View Full Version : C6 Tech/Performance
  1. C6 Seat Wiring help needed
  2. !!!another Satisfied Ls3 Customer!!!
  3. removing the exhaust i have a question???
  4. Bleeding the ABS?
  5. Inconsistant power delivery with 08 LS3 MN6, IAT's killing me?
  6. Sixth gear issue???
  7. has anyone done a full widebody conversion on their own?
  8. Superchips Power Programer
  9. FAST 92 Fuel Rail & Firewall Kits Install Instructs/Pics Needed
  10. Odd noise when I rev the engine.
  11. New Halltech Dealers. Guess Who?
  12. Another JSB
  13. Nitto Invos soft sidewall?
  14. a6 shift knob
  15. whats the smallest wheel you can fit on the rear
  16. Ccw's On My C6
  17. Auto trans with LS-7?
  18. Oil Leak at Oil Filter
  19. Auto Start for C6
  20. How do you Remove Center Console - C6 Vert 2005
  21. Which bilstein to order
  22. Can a C6 HUD Unit be retrofitted into a 2005 Cadillac CTSV?
  23. Livernois/Detroit Speed Shop saves my C6
  24. Dyno sheets
  25. LS7 in Standard C6?
  26. maryland speedshop has a special on VARARAM
  27. UPDATE: Header/xpipe low gains and timing
  28. Do we have a definative answer for "Service CHarging System"?
  29. Removing front rotors?
  30. 160 Stat = new Plugs?
  31. HoosiersR6, Pilotsports, NITTOS
  32. Question about oem radio please
  33. c6 shock installation how to manual
  34. Looking For New Shocks
  35. How do I remove hood shocks?
  36. How to get to thermostat??
  37. DRL: Can they be programmed so they CANNOT be turned off?
  38. 160 Degree T-Stat?
  39. installing oem navigation
  40. Devil's on the treadmill
  41. Has anyone cut open
  42. Took the 08 Ls3 Vette to the dyno after the headers install
  43. Need Advice
  44. titanium retainers
  45. is LG for real or are their numbers skewed?
  46. L92/L76/G6x3 - Will it hit 500?
  47. Where to buy gears?
  48. For those that have replaced their A6 shift boot
  49. World’s first C6 with 3.42 gears, A6 transmission and 3600 stall converter?
  50. Strange vibration after torque converter install – anyone else ever experience this?
  51. Question - Any added a Parking Warning system
  52. Where to buy competition grey paint?
  53. C6 2005, where find bolt on turbo kit
  54. Traction Control/ active handling
  55. Caliper Rebuild . . . Torque Specs?
  56. L92 heads L76 intake cam recomendations
  57. Mod and void waranty or not
  58. New Sp551 Rims From Ccw And Shoes
  59. Need help immediatley with removing seat belt buckle!
  60. Only 7rwhp/7rwtq gain from Headers/xpipe
  61. Underhood Lamp Kit
  62. 17" x 9.5"??
