View Full Version : C3 General
  1. Windshield trim question
  2. Urethane or Fiberglass?
  3. Clay bar on Marilyn?
  4. 1980 L-48 Wont Start-Help!
  5. Key broke off in Ignition
  6. help passenger door will not open
  7. Anyone having luck with temp sending units?
  8. Radio Bench Test
  9. Paint matching service in Los Angeles/Long Beach?
  10. bumper core values to rechromers
  11. Am I being too picky?
  12. '81 AC Ducts
  13. Blacked out look.. ? ? Running lights/turn signals
  14. Disassemble of 69 SidepipeCover
  15. The end of the Goodyear Eagle GT II?
  16. Rocker panel plates....
  17. intake manifold and Carb under stock hood
  18. Strut rod/rear suspension question
  19. which radio?
  20. Speed Channel-Car Warriors Building 76 Vette
  21. stuck trailing arm bolts
  22. car cover advice
  23. Drivers side courtesy interior light- PICTURES PLEASE
  24. radio hook up help..
  25. New Wheels, Tires, Rotors, Calipers Coated
  26. So What's a 1969 350/350 motor worth?
  27. 1972 Delco radio problem
  28. Need pic of grille brackets
  29. New Help and Repair Pages Added today!
  30. Interest rekindled!
  31. crate engine for 1975 vette
  32. just a question
  33. The beast is still alive
  34. Help: I have to sell my 78 corvette… but what’s it worth?
  35. Are We All Insane?
  36. Car show season is here! Are you protected?
  37. New Corvette America Seat Cover Installation Video
  38. 1970 coup what engine belongs in it
  39. Vbp's march madness sale
  40. Pic of 1973/74 Front Bumper with Grilles Removed
  41. 73 small block-do I replace it?
  42. Barry Grant parts
  43. the vette is awake.
  44. Adding Cruse Control ?
  45. Wow! What a week.
  46. 71 lt1 ?
  47. hydroboost fitting question
  48. 2nd Annual Wounded Warriors Charity Autocross March 26th - Indiana
  49. 2nd gear & reverse
  50. rookie mistake....help please??
  51. No one told me you have to be inventive to restore a Vette
  52. Rear Differential #3899143
  53. 74 vette with 78 back window
  54. Full Throttle Corvette - great experience
  55. Balls-out 76......
  56. LED Questions
  57. Cruise Control Fuse Blowing
  58. Re-built Title? 78 Pace Car $4,000
  59. Color Bond Products
  60. C4 Exhaust Manifolds onto C3 SB
  61. Cleaning and polishing steering wheel
  62. Need information on headers and electric cutouts..
  63. 73-77 seat shims and bag
  64. 1971 Coupe Specs.
  65. How to check if a Vette has Matching Numbers?
  66. need help finding a transport company
  67. Anyone ever purchase from automotivetoolsonline.com before?
  68. Power steering pump
  69. Hardtops: How/where do you find one?
  70. New member....future C3 owner needs help
  71. So, what's so hard about it?
  72. 1974 vin??
  73. Rebuilding trailing arms on my 1969, need a little help
  74. Looking for an 'odd' part...
  75. XM radio deal ???
  76. What happened to "The 73 Spot" ???
  77. The Classic big block vs small block question
  78. Medium blue over silver 1974
  79. steering nuckle removal
  80. having trouble deciding what has to be removed
  81. Saw this blown Vette at the dealer today
  82. radiator half inch short
  83. Wndsheild leaking
  84. New Member
  85. Door panel removal on 75 vette
  86. 78 L82....annoying noise..
  87. OEM vs. Poly
  88. what's it worth; for the third time
  89. Moog tie rod ends and idler arm quality & stg box adj notes
  90. courtesy light switch/door jamb
  91. 1974 Mulsanne Showcar & 1969 Aero Coupe
  92. Valve Cover Bolts - Need Extended Versions
  93. Under layment for carpet
  94. Rear Window Frame
  95. Does anyone sell MANUAL window regulators?
  96. Help with rear wheel bearings
  97. W/Wiper valve behind tacho
  98. Need pics of LED tail light conversion
  99. Which Wheel Wins?
  100. Brand New $600 SS Header/Side Pipes
  101. Expert Answer Needed
  102. 79 Driver window guestion
  103. Restoration softwares
  104. Power Antenna Question about signal
  105. 79-82 Seats In a '71
  106. Looking for a Hatchback
  107. What size spare tire is too big?
  108. Door Panel Question
  109. Trouble with Antenna on 79
  110. Please support Texas legislation for titling custom cars
  111. error/delete
  112. 80 Headlight switch question
  113. NCRS judging a 1972
  114. T top R&R and painting
  115. Carpet & weatherstripping
  116. rivet nuts for door sill plates
  117. Around here...it's Never Dull..!
  118. Is this OK or did I become Bubba??
  119. Main spanish sportcar magazine publishes a seven pages article on my C3...:-))
  120. 72 T top
  121. Installing Fibreglass mono spring
  122. 350 Engine in a 65
  123. Newbie from Down under
  124. Spring prices have arrived in MI
  125. This Doesn't Help ProTeam's Reputation at all
  126. Cheetah SCS shifter?
  127. A/c box question.
  128. T5 for $260. Worth it?
  129. 77 turn signal problem
  130. Yellow '73 with T70Rs
  131. The Vette Shop in Michigan
  132. Turtle Wax ICE
  133. Some pics of the 'Cars of Dreams'' show today.
  134. 71 corvette jack
  135. 72 project...
