- are theee the correct headers for my car
- Who sells FAST?
- Lost active handling, telescopic steering
- Power steering fluid circulation
- NPP in a Box or Sunset Creations Controller
- Stupid question: but still need to ask
- A6 Trans operating temp range
- Will C5 Z06 Wheels Fit?
- ???? on changing to ram air induction
- 08 A6 Z51- 3:42 or 3:73 gears?
- Engine Knock
- Fan Settings for Predator and 160 stat
- Apsis' 08 Carbon Speedo Corner installed, *NEW PICS*
- Apsis' 08 Carbon Spoke Cap w/Radio Control installed, *NEW PICS*
- Who knows about pilot sport tires?
- Navigation System Disc Map Update -- 2005 Corvette
- what fuse do i need to remove for diablo preditor install
- Voltage problem on a 06 C6.
- K&N part #
- Exhaust back fires need help
- Wheel & Tire Upgrade
- That 10.92 Bolt On Car....
- transmission soft idle low
- Bake advice needed
- Questions on '06- Z06 Brakes
- 500rpm idle?
- steering wheel shaking
- shocks replacment little help
- Ah! Clutch sticking to the floor!
- clutch issue
- high mileage C6 Z06
- Which inner a-pillar cover?
- anyone running tsp torquer v3 in your vette?
- K&N Filter = HP
- 2007 paddle shifter upgrade to 2008 specs
- Some Quick Dyno #'s on Absorbtion Dyno
- Disassemble ls7 intake
- Front Tires Cupping on Inside
- FUEL EFFICENCY (upgrades)
- Fuel Pressure Question
- Need part numbers
- Wiring for a Miezere water pump?
- Clutch issues (maybe in my head)
- what exhaust is everybody using
- is this a good exhaust system ?
- C6 2pc Rotors
- Consumer Reports Rating
- Exhaust smells in car (???)
- NPP (dual mode mufflers) rattles or other issues?
- How do I check/change my air filter?
- I passsed Ron Fellows in a C6RS on the race track!!! {Video}
- Valvetrain Knock When Warm After Cam Swap
- Exhaust Tips Help!!!!
- Cam packages & valve train increased noise
- F-55 vs Base suspension
- Replacing fuel rail covers on a LS3
- Have anMGW Shifter on an '05? "Shift to Reverse" message is gone??
- Question for Chuck @ COW
- 11.33`s Video and Time slips
- Z-51 Package-Worth the $?
- What spoiler is this?
- Cant Get Car to Start =(
- Upgrading to 08 transmission...
- Apsis' 08 Carbon E-Brake Handle & Shift Knob *PIC SHOWN*
- Has anyone replaced exhaust tips?
- New Rotor and Pad Install Price, OHIO
- If you could do (1) mod ,what would it be?
- Hydraulic clutch fluid
- Intake, catback exhaust(no headers), cam only dyno #s?
- BFG 315 DRs, anyone running these?
- kooks headers
- Looking to install Z51 Sways soon Polly bushing question
- First impressions .... LG Long Tubes Headers
- Smelling strong exhaust/unspent fuel after installing bullets
- Best 05 M6 60' before blowing rear?
- lowering (cutting bushings)?????
- St Pete ALMS In car Video LG Motorsports GT2 Corvette
- Who has the easiest and best rocker arms?
- Best way to remove door panels?
- HELP...Multiple DIC codes
- Need help Car wont start
- Delivered with synthetic or conventional oil
- LS2 Cartek cam runs 11.33
- just lowerd on stock bolts
- Will drilled rotors work on Base C6
- Reduced engine power?
- Help clutch problem C6
- Aftermarket Exhaust Weights? For LS3 MT
- Hurricane air ram Question...
- A6
- B&b Prt
- AT shifting question
- Breathless Performance Party (Thank You)
- Running Race Fuel?
- Does the Corsa X pipe have an advantage over the 2008 GM X Pipe?
- Tire Wear
- Noob Headers Question!!
- Can anyone tell me where the coolant temp sensor is located?
- Vararam and 160 stat install
- L92 Heads, L76 Intake package upgrade
- Comparative DA correction test from AZ to NJ
- Will this work?
- HELP-Nasty Paint Chip in St Louis
- Do Koni FSDS affect ride height
- C6 F55 Brake Pads
- Z51 vs Z06
- Heads Up display error
- Can I bolt on the Z06 H or X pipe and mufflers to a Z51 C6?
- More NPP Questions. . .
- Does anyone have an offroad pipe?
- Injector Clip Release?....
- Questions about LS3 Automatic performance options
- How t0 tell if I have a z51 pkg.
- Honker filter
- Yellow c6rs at St.Pete
- Vibration
- New 07 Goodyear Tire issue
- off road pipe
- ati pro charger
- son of a ......beeyotch!
- keys wont open trunk
- Do I need more than a stock Stall Converter?
- Fuel rail covers with a FAST Intake manifold
- thinking about 08 a6????
- maintenence question
- Tire pressure sensor help
- 160 thermostat
- pass power window
- Radar Detector Cord
- Front wheel weight fell off...long term issues ?
