View Full Version : C3 General
  1. Blinkers not working
  2. next...
  3. I'm looking for a Coupon Code for willcox
  4. Starter.....
  5. Looking for repair shop in Edmonton, Alberta, Canada.
  6. Best Line From a Cruise Last Night
  7. Palos Cars show
  8. visited RK Motors
  9. new member with tach problem
  10. Tremec TKO 600 question
  11. Corvette Word Game Contest Winner! New Game Is Up!
  12. Please help w/ paint color!
  13. Assembly Instruction Manual A.I.M.
  14. Please help w/ paint color!
  15. Scale Model of your Vette....
  16. finding history of 1972 corvette
  17. Monza gas cap?
  18. C3 Brake Indicator Lignt
  19. C3 Power window motor replacement?
  20. Garage Fumes
  21. Insurance suggestion in NJ
  22. Funny story
  23. Corvette Day Priceless
  24. clutch adjustment - ran into a snag
  25. Turn signals not working? Related to factory alarm?
  26. Bumps under fiber glass at nose?
  27. My Corvette Journey
  28. valve cover ID help
  29. Lizard skin prep
  30. brake problem
  31. *Need Pics of 78-82 Black or Red Interiors*
  32. 1696 350 stock ignition/air cleaner
  33. 1972 corvette
  34. Hi all! has my old car shown up on here?
  35. speedo leak
  36. Need help, front of the car is comming apart!
  37. 1974 L-82 Production Numbers?
  38. dealings with with someone in the uae or qatar
  39. I Hate Mice!!
  40. What is wrong with my fender???
  41. CLARIFICATION 74 and below
  42. Strpping paint off of chrome
  43. Map Pocket 69 - how do I reconnect?
  44. How the #@&%#? do you block sand a C3??
  45. Nice chop cam for a 350
  46. 67 flexplate
  47. 1973 restoration update
  48. Little video running
  49. People familiar with the C3 market, please appraise these two vintage C3 racecars
  50. 79 front bumper
  51. Potential '71 purchase...need advice!
  52. 1970 Stingray Corvette, 454 and 390 horsepower-- Carborator questions
  53. My car looks so small.Pic
  54. Air conditioner pump guestion
  55. Beat the heat and run the streets with vbp's summer sale
  56. VHT Flameproof Coating
  57. Steel Cities grey- a big premium?
  58. Tires/Wheels
  59. Tilt / Tele Colum Differences
  60. Antenna issues- what to check first?
  61. Broken? Wiper vacuum hose on 69
  62. Chrome polish suggestions
  63. which Assembly Instruction Manual?
  64. Painted T-Top Hardware
  65. worn trailing arm bushings
  66. Please don't be mad...
  67. C3 experts: appraise this car
  68. My 72 is a 81...where do I learn body differences? NOOB here.
  69. Local Car Show Locator
  70. Rad Cap Pressure
  71. Blast Cabinet
  72. Car Shows in Kure Beach,NC
  73. Bubba Does House Work too!!
  74. Can't get air out of brakes
  75. Car History thread
  76. Fender Replacement
  77. Off set trailing arms
  78. ? about GF432 fuel filter
  79. 79 pictures of overflow tank hookup?
  80. Storing your Vette (primarily for winter time)
  81. Anyone remove front plate and move center grill?
  82. A dye question, (visors)
  83. 1970 390hp 454 question
  84. Shoulder belt mounts
  85. Anyone try to have a radiator cap restored?
  86. 78 Front L/R Grilles
  87. Correct AC or other Spark Plugs for Factory Aluminum 14011077 Big Block Heads
  88. 68 vs 69 convertible bodies
  89. Northern Tool High Lift Floor Jack On Sale
  90. My Corvette Story
  91. Need Calipers/Brake System Replacement
  92. Tapping iron heads, what tap material?
  93. Anybody seen this 72 restomod in person, WPB, Fl.
  94. 1982 value
  95. ++++ St Jude Auction #60 Otterbox Defender Cover for the Original Ipad ++++
  96. *>>> St Jude Auction #59~~~Piloti Driving Shoes <<<*
  97. Rear Deck Plenum Grille
  98. Trailing arm ArGGGG
  99. Flex bumpers
  100. 74 radiator removal
  101. 78 Speedometer not working
  102. 81 heater core R/R TODAY!
  103. Power window fuse question
  104. SIDEPIPES! take two, new plan!
  105. Photo Shop Help (Pics)
  106. your thoughts on what defines a classic car?
