View Full Version : C3 General
  1. Using A/C condenser as a tranny cooler
  2. Lower Steering Column Cover - attachment
  3. Coolant Tank - "puke tank" reproduction
  4. whats the correct end link sleeve length for an '81 front sway bar?
  5. Trim removal from hardtop help Please!
  6. C3 Recalls (Campaigns) & Service Bulletins
  7. Fiberglass repair work in Atlanta metro area?
  8. Help on fixing small gas leak on tri-power
  9. Seat Belt Warning Light Button
  10. need a mechanic
  11. VIN codes
  12. AC Condensor
  13. 5/8" OD shank locking lug nuts...
  14. Stranded at work
  15. Did anyone see the red 70 LT1 at auction?
  16. Rusted birdcage for the layman...end result?
  17. Should I buy it??
  18. Turbo Corvette by Corvette Clinic
  19. 69 Convertible - need custom stereo help
  20. Sold 1978 Vette for 6,000
  21. ? Double latch t-top panel
  22. A few questions before I buy
  23. New Home for the Vettes
  24. Rear fiberglass mono spring replacement
  25. That explains it.....
  26. Went to a Porche show this last weekend..
  27. Whats a fair price for a 69 BB coupe #'s match in NCRS top flight condition ?
  28. Rubber bumper 0-60 Performance no so bad?
  29. Dealership question
  30. Windshield trim problem
  31. Inexpensive replacement rearview mirror
  32. Wasp(?) nest in interior
  33. Poked a small hole in my radiator...
  34. need info on 1970
  35. 1971 Corvette ZR2 whereabouts
  36. "California Stingrays" Solvang/Buellton GTG (Video)
  37. 69 detail help
  38. Hello! New guy here
  39. Amazing C3 Destroyed in Ringgold Tornado
  40. Grinding and clunking in left rear wheel
  41. Indoor Car Cover for 69'
  42. carb
  43. header paint
  44. GM Sidepipe Covers?
  45. Stupid Question
  46. PO2 Help
  47. What would you do?
  48. How to determine build date?
  49. How much does a YJ8 rim weigh?
  50. Ocean City, MD
  51. American Grafitti - Petaluma, CA - this Saturday
  52. Super Chevy Show in Richmond this weekend
  53. Lake Lure, N.C. for WWP 5-21
  54. Purchasing a used block to learn on/build for my '80
  55. Cars of interest Greenville SC Craigs List
  56. Seat Removal question 71 coupe
  57. Custom data plate ideas
  58. Frame checks?
  59. pinstripes and other painty things
  60. Garage Workspace Solutions
  61. LS1 A/C compressor... why can't I use it?
  62. windshield question??
  63. What Year L88 drop base air cleaner ?
  64. car covers, help!!??
  65. Bolt headstamps, size, length etc.
  66. Noth Texas C3 GTG at Sonic?: 05/21/2011
  67. Corvettes at Carlisle Giveaway '91 Corvette ZR-1
  68. Replacing Interior Soft Parts - Advice Being Solicited
  69. Need Help with Door Hinge Shim Install
  70. NCRS shoulder belts 69 ?
  71. which brand is the BEST!!
  72. MakoVette progress
  73. paint body problem
  74. Need photos of dual exhaust tips on C3 (80-82 if possible)
  75. Joined the ranks of C3 owners!
  76. Exhaust maniflods....
  77. Anyone have pic's of the 69 Repo Fiberglass heat shields?
  78. What is the most miles you've seen on an original Corvette engine with no rebuild?
  79. Is it a Firebird or a vette?
  80. Air,heater control switch question
  81. 77 Fuel Filter Replacement
  82. BF Goodrich RWL or Diamondback Redline on 69 Lemans Blue
  83. C1, C2 and C3 fun
  84. 68 not run in 10 yrs
  85. Should I worry? Just bought an 82-original tires and brakes
  86. Which Manuals to Buy
  87. The NEW C3!!!!
  88. Rear Main Seals
  89. Engine Paint
  90. Question about my early 1980
  91. radiator and fan out of car...any other projects to work on?
  92. NCRS Regional, Wildwood, NJ May 19-21
  93. AIM vs Factory Assembly Manual
  94. Anyone going to the Jefferson, TX 1st Annual Corvette Show?
  95. Why is it so hot in this car?????
  96. 78 Anniversary production numbers question.
  97. 74 A/C Heater controller
  98. Help with value of 79 L-82
  99. 5 June...anything going on in san antonio, tx
  100. The Wall ( not pink floyd)
  101. Tire size for 72 lt1
  102. dash pad and AC fan
  103. nothing is easy
  104. *~* St Jude Auction #41 Mac Book Pro *~*
  105. Install pulley on power steering pump
  106. Which Willcox carpet did you use?
  107. Conversion to a t5 manual trans from a t4
  108. Will '69 rocker trim fit a '71?
  109. Can anyone breakdown a 71 VIN#?, please,thanks.
  110. New Holley Idle Problem
  111. Motor and Trans going in....
  112. Turn signal lenses
  113. What`s the best restoration guide?
  114. 69 trim plate ?
