View Full Version : C6 Tech/Performance
  1. Invite to all Breathless at NASA Road Race event at Sebring International Speedway t
  2. What wheels work with big brakes?
  3. The 1st Day Of Summer And Had To Put Vette In The Shop
  4. C-6 exhaust
  5. Awesome Car --> 1.26G
  6. Employee Pricing Is Back!
  7. Beware: Anyone with Fuel Gage Problem
  8. c6 wheel/tire size questions
  9. c6 wheel/tire size questions
  10. Pulls to the right after alignment x2
  11. New Cartek Clutches In Stock!!!
  12. Headers and clutch fluid?
  13. How long to set adjustable end links?
  14. Larger Tires and Widened Wheels on C6
  15. Passenger side door won't lock shut
  16. [PICS]New and Improved K&N FIPK **Exclusive Look from LG Motorsports** [PICS]
  17. ls3 vararam question
  18. G.M Link Kaput??
  19. 3M Invisimask
  20. C6 rear end noise in low speed operation
  21. lifting C6 using fl jack need pics
  22. Corvette left wife stranded this morning!!
  23. anyone just running aftermarket mufflers in their stock catback?
  24. Anyone using additional cooling fans?
  25. Brembo
  26. highest coolant temps
  27. HAs Gm fixed the DBS (Dead Battery Syndrome) on 05s
  28. Something let go in the 08
  29. widest tire on stock c6 rims.
  30. Kooks stepped headers
  31. Shock Talk
  32. Need Advice on Z06 Seats
  33. CEL Question...Diablo Tuner
  34. LS3 stock head flow #s?
  35. Tune cost
  36. paddle shift shift points
  37. Breathless Performance 4th of July Sale 15% for a limited time ONLY
  38. What mod next???
  39. bose 6 disc from a 2006 into a 2007
  40. Breathless Performance 15% Discount for a limited time ONLY
  41. Front Bumber Spoiler
  42. code P0621
  43. LG Motorsports News Letter **SIGN UP TODAY!**
  44. HELP 1-4 shift Transmission Problem
  45. Full Exhaust and CAI Install Just Finished
  46. Brembo Brakes
  47. Need new brakes HELP
  48. InCar-Infineon Sears point Qualifying laps LG World Challenge C6
  49. MPG drop
  50. MPG drop
  51. Heat extractor hoods - got pics?
  52. Header question(s)!
  53. Radiator???
  54. plug wires??
  55. Need help with front widebody conversion
  56. Proper voltage reading?
  57. questions on vararam install - please help
  58. Question about Koni FSD shocks
  59. Advice on air induction
  60. Removing tarnish from exhaust tips
  61. BIG Thanks to Vengeance Racing...
  62. Where to hide bottle?
  63. Acceleration Put Into Perspective
  64. ^^ St. Jude Auction #37: C6 Mufflers from GHL MOTORSPORTS w/free s&h ^^
  65. Removing Battery Cable
  66. Strange A6 problem
  67. MGW Shifter Results
  68. Brake Pads: carbotech vs. posi vs OEM ceramics
  69. Breathless Performance 4th of July Sale
  70. For people thinking about getting a stall converter for their A6
  71. Anyone w/ the A6 broken any driveline parts?
  72. Textrailia Users Step In
  73. z51 gear ratios to stock
  74. Just Finished A Custom Nitrous Install. *pics*
  75. 2005 C-6 completely dead
  76. Slicks on a stock clutch ???
  77. Wilwood product and services for the forum
  78. Spin + AFR 205s = WOW
  79. Poly Suspension Bushings ?
  80. Question about DRLs
  81. 305 width Toyo R888
  82. Steering radio control and 2006 radio ?
  83. Another Teaser Video Before the Full Tech Thread
  84. Help!!! I Need a Paint Guy in Northern VA
  85. Airaid intake for my 08 LS3 (pic)
  86. Oil Filler Tube
  87. Sirius Radio antenna location
  88. Error Codes
  89. *****Gettysburg PA Tune and Porting session 7/18-7/26*****
  90. Suspension homework
  91. Pfadt poly sway bar bushings; best bang for the buck susp upgrade!
  92. C6 Rear diff. build?
  93. Adding Headers...and problems which occur with 02 Sensors
  94. Must swap Diff to swap rear gears?
  95. Cant decided on intakes.
  96. Rear end upgrade time
  97. Intake Manifold?
  98. Advice needed on building a forged stroker
  99. RPMs shifting at the drag strip
  100. Slow Trap...HELP! 12.168@119.34
  101. Question about using ETHANOL Fuel
  102. C6 DVL is saved by his tow hook ......
  103. LG Header with cats that is leaking?
  104. for those with hi-flow cat knowledge only pleas
  105. Need Brakes...
  106. Noise in rear differential
  107. what size lug nuts?
  108. I please URGENTLY need the assistance from fellow performance shops and tuners.......
  109. Over size transmission pan for A6?
  110. HELP Check engine light on!
  111. B&B Stocking Dealer
  112. AEM wideband gauge installed! (PIC)
  113. New Pioneer Nav
  114. pix of Cartek heads???
  115. Ran my Maggie car down the 1/4!
  116. Will you lose HUD if you install aftermarket NAV?
  117. headlight problems
  118. diablo and vararam what can i expect?
