View Full Version : C6 Tech/Performance
  1. aftermarket nav system
  2. Will a C5 Z06 Ti exhaust fit on a C6?
  3. ZO6 twin turbo system - new pics and tech info
  4. Help, Anyone!
  5. Recommend Please
  6. Front brake air ducts ???
  7. Apsis' C6 Front Splitter (Z06 Style) Painted Black & Installed, *NEW PICS*
  8. LS3 with NPP want to add headers
  9. C6 caliper question
  10. Question about differential fluid
  11. C5 seats in a C6?
  12. Rear Hatch button / fuse location ?
  13. 415ci LS3 Upgrade - More Pics
  14. 2006 Differential Failure
  15. Z51 Springs Vs Base Springs
  16. ZR1 at Spring Mountain
  17. Traction Control Check Light
  18. Shopdog
  19. Clutch Chattering in Reverse
  20. cams for daily use with stock heads
  21. '05 A4 rev limiter
  22. Supercharging or cam and headers on C6
  23. Homemade powerful Magnetic Oil Plugs
  24. want to give my c6 steroids
  25. Bowmanized Callaway/Eibach coilovers dialed in - happy camper!
  26. Clutch Fluid BLACK After 11,000 Miles...
  27. ran my my LS3 VS. 07 LS2 MOD'ED
  28. Wind diverter for C6's
  29. Frame rail question
  30. my exhaust stinks
  31. will bushingless spring bolts cause A arm damage?
  32. Need Help guys interchangeability of headers from LS2 to LS3
  33. XM add on
  34. c6 scca t-1 z06 fender regulations
  35. Vararam install and dyno tune next Thursday...
  36. Maybe this 08 A6 is quicker that it feels
  37. Aftermarket stereo guys have a couple ?'s
  38. how do I remove the dash corner pillars?
  39. Aftermarket shocks
  40. Corvette Track Days at Spring Mountain Video is up!!!
  41. A6 Tranny cooler
  42. ATTN: People with tunes
  43. Replaced MGW shifter shaft
  44. Need some time slip analysis
  45. Borla Stingers: Sport or Touring??
  46. When changing intake manifold at what point
  47. 415ci LS3 Upgrade - Pics
  48. Best price on fast intake for LS2??
  49. Invite this Sunday Homestead Speedway NASA race & our Z06 Testing
  50. Where can I pick up new OEM NPP Mufflers at a good price (and related parts)
  51. Race Gas at the track??
  52. Diablo2 for 06 07 vettes??
  53. LS2 VS. LS3 Can you feel the Horsepower??
  54. E3 Sparks Plugs performance Gain
  55. Car lifts for the garage
  56. Underneath car squeek, squeek....fixed
  57. Codes and no oil pressure?!!!
  58. Voztech mount
  59. Active Handling Not Working. Fuse?
  60. Mp# Aux Jack For 06
  61. can you change the shift pressure on a 05 with diablo preditor
  62. Lightweight Flywheel HP Help???
  63. Coolant Leak
  64. 2006 Differential Case
  65. 1.8 aftermarket rocker arms...
  66. Mo pics of my 415ci LS3 upgrade in C6 Gen
  67. Is anyone using these ported L92 heads
  68. Norris Motorsports Cam Swap Packages - Starting @ $1595
  69. What is your normal operating temp for A6 transmission?
  70. Won't turn over
  71. K&n
  72. anyone use stainlessworks headers ?
  73. coilovers, spring rate versus wheel rate?
  74. crank pulley flew off tonight WTF!
  75. Exhaust tips
  76. Front Bumper Replacement
  77. Best intake manifold for C6 07 mn6
  78. How much do I lose?
  79. $$$ Join CLUB NAKID for the summer sale and save $$$$
  80. Need info - Instrument cluster removal
  81. Where is the option sticker ?
  82. Are the C6 coupe & 'vert chassis identical?
  83. Apsis' C6 Z06 Style Front Lip Finally Done, *NEW PICS*
  84. Relationship between weight and 1/4 ET
  85. Bellmore, Long Island tonight
  86. LPE heads for my C6A6
  87. Plating Gurus: Question about Chrome Plating Rear Sway Bar!
  88. Got my dynojet numbers yesterday
  89. Stock lifters - prone to failure with big cams?
  90. oil cap missing-any damage?
  91. I like all stock but...
  92. Question about new breaks
  93. Install ?s onZ06 mufflers on '05 6MN
  94. B&B Bullets
  95. Question about headers and exhaust
  96. Aftermarket exhaust?
  97. Procharger Temps.
  98. HUD wiring in 1LT
  99. Oil Overfull
  100. New grill with front license plate...
  101. Brake question
  102. Exhaust Cut-Outs: Will they affect my Cam/Tune?
  103. Need to hardwire a V1 (non-Inviscord)
  104. What mods would you pick for an Ls3 and $5k
  105. Setting up Comp Cams Roller Rockers 1500(T & D)
  106. Installing a ProCharger.....
  107. video 08 z51 mn6 vs bmw 335I
  108. Brake Rotor Question
  109. 10.901 NorrisMotorsports C6 A6 S/C
  110. MGW Shifter Price (George)
  111. MGW Gives Me Hope!!
  112. Installing Exhaust
  113. new pb bone stock 08 Z51 mn6
  114. Coupe Proximity Sensors
  115. tach wire, tps wire on 2006 vette
  116. C6DVL and the vacation
  117. Need experienced tuner for LG G5X3 cam....HELP!
  118. New C6 scrapes Driveway
  119. Help installing ZO6 pipes on A4
  120. replace front turn signal
  121. A must for ALL 6 speed manuals!!
  122. Apsis' Carbon w/Machine Silver Background, *NEW PICS*
  123. can't get into any other forums.......
