View Full Version : C6 Tech/Performance
  1. L76 Fully Assembled no longer......
  2. Dual Purpose Brake Pads
  3. Help, Service messages on DIC
  4. How to turn off CEL?
  5. MGW shifter
  6. Controlling Headlights
  7. Building my beast
  8. MGW question
  9. Summer HEAT A/C Not kicking ON!!! HELP!!!
  10. Intake changes
  11. ~~~ St Jude Auction #48 Pfadt Coilovers C5/C6~~~~
  12. need help on tires in a bad way.
  13. Best Price on TPMS ?
  14. Kooks-Corsa
  15. Custom Tune 100% Stock on a C6
  16. Installing a new shifter. ???'s
  17. Party @ Breathless Performance July 20th
  18. LS3 fast
  19. Engine Ground Map?
  20. Window 2008
  21. Kooks headers installed, woosh sound with acceleration. Plz HELP!
  22. R-compound tires: observation on warm-up times (Nitto vs. Toyo)
  23. Performance Mod's that will increase Average MPG's
  24. Another stall converter question
  25. HELP...Passenger window stuck down!
  26. Vert power lid pull down
  27. LS3 - Is the crank keyed?
  28. Reset Tpm Help Needed
  29. C6 Guys -- My line lock kit is coming your way!
  30. Burn outs: Line Lock or Power Brake?
  31. CAGS Eliminator Question
  32. B&B PRT Section Only
  33. Question about the ABS light.
  34. C6 Stereo Amplifier Question
  35. Stupid Navigation!!! 05......No IDEA!!!
  36. I would love to hear the rt66 with cam and long tubes.
  37. Pictures of my new Ported TB
  38. Chrome/polished Corvette emblem on rear facsia?
  39. Any thoughts on the Michelin Pilot Sport PS2 ZP ?
  40. Reflash,optima Yellow Top+tender=dbs
  41. Sway Bar Swap Trouble
  42. DSOM Painted Calipers
  43. Wake up ol sleepy A6 ... Thanks ECS
  44. Highest RWTQ from and NA 6.0 liter LS2?
  45. seats
  46. cutout versus npp/fusion
  47. Individual cylinder management?
  48. What mods result in increase MPG
  49. Best sound proofing material??
  50. Lower Temp 'Stat in LS3
  51. Need help with upgrading tires
  52. Factory Vacuum Source For NPP?
  53. clutch
  54. Holy sh!t! Left front wheel locked up! Service Active Handling
  55. Ordered Hawk Ceramics, do I need new clips?
  56. Jacking up the C6 LS2 for dummies
  57. Jacking up the C6 LS2 for dummies
  58. AutoXray GM diagnostic scanner
  59. Corvettes of Dallas Signature Series #002 the monster is realeased! (pics inside!!)
  60. LG and Borla Touring 1k miles review....
  61. Need help on something simple
  62. Leaf Springs
  63. NPP & cam/heads
  64. What's better, the X before or after the cats?
  65. need advice on selective ride problem 2005
  66. stall converter question..
  67. ANY gains from .......
  68. Baby Got a New Pair Of Shoes
  69. Some performance advice please
  70. LS3 thermostat same as LS6 thermostat?
  71. LS2 timing chain break
  72. Where to buy smooth coupler?
  73. easiest way to change headlight assembly
  74. Would this be ok to do to jack my car up?
  75. Advice on 07 seat electronics.
  76. Curious, how does one get a C6 onto a flatbed?
  77. LS3, LS7 MAF Pinout
  78. porting LS2 intake?
