View Full Version : C3 General
  1. 134 conversion
  2. Strange frame issue
  3. Corvette Central Power Outage
  4. Any LT-1 Dyno numbers out there?
  5. 73 bumper
  6. Another Barn Find - This One a 73
  7. Carb Fuel Fountain
  8. Question about seat rail extensions:
  9. Father's Day Cruise
  10. Speedo slow, found out hard way
  11. Michigan Vettes!!!
  12. Trim Tag Upper Number
  13. '71 LT-1 engine vibration.
  14. Happy Father's Day!
  15. Tank Stickers and L82s
  16. Speedometer drive gear location
  17. ***do you like smoke??? - burn out contest pictures***
  18. Front Parking Brake Cable Instalation
  19. engine pull
  20. All vette show south beloit il.
  21. Good Picture...
  22. willcox corvette vendor
  23. My Experience buying a C3
  24. Sill Plates
  25. gas question
  26. Where to buy good fitting 'over seat' C3 seat covers
  27. Fuel Cell
  28. Has anyone ELSE noticed???
  29. VIDEOS: Gauges, Chambered exhaust & LED's
  30. Aftermarket gauge question...
  31. 1977 curious dash bracket
  32. Trim and Paint code
  33. Help with starter code
  34. 1979 corvette
  35. What does this switch do?
  36. What kind of hood is this?
  37. I need a "Stingray"
  38. C3 Production numbers question / trivia.
  39. Plug wire shields
  40. Classic Car Insurance Help, Please
  41. '73 Corvette loaded
  42. Question on an alternative to Glyptal
  43. How much work would this take to make look nice
  44. Hooker Header Quality -Jet-Hot coating
  45. Anyone Here From the Utica-Rome NY Area?
  46. Power Tour: 2964 miles/10 days in a '72 vette
  47. My R&R C3 Build up!
  48. please help with 82 crossfire
  49. none working gauges 79
  50. C3 vin location on a bare frame
  51. Drivers door wont unlock?
  52. What weight Royal Purple to run in my 78?
  53. 3 inch spacers
  54. United States Congress sets National Collector Car Appreciation Day as July 9, 2010
  55. What brand stall converter to go with?
  56. Vapor Lock, Carb, Fuel Pump and filter questions and help needed!!
  57. Kelsey to Produce Good Year’s P255/60R15 GT Radial
  58. Dyeing carpet in the car
  59. Yet another body mount replacement question
  60. Another intake ??
  61. '75 T-Tops
  62. Whats a 77 T-Top stingray worth????
  63. Great way to make a new garage for your vette!
  64. Cavalcade of Corvettes
  65. Has anybody bought something from "Wheels for less"?
  66. Headlamp bushing '75
  67. Vintage Air ???
  68. June 25th and 26th FAST and Factory Stock Musclecar Drags
  69. C3 Vert in a GQ magazine ad....
  70. Pics of 17" rims on '74-'77 wanted ..
  71. Aerocatch hood pins
  72. Finally getting my 69
  73. It Finally Happend
  74. need a shop West TN area
  75. Questions about a '71 - '74 Stingray
  76. T Top Pad Replacement Problem
  77. steering column
  78. *Carpet - Who's The Best?*
  79. brake booster?
  80. 3883948 block question.
  81. torq thrust II backspacing
  82. slp wheel pictures
  83. 72 454 4 speed
  84. Madvette Motorsports Father's Day sale
  85. Tire question
  86. Steering Fluid for Borgeson Gear Box
  87. Removal of top exterior w/s molding 71 vert
  88. What's new at County Corvette - Pictures!
  89. Garage advise...re: roll-up doors
  90. Help/Advice Needed on New Convertible Top for 88
  91. How do i remove the wiper arms on my 76?
  92. Tach and Speedo Lights are out
  93. 427
  94. Looking for replacement seat belts (Andover?)
  95. Dimensions needed
  96. Need console wood kit help...
  97. From c4 to c3 any difference..?
  98. Need Choke Rod & Coil
  99. help wanted
  100. Century Farms Winery-- Music at the winery in Jackson, tn.
  101. Need rec on SS caliper supplier for '72
  102. Whats a 76 vette with a 4spd and L82 worth?
  103. 77 block code
  104. new tires
  105. Can I post this?
  106. Show me your flames!
  107. front bumper switch...
  108. 81 Vert conversion
  109. A little help please? (74 C3 Vette)
  110. Back to the 50's Car Show in MN
  111. War bonnet yellow
  112. Horns missing on my '81
  113. C5 rear bumper on a C3 body?
  114. Engine ID Help
  115. Tranny ID Help
  116. Directionals Blink Slowly
  117. 1975 Corvette Leaf Spring
  118. Is '72 Saddle color "medium" or "dark"?
  119. Need some help... idling is wayyy off
  120. Got Pics and Need Pics of 81 Front Air Dam
  121. Bending my own brake lines
  122. overheating, is it my thermostat?
