- can u help?
- Racing in D or racing in S
- Time Slip!!!!! Thank You Cartek!!!!!!!!!
- Which header & how much hp to expect?
- More Money Equals Better Automobile Or
- C6 Gauge Cluster Wiring Diagram
- What rims/tires(drag radials) are you guys using at the track ?
- Poly engine mounts?
- Victory Red C6 w/ Black or Grey Wheels
- vids of cam/headers idle & M2W switch
- Who makes the best oil catch can for the money?
- LS9 info
- Too hot?
- Looking for shop in New Jersey
- clutch spring?
- C6 with muffler valve option ???
- I need a little extra kick
- STS Turbo Systems in Utah. Anyone dealt with them ?
- Chuck CoW TUNING - ORLANDO, Florida - JUNE 5 & 6
- Fob
- Question on Magnaflow's
- interesting wiring harness issue T.S.B.
- Corsa Xtreme Feedback
- How to strip painted OEM Speedline wheels?
- Rear Bumper 74 ?
- black c6 with competition gray wheels
- installing now need help
- need radio help
- 160 thermostat
- Fan trick for the C6?
- Fixed the radio problems in my brothers C6 this weekend.
- Does anyone have a spec clutch kit installed
- Just Finished 160 Stat Inst. --- What Fan Settings?
- Ported & Polished LS2 Heads
- Tire question
- Trans mission drain plug
- Paint code
- How much does a dealership charge for ....
- And On The 6th Day It Was Sold - Corvettes of Dallas
- service charging system soon warning
- How much to do gears on an 05 coupe?
- Wheel weight lost
- C5 catback on a c6?
- NPP Controller
- Complete ZO6 exhaust A4
- I am really excited about my car's transformation...
- valentine remote
- need help with HP Tuners..please
- Matching leather A-pilar pods
- Locked PCM question?
- can you demo your BORLA or CORSA exhaust system?
- Squeeking noise when cold
- Help w/ Alpine HeadUnit IVA-W205
- Traction Control Won't Let Car Go Over 140mph
- 1st track day
- No A/c On This Great Wkend
- Anyone widen stock C6 wheels?
- z06 brake lines for regular c6, also DBA rotor questions
- Too much Exhaust noise
- red drops on garage floor
- Run Flats
- I need help with these Doors and or Fob
- Which side is o2 sensor BANK 1 ?
- Corvette Shops in NY
- oil temp c6
- Doors will not open!!!!!
- Ported FAST + Ported TB + No Tune = CEL?
- Vararam Quality -- They need to do better
- Question About Spark Plugs
- MGW Shifter Question -- 2008 C6
- what is the gearing in a base versus a Z-51?
- What exhaust would you use
- Vararam Z51 Condensor Bracket
- Why a 160 deg Thermostat?
- oil drain plug question
- Bleeding my clutch
- Leaving car oil free over night...any danger?
- Tire pressures for larger sized tires
- Starting Problem
- Both fast and ported intakes seem great but couldn't you.....
- Spin to tune my 07 C6 tonite
- my car makes a clicking sound when i turn left
- Any reviews on Pfadt Street Sways?
- Any ZO6 Owners using the Corsa ZO6 Exhaust?
- Need some advice on mods for C6 A6
- exhaust tips on NPP
- New Jersey - Anyone have BB Route 66 or Corsa Touring Exhaust
- i want to paint my calipers........info
- Time for my first oil change, what do you guys recomend?
- 3 radios later and still not fixed!
- New Best 1/4 NYIRP***Timeslips,Video****
- Dash Removal Help
- Rear End Clunking And Rattling Repair Info
- 2008 transmission troubles
- Installing fast 92 help!
- Navigation thru HUD problems
- Some BB Bullet Questions
- Intercooler for maggie
- Need instructions to remove base seat covers
- How Many Miles Between Oil Changes ?
- My 08 - Way to quiet, who's got best prices and whats loud!
- Does Lingenfelter have their own people that tune?
- Official Exhaust Thread!! Post your Setup, Likes/Dislikes!
- High auto transmission temps?
- Callaway has the 2008 magnuson S/C
- Twin Turbos?!?!?!
- Name that part.
- Mustang dyno help
- Idle adjustment on a C6 LS2??
- DMH Performance Low Profile Cut Outs Now Avaliable @ Corvetterecycling.com!
- I think i've picked out my intake & headers, expected gains w/o tune 08 LS3
- do I need a new clutch?
- B&M or Hurst short shifter? C6
- Window not indexing
- How can i turn my fan on at 160-170degrees
- Tranny swap, can I and who will do it?
- two round springs fell out from under the dash
- wheel spin with AHS on??
- Help....car was tuned then started ticking
- Engine building at EPP
- Vararam Green filter question
- A question on brakes
- Traction control button doesn't work
- BoostMonster: H/C car gives up the juice for a little boost
- Nitto NT-01's
- H/C vs. FI
- A/C compressor - constant HP draw?
