View Full Version : C6 Tech/Performance
  1. Anyone have an Exo-Skel for sale? Vendors please help...
  2. Lowing your car/or raise it?
  3. Anyone else have this problem ???
  4. jack stands
  5. Check oil level msg,dic
  6. Key Fob issue...
  7. Reflash
  8. 2005 C6 Probs
  9. Are LS2 and LS7 throttle bodies interchangeable?
  10. How far can you vary from stock Fr-R tire ratio before active handling balks?
  11. C6 oil leaks?
  12. Interesting tidbit on LS3/A6 "quicker upshifting"
  13. Best price for oil catch can?
  14. lowered on cut rear bolts
  15. Rear Tire Question?
  16. LS 3 Stock Intake
  17. Dyna tech headers what do you guys think
  18. cheapest drag radial / rim set up?
  19. Have any of you guys tried these?
  20. NPP vs. Aftermarket Cats
  21. 11.68@121 ls3 a6
  22. Borla S-Type (Stingers) Installed... DIY Tips
  23. Lowering car on magnetic ryde???
  24. Clutch Install
  25. Help Installing My Honker
  26. Need More Power...
  27. Oil change
  28. Is the Predator considered a Mod?
  29. Vortex Rammer
  30. Headers with NPP Exhaust
  31. 3150# c6, 1.50 60ft, 365RWHP TURNS 10.90 in Quarter
  32. 255/35/19 Pic Request
  33. Adjust headlight beam up or down?
  34. Help.... Window Stuck in Down Postion
  35. 2006 C6 Vert Roll Bar Solutions ???
  36. how to make 450HP
  37. Cams
  38. who sells complete 4L80E transmissions
  39. No cats with tune, HOW STINKY???
  40. cat broke up
  41. Nnp
  42. Z06 bumper on C6
  43. z06 front fenders/install question
  44. Non- Run Flat Tire Question
  45. ceramic brake pads?
  46. Exhaust squeaking when going over speedbumps in my '08
  47. Roy at Cartek
  48. will this work?
  49. Sounds terrible!!
  50. Install Write-ups
  51. Help/ Auto Mirror
  52. Tech guyz - see general- car lift thread
  53. URGENT exhaust install help needed
  54. Magnetic oil drain plug for '06
  55. pilot sports
  56. How many of you installed a cam w/ NO
  57. Pulled the trigger on heads and cam
  58. Paddle shift will not engage
  59. Front end noise on 2006 C6
  60. Only this can happen to me, Schrader 21210 failure TPMS tool
  61. high oil pressure
  62. is worth trading to get the ls3
  63. can you fit front z fenders on a c6 bumper
  64. Fichtners Spring Special Is Back!
  65. lifter noise
  66. Rear Tire sizes Max
  67. question about 08 stock intake
  68. Referals in NJ or Philly area Corvette performance Shops
  69. Z51 Brake package question
  70. Dyno Results -- LG Pro Long Tubes, Trick Flows, and Callaway Intake
  71. Diablo Predator Programer vs. Dyno Tuning by changing computer program.
  72. Callaway shifter help
  73. Anyone swap a mgw for a calloway shifter?
  74. Question about clutch repair ???
  75. disapointed with my latest runs at irwindale
  76. Diablo Predator Programer vs. mail order tune
  77. proformance pkg deal good deal?
  78. Corsa Extreme and Halltech installed
  79. K&n Fipk
  80. corrected 1/4 times
  81. Cartek Cartek Cartek
  82. Intake And Exhaust Hp Gain
  83. Thanks ZO6 cans installed.
  84. Quad tip Stingers... tip alignment issue?
  85. Apsis' Speedo Corner in 4 Different Carbon Look Finishes, *PIC*
  86. Quick jacking question
  87. Diff leak
  88. 160 deg. stat
  89. Anyone heard of "Lethal Injection" in Florida?
  90. Another Muffler Question...
  91. LS7 intake on LS3
  92. vararam intake and oil cooler 05c6
  93. Possible to add a telescoping column?
  94. Drag radials in 21 century sizes....finally
  95. Shifting probkems in my Z-51 C6 ?
  96. Question RE: rubber trim
  97. KDW2s 255/40-18 295/35-19 installed today
  98. How do you pull the XM antenna cover off?
  99. Need Help Alignmnent Specs For Lowered Car
  100. a converter with 3.42s in the A6?
  101. Oil Pressure
  102. Brake Shoes???
  103. compression???psi
  104. Question about Predator
  105. Help w/Predator
  106. Advanced Dyno Rocks
  107. Help please
  108. 3.90 Gears, Opinions?
  109. Cam/FAST C6 Vs M6?
  110. Help ZO6 muffler install to 06 a6
  111. Yella Terra Rockers 20 Hp/ Tq ??
  112. will a c6 zo6 catback fit on a c6?
  113. Has anyone removed stock mufflers and just added tips?
  114. Pfadt Spy Photo!
  115. All With Mgw Shifters Please Read Asap>>>>
  116. Whos HEAD / CAM package to go with ?
  117. Adding NPP after the factory in a 2008 convertible
  118. #10 Engine Bay FUSE
  119. Wheel Size Question
  120. Engine oil question
  121. Less TM on the upshifts in Sport Mode - Corvette Quarterly
  122. 229/229 114 Cam in LS3
  123. First Video: Sebring In Car-ALMS GT2-LG Motorsports
  124. *****Cartek Rippin it up w/pics*****
  125. not a happy camper. nail in brand new tire
  126. Anyone installed an oil catch can on a vortech or procharger?
  127. Just ordered B & B Bullets from Horsepower Sales
  128. Ls7 Clutch same as 07 LS2 Clutch?
  129. Magnaflow 15886
  130. Cartek
  131. Question about A6's stock and tuned at w.o.t throttle...
  132. Does NPP in a box work with B&B Fusion?
  133. rear brake caliper pistons
  134. Lg Motorsport
  135. Checking brake disc pad wear--06 Base Coupe
  136. NPP or Retrofit Z06 Exhaust?
  137. Oil pressure problem
  138. Back to the mod shop today
  139. open shroud what is this mod
  140. Are magnetic drain plugs now?
  141. C6 M6 excessive wheel hop
  142. Tire Size Question
  143. T/B spacer W Vararam?
  144. Disregard
  145. Botched download disregard
  146. shift speed of C6\A6\ ls3
  147. 450 rwhp + new tires awaiting install = FUN!