  123. Shark Quarterly
  124. Please learn your bolt grading
  125. Superlifts auto lifts
  126. Changing from 3.73 to 3.08 or 3.36 rear gear
  127. Paint shops in Indianapolis area
  128. New intake manifold gasket every time?
  129. 1974 Stingray Project
  130. Couple of pics of the 72
  131. C3 Daily Driver?
  132. Borgeson power steering conversion results
  133. How bad is this rust?
  134. Headlight Switch - 1974
  135. 82 Collector Edition Paint and Trim Tag
  136. Jig Saw puzzle anyone???
  137. PO 2 Wheels
  138. 1970 corvette survivor
  139. Help IDing Center Console Bezel
  140. Anyone recognize this part ?
  141. Seat install help needed
  142. 190 mile drive today: WOW was it hot out
  143. Canopy cover for a coupe
  144. Canopy cover for a coupe
  145. 69 project almost done
  146. cross member install help
  147. Looking for a C3 with a Carb
  148. T-top Storage Under Car
  149. fuel Problem
  150. Vert top and hood prop rattles
  151. Off brand tires?
  152. How to handle the test drive when selling you car?
  153. another vette
  154. Have anyone used Cat. Lee Stip Stap to remove paint?
  155. Buying an engine and need advice...
  156. Need bodyshop that does welding corvettes.
  157. itty bitty tennie weenie RIVET
  158. Happy Birthday
  159. Fuel lines for new motor
  160. Looked kinda nice at a show today
  161. AC solenoid
  162. 81 Interior
  163. Ammeter tech and questions...tech heads.
  164. Stripped screws...
  165. Pillar gauge pods?
  166. Interior Parts Fit and Finish Aftermarket
  167. $27.99 Exhaust Tip Polish Kits ^^Only 10 Kits Remain!^^
  168. will a 78-9 Pace car rear spoiler fit-
  169. Shudders when lettign the clutch out...
  170. Braking indicates turn
  171. differential cross member fit??
  172. Radio/Shift plate install done!
  173. back to where she was born
  174. **LG Motorsorts / GrandAM Mid-Ohio Corvette Corral***
  175. Saying hello for the first time
  176. 72 AIM - Differential
  177. Wiper door molding clips installation question
  178. Power Windows Dont Work
  179. 68 427 Coupe NOM 4speed on Craig's list
  180. differential side yoke install help
  181. 1982 Transmission info
  182. 1980 Rear Bumper question
  183. What's the stock color for water pump and attaching bolts for 1974 L-48... orange?
  184. Looking for a picture of an original 69 BB alternator setup.
  185. 68 owners : How is the round lock trim bezel on the outer side of the door removed ?
  186. C3 Windshield Replacement
  187. speedo
  188. Recovering stock seats
  189. AWWW Look at this beauty
  190. 68 question
  191. What are these parts called and where do I get them
  192. Race Ramps Father's Day Special - 15% Off!
  193. carb\intake combo on '69
  194. Who here has multiple C3's?
  195. Thinking About DIY vs Paint Shop?
  196. Any one doing an interior restoration on a '68 coupe
  197. Hushmat installation question
  198. Tampa, Ft. Myers area body lift strap
  199. 69 zl1
  200. Re-cover 68 headrest with leather
  201. A/C Compressor mounting
  202. C3 4 Speed Pedals - same or different?
  203. gauges
  204. What kind of tires do you recommend
  205. Help me price my car
  206. Need To know
  207. "engine miss only at operating temp"
  208. July 3rd Car Show in Las Vegas
  209. New insulation under carpet questions
  210. keyed 12V again, wiper motor splice or not?
  211. Restore as original or customize - What to do?
  212. Cleaning the engine
  213. Starter solenoid for an 81??
  214. 1968 Value
  215. WTB...1974-1982 Corvette To Make A Drag Racer...CASH in Hand!!!
  216. Stupid moron changing a motor
  217. silly ?
  218. Looking for a references photo of late 70 LT1 Engine Pad
  219. lower control arm bolts
  220. 74 engine bay decals ??
  221. No Refund! Am I being unreasonable?
  222. My detailed engine bay.
  223. Took my vet out today.
  224. Weatherstrip Adhesive
  225. Scan tool opinions
  226. 8 Track Playback Speed
  227. Borgeson Rag Joint won't fit my column
  228. Seat covers on the cheap, I need a single?
  229. Help... I need a hex bolt
  230. SOS afraid to break parts
  231. changing brake fluid from silacone to dot 4
  232. Arizona Bone Yards
  233. Need to Kill some time?.......Here is an old TV Film about St. Louis and Corvettes
  234. c3 convertible windsheild post measurments
  235. Anybody be at the "Standing Mile" Races in Goliad,Tx.
  236. Set time on radio clock
  237. Colors to match a blue interior, Show us!!
  238. Fiberglass repair
  239. Power lock question
  240. air cleaner
  241. Replacing seatbelts in a 72
  242. Pictures please-73 with black side pipes
  243. help tire size
  244. 78 SA wheel question
  245. C3-related: Mecum Lot # S142
  246. ZZ4 vs. ZZ4 Fast burn price difference
  247. engine colors
  248. Lizard Skin Ceramic Ins.
  249. Anyone have experience with a slavage yard engine?
  250. Some 'eye candy' - well in my humble opinion...
