View Full Version : C6 Tech/Performance
  1. nevada race
  2. 2006 C6 Z06 seat info
  3. Guys with the Vararam QUESTION!!!
  4. Cartek Track Day!!
  5. Question about Vararam (or other similar intakes)
  6. Predator and new intake installed !!
  7. Atlanta Area events this weekend (may 17)
  8. Brake Bleed screw location?
  9. Who's running the Comp XER 224-230 Cam?
  10. Texas Motorlex in Ennis is having a Test and Tune and Dyno Special
  11. Z51 6spd with gears? Anyone done it?
  12. Heads only
  13. Textralia OZ700 X-Grip clutch problem
  14. brakes issue
  15. Video: ZR1 at 205 MPH
  16. Spin-fast 92
  17. Vararam input
  18. Water Wetters
  19. Breathless Performance "We are doing it again!!! Big Party"
  20. Another MGW Shifter Installed, Very Happy
  21. replacing keyfob battery
  22. Z51 Supercar tires- Are they nondirectional?- Mounted backwards
  23. Video request - American Racing headers & bullets
  24. Video request- LG Headers + NPP Exhaust
  25. Thanks to Rick @ Synergy my car is now ALIVE!
  26. Help on diagnostic codes?
  27. LS3 Knock sensor torque ft lbs??
  28. Best Stainless brake lines?
  29. Tire Pressure Monitor swap
  30. 2005 A4 - Harsh 1-2 shift
  31. Question at Installing Halltech Ram Air
  32. Special Accessory Sale!
  33. Navigation system upgrade DVD,s
  34. drilled and slotted rotors
  35. Firestone Run flats
  36. Any news on FAST for LS3?
  37. Checking A6 Fluid Level
  38. Fast Vs. Ported
  39. Active handling problem
  40. What Size tires do you have?
  41. help - '06 Z06 grill re-install
  42. HELP!! Transmission Problems Again
  43. LS3 mild cam/UD results
  44. Painted intake manifold??
  45. anyone else have issues with NPP exhaust soot
  46. Taking Advice on Mods; planning your own path
  47. Powerlabs hits the dragstrip for the first time... Comments please?
  48. Exhausting
  49. Got my 3m Invisguard installed yesterday!
  50. Voiding GMPP
  51. Piller pods
  52. A/C queston about r134
  53. Question about water temp
  54. '06 Brakes has Serious Squeak Help!
  55. Any benefit to swapping 07 h-pipe to 08 x-pipe?
  56. Widening a Cray Scorpion 1/2" to fit 325s?
  57. Autocross
  58. Brake Fluid help!
  59. Is This Right?
  60. Basic question about tuning
  61. Z06 Wing
  62. Z06 Wing
  63. Upgrade advice?
  64. bulb change on map light
  65. Does anyone have a close up picture FAST90/92 MAP sensor relocation w/ Spin Firewall?
  66. GHL Exhaust!!
  67. Installed pics of new Hardbar/Penske coil-overs
  68. Stock Zo6 Headers on LS2
  69. ZO6 front and rear wheels on C6 coupe???
  70. Park Switch
  71. Filling-the-gastank problem?
  72. What kind of paint for wheels?
  73. Headlight Aim Question...
  74. simple question about disconnecting car batteries
  75. Vararam on Sale @ MarylandSpeed - Lowest Prices Ever!
  76. 08 C6 shifter
  77. Problems at the track with A6
  78. Autocross Advice Needed
  79. Halo Bar Removal.....how?
  80. New Tires??
  81. Bad O2 sensor?
  82. Hey C6 Manual tranny owners, have you seen your clutch fluid lately???
  83. Want to get 19/20 but tire question??
  84. expectations with modifications
  85. First time at 1/4 mile
  86. C6 Issues?
  87. What is the best brand of 160 degree thermostat?
  88. C5 vs. C6 rear differential
  89. C6 Dimming Mirror Lamps & Hatch
  90. PCV Catch Cans Work!
  91. Exhaust Question
  92. Alignment, acceleration and road groove problems
  93. Need to replace battery, any recomation's?
  94. CD player will not play any the songs past song number 5?
  95. Manual Vs. Auto Trans
  96. LS2 Port Works Sale (Ends Sat May 24!)
  97. Help with a 427 Stroker Kit for a 2008 LS3 A6
  98. AHS in Comp mode = faster??
  99. my LS3 Dyno b4 & after
  100. ZO6 wheels on C6
  101. 2009 new steering rack
  102. Trouble finding were to install the skip-shift.
  103. T or F-- engine braking is bad??
  104. Finally Some Traction!
  105. A 2008 Callaway Corvette
  106. Please help me fix what I messed up.. Agh
  107. Retune??
  108. Over Speed Warning
  109. Computer Codes
  110. Engine Mods
  111. check engine light on
  112. all right experts its your time to shine
  113. B & M shifter
  114. What to do next?!
  115. Noob question about manual shifter
  116. Vehicle Inspection Not Good
  117. Looking for headlight wire under the dash
  118. 21CMC15 Camshaft w. 92mm FAST results
  119. Do You Know How Old Your Tires Are?
  120. instructions for taking out headlight assemblies??
  121. Is Chuck CoW coming to Texas this month?
  122. Check engine lamp
  123. 08 zo6 quarter mile times stock??
  124. HELP!!! Vararam Install / Performance Questions
  125. New Setup.
  126. ***OFFICAL LG MOTORSPORTS / JMAC RACING RELEASE*** Specs and Pictures inside!!