- Possible New C6 Onwner...first mods
- Manual Shifter Difference
- Oil is dark brown: Good or bad?
- New Available GM Parts/Accessories!
- Head/cam results-do they seem low?
- GM Parts House April 2008 C6 Specials!
- Some interesting reading/tech info/findings about utilizing E85/ethanol fuels in a C6
- Aligned my 08Z51 today . . . results and impressions inside.
- Just how durable is the ls2?
- C6 wheel weight/split spoke vs 5 spoke
- how much slower is a c6 coupe with the top off?
- Lingenfelter Head & Cam package results
- Bilstein HD or Sports for street driving???
- Callaway C6 Honker on LS3
- Aftermarket tune vs Warranty
- Retro '08 OEM Non Nav Radio into an '07
- Sway bar installation - torque setting
- Gear Shift lubrication
- First impressions...3.90 Gears
- Quick question on a 2005 C6 (looking to buy)
- '05 differential upgrade
- New PB - Auto LS3 - 402whp - 11.6
- what drag tires will fit a Z with StopTechs 14 inch
- Check engine light
- Stock muffler/tip replacement options for A6 vert.
- 2008 Z51
- NPP Sound Tuning......The 3 bears approach...>>
- "New APR Product For Your C6 Corvette"
- #### St Jude Auction #16 Be Cool....Dewitts Radiator for C5/C6 ###
- oil check question.
- Would you consider a 'Mild to Wild' switch as 'still stock' on an NPP equipped car?
- help
- Tune needed in Denver Area
- RP or Amsoil, best mn6 cold shift remedy ?
- Fuel Octane for LS2 vs LS3
- Opinions on B&M 70297 Tranny Cooler- electric fan style
- Idle ground speed?
- LSX Crank Bolt Pattern
- Sewing machine
- Clutch questions
- Corsa vs. Borla
- Stage 1 tune from CAM!!
- Cam Review on C6 (Comp vs Crane)
- Kooks vs LG Headers
- Cats
- rear hatch button
- Whats the largest Tire for 07 C6
- Steering wheel groan & shudder ?
- Can you Tune a Car with an MN6?
- What's the best bang for the bucks mods for Auto Tranny 2005 C6 vette?
- 454"LSX C6 pics!
- Shift Points
- How to safely increasing redline limit on LS2/3?
- Long crank at start and fuel pressure loss
- Another Crystal Red '08 Callaway Corvette
- Brake Pads
- Corsa Sports Installed This Morning! Wow!
- Solved my Ticking noise...
- Headers, CAI and No Tune?
- Question For BORLA Stinger People
- Vengeance Modified C6 Z runs 10s@138mph on STOCK RUNFLATS!!
- C6 Tire brand change Info.
- BPP Vortex Rammer Install & Review
- Probably a dumb question
- GT11 + dual valvespring noise?
- Cartek built 604 RWHP cross country trip
- 12.155@118.11 = Good or not?
- NPP Sounds when open
- Apsis' 08 Carbon Navigator/AC Bezel installed *PIC SHOWN*
- Drive by Wire Solution
- XR Compaison of Stock vs MSD Plug Wires
- Injector size question
- Headers - Coated or Uncoated?
- C6 Guys, St. Louis area.......
- Does Your Car "slide" Also?
- steering wheel radio buttons
- OEM Wheel Painting
- Seal Part Number????
- Looking for Z51 Sway Bar Install Walkthrough
- Oil Filter?
- C6/Z06 w/Nav-Bose Radio/Speaker Mute
- How to get the best 1/4 times in C6 M6 ?
- C6 radiator fan speed
- Dumb Ass Move Of The Day
- RIP: my transmission
- Question about gears
- 17 Sets Of Instructions are On Line
- key fob
- New 46lb/hr Pico Injectors for LS7, L92, L76, LS4
- Tire Size for a C6
- Any crazies here replaced their ls2 for ls3 engines?
- LS3 vs. LS2 MN6 car, z51 gearing vs. base etc?
- Clunk, right rear in my '08
- lighter wheels/tires more HP???
- Hardwiring a V1
- Water hitting the exhaust???
- "The List" & LS2 vs LS3
- LS3 and headers
- *** Hotchkis Sway Bars ***
- Bassani Catback with C6/A6...Any installation/fitment issue?
- Spring Mountain Summer School Special
- New Shoes (R888s) lowered/corner weighted, canyon cruise, {VIDEO}
- B&M Sport shifter installed. Pics inside.
- Dyno Tune
- can tips be changed on npp option
- TPMS programming
- Z06 Mufflers on 05 Z51 M6
- Texas Mile yesterday - Poor 4/5 shift
- Tire psi sensor canister
- SLP/dealership mod WITH warranty intact...
- Weatherstrip Question
- kooks headers with magnaflow cat-back
- sears jack part#
- Will I lose power if I switch from Corsa Sports to the stock catback?
- New PFADT Sport Shocks Available NOW!
- I think I am changing the cam,,,,,AGAIN!
- Anyone have an Exo-Skel for sale? Vendors please help...
- Lowing your car/or raise it?
