View Full Version : C3 General
  1. '77 horn issue
  2. What is the difference between these switches?
  3. 68' radiator core support question
  4. 75 L-48 Help
  5. door lock rod
  6. Brake Problem
  7. Long time wrench but a new guy on the block
  8. steering column interlock cable problem
  9. Does taking belts away increase engine performance?
  10. USA Today Corvette photos, C3's
  11. speedo cable intalation problems
  12. Center gauge cluster screws help please?
  13. 75 wheels & trim - questions re: originality
  14. Bear Mtn Cruise last night was C3 heaven! PICS!
  15. Wife - Cost of restoration parts!
  16. 1980 Spare tire tub/exhaust touching
  17. Wilwood Parking/E-Brake
  18. Happy Canada Day!
  19. 73 Fender Fit and Car Value??
  20. Poly Leaf Spring Bushings
  21. Identification
  22. 74 fiberglass sidepipe covers problem
  23. Cheap A$$ Starter!
  24. wiper arm adjustment on early C3
  25. Big Block brackets???
  26. creaky t-tops
  27. '79 A/C Low R-12?
  28. Dip Stick Height
  29. R.I.P. Jimmy McCutcheon
  30. Thinking of buying a lift from Direct Lift
  31. 1st Time Corvette Owner
  32. Door mechanisms--What a pain.
  33. 1977 Chevrolet Corvette
  34. It's my birthday today
  35. Engine Weight?
  36. Only REAL Corvette
  37. Can I afford a C3?
  38. What to do with '81 take off parts
  39. Rubber Reviver
  40. Delayed Defective Part Install Frustration
  41. Replacing My L48 With Crate - Questions
  42. 1972 Front Clip Assemble
  43. Factorcy Aluminum SBC water pump?
  44. Just got a "garage find" 73 project
  45. Need info on Convertible tops
  46. 2 69 roadsters for 12K
  47. Starter Dilemma
  48. Willcox New Summer Sale Starts Today!
  49. Well... exciting times for me!
  50. 1981 5 speed
  51. Why no pictures?
  52. my '82 passed emissions test!
  53. Rearview Mirror Glass Replacement
  54. What was your most "silly" mistake that you've ever done to your 'vette?
  55. Dreaming About Corvettes?
  56. check out this chrome bumper
  57. Engine - Transmission ID Number Locations
  58. air tank and vacuum canister???s
  59. backwards cat?
  60. Can I get a vote?
  61. My son's first quick ride in the Vette
  62. Simple question need simple answer.
  63. Corvette Fever, Port Dover, Ontario, Canada, car show
  64. My favourite picture
  65. New Velourtex Lloyd mats available at GMPARTSHOUSE.COM stating at 54.99 shipped
  66. 69 stainless upper windshield molding?
  67. AC working after 13 years
  68. Where can I buy a 76 rear view mirror sticker?
  69. Anyone have dimensions for SharkBar or roll bar of this sort
  70. GM 350 crate motor dipstick
  71. Dropping Steering Column
  72. brakes
  73. 1969 427 AIR cars.
  74. Wheels?
  75. Heat Valve ?????????
  76. Screw kits,which vendor's kit covers the most
  77. Tires for my 79
  78. Dash harness?
  79. where to get 12 volts?
  80. Oil for the AC compressor
  81. C3 STINGRAY GIVEAWAY: Des Moines, IA
  82. 1970 L46 motor photos needed of...
  83. Seized 4 sp tranny
  84. Speaker Depths
  85. New Corvette Club in Denmark for classic Corvette
  86. Back-up light switch
  87. First Ride Of The Year....Not The Best
  88. Info on the Hot Springs Show....2011
  89. 69 brake rotor recommendations
  90. 71 Corvette Horn
  91. vacuum line routing
  92. Anybody restoring an old racer?
  93. What a difference 40 years makes!!
  94. Lifters
  95. How do I trace a C3 by VIN?
  96. 78 Headers
  97. Tach just stop working
  98. Finally running
  99. vacuum hose diagram
  100. woodbridge mall car show
  101. Steel front end on a 73 coupe????
  102. 73 to 82 Body Mount Kit Differences?
  103. Dip Stick......
  104. Barrett Jackson auctions
  105. Bloomington Gold Auction of a '73
  106. Fishing blooper's
  107. My teenage daughter came for a ride today
  108. Don't you hate it when it rains on the way to a car show?
  109. My seatbelts from Andover came in
  110. What bolt size do i need for adjustable strut rods?
  111. C3 stingray concept: i likeeeeee
  112. Rear deck compartment change out
  113. Muscle Car era and the Corvette
  114. Bolt size needed for spark plug shields
  115. Questions about taking long trips in a C3...
  116. Center caps don't fit
  117. Hear ye! Hear ye!
  118. Replacement Seats
  119. hood wont open 1975 help
  120. Selling my 68 project--all original
  121. A little help with this please
  122. 1981 door jam sticker pic
  123. 13 Digit VIN Decoder
  124. Hi Ho, Hi Ho, It's Back To Work I Go!!!!
  125. Thank God for spare parts!
  126. Replace Dash Lights with LED?
  127. Torque Wheels for 79
  128. Any Bloomington Gold pics from this year?
  129. Hey folks - looking for C3 convertible/4-spd...
  130. Threshing Festival - Thamesville Ont
  131. is the interior color "red" close to "firethorn" ?