  115. C-3 Vent Windows?
  116. 1969 vert bb value
  117. All Corvette car show (Myrtle Beach, SC)
  118. Lizzard Skin?
  119. It keeps getting better.
  120. Speedometer Died
  121. 82 Air Cleaner Lid Disassembly
  122. She's Here at last!!
  123. Check this out
  124. Humiliation
  125. 78 Pace Car Value
  126. R44TS vs R45TS spark plugs
  127. 70 original miles!!!
  128. The great clean out caper...
  129. French locks
  130. Outer door seal/felt questions
  131. 79 rear bumper mount help
  132. NOS 074 and 291 heads what are they worth
  133. Help Needed - Willcox Weatherstriping Inner/Outer Pillar Post Clips
  134. Blower motor switch inop
  135. Rear back together and new rims
  136. store car on ground or up on blocks to relieve springs
  137. '78 convertible conversion update
  138. need parts for 79
  139. Whats it worth? 81 4 speed project
  140. Disconnect ram from relay arm?
  141. keys locked inside 1973 corvette (Help)
  142. 1969 427 black on black. estimated value
  143. Happy birthday!
  144. Vbp's "spring" into summer sale
  145. 1969 MA6 option L71 car
  146. C O R V E T T E lettering on a 75
  147. Thoughts on 77 Coupe
  148. 900 paint code '68 big block vert
  149. 1972 Questions
  150. Little Favor-ALT Belt Guide
  151. Finally cleaned under the hood
  152. Hey, need some help
  153. What's this '79 worth???
  154. Custom headlights $50120
  155. napa part #
  156. Calling All Corvettes/GM Vehicle's for Open House @ GM in Philli
  157. Question on side pipe covers
  158. reproduction belts dont fit?
  159. What do you think of this one?
  160. Not sure if this belongs here, An amazing image hosting site
  161. CompCams CamQuest and Desktop Dyno accuracy
  162. 1972 LT1 questions
  163. Transmission Cooling lines INSTALL '73
  164. Cheap radiators on Ebay
  165. 82 corvette door lock
  166. 36 hours later....
  167. school me in chevy lingo
  168. Car pics
  169. Anyone Have this or seen these?
  170. Side Pipe Shields under $300?
  171. Took some new pics the other day!
  172. I think I have a problem
  173. Deciding between NOM or Original C3?
  174. hard top price
  175. How flammable are our cars?
  176. Today was big day...
  177. I like my car
  178. Help me to indetify this one
  179. ~~~ St Jude Auction #40 Autographed hero cards from 12 Hrs of Sebring ~~~
  180. In Shock
  181. What Shocks?
  182. newb- '75 question
  183. Anybody know where to find a Briggs and Stratten alarm key blank
  184. Belt Questions 69 427 with PS and AC
  185. Door Hinge Shim Help
  186. Corbeau Seat Help!
  187. Vacuum hoses
  188. "Restoration Packages" from GM are online
  189. "Restoration Packages" from Chevy are online
  190. Celebrity Ownership of 1978 Pace Cars
  191. Production numbers question
  192. Holley regulator install... pics? ideas?
  193. Research before i buy
  194. finally time to work on the 77
  195. Tight fit!
  196. Instrument lights not lighting??
  197. 1968 Corvette Battery Charged but No Power
  198. Question on correct heater hose routing on a 70
  199. radiatorclassic
  200. ... and then something strange happened.
  201. Cool Flex Hoses
  202. I wanna see some.... stock, modified & custom vettes
  203. Front Clip Advise
  204. Mayday at the lake 5/21
  205. 7029215 carb date and build date
  206. Gunmetal Interior
  207. hotels in bowling green ky.
  208. backup lights staying on 72 vette
  209. A Laugh for the OFC (Old Farts Club)
  210. Looking for enclosed car trailer
  211. 1979 factory hatchback - rare?
  212. 79 Vet differential
  213. leaks & mold
  214. metallic vette???
  215. Vader Vette
  216. Replacement T-Tops
  217. 78 fuel gauge problem
  218. Instructions for replacing front fender?
  219. Replacing dash vents
  220. Is anyone familiar with this car?
  221. *~* St Jude Auction #39 Flying Wild Alaska - Hat signed by pilots*~*
  222. Emission rules in your state / county
  223. Bleeding Question
  224. Side pipe exhaust leak
  225. *** '68 fan question ***
  226. My boy behind the wheel
  227. Love my vette
  228. What is best way to clean white letters on tires?
  229. convertible owners please
  230. so you want to take the vette out for a drive?
  231. Headlight Issue in my 77
  232. Where do you get tech info?
  233. 79 and Shifting
  234. Choke Light 1981
  235. lifted the rear end?
  236. C3 Split window
  237. My "New" 1982 Corvette Restoration Thread
  238. Choke Light 1981
  239. 1980 horn button blues
  240. tire size for 72 corvette
  241. Assuming you just put an LS1 in a c3 corvette there's only one thing left to do....
  242. Live from the garage!!
  243. L79 parts
  244. 1968 outer splash shields
  245. And here we go!
  246. New Tranny Value
  247. Best way to start is crushing a pinky
  248. Intake Manifold
  249. 1969 Riverside gold paint code?
  250. Do I have a 76 Vett?
