View Full Version : C6 Tech/Performance
  1. Paddle shift auto
  2. will corsa sports from a standard car fit a auto ?
  3. It's Time For The 4.10 Gears
  4. What is this piece from???
  5. High Speed "Active Handling Activated"
  6. Injector question and fittment issues
  7. 12.47 LS2 with minor mods
  8. Searched but can't find (Stock LS2 head flow numbers)
  9. Newb seeks assistance with first round of mods
  10. Clutch contributions to 1/4 mile runs
  11. EXHAUST Aftermarket/factory warrenty
  12. Need Help With Replacing Wheelhouses
  13. rear main seal leak
  14. Help: found fluid on plastic radiator shroud
  15. Water Temp Guage Suddenly Not Reading Water Temp
  16. Installing Z06 Brakes
  17. Check out the new Genuine GM two-tone shift boots/knobs!
  18. 2008 Crystal Red Carbon Fiber Center Console Anyone?
  19. GM Parts House May 2008 C6 Specials!
  20. Tire Pressure Sensor all scan except RR???
  21. LGs + tunnel plate + rear O2s = Bonk! (pic)
  22. New Vararam Model/Improvement Coming Out?
  23. ?? Variable Assist vs Understeer
  24. Batter cover for Optima Red Top?
  25. Need an axle back recommendations.
  26. LS3 Cam question
  27. Computer reset??????????? Help!
  28. Best Streetable Cam w/ Stock Heads?
  29. Apsis' C6 Side Air Vent Most Update, ONE BIG STEP FORWARD!
  30. gas/dead pedal
  31. Got my Hotchkis Sport Sways, Hole setting question?
  32. F&R Z06 Spring install....How to?
  33. BFG KDWII's - Noisy?
  34. Digital Torque Wrench
  35. Why OEM coils are the best
  36. My New Best!!!-11.39 @122.5
  37. How to for removing Intake?
  38. Pictures of LG Motorsport Project "JMAC"
  39. RevXtreme A6 tune
  40. Urgent! Please Help.
  41. Going Drag racing -Need ice?
  42. Brighter back up lights?
  43. Z06 Calipers
  44. For the money, what do you think is the best intake?
  45. Best bang for the buck mods for 2008 BASE MN6?
  46. **ECS CAM ONLY = 10.845 @ 128.58 C6 DVL lives on **
  47. PS2 Question...
  48. How To Take Screen Off Of Maf Sensor?
  49. Front end Alignment
  50. Do Z06 fender&1/4 panels bolt onto a C6 Vert?
  51. A4 torque converter, stall Vs stock, procharged A4
  52. FYI: Vararam Improvements
  53. 2005 Corvette body fastener help request
  54. The Answer for SCCA Super Stock Sway Bars
  55. Paging Talon help !
  56. Need help urgent for nav istallation
  57. Fire Extinguisher Mount
  58. ?? for suspension guys
  59. Cammed LS3 #'s are in...
  60. Best forum seller for LS3 Vararam
  61. vette-air/k&n combo on a ls3?
  62. Cams
  63. Opinion Needed about "Sticking it to the Ground"
  64. GM Denying warranty Claims
  65. Underdrive pulley
  66. yella terra ultralights help
  67. 05 c6 grinding noise
  68. mods and warranty (non drivetrain)
  69. ***New ForgeLine Wheel*** From LG Motorsports
  70. 08 6 speed roughness from 1-2-3rd gear
  71. Rebate Check Sale...Please Read Inside!!!
  72. A Tuneup or Predator Tune?
  73. Installing different lifters and Rockers...would push-rod length change?
  74. Interested In A Chuck Cow Tune In Kentucky Again
  75. Excellent Tech Articles on L92 Heads
  76. Headlight Problem
  77. Just installed C6Z front spring
  78. When you have a tune?
  79. Gears - One Last Debate before Spin Leaves
  80. Help with Lowering the C6 - Having New Tires Installed Today.
  81. Display on GPS/Radio...
  82. z06 brakes and oem c6 wheels
  83. Am I going to need a tune?
  84. What Is the Best Way to Install Fuel Rail Covers ,
  85. When to change plugs and what plugs??
  86. Reset oil monitor
  87. flashing HVAC display?