  124. Clear Bra installed today......don't like it
  125. Maryland speed shop header special LOL!
  126. adjustable gear set, timing wheel, cam changes
  127. Over axle pipe romoval???
  128. oil pressure ?
  129. Torque Wrench
  130. Is too much oil going to hurt my engine?
  131. ***Ace Slick Wheels***
  132. Crank/Cam Position Sensor Relearn
  133. 6th can really be a gear!!!
  134. Tire size ??
  135. Steady Check Engine Light - Runs Fine
  136. Anyone run the Kuhmo runflats?
  137. Sarasota Bradenton Tune Special!!!
  138. Cleaning Vararam filter at 4500 miles
  139. Flowmasters American Thunder #17427 or Magnaflow 14336 muffler swap?
  140. Best Header and X-Pipe Sizing
  141. thoughts on COW tune on leased Vette?
  142. thoughts on COW tune on a leased Vette?
  143. CHUCK CoW TUNING @ C5 C6 BASH - CORVETTE MUSEUM - BOWLING GREEN, KENTUCKY
  144. Anyone have this setup?
  145. Kooks 1 3/4" Headers Installed...WOW!
  146. Headers or tune
  147. Is it me or what??? Went to the track tonite
  148. 20" Nitto drag radials?
  149. Experts...chime in on catch cans
  150. Best Tire Pressure for HPDE track event Nitto Invo Tires C6?
  151. Stock Ride Height ???
  152. C6 Hood - Painted
  153. Drag guys: what clutch are you running
  154. convert off road X to high flow
  155. Setting camber at home; any help out there?
  156. quareter mile times of supercharged c6's.
  157. Anyone have any experience with VRX cam
  158. Can I extend the wires on our front O2's?
  159. Horn ! Beep beep ! Argh !! 1980 Vette
  160. pics and videos of new race knob from MGW>>>
  161. Headers and Stock exhaust??
  162. Tire question????
  163. Factory Warranty
  164. B&B Fusion owners please respond....
  165. 07 C6 Horse Power & Tuning Question?
  166. Less common/less expensive mild exhausts?
  167. What is a must to do immediatly?
  168. Parts swap from my C5 Z
  169. Anyone who did the Ace Slick+Z06 brake conversion.....
  170. What is involved in changing the valve body in an A6?
  171. Steering wheel spokes replacement
  172. customized muffler
  173. Will Koni FSDs work on a 2008?
  174. MSD Blaster Multiple Spark Coil Kit. what?
  175. Header install C6 07
  176. Engine tune does not void warranty?
  177. Drag Racing
  178. '08 A6 problem
  179. Square bottom steering wheel
  180. Brake Question
  181. What Header is faster in 1/4 LG or KOOKS?
  182. '05 c6 4 speed auto question
  183. Magnetic oil drain plug
  184. What is wrong with my C6 A6?
  185. Aftermarket MAF
  186. FLYCUTMONSTER: making big cams fit with optimum compression
  187. Headers Question, Please Help
  188. A6 converter install
  189. 160 stat question
  190. Burnt oil smell
  191. Need help painting calipers
  192. Need clutch help?
  193. Stage 5 converter
  194. MarylandSpeed.com
  195. Check engine codes, P0894 and P0700
  196. Aux wiring? any easy way like the C5 has
  197. Horn switch
  198. Orange peel on doors
  199. CDNPERF STAGE 2.5, 45rwhp Cam Only!!!!!
  200. Help with selecting Drag Radials
  201. Battery removal on a 2007 Z06
  202. Anyone have a timing belt break?
  203. GM Bulletins
  204. A6 fluid change
  205. Active handling
  206. WTB Used NPP mufflers
  207. 4 Car Length Victory
  208. Anybody need a K&N setup for LS2
  209. Bose System Help
  210. A Vararam must read
  211. Engine Experts, ideas
  212. SLP Loudmouth
  213. Oil in intake manifold
  214. need help with GM direct dot com
  215. Would a pipe expander work for this
  216. Trying to make 500rwhp
  217. Z06 type fenders for a 2006 C6 convertable
  218. Idle speed control valve?
  219. Just installed Corsa Sports
  220. Z06 MAF Sensor???
  221. Best Duster ever for the interior
  222. Euro Taillights
  223. How Difficult
  224. MGW standard shaft thread size & '08 chrome ring
  225. Need replacement tires for 06 Z51
  226. C6 mod's - opinions?
  227. can i just replace my mufflers?
  228. Bbk Headers And Cats For Less Then $500?
  229. What do you think my car would run??
  230. Brakes make high pitch squeal
  231. Signal light double time
  232. Supercharger kits for 08?
  233. LS3 Vararam Question
  234. 425 RWHP C6 A6 with a set of AFR's
  235. 425 RWHP C6 A6 with a set of AFR's
  236. FINALLY, good numbers..
  237. first run 08 z51
  238. Vararam Installation????
  239. Popping noise from coil overs...?
  240. Looking for help?
  241. Direct Port Nitrous
  242. Has Anybody Done the MGW new shaft mod
  243. Got My Wheels!
  244. Apsis' 08 Carbon Stick SK Top Cap installed, *NEW PIC*
  245. Apsis' 08 Carbon Push Button Opener installed, *NEW PICS*
  246. Any Performance Added Value
  247. [3.90 vs 4.10] First drive comparison
  248. alternator removal, help!
  249. R&R Radio fuse for Predator, now radio is dead!
  250. Mods and Warranty
