- My H/C/I Vette VS. VOLVETTE TT yes Twinturbo LS1 VOLVO
- 440 RWHP 1/8 Time?
- Question on a cam with a auto trans
- 98 C5 Auto with borla quad and 2 cone KN
- How can peoples cars not perform?
- Took my Vette to the track
- New C5 owner...Question about runflats and acceleration.
- What gear do you cross the traps in?
- Perceived Trottle Pedal Pressure
- Back to Stock Intake and Exhaust Manifolds
- come help me bench race.
- Vararam intake installed
- NOS results
- Care to analyze my dyno sheet?
- first visit to the track with blower installed
- 127.15 MPH 3580 lb car!
- 02 Z06, switched tuners, reading low, low numbers like this normal?
- stock c5 1/4 mile time?
- have anyone use the F 11 cam in here
- BPP Vortex Rammer or Diablo Predator ?
- 10.96 @ 125.35 New best!... in the middle of May?? YOU BET!!
- Questions about the stock drivetrain.
- anybody here have a 427 with L92 heads?
- Seeking advice/experience re gears
- $199 Street Tune special continues!
- 433rwhp with stock parts!
- Piston swap is it worth it
- Nitrous question
- Problem with light flywheel
- YES! 11s
- please help with choices between these 3 cams
- Went to dyno today??
- Found 10 HP in Chattsworth
- Intake Q's
- how much heads and cam for 450rwhp
- TPIS or FAST Intake?
- Vinci XXX cam is in
- Dyno results...Real time halltech, corsa, fluidampr results.
- what does it take to get a Z06 to outrun a Yamaha R6?
- Which intake???
- anyone have MTI X1 cam dyno results?
- New Standing Mile Record!
- $199 street tune this Sat at BMP in FL!
- Very Interesting: GMHTP aftermarket cylinder head comparison
- Want to run 12.90's
- Track times to go with my dyno numbers
- Install Twin Turbos or Not
- Inexpensive/Good Chassis Dyno Rental in Bay Area?
- what is a typhoon manifold'?
- Poor dyno and KR with my American Racing Headers:(
- Baseline Dyno done today
- TSP402/ETP215/G5X4.....#'s
- another 'guess my HP' thread
- 383 Dyno numbers for my 02 Z06
- What gains if any?
- First Dyno/Tune 99 MN6 w/Bolt ons
- Shifter problems....
- Guess rwhp and WIN A PRIZE
- 1/8 mile times
- May12, the dyno, what is your guess
- Bolt-Ons Dyno Results
- Where is all the Kenny-Bell Results, Are they junk?
- And so it begins...
- Honker Dyno Results
- Gear change, what should I expect?
- Stock '03 Z dyno
- My 60' sucks
- I need info on a nitros kit
- 1/8th mile times
- H/C Combo im looking at for an FRC
- '99 Frc W/vortech Dyno Results...
- Vette Doctors little 402 hangs with the big dogs
- curious aboutNovi 2000 Dyno & 1/4mile times
- LPE GT11 Cam
- New Best A&A P1SC
- Everyone that posted times in "Official C5 1/4 Mile Times List" [step inside]
- do you put your vette on a trailer?
- LS 6 243 heads
- Test tracks in SW FL?
- Catback Corsa vs Stock Ti
- Expected Dyno Numbers
- zl7 package worth it?
- Can you run in the 10's?
- 400rwhp Z06 with only bolt on's? possible?
- WATB cylinder heads for stock cubed LS1
- How will i do vs my friends 97??
- Boweryboy Sets a New Best 8.54@164 in his Vette Doctors IRS C5 Rear Mounted Turbo
- Beaten bad by a Cobra last night
- Turbo Buick vs Z06 Revisited MIR
- What should it do?
- Dyno results on a 99 H/C
- Finally in the 11s
- Stock Bottom End, Stock Head A&A P1SC Dyno Numbers
- New Best MPH
- Drag Racing C5/c6 Bash
- has anyone tryed the QA-1 shocks ?????
- In the 12's...
- 3/31 results
- Dyno'd My Stock 02' Z Today...
- Dyno Results-'02 Z w/ light mods
- G5X4 owners
- 98 coupe going to the dyno next week...
- Track results 3 30 07
- MS4 & Fast 90/90 Results, 462rwhp & 407rwtq STOCK HEADS
- smooth air bridge hp gains?
- My Dyno Results are in!!!
- c5 mods first time post
- B&B exhaust
- RPM Transmissions does it again
- z06 should i tune it
- New ET Street Radials!....
- 427HP at SWtuning in OKC
- Texas Speed dyno results
- Cartek 4x H/C runs 10.41@131+
- Official C5 1/4 Times List
- My 97 c5 a4
- What would i get out of a LS6 intake
- Went to a local track Sun.
- Any numbers on Dyno w/ Lt headers on a Z?
- ***Cartek C5/C6 gear Special $1195 Installed***
- Kudos to Ranger
- I In The Tens !!!! New Pb 10.848 @ 122.79 !!!!