  88. Ace Slick Wheels VS Factory Repo
  89. Quick Corsa / Stock Exhaust Question
  90. NPP dyno question??
  91. How much to insall gear set and output shaft?
  92. On dyno's, what does smoothing mean?
  93. traction control
  94. LS7 Exhaust block-to-manifold gasket puzzle!
  95. 14" rotors on stock 18x8.5" front wheels
  96. Who sells the best cam for a c6 a4
  97. Must Read For All Corvette Owners
  98. Dyno numbers what do you think
  99. To all the Vararam haters...
  100. Callaway 580 hp Vert! Will it be worth it?
  101. A6 with 3:42 gears?
  102. Is A HUD Display Viewable On A Non-HUD Windshield?
  103. NGK Iridium IX TR-55IX Spark Plugs
  104. 2008 Stock Intake w/Vette-Air VS Vararam
  105. MSD coils installed
  106. Need Help.......
  107. Dart is sold and the C6 is for sale....any last DIY requests?
  108. Need help with PO 300 code
  109. Question: High Flow Cats
  110. Can anyone tell what Bellhousing this is?
  111. Fresh Dyno #s!!! 762.9 RWHP (Video & Graph)
  112. Z51 Brake brackets
  113. Porting a Throttle Body and Intake?
  114. Question about installing AVIC D3 with bose.
  115. People that had torque management reduced
  116. Oil drain plug help!!
  117. I-Charger ? Anyone heard of it ?
  118. legenfelter intake for LS3
  119. Roof Leaking
  120. Breaks Squeak
  121. How many rwhp with these mods should I expect?
  122. CEL and DTC U0001, Weird Electrical Problems
  123. Ported Throttle Body
  124. Has anyone put Z51 springs on a F55 car?
  125. What Drag radial size??
  126. Question about Gas Cap
  127. Any Good Tuners In Kentucky
  128. dic battery voltage question: logic behind behavior
  129. Problem with brake/rotor?
  130. New from 'Hidden Bolt' Option from ForgeLine and LG Motorsports
  131. Fluid Leak
  132. Convert 08 A6 to F1 style paddles
  133. Fan setting for 160 stat.
  134. Need Diagram for 06 PCM.....
  135. Can 09 Bluetooth be fitted in 08?
  136. Fuse for NPP exhaust
  137. Best Headers?
  138. Jesel
  139. Official word on Firestone Wide Ovals?
  140. Caliper powdercoating and system bleed
  141. Good Tuner/Mod shop in Phoenix, AZ area
  142. *** Chuck CoW's MAIL ORDER TUNING available to ALL! ***
  143. american thunder
  144. *** How to make your A6 Corvette AMAZING! ***
  145. Changing Stock C6 exhaust to Z06?
  146. koni fsd or billstein sports
  147. Why won't my parts play nice?
  148. LS3 Intake question
  149. My Lingenfelter 403
  150. Tuner question?
  151. What compression does LS2 have stock?
  152. Best replacement tires for my C6?
  153. Chrome wheels. East Coast vs West Coast?
  154. Looking at the corsa axle exaust What cha think??
  155. Top Speed w/4.10's
  156. cuotut rattle
  157. please post obd instructions
  158. Delayed acceleration update
  159. base suspension upgrades
  160. Trick Flow Heads vs AFR
  161. Which NPP contoller?
  162. Finally....402/407 at the Wheels
  163. Rear 12v hook up
  164. Best Street & Track Pads ???
  165. GM Performance exhaust
  166. DOT5 ok?
  167. Is there any way the date a tune was done can be detected.
  168. For an A6 are Headers worth it?
  169. Need Help! Removing stock C6 Exhaust Question
  170. Stored c6z 2007, (7 mths) cannot start car.