  136. Put 150 miles on the Vette today
  137. restoring heater box
  138. Rivets for Window BlowOut Clips
  139. Help me find this hood scoop for '69
  140. Embarrassing moment. Stalled at the red light.
  141. 1973 Tachometer Cable missing knurled nut
  142. corvettes caught on fire
  143. Mixed 69 body panels??
  144. Change Tranny to 700 r4
  145. 69 Carpet Replacement
  146. Rear astro vent doors
  147. chrome bubbling
  148. Looking for Laguna Gray
  149. pics of drive train after rear end rebuild
  150. NCRS Chapter meet 3/12 - Corvette Mike's
  151. Getting ready for the cruise and this happens
  152. Let's see your shots in primer
  153. Starter solenoid??????
  154. thermal protection
  155. Radiator Removal
  156. 1969 colors, production numbers
  157. Are you ready for spring?
  158. Rochester carburetor ID need help
  159. Opinion on 68 value
  160. Nice Day for a Ride in PA today !
  161. hard brake pedal 1982
  162. just starting a frame off resto 79, any tips?
  163. At what point does it become a kit car?
  164. Trailing arms
  165. 1968 convertible 327
  166. 1978 corvette power antenna wires
  167. Sold my vette
  168. Under carpet surprise
  169. viper sound
  170. 73 exhaust tips
  171. 78 Pace Car T Top Strap Hooks
  172. Warning
  173. Restoration Progress
  174. Is this a good Trade?
  175. Promotional films for the 1981 & 1982 Corvette
  176. I'm Alive
  177. Flasher and courtesy lamp holder..
  178. Can I see some '77/L82 Pics?
  179. Enhanced Build Sheet
  180. Is VetteWorks still in business?
  181. Strictly Corvette and American Muscle Car Show
  182. Defroster Grill
  183. decode engine number
  184. Did 79 Corvette key holes energize the motor?
  185. MPGs???
  186. Lug nut question for Boyd wheels
  187. Want pics of satin paint jobs
  188. corvette shaker hood scoop
  189. Pace cars needed for Central Pa. display
  190. Corvettes at Myrtle Beach
  191. Tail lights mod questions
  192. C3 Chrome Bumper Corvette Takes Out a Papa Johns
  193. Pulled the trigger
  194. Abbreviations
  195. 1980 corvette transmission question...
  196. Better Gas Millage
  197. Front Bra questions
  198. Foxy Vette!
  199. I need your opinion; want to get it right
  200. Comments on the factory look alike radio 72?
  201. A/C ? Should I spend $$$ to get her going ?
  202. 350/350hp
  203. Anybody in South Florida going to the show?
  204. steering column part
  205. SEAT Question - '73 Vert
  206. Need to lower auto tranny
  207. Question on interstate vehicle travel upon car purchase
  208. Might buy a '75 - looking for thoughts
  209. C3 Vinyl center stripe?
  210. Instant way to become the Quickest C3 Owner
  211. ID rear clip
  212. rebuilding wiper doors
  213. Is it just me? CF Advertising on threads
  214. Damn this is going to cost alot.....
  215. Help ordering a bumper
  216. Anyone Make Their Own Parts Washer or Sand Blast Cabinet
  217. '77 valve stems
  218. >>>> St Jude Auction #23 STOP!!! Rotors and Pads Winners choice C2-C6 <<<<
  219. Missing L88's???
  220. 78 Electrical Problem interior lights
  221. L88 vin numbers???
  222. 1972 Corvette from the movie "I Am Omega"
  223. Finally adding some power
  224. Looking for someone in LaHabra Calf.
  225. 1968-72 needed for bumper test fitment
  226. 74, 454 convertible pricing?
  227. Everybody needs to watch this L88 video. WOW!
  228. Very cool
  229. NCRS inspector Virginia Beach?
  230. Vette shop carnage
  231. Old Corvette Add
  232. I might be Bubba!
  233. Input Appreciated
  234. Steering Wheel
  235. Finally received the A/C comp. cover.
  236. St Jude Auction # 22 Yellow Yellow Yellow GREEN!
  237. Maxjax Pump ?
  238. Hood won't release on one side, help!
  239. 2011 Run to the Sun - Myrtle Beach
  240. Coil Resistor Wire
  241. Chicago World of Wheels/Chevy Vette Fest C3 pics
  242. going to california for march meet.
  243. Look at a car in Savannah, GA?
  244. Finished!!
  245. It's a sickness
  246. 1980 vette engine number
  247. Need some pics of a 1980 "California" 305 V8
  248. Missing odd interior Door part - '73 Vert
  249. Any Houstonians with Project 'Vettes?
  250. Can I get a C3?
