- 500 WHP through the A6 Naturally Aspirated
- RevXtreme
- What #s should I be happy with?
- LS3 w/ yella terra rockers?
- What Size Mickey Thompson
- Corsa, Borla, B&B, Magnaflow, Bassani, SLP, etc.?
- When to shift at the track - at peak HP or closer to redline?
- Why use a t-stat?
- B & B Special at COD
- Cartek LS3 H&C results inside...
- Brake pad upgrade??
- Check engine light and code...any suggestions?
- update on vararam check engine light install
- new tires, will the sensors work?
- Radiator upgrade
- Question about removing headlights
- Installed Corsa Extreme Today
- 315/30/18 MT's what wheels to run ?
- Ugh... INCOMPLETE Vararam instructions!!?
- Added Z51 sway bars and they creak. Problem?
- Doing my brakes Thursday. What tools do I need?
- Got the Magnaflows installed today.
- Wierd Grinding Noise When In reverse A6 C6
- Remote Clutch Bleeder Install Instructions needed
- ZO6 or standard paint matched rear spoiler?
- Cartek L92 H&C setup on LS2 results (482RWHP/429RWTQ)
- Awesome Deal on Borla Stinger w Quad Round Tips (3 systems only!)
- Switching out seats.. how complicated is it? Red to Black
- Dynoing before and after headers - LS3 - cam only
- "Beat the Heat" Header Sale @ MarylandSpeed - Kooks, SLP, SW and more!
- GM Accessories: Did they make color-matched door handles & rear light for a '05 DSOM?
- LS3/L92 heads & LS3/L76 intake on a 6.0L LS2? What kind of gains?
- Black box mounted to chassis on pass side next to tranny???
- Kooks headers
- Ac ????
- An other oil leak question
- Need PFadt suspension help
- RWHP on a stock or near stock LS3
- Does anyone know for SURE!
- 08'pace car..
- Will The X-pipe Do Much For The Ls3 Or No
- Ls3 or 427
- AWESOME video presentation with Corvette aero products.
- oil drain plug location?
- Brand new 08 loses power on hill down to 10 miles per hour!
- Question about steering wheel vibration
- Aftermarket Intake: Best bang for ur Buck?
- Question
- Paddle Shift - Clunking
- 6-Speed Automatic in a C6 Z06
- need advice..
- Looking for Tire recomendations...
- Bunch o' codes, help please?
- Anybody try Ling gt2-3 cam in ls2?
- Lights flickering & volt gage fluctuating
- Tuner near pensacola??
- gears!!!
- Problems w/ WCC Lowering Bolts - pics
- Done with the header/xpipe install... Thoughts.
- What modifications for increased fuel mileage?
- Air conditioner display flashes
- Random but..color of stock torque converter?
- Not sure what shifter I have and want another shift knob...
- A6 3-2 Downshift problems
- How can you determine how much slippage?
- Underdrive pulleys & AC
- Adding 3:90 gears
- Lowered car, help with raising...
- Does Ramming it in make you feel sexy?
- How much popping do you get with cat back and headers
- 2008 A.C. Problems
- Dumb a$$ question #734
- C6 Posi Rear?
- MGW shifter vs. the rest
- my next mod?
- What's the difference in Z51 and Z06 sway bars?
- dual resevoir oil catch can
- Advice needed,,,,
- AC expert question what do I have 68? it's a 69
- Help
- Stock vs Kooks Weight
- new tire question
- Is there Corsa 2005 A4 exhaust system?
- bogart rims
- Best headers, exhaust system, & intake for '05 Vette?
- keep loosing center caps
- Headers Vs. 4:10 Gears???
- FI vs NA cams
- CloneMonster Airflow - The Cory Harris Advantage
- Tire/Wheel Balance?
- Found some bad spots on the hood! Help!
- Cam swap...typical labour cost?
- AintQik & SpinMonster in... "The Rat Rod, Corvette Style"
- Those of you that have installed a Callaway Honker CAI on an '08 LS3...within
- Best initial performance mods
- Looking at BFG KDW2 255/40/18 & 295/35/19
- Zr1 Owns The Gtr!!!
- Anyone a Typhoon Intake?
- Header/xpipe install trouble! Help please
- brake noise
- Dyno day for the LS-2
- Anyone up for a challenge?
- Popping/Grinding noise when turning....
- 275 front and 345 rear
- Rear spoiler question.....
- Any problem with 245/40-18 and 345/30/19?
- Altitude
- Help me choose a cam for my LS3 A6
- Perfect Light
- Can you recommend a place in the Long Island area?
- Awesome Diablo Predator Sale- Get a Free Interface Kit!
- FAST, 4.10's, Line Lock
- Drag Racing in Europe
- Starting the process... my first installation.
- 30.8 mpg in my Z-51 07 Vette
- Skip Shift Question
- Hats Off to Chuck CoW
- What do most ls3's baseline?
- Maryland Speed
- Corsa Extreme converted-
- Corsa Sport Exhaust Question
- Remove LG's in order to replace clutch?