  132. San Antonio Tx. Vette Clubs ??
  133. Chassis height measurements
  134. Th400 Experience
  135. Passengerside Shoulder Belt Problem on a 72
  136. instrument lights
  137. L86 vs LT1
  138. C3 - C5 Transplant
  139. price spread
  140. C3 production numbers
  141. New Here
  142. New iPhone app: Corvette Birthday Calculator
  143. Replacing lower ball joint dust seal only
  144. 496 Big Block {PART 2} PICS!
  145. 496 Big Block {PART 2} PICS!
  146. Group Shot
  147. N.C.R.S - Tri - Power Carb Date Questions ? ? ?
  148. interior light problem
  149. Thermostat Housing.....
  150. Should Vendors participate on CF?
  151. Chrome bumper rotting in a barn story :-(
  152. Seat Belts Code 42 F 68
  153. How often have you heard "I like the Stingray"?
  154. My Farewell
  155. fusable link 68 voltage reg
  156. first ride as an owner
  157. Has anyone made a Custom latch to hold down convertible deck
  158. Crash - Fix or Replace?
  159. Corvette weight !
  160. Got some decent pictures
  161. EGR valve replacement on a 78 S/A
  162. '79 Interiror Question
  163. Original finish questions
  164. 1975 rear differential cover?
  165. LAB Engine Builders in Lindenhurst (LI, NY)
  166. What is it ? Corvette ?
  167. 7 blade fan
  168. garage floor
  169. Aftermarket AC question...
  170. Scratch
  171. A.I.R. system whatzit?
  172. A/C Oil on hood
  173. 74 Original Radio problem ??
  174. Door jam vin sticker replacement
  175. 75 shift boot pic please
  176. I need tips on installing coil springs!!!
  177. Drivetrain suggestions
  178. Hood Won't Line UP
  179. Bright Light Dimmer Swith Wire hot to touch
  180. New Alternator Recommendation Request
  181. DeWitts @ Bloomington (St. Charles)
  182. 77 steering column question
  183. This auction report will make some of you happy
  184. What to look for when car shopping?
  185. Autometer guages in 75 dash/Tach and Speedo
  186. Question about upper control arms...
  187. What is that???
  188. 72' engine rebuild
  189. who/? buying parts online.
  190. Drive your vette to work day
  191. Need help with pricing
  192. 72 Interior question
  193. 1970 numbers matching question.
  194. 1976 Paint
  195. C3 as a daily driver?
  196. 73 Sports Wagon?!?
  197. Gear reduction starter install
  198. Texas Vettes!!!!
  199. Help identifying this carpet pc
  200. Thinking of buying a 74 Stingray
  201. Milky oil and my options to fix it
  202. what would you offer??
  203. A new generation of girls and vettes
  204. Lynndale Blue on a C3
  205. BB radiator/fan shroud on a SB
  206. DeWitt's at Bloomington Gold
  207. headlights
  208. What should i look for when shopping C3s?
  209. soft parts goo?
  210. Can someone please snap a pic of their 68 or 69 convertible door.
  211. The Dark Side
  212. 1981 Gauge restoration.
  213. Motive Power Brake Bleeder
  214. best glass bumper cover suppliers
  215. Shift Knob ideas
  216. Looking for 69 C3 previously owned-
  217. •► ► SATURDAY JUNE 26th LUNCH @ CoW ◄ ◄•
  218. Two Interior parts?
  219. Can't believe I sold this one...
  220. VIN question for my engine
  221. Any Tips For a Newbie? - Looking to buy a '78 L-82
  222. L-88 hood
  223. new strips
  224. OT: Topless Photo at Car Show
  225. Installing new windows felts
  226. 1st Vette for Newbie Vette Enthusiast - Computer fears - Good Deal or Not?
  227. Steeroids June sale
  228. Testing a 68 vacuum system-just sharing !
  229. 1970 LT1 Ignition
  230. Vintage Air - Compressor Outlet sizes
  231. do i need an expensive aluminum radiator
  232. What should I look for in an air compressor?
  233. F70-15 Alternative
  234. Filmed a spot on Thai TV last night.
  235. Finally figured out how to post pix
  236. Another lesson at my wallet's expense
  237. Any idea what adhesive to bond the H-L header brace to the old bonding stripp
  238. Is this original engine?
  239. Repairing hole in fiberglass and avoiding shrinkage?
  240. THIS MONTH (in GQ!)
  241. Starter Removal for 1972
  242. 79 to 80 bumper
  243. Started work on putting the car back together
  244. 74 corvette replacement bumpers.
  245. 74 Corvette tire replacement
  246. 74 corvette tire replacement
  247. Body Dolly
  248. Vanity plates idea
  249. Dropped AC Temp on the '71 about 10* at Registers
  250. Went to see this '69 L36 coupe, value?
