View Full Version : C3 General
  1. << I M P O R T A N T >> Is this your 68' ?? # 422152
  2. Shifter Knob
  3. Rear wheel bearing removal
  4. Divin' In!
  5. 75 coupe heater core
  6. 1972 wiper arms...tech input
  7. Corvette Accessory Compass
  8. Corvette nuts of FTW
  9. Vettes at Detroit Autorama
  10. Recent Show in Orlando- is this Yours?
  11. " ICE" Turtle Wax
  12. Will quality sound deadener reduce noise with out putting it in the dash or firewall?
  13. BB valve cover re-chrome?
  14. Frame Stencil Information
  15. 80/20 vs cut pile carpet
  16. 72 shifter knob help
  17. Nova Guru's
  18. Second Problem with new car! *ANNOYED* lol
  19. Power antennna not going up!
  20. Baby's home from paint jail
  21. New engine - Before and after pictures
  22. Is there a better deal on a hood than this one?
  23. How do I estimate the value of my 78???
  24. Gauge Bezel/Radio Removal questions
  25. License Plate Light?
  26. Going to Atco Tomorrow? Ride together from Exton, PA
  27. A thread for the guys who restore Corvettes for a living
  28. Tire pressure..What is everyone running ???
  29. Opinions on fixing this
  30. Good bye Blacky
  31. 73 Primed again
  32. OEM vs Reproduction
  33. does this steering wheel fit a 74?
  34. VBP 460 Front Coil Springs FREE
  35. Need Wiper Pics For 72
  36. I'm crawling out of my skin!!! Rant!
  37. leak in passenger footwell
  38. water leak to passenger side footwell.
  39. C3 owners in VaBch, VA?
  40. It would seem a dumb iussue, and maybe it is...
  41. Rear storage compartment rivot question
  42. Homemade stand for Corvette Hardtop
  43. How do you let a Vette turn into a POS ??
  44. Triple play
  45. Need help with electrical
  46. Roof Panel Carrier Setup
  47. C3 Roadster soft top questions
  48. How to Secure Wheel Caps to Alum Rim
  49. Looked at a 79 today and have Questions
  50. Any members live by Tinton Falls N.J. This could be fun
  51. past history
  52. Bloomington-Damn, Didn't See This One Coming...
  53. 1968 Front End
  54. Spray Booth - Houston area
  55. Do these axle seals look new to you......
  56. 79 cruise control
  57. Here ia MY story..guage repair
  58. Tire size for 17x8.5(F),18x9.5(R)
  59. My Shark is getting lower!?
  60. Serpentine belt system on C3
  61. Question about VB&P transverse spring conversion
  62. Parts manual HELP
  63. Buying first Vette. What do I look for?
  64. Astro ventalation
  65. My First C3 Brake Job !
  66. How much to paint hood/door/fender?
  67. 73 Vette Tires?
  68. 77 C3....few questions
  69. To our C3 friends...
  70. 1982 white/silver hood photo
  71. Stainless Steel Hoses suck
  72. replace the Plenum Valve or actuator?
  73. Trying to Cracking My Block due to Freeze
  74. Sidemount Header Question
  75. Uuuummm, Wow!!
  76. First problem with new car. won't start.
  77. Does anyone remember this ?
  78. Who sells these for a 68?
  79. Centerbolt Valve Covers... What You Got?
  80. Anyone have white Autometer gauges w/blue light?
  81. Behind the Dash Wiring
  82. Front of hood alignment
  83. A Key to Grind!
  84. Custom Fuel Door Installed !!!
  85. Foglights and Signals 'Installed'
  86. Edge trim on T-tops
  87. Baby got first primer coats last night.
  88. 1980 engine question
  89. What project would you choose?
  90. Door pillar paint
  91. 73 ctr grill
  92. seen a widebody today
  93. Nostalgia
  94. 82 transmission tailhouse cracked
  95. 76 replacement carpet
  96. Did willcox send me the right seat foam? (pics)
  97. 1980 dash removed ! Crack....
  98. TIPS on cleaning gauges ?
  99. Antenna Question
  100. All Cracked Up?
  101. Xmas in march
  102. Worth It??
  103. Thanks George W
  104. Vanacor - GOOD or BAD?
  105. 78 pillar weatherstrip, does this look right?
  106. Washer pump filter for '75??
  107. '70 Power Steering Parts Question
  108. Pictures of Light Beige - please
  109. Carpet differences 69 and 71
  110. Well, I got back in the game.
  111. 0 to 60 times?
  112. Did 78 non L-82 have a smog pump?
  113. Is it OK to "duplicate" my athentic tank sticker?
  114. $100 Rustoleum paint job
  115. 1982 CE Advice
  116. Corvette Forum Picnic to Benefit St. Jude's!
  117. Where Can I Find Muffler Tailpipe Extensions?
  118. Anybody Going to the Laguna Seca Historic Road races March 14 -16?
  119. 427 casting# help
  120. I just bought a 1969 Roller, dropped the gas tank and found a tripower buildsheet
  121. Fake tank stickers
  122. seat belts
  123. New clock...
  124. '76 and Earlier? Take A Look...
