- Compression testing
- Opinions: Front 225/70-15 and Back 275/60-15 for my 1979
- My New C3 CONVERTIBLE
- new to corvettes headlights on 80 don't go up or down?
- What is the stock stall for converter from a 77 l48 with a th350?
- Classic: Power Steering Leak
- t tops on my 80 vette wont lock down
- Exhaust manifold gasket, did it come with any?
- Locating build sheet and removing tank?
- 72 Auto 1/2 done (don't try this at home) :>)
- Gm investing in Bowling Green
- C3 interior
- Seat Covers- Leather vs. Leather Like
- 1981 Vette Body style factory options?
- Alarm - an Option in '73?
- rare heads and intake, help I D
- Re-routing emergency brake cable
- 427 radiator questions
- Vbp's "spring" into summer sale
- Restoration Shop delays...is this a common problem?
- Bad knee, anyone deal with this?
- Need Interior
- My friend's C3 1977 Vette in Jordan
- If its not one thing its another
- Willcox New Sale.. You asked for it... Details inside!
- PW Switch Orientation - 73 Vert????????
- Lehigh Valley Cruise this Saturday night May7th
- Ignition shield question
- Tire Dilemma!
- windshiel scratch
- Do 79 Style half axles use "French Locks"?
- 79 tail lights mounting help needed
- Huge Fikse Wheel Sale - Celebrating 1 Year Anniversary of Company Re-Launch!
- Brake information
- Advice Needed - to repair or not?
- Looking for my first Corvette. What should I check and watch for during inspection ?
- Anyone changed there auto gear knob?
- C3 Zr1 bumper
- rearend dissassembly help
- Help with T-top alarm connection on '78
- Help. Please
- HELP! Can't get the hood open on my '78
- Shifter
- 2 wheeled Stingray
- Questions on Trading 07 Mustang for 74 Stingray
- Deciphering #'s on fiberglass LT1 / BB hood stamp?
- Damn. Good bye all
- bose radio head WTB '93
- Holley Carb for 454 LS6 "clone"
- Info wanted on Taurus/Lincoln Mark VIII electric fan setups
- Which Version you like most ?
- Problem with headlight operation
- 1981 t-top adjustment
- Corvette restorer in the midwest?
- $2500 1977 Rebuild.
- 3.08 or 3.36 gears wanted -3.55's to trade
- Borgenson steering box installed...
- Mall Car Show
- Upper Cowl Drip Rail
- Rear hatch latches and lever mechanism
- Any C3 fans in the Chicago burbs?
- side pipes for 78???
- #4 body bracket
- Help a new guy with his 1970 BB Convertible?
- 50 hp...Lost and found!
- 81 Starter Harness Question
- Stripped Threads on A/C compressor
- a/c blower motor spacer
- Price check on dad's 81?
- 4 speed manual trans reference in a 82 assembly manual?
- date casting code question.
- A/C Condenser mounting bolts ?
- Trying to get the vacuum system running..
- Spring Carlisle C3's
- VBP special still looking
- Installing luggage rack
- Somers Cruise Night
- Floor drains
- fuse box diagram needed for a 1982
- Comparative Shipping Costs...wow
- New chambered exhaust!!!
- California Stingrays Cruise to Solvang/Buelton Pictures
- New Motor
- Steering column Uh Oh!
- 1971 Wiper Door Not Closing All the Way
- where to get a motive brake bleeder in dfw
- Door handles. Repro vs GM
- Stupid Question time...
- corvette college??
- Big Block/LT1 hoods
- Sand found in my Corvette?
- Oil Blowing from Filler Neck cap
- Vette drivers in Louisville Ky
- C3 Project Car Pricing
- Need some Carb help- having issues.
- door panel
- Willcox small order missing parts?
- Corvette Parts Supplier Info
- What is the correct carb for a '78 L82?
- Can upper corner windshield trim moulding be installed without removing winshield?
- glass t tops
- Talladega To Aid In Alabama Disaster Relief
- Corvette pedal car....C3?
- Matching numbers...well...not necessarily
- VIN # Question 1975 Stingray.
- passenger side vent
- a question for those of you who have replaced your carpeting
- c3 exhaust
- 1970 Stingray Corvette, 454, 390 Hp. Help Please
- Paint Questions
- Transmission oil seal question
- 1979 corvette fuel gauge problem
- Good Find, Good Buy
- Vette inspection in Colorado Springs area?
- 74 seat belt starter relay interlock switch ?