  127. Z51 Sway bar install done
  128. Wiring a Electric Cutout on a C6??!
  129. 1/4 racing***Timeslips,Video`s,Pic`s***
  130. German Castrol 0W30
  131. As Seen on 20/20 Tire Age?
  132. What to expect on the dyno from an LS3??
  133. Cruise Control Quit Engaging?
  134. Apsis' C6 Instrument Cluster in 08 Carbon Will Have Price Increase, *ORDER NOW*
  135. All-new shifter for C5 & C6. Now available.
  136. Z51 Guys is there an improvement with Hotchkis swaybars ?
  137. Fully Built A6 Transmission!!!
  138. Mgw Shifter Fiiinnnaaallllyyyyyy Online!!!!
  139. Kooks LT headers installed this week
  140. Lifter Noise on Start Up - 17K Miles
  141. Convertible roll bar?
  142. Advantages of A4 over A6
  143. Proper Voltage?
  144. 08 A6 back from the track not so happy
  145. 10% Off Sale Extended Through Sunday!
  146. How much lighter is the Z06 Magnesium engine cradle
  147. Can we fit Hoosier 295/30/19s?
  148. A6 swap into an A4 Car
  149. Nitrogen fill for stock run flats
  150. help my car wont start after restoring stock yune
  151. Ways to increase horsepower?
  152. Turbo guru's come in please
  153. Chuck CoW to Boston MA. in July
  154. 327 153 tooth flex plate or 168 question
  155. CEL code 0124
  156. Need Help Asap...look!
  157. GM Accessory Console Lids Available Again!
  158. New GM Accessory Sill Plates Available!
  159. performance intake manifold
  160. Check Engine Lite ....
  161. Does the A6 trans downshift when you kick it in paddle mode?
  162. C6 Fuel Tank Removal
  163. Oil wieght?
  164. Apsis' Poll: Are you interested in Carbon Hood?
  165. Apsis' Poll: Are you interested in the Carbon Roof Panel?
  166. 180 degree T stat from Hypertech
  167. X-Pipes??
  168. Lexington Ky Chuck Cow Tunes Totals 8 Now
  169. C6 Tires..is larger possible?
  170. BF Goodrich Drag Radials - Whats UP?????
  171. New best 11.0 at 128
  172. Front facia extension removal
  173. TPMS 2006 vs 2008
  174. Anyone have a roll CAGE?
  175. Tire and Sensor Questions...Please Help
  176. Anyone run at Ennis? Need info please
  177. 0 to 60 best time for 08 coupe?
  178. 9.5in wide x 19 front rim any one running a 285
  179. Went to drags tonight 08 A6 Z51
  180. B&B Bullets LS2 vs LS3
  181. Removing computer programs
  182. Cartek
  183. C6 z06 brakes and aftermarket z06 wheels question
  184. Engine oil analysis
  185. Pass Time
  186. Who Is Using Ngk T6. Advice
  187. EFI Live vs. HPtuners
  188. Source for 18x10 and 18x11 wheels
  189. How much fluid goes in a 2007 Z51 Manual tranny?
  190. GM Exhaust systems
  191. Tire Pressure Sensor re-set device
  192. Service Tire Monitor ???
  193. C5 mini-tub vs C6Z rear wheel offset...
  194. K&N filter problem
  195. NPP Converstion
  196. Help confirm suspicions- bad CV on axle?
  197. Glove Box Removal ?
  198. RWH/Torq vs. Crank
  199. Rear part numbers
  200. Anyone running a 3600+ converter in an A6?
  201. Wheel size Question
  202. Using drag radials for first time
  203. Amsoil... is it worth its weight ?
  204. 1/8 racing***Timeslips/Video`s***
  205. Hydraulic lifters and redline
  206. PS-2 Michelin Track Pressure Recommendations
  207. What clutch fluid are you guys using?
  208. Inspection?
  209. Removing stock Mufflers on 07 C6
  210. ?? Removing the lower rear bumper insert??
  211. Z06 Front Brakes
  212. Wiring Connector plugs, esp. for c6 horns
  213. is this normal
  214. Looking for a vette tuner in Seattle / Tacoma area
  215. Header Installation - Question
  216. Fuel injectors for ProCharger LS2
  217. Don't Buy Ngk Tr55ix Spark Plugs
  218. 08 exhaust question
  219. Codes
  220. Stealthy Cam For A6 ???
  221. Belt Replacement
  222. 2 PCMs
  223. door problem
  224. KDW2 vs Nitto Invo?
  225. "UPSHIFT NOW" Displayed in DIC
  226. Are C5 and C6 HUD Projectors the same?
  227. Kooks 13/4" Installed With Ngk Spark Plugs
  228. Mgw Shifter.....wow.....
  229. heads/cam choice?
  230. newbie needs supercharger advice....
  231. tunnel plate
  232. Tech2 in NorCal? Need to turn off F55
  233. Remove Console?
  234. Parking Brake removal
  235. Ranger clutch fluid how about brakes?
  236. O2 Sensor help
  237. Looking to do gears
  238. Anyone know how to R&R Rear Wheel Bearings
  239. HELP, I won´t start ´05 coupe auto
  240. C6 ZO6 door won't open
  241. Airbag Seat Sensor Q?
  242. Idle clip of my cammed LS3
  243. Stainless Works exhaust system?
  244. Back from the 1/4 (stock 08 Z51 A6)
  245. MAF Plug Exchange
  246. Lost forward gears in 08 A6
  247. can you have just one?
  248. check engine light on even when cars off
  249. Review: Apsis Z06-style splash guards
  250. Installed my Ipod...pics!