  171. Help location XM on 08 with nav C6
  172. WOW ... Mich PS2's
  173. Help!! location of XM Box
  174. Vararam Question!!!!!!!!!
  175. Water leak with Corsa Catback
  176. Yet another Vararam install question
  177. FASTintakeMonster....DIY intake manifold swap without cutting the firewall
  178. Underhood Light Switch?
  179. Front brakes on the Rear??
  180. Tire pressure sensors
  181. Diablo Predator
  182. Are 08? polished and chrome wheels the same
  183. Hey Elite Engineering!
  184. E3 Spark Plugs
  185. How Much Would It Cost To Install Fast Intake///
  186. Z06 Oil Change
  187. Problems with door and window?????
  188. Clunking noise first thing in the morning
  189. Exhaust Smells Inside Cab When Flooring Accelerator
  190. Wheel Alignment Policy?
  191. Double Clutching
  192. Specs of LS2 Stock Cam?
  193. Can someone please help me understand pulling timing ?
  194. thinking of a cam for a a4
  195. Bigger Fuel injectors
  196. Broken Axel
  197. Paddle Faddle
  198. installed vararam p.o.s.
  199. Headers and air intake ???????
  200. Apsis' 08 Carbon Instrument Cluster, *NEW PICS*
  201. Livernois Motorsports C6 Head/Cam Package Special
  202. ATTN: AutoXers and Road Course Enthusiats! Need Help with Alignment Specifications
  203. C6 Throwing Codes P0135, P0030, P0053
  204. Spring Exhaust Sale @ MarylandSpeed!
  205. Help on tires for C6 with Supercharger
  206. ***Latest video Long Beach Corvette GT2 incar LG Motorsports
  207. Anyone have a P0449 code?
  208. How Much Gas for Drags?
  209. Clearing up misconceptions with the PCV system
  210. C6 Melted Tie Rod Ends Problem. Denied Warranty Claim
  211. synchronic bov's
  212. Just washed car - odd tire noise from the valve stem area?? not a leak though.
  213. STS TWIN TURBO KIT vs APS TWIN TURBO KIT
  214. Prep for drags question
  215. High flow replacement cats?
  216. GY warranty
  217. Stock Wheel weights
  218. Gettysburg PA Tune and Port Session 5/9-10, 5/12-15
  219. Paypal stinks
  220. The challenge... can it be done..
  221. LS3 catch can hose connection
  222. Are the springs in a F55 car the same as the base suspension?
  223. Just installed Z51 sway bars on my F55 car
  224. Removing center console bezel
  225. Exhaust change on Race Ramps
  226. help: which cam best for stock head
  227. leginfelter intake
  228. Cause of 'Service Traction Control' on DIC?
  229. Is This Normal?
  230. invisible bra installer in ST Louis
  231. Scraping in turns
  232. Too Cat or not Cat that is the question
  233. Cutting out the screen for the M.A.S.
  234. jorgens products
  235. 415ci LS3 Upgrade - Dyno
  236. Where should I order Z51 springs & sways? What parts do I need?
  237. Non XM radio IPod connection for C6 2007
  238. Question??
  239. Airbag light coming on
  240. Nav to 6 disk radio ???
  241. lowering 2005 c6 on stock bolts
  242. C6 Navigation System Manual
  243. C6 Glass Top Noises
  244. LS3 / LS7 Based 427 - What are the Differences?
  245. Callaway GT3, GT4 Racing at Silverstone
  246. 415ci LS3 Upgrade - Video
  247. cold air intake and code p0175 (rich) c6
  248. HELP... Interior Mirror's Lights Stay On ... HELP
  249. 08 manual trans grinds the gears
  250. Weight under 3100