  125. Corvette frame VIN ???
  126. Shift Knobs
  127. Rally Wheel Center Caps/Trim Rings - Materials??
  128. First Drive
  129. Almost Spring
  130. Z03 mixed feelings
  131. Manual brakes how bad compared to power?
  132. light replacement.
  133. lil' John Buttera, R.I.P.
  134. First attempt at a video
  135. Front Suspension vs Rear
  136. Need Ideas on Battery Box repair...
  137. Corvette Z03???
  138. window problem
  139. Anybody used Dynamat in their car?
  140. collectors edition
  141. 1974 LED Taillights
  142. blue sky classic cars!
  143. Ohio get together
  144. Rear Deck Hinge Replacement
  145. C3 carpet suppliers
  146. Where did this fall off from???
  147. what is this?
  148. Corvette Registry 1970
  149. Rear Compartment Units
  150. Question And Advice
  151. Engine Compartment Questions
  152. New tires on the Vette!
  153. Anybody have pics of engine compartment
  154. Magnaflow vs Flowmaster
  155. curb weight for '71 convertible?
  156. New Dash Pad
  157. 17 inch Torque Thrust II questions
  158. 1969 radio delete question????
  159. C3 autorepair shop in CT
  160. test
  161. 1968-1976 Heater Control Rebuild Instructions Are Done!
  162. v.i.n. and trim
  163. Dash Advice
  164. 78 25th anniversary value
  165. [Event] Make A Wish Corvette Rally [Event]
  166. paint question
  167. 1982 Special Edition Wheels
  168. Fiberglass repair
  169. Door Rust Repair (Rookie Needs Guidance)
  170. Broken kick panel plenum door question
  171. 1972 interior lights
  172. Replacing the Radiator. Tips and Advice?
  173. 1980 Carrier ??'s
  174. New carpet & sound deadener??
  175. Engine Compartment Hoses
  176. Fan Clutch
  177. Questions on a 1979
  178. windshield
  179. Center options needed for late C3 rims
  180. Need some opinions about C3 Corvettes.
  181. Screen in wiper box missing
  182. Sales Brochure
  183. Source for stainless steel wire mesh?
  184. Gyopp's mouse starts to roar
  185. Front Bumper Guard
  186. Cable Hook up Back of Tach,
  187. New Project!
  188. Need advice: Hood stripes
  189. Need a sticky tire (255/60/15)
  190. Pics of my new exhaust...
  191. Adjusting Convertible Top
  192. Decided to share the 77'
  193. Paint stripper
  194. Anyone close to Green Bay?
  195. Wheels for my '71 - Backspacing, Off-set?
  196. Looking for C3s for 'C3 of the Week'
  197. Don't tell Curt. (Pics)
  198. Purchasing Weatherstriping
  199. Ball Joint Help
  200. 1978 PS control valve rebuild
  201. Uniroyal Tiger Paw CTS ?
  202. Look out!!!
  203. Finding my 65
  204. Vacuum Line Kits
  205. Louisville Vettes. (Pics)
  206. wiper motor--D and M Restoration
  207. Gulf Coast Vettes Fail To Honor Gift Cert.
  208. Autoshow Corvettes
  209. Manuals, Books Suggested for Full Restoration... And where to purchase.
  210. Anybody going to "Vette's in the Valley" in May?
  211. What did you get done this weekend?
  212. Opinions: '73 LT1 engine listing
  213. Jet-Hot Sterling Silver finish
  214. Radio installation procedures - Any recommendations?
  215. How many 1979 L82s ?
  216. Thinking of yanking the M-22.
  217. 1/2 done with paint (pics)
  218. Battery Tender Question
  219. Rear clip options for '77
  220. Nebraska weather sucks
  221. Corvette vs Infinite G35
  222. $450 to re-register my vette?!?!
  223. L88 induction on ecklers hood?
  224. Problems fitting bumper brackets after new nose.
  225. Tail chasing...help me catch it!
  226. Maaco Painting nightmare
  227. Seat Backs.........
  228. 69 Front Crossmember??
  229. here it is, 82 vette parts car, 1400 bucks pics
  230. Am I doing this right?
  231. Corvette/Cobra Run
  232. corvette factory specs by year!
  233. Help Please Electrical Question
  234. Vacuum lines
  235. Parking Brake Cable
  236. 72 Corvette Keys - Help . . .
  237. Corvette's In Storage
  238. Run to the Sun...6:32am....
  239. creative upgrades for interior
  240. Is anyone using this 'in-car' camera mount?
  241. DiamondBack?????
  242. High altitude to low altitude conversion?
  243. How many miles before rear half shaft universal replacement?
  244. 1972 454 vs 1971 454
  245. rear spring bolts
  246. Battery Compartment ?
  247. Rotor removal--Help!
  248. 1978 Pace Car L-82 Project in Atlanta. Value?
  249. buying my second corvette-registration question
  250. 1982 'lazy' alternator......