- The car is getting a face lift I need some ideas
- *** New Cartek Heads = 70rwhp & 69tq On An A4 ***
- My best times yet
- How will it do?
- New times, input appreciated.
- Baseline number in/Cam only coming soon!
- Stupid questions...
- Tune and dyno results by Pro Dyno Tech (Indiana)
- A4 H/C 346 cars what is your RWHP
- Need New HP fuel pump and assembly 99 C5!
- How much power is needed to break 10's ??
- Just bought some heads, need some advise?
- New best in the Z
- 1/8 time
- Traction
- Thanks To CARTEK
- Opinions please.....
- Sooo, what would I trap?
- Should I Re-Tune
- Am I in the 7's in 1/8th
- Dyno results sound low? Power increased after 2 weeks.
- 1/4 mile
- Went to the track yesterday
- New spray times
- Am I in the 10's in the Qtr?, 1/8 mile results inside..
- Worth re-tuning?
- Full bolt on Zohh dyno
- for those who drag race?
- 3/3 beech bend raceway
- Guys with new trickflow heads
- ?Who runs 28s in the rear and does it effect your ABS/TCS?
- Dyno'd stock 2000 coupe w/ 100k miles
- First runs with my 427 STS kit
- Vette Drs H/C tuning pkg...
- Tried out the new clutch last night!!
- Port Matched & Coated
- Tires And Wheels Ready To Rumble
- Aggressive Cam on stock block?
- forged 346
- Qtp cut outs and turbos
- 449ci semi solid roller pump gas Z
- 2 kills in 2 days for the C5
- How much is needed for 11's???
- What type of 1/4mile time can i expect with this setup?
- L92 Results and Plan B
- 0-60 times
- Bolt On Dyno Numbers
- Standing mile
- LG Pro longtubes VS Kooks
- aftermarket tune
- Blackwing re-oiling question
- ETP 4.8/5.3 vs. Trick Flow 205's 30 rwhp difference!!
- dyno'd my c5
- Long tubes and HiFlo Cats WOW!
- Took the car out again
- C5-R/9 sec/2000 Coupe Tear Down - Results Inside!
- My 403 LS2 L92 L76 ALL MOTOR!
- Mods and Dyno Results
- Tire question
- Vararam, 02+ h-pipe, ported TB dynosheet
- TR6 gap in a 383
- New ET and Dyno numbers on Dry hit
- 10.71 Video New Personal Best
- Jet Hot coating or not
- New dyno results
- Twin Turbo Corvette C5 vs Subaru Impreza WRX STI - istanbul/turkey
- Cold Air Intake?!?!?
- When is the next Dyno day
- Northern Virginia dyno day POSTEM UP
- My 11 sec stock Z06! (K&N, BFG)
- Drag Tires And Wheels
- Video of New Best 11.22 w/1.56 60' Moroso
- More 383 Results
- Stupid question time....
- anyone running Y2k wheels?
- New mods= 5mph loss in trap!?!
- New personal best finally in the 9s
- Recommendations for Drag Racing C5
- My 383 results.
- 70 rwhp
- Took my Z to the strip.
- what gear should I finish quarter mile in.
- New personal best - thanks Andy!
- Head Games
- MS4 dyno results update
- Just installed, Tony Mamo ported Fast 90/90
- Finally ran my new clutch at Moroso!
- Dyno results from head change
- Another thread you guys probably will hate....
- 1/4 mile pass without accessory belt?
- So how do I get my car to 60'?
- Ported T/B and some
- Trickflow 215 Heads and Vette Doctors custom cam results.
- PINKS! at MIR June 9th
- My car (warning lots of photos and videos)
- ZO6 Catback vs. Others
- dyno results... no sheet sorry
- Max Lateral G...
- What size rim are you running w/28x11.5 tires? fitment?
- New Years Resolution
- New best 11.5 @ 121
- Sway bars?
- dyno quarter mile runs
- AR headers and Intake what rwhp is expected with a Z06?
- 315/30/18's on CCW's
- Recommendations For 400rwhp...
- ECS Amer. Race Header Install
- What offsets to get for C5 or Drag Racing?
- Best performance no power adders
- 2001 MN6 Dyno - Is this Any "Good"?
- projected quarter mile time
- Need Pics of Bogart Skinnies at Front fender!
- L92 408 first results....
- Break Boosting a Surpecharged C6
- Shout-out to BlownZ06's Fantabulous H2 Towing Service
- Tried Cecil county again yesterday 00FRC H/C/I
- Don't laugh...it was my first 1/4
- New 402 track results
- Some Things You Should Know About Certain Vendors!
- Custom Exhaust
- Cartek c5 vert with a little p1 blower
- LS2 Heads
- question about 1/4 time
- CORSA X-PIPE or BASSANI X-PIPE
- Pinks All Out
- Experience with MTi cams????
- 12.22@116.18 CAI & Street Tires @ MIR
- Selecting a Turbo for C5