  148. Looking to buy a ported intake/TB....HELP
  149. Aftermarket Wheel/Tire Question
  150. Will a Z06 spoiler fit a reg. C6?
  151. A new "Pay it Forward", step in
  152. need BIG favor from fellow forum member near or in Melbourne Fl>>>
  153. WTB two 19" OEM silver wheels off '05-07
  154. Last Week For Forgeline Sale!!!!!
  155. Omega jack improvement
  156. Forgeline Gunmetal VR3P Rims on a Silver LS3
  157. Will my service engine soon light come on if I remove the cats?
  158. Bondurant course package for sale....
  159. Who has ported their LS3 TB's and Intakes?
  160. Tunes by COW
  161. Need help on Z06 exhaust system
  162. What gear?
  163. z-06 sway bars vs. z-51 sway bars
  164. Forum newbe needs radiator advice
  165. possible disaster--service active handling DIY mix-up EVERYONE PLEASE READ
  166. Disabling Speed Sensor on NAV System
  167. LS3 Cam Results @ LG
  168. Tunnel plate installed!
  169. do I need 4 TPM sensors, or is it something else??
  170. How to attach Pressure switches to aftermarket rim?
  171. MGW - The shifter we always Knew someone could build...
  172. Clutch
  173. Cold Air Intakes?
  174. Piston Slap / Sea foam
  175. Need Help With Autocross Tires?
  176. Underdrive pulley
  177. LG headers+cats+Corsa Z06 exhaust+Halltech on '06 A6(Dyno Results) need input,advice
  178. GM T1 Swaybars...
  179. Woodburn Raceway
  180. Procharger install, do you have to remove the Radiator?
  181. What are your LS2 cam only #s?
  182. What are your LS2 cam only #s?
  183. What are you LS2 cam only #s?
  184. Ok guys car problem help?
  185. VIDS from march 22nd drag event, many corvettes c2,c4,c5,c6,ls2,ls3,ls7
  186. Power Steering fluid for 2005 Corvette
  187. Does high flow cats make much of a difference
  188. I ran a perfect .000 reaction time at the drags today!!! {Video}
  189. I just don,t understand
  190. 08 come with nnp valve??
  191. Rubber Conditioning
  192. 2008 LS3 Mobil 1 Oil Filter #
  193. Dipstick on a c6.... I am so confused.
  194. corvette / cadillac key fob interchange???
  195. Cam comparison thread
  196. Z51 tyres DOT date codes anomoly?
  197. Need some Help Building Shortblock?
  198. relay clicking behind radio v2
  199. powder coating brake calipers need reco
  200. Tunnel plate installaton help please
  201. electrical
  202. Another Vararam Install
  203. C6 with Z51 - are aftermarket Shocks/Sways noticeably better / faster?
  204. Need Help Fast! How To Remove 2008 Z06/mn6 Shift Knob?
  205. 2008 C6 Black Paint Code
  206. just got home from track..
  207. Is there any cat delete pipes?
  208. Anyone have a chassis ground schematic?
  209. Yet another MGW shifter review - Thumbs up
  210. Build your own LS X motor on line at GMPOWER ...
  211. toyo r888
  212. Kooks W/ Npp Exhaust?
  213. 2007 C6/A6 on the Dyno Utilizing Diablo Tunes
  214. tranny problem
  215. Hesitation
  216. torque management
  217. Planning a 2009 A6 purchase and I had some questions
  218. In an effort to make my car more of a sleeper I did this:
  219. Z06 front splitter intallation on C6
  220. Good Tune shop in GA
  221. Need help stock 07 a6 z51
  222. C6 Front Bumper Cover Removal
  223. HELP, can't get my C6 auto trans into park!
  224. DIC control lights acting up
  225. Hole in Convertible Top
  226. C6 wiring diagrams or ground locations?
  227. Does a tune void Warrentee?
  228. 2007 A6 with 3.42 Gears Short Video
  229. Apsis' 05-07 Carbon w/Color Match Background *PIC SHOWN*
  230. Dead C6 - Looking for Help
  231. Engine lean
  232. Apsis' 08 Carbon Shift Knob *PIC SHOWN*
  233. 2.5" vs 3" Axle-Back on an LS3
  234. Cruise control studder on downhill slopes
  235. C.A.M lays it down!
  236. What does NPP stand for?
  237. 11.46@122.96, A6, 1.72 on Runflats, cam only....
  238. **LG World Challenge Hood Special** NOW UNTIL MARCH 31st!!
  239. Dyno results from swapping AR 1 7/8" headers for LG Pro longtube headers.....
  240. Just DIY installed BPP Vortex Rammer
  241. Speaking of clutch springs
  242. Can the NPP option be added to an 2008 the way the factory did it?
  243. Who has added an additional garage to their existing property?
  244. Exclusive photo's of the new home of The Vette Doctors...nice digs for sure
  245. how to heat the tires with dr,s??
  246. C6 Tuning
  247. LSx gas mileage?
  248. Center console matching
  249. No hardware changes for A6
  250. First time at track 08 a6 z51