  79. Apsis' 2008 Radio/AC Bezel in 08 Carbon Now In Stock
  80. electric cut out help
  81. 2008 Rear Fascia
  82. Houston Tune
  83. Best Header Gaskets?
  84. Meziere Electric Water Pump???
  85. GM Performance Rotors & AC Delco Rotors...same item?
  86. L92monster: H/C package-DYNO numbers AND cam specs
  87. G1 MTI cam, Installed Sound Clip
  88. About to buy FAST... Questions/Suggestions?
  89. LS3 underdrive Pulley
  90. Cross Drilled Rotors: Any photos of EBC or GM Proformance Cross Drilled
  91. "Might get Nitto 555r's instead of,,,,,
  92. ign and courtesy lights
  93. Borla Stingers umm what did you say.....
  94. Large Catch Can Placement
  95. Transmission % loss?
  96. A-6 missed shift from 1st to second?
  97. Found Some 315 45 16
  98. transmission oil temp
  99. C6 Turns Into Monstor -- The Sequel
  100. Paddle Shifter Question
  101. Z06 mufflers
  102. Will a c4 wheel fit on a c6?
  103. Dyno tune for 08 6.2L
  104. Here's the plan//what am I missing?
  105. How much would it cost, and how much power for these mods....
  106. Kooks, LG, ARH, SLP, B&B, Stainless Works, Dynatech, etc. Headers & X-pipe
  107. My LGs and The SEL
  108. Inside front tires feathering
  109. MZ6 or MM6 TRANS?
  110. A few questions about the z06 and G-tech
  111. 50k service
  112. Best cam for overall torque? (YAWCQ)
  113. California Emissions....help please.
  114. Is SLP the only company who offers an underdrive crank pulley/balancer for C6s?
  115. $24.99 For A New Sound To Your Existing NPP/Z06 Exhaust
  116. performance axle or regular???
  117. 3600 Miles And No Rear End Clunk!
  118. Bullets or Corsa Extremes???
  119. Got my new project today 416CID Stroker
  120. Ok I'm at my wits end with Chevy on this power steering noise/ shudder...
  121. 2005-2007 MagnaCharger/Install/Tune @ Vengeance Racing!!!
  122. Finally 4.10's are going in
  123. B&B Retro Fusions In Stock and On Sale - Includes Round Tips w/ Wiring Kit!
  124. Invo Tire Sizes
  125. Actual 0-60 of 98 LS3 Npp 6m
  126. new '08 + Vararam + hard rain
  127. stupid question
  128. Will 345/30/19 fit on the rear of a stock '05 C6 w/out modifications?
  129. ok im lost - program spare key fob ?
  130. what gears and stall
  131. Bi-Mode Z06 Exhaust install on '06 Z51
  132. Need help sourcing 6L80E Tranny Parts
  133. New Vette needing mod ideas
  134. LG Motorsports making another run to Phoenix area
  135. Zo6 Spring Rating compare to C6
  136. What do I need to do to get my C6 into the 11's
  137. 2006 A6 Transmission Question
  138. Zo6 Exhaust Question H or X Pipe
  139. STUDmonster: ARP head studs vs. bolts
  140. Oil Pressure Sensor Pin Out
  141. Z06 Speaker panel dent??
  142. Headers and heat?
  143. 418.9 hp and 416 tq
  144. New brake pads
  145. specs on gm shocks?
  146. Head bolts / Studs?
  147. Vibration at 85 mph-balance or alignment?
  148. Starter Solenoid Click but No Engine Crank
  149. Cut outs - Whose to use?
  150. American Racing Headers/The Vette Doctors/ECS/Redline Mtr.Spts. In Carlisle!!!
  151. CAGS fuse???
  152. Is there such a thing? Cam that'll give you lope yet increase fuel mileage?
  153. 315 45 16 Mickey Thompson
  154. whos put headers on a z51 08 mz6??