- Hawk HPS versus Wagner Thermoquiet Brake Pads
- I need a performance shop in PA to Upgrade my ls2 motor in my 07 vette...Please help
- buzzing sound from center dash 08 coupe/bose /nav
- Vararam Installed! Results!
- Do they sell the Bi mode exhaust ......
- VARARAM question - air in air out?
- Wheel spacers?
- How much more horsepower?
- I'm in the middle of installing the Vararam...easy question!
- RPM dip/power steering loss
- Corvettes of Dallas "signature series" twin turbo 001
- K&N Intake Problems?
- nav question
- Best Georgia Shop For Suspension Upgrade
- Help Needed With Z06 Brake Rotors and Factory Brake Pads
- Does anyone have the TSB handy on the clunky rear-end issue?
- Mis-Fire I Can't Identify
- Corsa Xtreme
- DTE - 3.15 gears - thanks Phil
- differential clutches 2007 z51
- What gains from 3.42s to 3.90s?
- wheel widening???? anyone in NJ
- Need part number for fender vents
- ABS malfunction
- Funny Electrical Problem - Window Indexing
- Navigation Help!!
- C6 LG PROS Now Available Special Pricing
- FAST 90 vs 92??
- HP and exhaust systems
- Wild to Mild switch
- Z06 front brake vents or ducts part numbers?
- Question for those that have ordered Kooks headers and midpipe....??
- Highway engine rpm numbers for an A6 with 3.42 gears
- Oil cooler question
- LS3 in my 2005 Vette?
- 05 wnt start and wont shut down...
- Will C6 Blackwing fit a LS 3
- LS3 header consideration, guys with dyno data please chime in
- installing braided steel brake lines
- Can the 2008 Z06 Fob be used with older C6's?
- P0050 P0064 codes help please!
- SLP Loudmouths
- Automatic Supercharged corvette questions
- G Tech SS
- Anyone added Z51 Coolers to '06 non Z51 6 Speed?
- Firestone / Firehawk experience anyone ?
- Don't Buy Pulstar Spark Plugs
- Normally I dislike 'how fast will I run" polls...
- Marker / signal lite problem
- Top not secure
- Say it ain't so, Z51
- Wax Finish On 07 Vert Monterey Red
- What tire pressure do you keep?
- Piston Slap Question
- Help! Is this a Z51?
- B&B Bullets in PHX area to listen too?
- C6 Front Bumper Cover
- Need help with Vert top
- FM Antenna Location
- Exhaust question for northern New Jersey vette owners
- Help! rear hatch opens when I open drivers door
- oil wear monitor question
- L92 on LS2 Cam question
- 0 oil pressure on startup
- Programmers cannot read my car...HELP PLEASE!
- Question for Tuners? Or anybody?
- 2008 Z06 Exhaust
- What gas do you use?? Sunoco?
- Biggest rear tire that fits on stock 19x10??
- Tpms Help
- SLP Loudmouth Weight
- 100mm Throttle Body C6 Z06 Dyno
- Those who have Kooks longtubes, questions..
- Cam only Ls3
- paint question
- Z51 Package includes?
- changing my brakes
- redline D4 or D6 ATF on A6 tran
- Tire shop recommendation in Savannah, GA?
- k&n with vette air versus vararam?
- How to launch a Z51 manual
- I am new here ,hope i am doing it rite!!!lol
- Brake Pad Replacement?
- any good shops in phoenix area ?
- Harness Bar and Harness Suggestions?
- dealer verdict on acceleration issues
- I need cam suggestions... STS Twin Turbo Kit.
- z06 brakes for the front c6 Z51 ??????
- z06 exhaust, manual vs. auto fit?
- Tire pressure question
- bogarts on your c6 step in
- Car won't start at times
- Stock 08 LS3 A6 dyno #'s within.
- Militec - Anyone have any experience?
- Exhaust cut outs?
- Picked up a 05 c6....problems
- Anybody using Patriot Gold Extreme Dual Springs?
- Vengeance Racing Cam/FAST/Exhaust Dyno
- Maggie and SpinMonster do the Dance
- Z06 Oil Cooler bolts right on to LS3/Z51 oil lines!!!
- Ponch does 10's and conquers Sealy
- New Best Pass...Timeslips
- The right Heads and cam
- LG Motorsports
- can someone help me with this problem on my car please
- ECS, again
- Drag Racing suspension upgrades?
- Nitto Invo VS Goodyear Run-flat
- Bought a Vararam - should I be afraid?
- What's your opinion about ceramic coating headers
- What's your opinion about ceramic coatint headers
- Mickey Thompson Drag Radials
- Any All Motor C6's in the Mid/High 10's or better
- Chuck CoW is in DALLAS, TEXAS TODAY!
- Instructions for changing c6 brake pads
- computer and exhaust system
- Question for the transmition experts.
- Where Is Chuck Cow Now?... I Know Where He Will Be!
- I Need MORE POWER! PLEASE HELP!
- Where is the 650 rwhp NA
- 08 mods