  119. Will these wheels fit my C6 w/o ZO6 fenders???
  120. Trying to install FAST!!! NEED HELP!!
  121. tire weight difference
  122. *St. Jude Auction #36: LG Motorsports Street Series Headers C5 or C6 *
  123. How far are we with the A6 upgrades???
  124. Is this a good idea for an exhaust setup?
  125. Anyone have pics of an LG end links install?
  126. Header/exhaust squeak on rough road?
  127. Varam question
  128. Thoughts on heads ? Lingenfelter 616
  129. How quarts does the MN6 Z51 trans hold??
  130. Electrial connector anchors wanted
  131. Best Launch for a A6?
  132. 4.10s to be installed Tuesday!! Chuck Cow
  133. Dynoed My Car Yesterday...454rwhp
  134. LG Motorsports Email
  135. Valve Cover Help
  136. Spacer Question
  137. Steering Wheel Alignment Question
  138. opinion jack stands what height?
  139. BB Route 66, GHL, Corsa...overall weight of cat-back?
  140. What it takes to beat a Z06 in 1/4 mi? (pics)
  141. What it take to beat a Z06 in 1/4 mi? (pics)
  142. gas mileage went way down
  143. Need full scoop on engine drag control feature
  144. 06 Vette Wobbling crank pulley? Help!
  145. 2008 c6 final gears.....(best ratio??)
  146. Who have L92/L76 Setup?
  147. Battery disconnect does what???
  148. LS7 Transplant
  149. Non Z-51 Oil Cooler Options
  150. Pink fluid on garage floor
  151. Question about the FAST 92mm LS3 intake and TB.
  152. Dyno Resultes for 05 and 07 M6 LS2's
  153. ls3 cam install, should i go with a colder plug?
  154. ZO6 Brakes
  155. Advice wanted: suspension setup for C6 rear widebody mod
  156. 05 TCM part Number?
  157. Installing a wideband...HELP.
  158. Exhaust install question..
  159. HUD repair?
  160. ignition wire ??
  161. Painting Calipers On or Off the Car?
  162. HUD Installed..Sort Of...Need Help ASAP
  163. Headlight adjustment
  164. Calling all Cam Only cars.
  165. I'm Due For A New Clutch!
  166. Help with Underhood Light Kit
  167. Treated myself-
  168. Mail Order Tuning From Chuck CoW
  169. Horn stuck-cause?
  170. Fuse Question
  171. Free Shipping on Cam, Cam Package, Power Packages at RR's Father's day Weekend
  172. How often do you see the engine drag control message?
  173. Apsis' Carbon RIM CAPS Now Available, *PIC SHOWN*
  174. corsa sport/touring question
  175. 427 YSI @ 10 lbs of boost. Cartek
  176. how to reprogram windows?
  177. Katech spark plug holder tool
  178. B&B Exhaust Now at MarylandSpeed! - Introductory Offer!
  179. ls3 cam install - do i need anything else
  180. 2008 Corvette LS3, Manual Trans - NEEDED in Memphis, TN to test new prototype part
  181. Outside temp sensor location?
  182. Need wide-band controller (have Bosch O2 sensor)
  183. Z06 will not go into gear but runs
  184. Make a non Z-51 car handle like a Z-51
  185. how are the 08 balancers?
  186. Defi gauges-Anyone have them?
  187. The Corvette Commandments:
  188. Z51 Sway Bars Bolt Torx Numbers
  189. BCM fried
  190. Hawk HP Plus Pads - Noise Control
  191. Need More Power
  192. LG Motorsports Transport making a run to Virginia, how needs a ride?
  193. Help Locked Out
  194. When doing a cam install on an 08 with a 3 bolt cam
  195. Installed the full ZO6 exhaust on mny '05 coupe
  196. Vortex Rammer, Tune and 160* Tstat
  197. HD front bearings now available from Hardbar
  198. Anybody live near Chuck COW's shop
  199. Masking Rear 02 Sensors P0240 P02030 Lingenfelter
  200. Supercharged horsepower = not real HP?
  201. A6 tuning opertunity
  202. 440 to 450 rwhp?
  203. do mods void factory and extended warranty?
  204. MN6 making bad noises
  205. HELP WANTED: Weird Paint/wrap question on my "used" 06 C6
  206. Bbk
  207. GM's fix for popping top
  208. Changing all fluids
  209. dealer installing new tranny
  210. Airaid now available for LS3 engines
  211. lifter collapsed, lost engine, new 402 to dyno this week
  212. Borla Exhaust looking for R&D Partner w/C6
  213. adjusting exhaust tips
  214. c6 dosent hold the road
  215. **LGMotorsports and ForgeLine, NEW FINISH**
  216. What's That Clickin Noise?
  217. Just wondering!
  218. Dyno'd 452Hp, 402Trq @ Almost 99 Degrees!
  219. Engine RPM fall-off rate between gear changes...what controls it?
  220. Ragin Racin Introduces LS2&LS3 Camshaft
  221. c6 rear speaker install help
  222. Bare cam swap
  223. Unplugging mirror power plug!!
  224. Tranny cooler config.
  225. trouble code
  226. TVS 2300? I-Charger?
  227. Brake Longevity
  228. Tune for my 2008 Z51 A6
  229. ticking from aerated oil on #7? - oil pump oring torn/pinched?
  230. Z06 sway bar and or shocks on Z51
  231. Clutch issue
  232. where are the metal spacers
  233. Rail covers
  234. Guys I need help brainstorming
  235. Is it me or does the stock shifter stink!!??
  236. DIY Cam Swap
  237. Opinions on high mileage C6s
  238. shocks on a stock C6
  239. Memory seat problem.
  240. Dr Frankenstein Begins
  241. Blackwing SLP or K&N series 63 air intake for LS3
  242. MN6 Trans Fluid Question
  243. Any good c6 shops in south Florida.
  244. After Installaing The Vararam.......
  245. C6 Door Speaker Wiring
  246. doing headers and cai, should i do a thermostat
  247. CARTEK ***CHANGES and SPECIAL***
  248. Pfadt - Powertrain Mounts
  249. Helmet rating
  250. BB Fusion