  63. 06-08 Gearbox & Diff mounting flange
  64. COD Special - Week of July 21
  65. New Modular Photo Shoot, with a new Wheel Combo!
  66. What are the widest tires recommended on stock wheels?
  67. I thought you guys were crazy! '05 DBS
  68. Tuners in my area
  69. Rear axle ratio = Confused??
  70. List of cheap mods
  71. OH MY GOD! My TIMING CHAIN BROKE! WHAT NOW?!?!?! @ C.O.W.
  72. Fuel gauge reading wrong....Please read this and try and help....Please!
  73. Headers
  74. Question about my drag setup
  75. New tranny, trouble with 4-3 downshift
  76. Camshaft noob - Pros/cons about the GM hot cam?
  77. Qustions regarding Procharger p1sc LS3
  78. Halltech Killer B widebody install
  79. Tidewater, VA C6 owners question?
  80. Electricians please step in (Issue with Voltage)
  81. Ride height adj
  82. ForgeLine wheels at Carlisle with LGMotorsports
  83. 2005 battery went dead - now no stereo
  84. need a good tuner near Scranton, PA
  85. Another LG Pro equipped LS3 **30RWHP and 45RWTQ!!!**
  86. My alignment specs -- Look good?
  87. Any Good Tuners in So. Cal
  88. I've come Ungludded.... Another creaking top thread (07' c6)
  89. Injectors: Maxxed out the 63's... Can the factory PCM be tricked to handle 76Lbr's?
  90. Are OEM air filter AC deloco?
  91. Anyone switched from BFG KDW2's to Nitto Invo's, comparison please?
  92. Squeek!
  93. Does a new LS3 surge a little during break-in period?
  94. LED Interior Mod
  95. LS3 A6 1/4 Mile Drag Times???
  96. First Engine mod...
  97. Supercharger for a 2008 Vette ??
  98. Thought You Might Want To Watch Corvettes of Dallas Signature Series Go For A Spin
  99. If EV1 style (longer) injectors are used, will the fuel rail covers still fit?
  100. Horsepower limits of A6
  101. PLEASE Help- Need to find clutch date code
  102. Apsis' C6 Splash Guard Group Purchasing Special
  103. Does anyone make 60 lb. (or close) injectors w/out having to use adapters & spacers?
  104. Could the Street Warrior be close at hand?
  105. More tools from the pros at Katech - Bartec TPMS Trackside programmer
  106. ZR435 Corvette
  107. Vararam Installed With Questions
  108. LS3 casting number
  109. 06 Z51 0-60 Times
  110. The day has come!!!
  111. CEL- Oxygen sensor failure
  112. LS3 camshaft LSA's
  113. Help with Drivers side Header
  114. Intake manifold swap
  115. Battery
  116. Vararam Help!
  117. A6 TUNES in South Florida = Breathless
  118. Casting number for L92
  119. Here Are The Gear Shift Reductions For The Mgw Shifter On A 2008>>>
  120. Wide body question
  121. XM/NAV Volume
  122. I finished my HardBar harness bar installation
  123. Underdrive pulley Question
  124. What are realistic gains?
  125. Looking for slicks and rims
  126. Expert Opinion needed on 1.8 RR
  127. brake fluid question??
  128. Help Electrical Gremlin Reeking Havoc
  129. Installed 160 Stat And Vera Ram
  130. Anyone Know If They Make Drag Radials For A 2008 Zo6
  131. Home Brew z51?
  132. 2005 C6 F55 Functionality Testing
  133. headers fit ls2 and ls3
  134. Quick question
  135. Grit cut groove in rear brake rotor--How clean out?
  136. whats the best place to get a fast
  137. Vararam VR-SC1 or Halltech Intake
  138. Brake Caliper removal
  139. Slicks and wheels
  140. Welcome2try and Spinmonster reunion thread.
  141. Help! - electrical issue w/aftermarket seats
  142. need help!!
  143. Whoooly Cow The 4.10's Are In The Whole Story
  144. IMMEDIATE HELP NEEDED FROM ANY C6 techs out there!!!
  145. Hawk DTC 70/60 - Huge squeal
  146. Mixing Tire Brands- HELP!!!
  147. Im cheap! Help me go fast on a budget!
  148. Help Please (noise)
  149. Do bigger tires fit OEM rims?
  150. What is a "mild" tune?
  151. Aftermarket shifters; '08 shifter notchiness; warranty etc?
  152. Radar Mounting Rear Mirror
  153. Thermostat Confusion
  154. Header coating - Is it a must?
  155. Track Run
  156. Precision Metalcraft sheet metal intake
  157. got to replace my H-pipe...