- RIP Joe Mondello
- 1976 rims?
- 73 front center grill
- 68 lost keys
- Does anyone make C3 Side exhaust plastic shields?
- 81 power window stuck
- If you are not currently a NCM member, now is the time at a 25% discount!
- 1969 427 Black on black
- Parking Brake Console - Missing something?
- 68 Vin 418031
- 454 swap
- 115818's 40th today
- Shark Bar for a '79.....
- front crossmember, should it stay or should it go?
- Power Window Conversion
- 82 wiring connections
- Pull the trigger?
- '73 A-pillar moldings - not STICKING!
- radio shaft spread 1980 corvette
- The UPS truck came today bearing goodies
- Pic's of the AC box fabricatio:
- B.F Good-rich red line tires
- 79 high speed blower motor fuse location
- L/88 Hood Decal
- Manual Steering - How bad is it?
- Help me Price- Very Orig 81. with pic's
- Worth more as is or fix it up first?
- does anyone make cloth seat covers?
- Seatbelt Solution
- Custom Interior Trim
- ignition switch
- CC coupon codes????/
- Pricing Variances Between Vendors
- Rim Question
- Alternatives to bubbas alternator mount?
- Vin Diesel sure has a thing for Corvettes
- horn wire
- speedo problems
- 68 tri power
- Oh well.....back to the salt mines...
- Radio Delete Block-Off Plate
- [CAR SHOW] Sat. 5/7 Sicklerville/Gloucester Twp. NJ
- 75 seats in a 76
- New Seat Assembly HELP!!!
- Suggestions on fabricating spacer for A/C box?
- heat and noise insulation
- Burnt oil on sidepipes...
- Couple of Pics of the new hood
- Wood Streering Wheel for '68
- Bumper Authenticity 68-73
- Recommendations for a tap and die set
- Looking at a 74
- Front cross member holes
- 73 corvette ls6?
- Need help with vacuum
- T Bar
- Tire Test Video
- What's it worth?
- Shipping/Handling/Core deposits
- What would cause this....
- vapor canister for a '71
- Indianapolis Inspector
- What is this? C3 split window conversion...
- Short Circuit in Courtesy Lights
- Panels on or off?
- Intermittent Windows
- ID of 2 parts from 69?
- 76 rear disc brakes
- 76 Wiper motor issues
- Engine removal, and other stuff from a manual
- 50s Car Quiz
- New 1974 owner, anyone know a good shop in Columbus Ohio?
- How much do i sell for?? suggestions please
- Drivers door sagging
- 1968 Experts
- Lasers could replace spark plugs in car engines (the future is coming)
- Convertible top - Do I glue the top to the front bow?
- Seat guestion
- Seat Question
- Gas filler boot has water in it
- Oh ya, I'm in love
- My sister in law just bought a Stingray!
- How many of you guys have a C4 also?
- 82 Power antena
- C3-appreciate/depreciate
- '78 Restoration Project
- Rotor rust.. prevention?
- 76 stingray value
- Speedometer dash lights go out when drivers door closes
- Hood fitment questions on '81
- Question on removing quarter panel?
- Who makes a good glass top
- Question about c3 power steering cylinder
- one of the best jobs.
- Wiper nut purchase?
- two post lift tire support
- when it comes to adds, you'll find bull everywhere in the world
- Any good trans rebuilders in Suff co ?
- radiator and shroud
- Just a random picture.......
- Fiber Optics
- Does anyone know what these are??/
- Special edition 81
- Ignition Shield
- alignment shop help Arl. Tx
- Body separation
- Stingray or not
- A pillar sealing, what goes where?
- 1972 TCS Parts?
- Rear of car seems to swerve or 'slide' to one side
- Shipping Via *Horseless Carriage* Any Reviews??
- Body off restore or not? Need some thoughts.
- Reno Speed Shops?
- 76 corvette build...speed channel
- lizard skin
- How to find specific production numbers.
- Any good restoration/repair shops in South NJ?
- Advice on Restoration (should I stay original?)
- Headlight adjustments,,
- what EXACTLY do I have here?
- 1979 tach issues
- Wiper switch woes
- Big Block Values
- Alignment
- End of an era...............sad day
- ZZ 4 emblem/badge where to place on car ?
- 1982 radio knobs
- 78 seat back doesn't release
- New 1978 Corvette Owner
- We Build Relationships While Saving Money!
- Custon Front Grills for a 77
- Group discount
- anyone identify this power antenna
- 1980 fuel tank question?
- Trapped in the garage