  155. My new Ride
  156. Adjusting angle of window glass
  157. ECS CAM only LS3 10.84 @ 128 vid
  158. Where to get smooth coupler???
  159. Installed NPP on 06 C6 got A Lot of Popping
  160. Piniging noise at low speed
  161. Adjustable Exhaust
  162. Quick Question???
  163. Dynomatting my car...
  164. Finally Installed the SpinMonster Ported FAST 90
  165. RF Spring Lower Bolt Won't Budge!!!!
  166. Are these voltage readings normal?
  167. Stock exhaust...what does it cost in HP
  168. DIC shows LOW FOB Battery...Question
  169. corsa exhuast
  170. port and polish intake manifold and throttle body in nc
  171. Kumho Ecsta SPT tire size
  172. Do TP sensors always read low?
  173. Clutch died today
  174. 06 A6 Z-51 Stock to Head, Cam, FAST Numbers
  175. Z51 Alignment
  176. Seeking LS3 head gasket information
  177. Finally clunkless!!!!!
  178. Help
  179. Custom Twin Turbo For Your Viewing Pleasure
  180. Removed OEM NPP's & Installed B&B Fusions - Estimated BHP Change?
  181. ported t.b. & intake for Z06
  182. electric cutouts on an A6
  183. I took my mufflers off. WOW
  184. Typical Charge to Install Thermostat
  185. Brake lines
  186. A6 didn't downshift
  187. C6 Zo6 Springs on C6 Z51
  188. Jeremy Formato tuning and porting 7/10 in Gville
  189. Noise from driver window driving me nuts!
  190. Oil coolers???
  191. Could having tire sensors from a 06 Z51 not work right in a 07 non Z51?
  192. C6 Z51 wants half shaft upgrade, use what?
  193. Can you shift without clutching?
  194. Did my brakes Friday (Carbotechs). Since when do rears go faster then fronts??
  195. Possible steering improvement?
  196. ls3 procharged and headers!!
  197. OMG - LG LT Install Done ....
  198. Removing Dash on 2006 Coupe?
  199. exhaust sound clips page?
  200. Tire Tread
  201. 100bhp per liter?
  202. fusion exhaust, wiring flaps closed ?
  203. Anyone with a B&B PRT system???
  204. Jump Start
  205. Ran my new LS3 - Advanced Dyno cam/header combo at the track
  206. no cats and header install on Z06, now hellacious backfire
  207. Just installed NPP on my 06
  208. Any suggestions?
  209. Brake pads easier than I thought
  210. Any dyno sheets of the G5x3 cam and L92 heads?
  211. Which air induction system?
  212. Dyno Results from G6X-3 cam 475 hp / 443 Tq
  213. Procharged 402 stroker still running hot
  214. Strange crunch sound?
  215. Bulletin For Popping Top?
  216. Any tips for installing Z06 LGTB's with Z06 mufflers on my C6?
  217. LS3 mods dyno numbers
  218. Put 19/20 wheels on my car and now it feels sloppy?
  219. Ominous creak from rear end
  220. A6 converter people, few questions...
  221. Eliminating Wheel Hop???
  222. Advice on adding supercharger
  223. Exhaust Commander
  224. help cant install fusion retro
  225. Shift Light HELP
  226. RevXtreme catch can
  227. Cartek LS3 Cam only (490.7RWHP/419RWTQ)!!!
  228. Wheel And Tire Help Please..
  229. Upgrading to Z06
  230. Adding Steering Wheel Controls
  231. gfgd
  232. Cam swap...new gaskets necessary?
  233. *NPP IN A BOX* Add NPP w/My Revolutionary Vacuum System–Used By VetteDR, ECS and COW
  234. Slight flicker of lights
  235. DiabloSport Predator Tuner vs superchip
  236. 450RWHP 405RWTQ what do you think.....
  237. Nos
  238. Trouble getting out of park
  239. Where to purchase mods....
  240. ZO6 exhaust help
  241. Manual Steering Rack?
  242. Any Photos: Baer DecelaRotors, Baer Eradispeed or Brembo Sport Rotors?
  243. Converter? We don't need no steenkin' converter!!!
  244. GM Parts House July 2008 C6 Specials!
  245. Genuine GM 2009 Body Colored Accessories Available!
  246. Genuine GM Full Width Racing Spoiler Available In 3 New Colors!
  247. accident damage C6
  248. catless x pipe
  249. 500 WHP through the A6 Naturally Aspirated
  250. RevXtreme
