- Sale-sale-sale
- Rust question
- carpeting issue-what am i missing.pic
- Expansion tank date help !
- need new c-3 front bumper..who's best quality and price ?
- Opinions/Thoughts on the repro Chrome rear bumpers?
- 69 radio question?
- Finally a little progress, BIG thanks to BSIEGPAINT!
- Help--->paint code question
- Plexiglass or clear mud flaps?
- Please help with 1981 corvette Harmonic Balancer
- Warning!!!!Found LT 1 Barn find
- Tail Lights Issue 68
- Engine ID #s Help
- Corvette Central Glass
- 73 to metal front bumper
- radiator stuck on rubber seals
- the weather is getting better!
- NAP Dual Mass Flywheel Update and special price
- Help with heater and AC!
- Pic Without Bumper Cover Needed.
- 3963512 block Odd date codes?
- Need help
- Factory Side Exhaust Temperatures
- Took advantage of the warm weather and got some work done
- What clutch setup
- Best way to haul C3?
- bilstein shock part # for 79
- `````St Jude Auction # 12....A Time to shine Pt 2 `````
- Just for fun to warm you up
- vendors for hoods
- ***1968-69 oil cap question***
- Attention all yellow c3 owners
- did anybody see this?
- Replace stock steering wheel with similar but better
- Need Audio Help (Antenna)
- book search engine ls and small block
- Dash Pad Clips
- 81 vette ,New member
- What do you think of this 1973 CORVETTE 4-speed?
- Who manufactures complete engines????
- Anyone remember Stauffer Chev. in Nuremburg, PA?
- just inherited a 75' thats been sitting
- Before and After Steering Column - Check This Out
- Brighter Headlights? Which one is best?
- C3 Interior Experts - Opinions Please
- information
- Rearend time
- redlines
- Is the 77 dash/interior unique????
- Console question
- a little fun with windows movie maker
- 2010 Hot Rod Power Tour
- fuel gauge getting hot
- Have Body Dolly
- Rear window storage tray question
- Little bulb
- info on 75 frame
- Fiero seat guys, do you feel high.
- lowering the stance
- scarcity of the model 1970 has to sell
- Anyone remember a Safari yellow 435 hp tri-power coupe in Connecticut?
- Frame rail protection (INSIDE)
- 700R4 / 200-4R - can they use the same inspection cover?
- Speedo Tach Plug Orientation
- Porter Cable Polisher / Buffer ?????'s
- help on removal of luggage rack anchors
- weatherstrip adhesive
- Hooking up vapor canister to Holley
- New member
- 69 side ouver vent restoration question
- NCRS Meet & Car Show in Kissimmee
- Speakers for my 79
- poeder coating valve covers
- Which is the fuel feed line?
- Stupid Question - Where does the light for the cagarette ligher go?
- Pics of '70-72 Distributor Area - Little Help Please
- Corvette Forum Member (bradc6) - C3 repaint AutoBuffs Style
- decode the "license plate"
- My first chip in my new paint... %^*#@*%#)
- engine ID#
- expansion tank dates ???
- POR 15 on firewalls interior floors
- Winter in Ohio...2+ mos w/o driving
- Virginia Vettes Aluminum Wheel, Trim Ring, Lug Nut SALE
- Is this ironic ???? Not a joke!!!
- Detroit auto show 2010
- 1969 Stingray Corvette Transmission?
- Matching Numbers? or not
- Anyone using a Braille B3121 Battery?
- Those pesky headlight vacuum gremlins again...
- 69 Stingray Hood Release
- Who Makes The Best Weatherstrip Kit?
- C6 guy needing C3 information help - Color combinations / rarity info
- 36 Today :)
- Hello from the past
- Will these wheels fit?
- Headlight wiring harness routing on my 72???
- Wedding cake anyone....
- Determining Sexual Identity!
- Great information for beginners...[video]
- YJ8 wheel on a 72
- Gas tank cleaning.
- 1968 seat question
- Corvette letters emblem restoration
- *~*~* St Jude Auction # 10 For Valentines day *~*~*
- [PSA] my 3rd annual "don't push your car by yourself" thread
- 68 corvette front bumper question
- '74 Rag... worth?
- '74 Rag... worth?
- Frame Alignment Before Body's Back On
- vette daddy. any other shots of your car?
- Garage Mishap!
- Free to good home!
- Floor Bord/Kick Pannel Area
- Underhood and Engine Compartment Paint?
- Do you have Feb '10 issue of Corvette Enthusiast?
- Window regulator for '71
- 29.9 MPG with a Q-Jet!
- 1970 LT1 Engine Restoration
- 1980 Radiator support, purchase advice, feedback
- C3 80 Vet - Front Side Turn Indicator Light Bulb Housing
- Bouncing speedo needle!!