  158. Alignment specs...are these what I should shoot for?
  159. cool vert lights on 81 today
  160. Vararam Install
  161. Lowering on stock bolts effects ride
  162. LS3 Sparkplug Gaping?
  163. track times 1/4
  164. Co Springs (tuners)
  165. New best 1/4!
  166. QMS BBQ day...TODAY is the day!!!
  167. I think I solved my wheelhop problem
  168. Torque specs
  169. NPP installation on non npp equipped 2008?
  170. new exhaust add on making car feel sliggish
  171. Fuel Line Disconnect Help Needed
  172. Cool C5 drag video...
  173. What does it take for a normal C6 to run with a C6 Z06?
  174. Race Proven Motorsports Cam only LS7!!
  175. Any gains going from a stock FAST to a ported FAST?
  176. ***LG Motorsports and ForgeLine together at Corvettes of Carlisle!!***
  177. saturday morning
  178. corvette 360 burnout
  179. Help with 8 rib belt install
  180. Changing All The Water Hoses
  181. Guys running DRs what to do about tire sensors??
  182. Nitto Invo louder than run flat?
  183. Air Intake
  184. Timing problem and bad HP/TQ curves
  185. Best tie down spots for a dyno pull?
  186. C5 wheels fit on the back of c6??
  187. Emergency: Airbag Malfunction in Scottsdale!
  188. Bottom line LS3 modifications, intake/tune/stat...
  189. TF Heads: Questions
  190. Change Clutch Fluid ???
  191. Exhaust cutouts
  192. Apsis' C6 Carbon Front Splitter (Z06 Style) installed on car, *PIC SHOWN*
  193. Bolton question?
  194. A Pillar vinyl covering
  195. High Quality Lowering Bolts ???
  196. More NPP sound tuning tricks....>>
  197. Hello from Spring Mountain, here to represent our Corvette driving schools & more
  198. sound from engine, like floating valves
  199. 2008 Cammed Z06 Closed vs. Open Exhaust Comparison - Video
  200. Breathless Performance Corvette Party July 20th
  201. '08 with A6 Muffler Swap
  202. Service Traction control coming on
  203. Which CAI is best
  204. ### St Jude Auction #49..Tuning is not a city in China...####
  205. Need cam advise
  206. Need cam advise
  207. Slicks Vs. Drag Radials
  208. Been Gone For Awhile. What Happened to
  209. TF245/ported FAST vs LS7/port LS7 intake
  210. Oil pressure @ idle
  211. what parts do i need to throw into my vette to be able to launch HARD on DR's safely
  212. advise needed on vararam/z51 install PLEASE.
  213. Why does the Z06 have the nose scoop ?
  214. Recaro's for new C-6?
  215. Where is the thermometer??
  216. Forged Aluminum Wheels
  217. 93 octane plus ethanol
  218. Any Solution?
  219. Is anyone running 18 in. dr's on repros
  220. New Dyno Numbers
  221. What are these hard lines for?
  222. RevExtreme's HO alternator
  223. Braciole mobile Heads continued part 2
  224. Testing a headlight?
  225. Killer Bee MPG Drop
  226. Starter sticking
  227. Powerbond harmonic balancer...pics
  228. stained my powdercoated wheels? Help
  229. Katech....whats up with your cam sensors?
  230. Make mental note for future reference...
  231. Uninformed
  232. Wideband, why?
  233. Some bad Z's with Modular Concept Wheels [PICS]
  234. BFG KDW2's vs. KDW NT's
  235. S/C Vs Cam + FAST + Gears
  236. **NEW FROM LG AND FORGELINE** New wheel styles, bolt colors, and finishes!!
  237. I have the bartec tool but didn't need it,,,
  238. I think my clutch packs are cooked
  239. GM Technical Service Bulletins???????
  240. Quick question regarding throttle
  241. New Heads Braciole mobile AFR or Trick flow?
  242. Handheld Tuner for 08 LS3
  243. help
  244. Granatelli MAF - keep it or go back to stock
  245. Will a 345 fit on a 9.5" wheel?
  246. dyno tune at Carlisle by Axcelerated Motorsports
  247. Corbeau FX1 Pro Seat
  248. Z51 Sways/shocks Vs Z06
  249. Recommendations for Best Setup for C6 Autocross
  250. Creaking top driving me insane. Are the new latches out yet?