- Are these covered under factory warranty?
- Removing And Replacing Brake Rotors
- HP Tuners- unable to locate VCM
- Installing Z06 Exhaust on a C6 Auto
- Steering Wheel Vibration?
- Halltech Beehive fit K&N Air Charger?
- MBRP exhaust
- Stick rear on A6
- Desoto dragstrip-Sat Morning!!
- stock ls2 clutch
- MGW Shifter Play
- oil leak???
- c-6 fast list
- Hi flow cats
- P2A01????DTC Help
- Anyone know how to remove the roof hooks in a coupe?
- "American Racing Headers Installs In Carlisle"
- ****$49.95****
- Any other slow "leakers" out there???
- caliper bracket bolts replace or not?
- benson race track thursday night in NC
- Looking to shave weight off my 05 MN6
- Need help with header parts!
- "Got traction"????
- Memory seats
- Traction Control Disabled w/ MAF Disabled?
- LS2-LS3 Differences, what are they?
- how hard is this to install, exhaust etc
- CAI Vs. Borla/Corsa/NPP
- LS7 torque cam?
- Need help with 05 C6 driver seat
- Best Ipod Connection For Bose W/ Nav
- PRC LS6/LS2 Heads Get A Face Lift!! 225cc Runners & More!!!
- Anyone with the definitive on brake squeal?
- Maybe a dumb differential question....
- LS9 Main Bearings
- ***ECS Mail Order Tuning Special ***
- Lowering With Stock Bolts
- Oil Filter Question
- Missed 3rd gear
- Fastest C6 (but with caveats)
- Invisicord???
- Brake Pads Part #
- looking for gm history report on 2006
- Ok, need advice on gears and converter
- Scosche AXIPCL2 IPOD interface in an 08?
- C6 Cutouts DMH or QTP
- Kooks/Corsa C6 Exhaust Specials!!!
- Directions for Header Install
- Interest: Chuck CoW tune in AZ area?
- biggest wheels on WB?
- Driving slowly around the neighborhood with endlinks disconnected?
- Wtb Chrome Or Polished Wheels
- I LOVE my local dealer... Not how you're thinking. Sicko!
- Magnetic Selective Ride Control - How does this work?
- What does it take to swap a Nav unit for a single in-dash unit?
- Cartek's LS 3 cam only!
- Super Chevy Show At Indy
- How Large of wheels can I go on c6
- Z51 brakes question
- CCW or iForged?
- disconnect battery and didn't ahve to index windows?
- vararam install check engine light on
- Looking for a cam for my LS2
- new to vettes... help me upgrade
- anti theft mode in C6
- When installing the MGW in an '08 are any mods to stock parts required?
- fish tailing
- anyone with ls3, vararam, and elite engineering catch can?
- how difficult is it to change the outside temp sensor?
- z51 rotors
- ** St. Jude Auction * Spring Mountain Advanced Driving School **
- Painting C6 Fuel Rail Covers
- Any trouble installing AR or Kooks 1 3/4 headers on a 08 LS3 A6 w/ z51?
- Adding Factory NAV to a C6
- Removing Brake Calipers
- C-6 Exhaust Module Fuse
- Replacing the studs on the rear wheel - how exactly is it done?
- Brake Fluid Res Leak?
- June intake and Throttle Body
- need help
- Anyone Running Nitto Invos???
- Question re: trunk won't open with button.
- Do you clean your MAS?
- K&N air filter
- approximate quarter mile time
- A6 vs. R6 hoosiers??
- Do you need 02 extensions - Headers w\ offroad pipe
- pictures of cars w/ 19 in the front & 19's in the back
- Advice On Gears/torque Converter
- ?prepping cal. brakets for paint?
- Need part # for front emblem
- Gene's Extra 15% off Genuine GM C6 Accessories!
- 3000mile oil change myth
- no competitive driving mode
- C6 problems
- 18 X 11 tire size
- Misconceptions about 07 vette Clutch & Diff
- Performance Potential of LS2?
- What kind of battery do you use?
- Weight difference between OEM Z06 wheels and aftermarket?
- Spec 3 Clutch and aluminum fly
- How difficult to update 05 steering to 06+?
- My #'s are low
- Gears on 05 auto
- Vararam installed on my new 2008
- Chek gas cap
- Help with fuel pressure problem!!
- LS3 Intake and Tune potential.
- Question,,
- what size are the lug nuts
- Borla Fitting Ques?
- Need Help With Tire Pressure Sensor
- Where can I find a maf connector?
- Paint
- How to remove seat mounting bolts ?
- Requesting Silver Convert pics
- What tires are available in 305/30/19????
- For the A6 guys with forced induction
- Brake Fluid Flush
- Wide and sticky FRONT tire setups
- LS3 X-Pipe??
- fast ported t/b's
- Strange Request: Suspension Components Weights?
- Scares old people and kids!
- How do you determine header pipe size?