- Seat back glove box...
- how to clean and restore door panels?
- Corvette 3D Wall Shelves
- What type was the original antenna on a 76?
- Fuse box goop
- Selling to overseas buyer
- Odd wiring find under the dash...
- 78 spring mounts
- 68-72 Metal Shroud Pictures needed
- Last Corvette Built in St. Louis Plant
- Auto transport woes.....
- Front end help please
- Who's converted their stock front clip to tilt?
- How to Determine How Rare is "Rare"?
- Service Special for Dallas Area
- Throttle cable help needed
- Show bars?
- Who does cluster assem. panel restoration
- Carb help please...
- '73 Switch or rheostat on side of console
- inner stub axels
- Found an '80 for sale -- would you buy it?
- TH400 Fluid Line Connections - Which way?
- 69 Headlamp Splash Shields - 1st Design vs 2nd Design
- 1978 headlight switch removel
- 78-82 Rear Window Clips - Willcox gets my recommendation
- Bolt size
- Pypes Vialators, anyone try them??
- Valentine's Gifts for Ladies
- Adding Fuel Injection to my 73
- Any one use or have experience with Vette net?
- Help with brakes please!
- Stingray Concept Diecast 1:24
- Got my original factory invoice for 79 - magic date on it!
- Posi clutch shudder - How much is normal?
- Fender Skirt Seals & Splash Pan Seals
- heads
- Hesperia/Apple Valley Alinement
- Decklid Hinge removal
- Let's see your pics of your C3 with TPI
- Heater probs
- Any military guys in Saudi Arabia or Bahrain?
- Diagonaising radiator fan clutch problem.
- How to insert the picture??????
- AC Relay
- Battery Location
- new stock look replacement radio
- Rally Wheel Question
- How many times have you heard it before
- Please help with timing chain cover, timing chain and gears.
- Tachometer Question
- 1978 T Top Rubber Seal Replacement - Some Questions
- Patriot Side Pipe Height Problem.
- Luggage rack
- Speaker plug/adapters?
- Cruising Van Nuys Blvd
- Center console side panels.
- Non vette seats, what have you got and how do they fit?
- C3 emblem/logo
- Storing original engine questions
- My first pic post!
- 82 corvette over heat/radiator problems
- PayPal for Payments
- Seats Came Home - Simply Stated - WOW!!!
- Painters in Indy
- enclosed trailer owners step inside
- WTB Coys c5 17x8 wheels...Where?
- Anyone going to Barrett Jackson next week
- Name change
- Aussie 'Vette nuts.
- Vortec heads - best spark plug?
- Does anyone have an AIM index they could share?
- 1970 T&T hazard flasher push button
- C6 Seats in C3 Car
- Do you use protection? I do! (hint..new SHIELDS!)
- Driveshaft yoke depth question, 200-4R install
- Vintage Air - Connector at Blower Speed Switch
- Please help
- Silicon Valley(Ca.) Auto Show Pics(LOTS OF PICS!!)
- Who's car is this??
- Old Chevy Dealer info wanted
- Lets see wheel pics
- 1969 export Corvette
- Differences in 69-72 window trays?
- ### St Jude Auction # 9 Time to shine ###
- STINGER Style Hood
- Anyone own 68 #406748??
- A very silly question....
- What kind of primer?
- "Buy a Vette" link
- Who does carpet dash mats?
- to the rum drinkers!!!!
- Headlight Vacuum Problem 80 Vette
- Whay color is the stitching on a genuine black interior?
- Why the paint line?
- Look ma, no vacuum (headlights or wiper door)
- What does "streetability" really mean??
- Is GM halting production of the 350 Crate Engines?
- carpet help
- 1980 Whats it worth
- Are there any Buckskin Vettes still out there?
- Astro Ventilation questions
- 2nd Annual Strictly Corvette Car Show
- Please help with intake manifold and gaskets
- Upper Dash Pad Replacement- New Skin or New Pad
- outside replacement door handles
- L-82 or no?
- A few new pictures of my progress...getting closer!!!
- The two sound deadener pads above each rear wheel well?? Help!
- Pics from Genova-Italy
- Billet Alum Fuel Neck and Cap
- What tension does 1981 corvette intake manifol bolts have to be at?
- Battery Help Please
- What is the most desired part ?
- Difference between S/B/ and B/B radiator supports
- Lighting up the engine bay
- Part Question
- Contacting NCRS ? ?
- Pic from Italy...
- Engine compartment cleaning techniques, products and tools thread.
- 1st Close Out Sale Lund Bug Shields
- Rebuilding 79-82 Seats
- 73 to 77 rear window conversions
- Re-torque headers
- airconditioner removal
