaster car show
  248. different hood latches?
  249. 1976 vette ac system questions
  250. Missing front brackets....Help!