  107. New Interior
  108. need some advice
  109. 1968 Corvette Tripower project
  110. My car turns 39 Today !
  111. Greenwood's 215mph ZL-1 LeMans Racer
  112. Water pump for '73 350 engine
  113. Figure out the garage pics
  114. About to rebuild my th350
  115. WooHoo, new seats on the way.
  116. Well here are some production # stats I didn't know
  117. Weber Carburetors - Artwork!
  118. Engine Stamp Question
  119. Spring re-install question
  120. Enough to make a man cry.
  121. Is my Cooling Fan on backwards? Pic
  122. '71 coupe interior work/questions
  123. Where to buy tires
  124. Smoking coming from rear of valve covers
  125. Gentry Lane?
  126. Help a newbie out !!! (please)
  127. Removing turn signal lever 1978
  128. Smog Pump
  129. Front clip freight dimensions
  130. reducing interior heat
  131. looking for a car show
  132. Some of your fav upgrades/tweaks
  133. My C-3s first, second place, pictures.
  134. My 1974 Break's Overheating
  135. Pulling the trigger on sidepipes- are these the right ones
  136. What's the value of a number matching 327?
  137. Trying out the new camera on the C3
  138. Wheels/Tires Value?
  139. '73 Engine Compartment - pics
  140. The End of Corvette and Chevy Trader?
  141. 1980 rear differential pinion shims
  142. Need help with cragar wheels!!!!
  143. brake lights not working
  144. Well Im Alive pt2(car pics)
  145. Body Mounts
  146. Free Shipping On All ACI Fiberglass
  147. Don't Sidepipes Need a Flex Joint? or can be Rigid Mounted?
  148. 75 wiring issue
  149. Power Outage at Corvette Central
  150. dual radiator fan assembly
  151. Garage solution- check this out!
  152. Corvette Club of Marion County picnic W/PICS.
  153. Procedure to diagnose steering/suspension problem
  154. Press Molded Stinger Hood
  155. Early/Late 1979 identifcation
  156. Custom stereo mount question
  157. C3 & c6 z06
  158. Bleeding Brakes with Power Bleeder
  159. Some input on "how much will this cost me" and anti-theft options
  160. New to Forum. Questions on buying 1969
  161. Crager rims
  162. Windshield Frame/Upper Fender Filler
  163. Z07 option
  164. Stingray cruise to Buellton 2011, Check it!!
  165. Failed inspection
  166. New R4 Compressor doesn't fit - Pics
  167. Very ODD Question about LARGE Car shows....
  168. 1976 turnsignal switch problems
  169. Seat Belt Externder for 82
  170. My Day Today - A Club Tour and Show
  171. Looking to buy my first Corvette. PLEASE HELP!
  172. seat swap
  173. 1969 Authenticated Fla License Plates
  174. Reunited once again!
  175. Cleaning house corvette parts.............
  176. Gotta Love Side Pipes!!
  177. Question about '69 AC Vents
  178. fire extinguishers - do you have one / need one?
  179. Wait... You want WHAT for your car?!?!?! (PICS)
  180. HorsePower question small Block:
  181. rear suspension knock 78 vette
  182. How to fix Wipers skipping on a 77
  183. Thoughts on Hedman Headers and Sidepipe Kits
  184. A/C vents on my '81...
  185. 1980 ac
  186. '73 starter n.g? other electrical o.k.
  187. 81 Cruise Control Servo
  188. Passing on 1973 Line on 1977 need opinion $$
  189. Tail of the Dragon Run Oct 21 - 25
  190. VetteNuts Insulation Kit Sale Ends Sunday 7/31!
  191. Do these look like correct valve covers?
  192. Vacuum Leak....
  193. Valve seal installation tools.
  194. 1980 L82 Horn blowing fuses
  195. Thanks for the help
  196. 1973 restoration
  197. 1970 Stingray Corvette, 454 and 390 horsepower-- HELP Please, out of ideas
  198. Video of just before I pull the Old 355 out for the LS swap
  199. Is 16.8 too much for this...
  200. 79 Coupe - Intermittent Grind When Braking
  201. 68 Smog Pump RESTORED By My Friend (Pics)
  202. Cleaning Engine Bay - Advice
  203. Exhaust Questions - Emissions
  204. My '75 got punched in the nose, need help
  205. "O" ring caliper issue
  206. Tach Board & Filter
  207. Got the clutch out and.........
  208. Issues with '68s?
  209. Typical C3 owner ???
  210. Couple of questions on painting/dyeing interior parts
  211. 70 LT-1 Hood- is it real?
  212. Elkart Green
  213. Matching #s quesstion
  214. Newbe just looking @ 1973 vette need help
  215. 1969 Stingray guidebook
  216. VIN number question
  217. 79 with opening glass hatch
  218. The '72 base engine
  219. pictures needed of installed '71 wiper arms
  220. Anyone have picture of 1969 Alternator Brackets?
  221. Looking for simple software sites to test new paint colors on uploaded C3 pics
  222. Pictures from the Wexford, PA Cruise-in Corvette Night.
  223. 73 Stereo Amp (convector) placement???
  224. how much is it worth?
  225. 78' fuel gauge fluxuates
  226. 1st post - 1st question
  227. 1968 Engine Numbers ?????? T10081R
  228. 1982 C3 parting out? selling as a whole? Advice needed.
  229. Exhaust Tubing Size
  230. Small Block Header Install - from top or bottom?
  231. Trans leaks from tailshaft
  232. Motion Phase III GT takes top honors at Eyes On Design Show
  233. carolina corvette meet
  234. having car undercoated?
  235. 1968 coupe with factory sidepipes.......
  236. C3 Win
  237. Need opinion: should i buy this 427
  238. Opinions on a potential C3 purchase [PICS]
  239. Paging Ernie Willcox
  240. Help - turned the a/c on and boom
  241. Can anyone identify this console trim plate??
  242. I need a piece of carpet
  243. grease ?
  244. Hello from the new guy with the '69
  245. Signs of a Big Block Original Vette?
  246. 68 tach...
  247. Step 2 of my at home paint job.
  248. Pictures Summer Nationals Worcester, MA
  249. An anniversary, but not a milestone.
  250. Long Shot!!
