View Full Version : C6 Tech/Performance
  1. Removing drivers power seat
  2. Loose rear end
  3. Broken suspension problems Needed help
  4. I drove the DVLmobile .....
  5. C6 LS3 Oil/filter questions
  6. New Purchase
  7. Oil plug
  8. What Would Happen If I did not use TPMS
  9. Throttle body
  10. Cartek Cam LS3 + Bolt Ons Hits 509 RWHP.
  11. actual header gains...
  12. need help with brake pads for track use
  13. Z06 Brakes & Track
  14. SLP Blackwing or Callaway Honker or XcelaCorp Xcelerator ?
  15. EnglandGreen Cam Package (Whiplash)
  16. only one mod...
  17. C6 advice
  18. No Good Vette Tuners In Kentucky?
  19. *** Special Group Purchase Pricing on LG Street Series Headers! ***
  20. Treat your Corvette to a set of LGMotorsports C6 Street Series Headers!!!
  21. Apsis C6 08 Carbon Navigation Surround Bezel Now Available *PIC SHOWN*
  22. '08 NPP mufflers vs. Z06 mufflers
  23. Paddleshift Blues
  24. Sand blasting/powder coating C6 wheels... Help!
  25. Help/tips for new drag racer
  26. Window tinting with window indexing?
  27. asp underdrive
  28. tires
  29. Structural foam injection and frame stiffening - Need Advice!
  30. 130.7 trap with the Beehive
  31. Tire sensors
  32. KB boost-a-pump install How To
  33. Do you need NPP
  34. Okay, show me your oil pans and starter motors, do all these things leak?
  35. AintQik and his magic carpets... err towels
  36. Crack in rear transverse leaf spring
  37. The official tuning tactics LS3 thread.
  38. Broken Rear Leaf Spring
  39. Spring pressures seated & open
  40. 05 c-6 freak?
  41. weight on Gumby wheels
  42. what are sizes of Sway bars Z51, Z06 and standard
  43. Questions for the LS2/3 Cam Guys .....
  44. Ls3 fuel rail and injectors on a Fast 90
  45. Differential problem; Any good Minnesota dealers for warranty work?
  46. F 55 option
  47. Need Help
  48. Stock vs Z51 Transmission ratios found...
  49. Kooks Headers On Special!!
  50. Size Wheels for ZO6 Brake Kit
  51. Oil Cooler on 2008 Z51?
  52. What can I get from TRUE cam only?
  53. I'm still confused about the z06 and ls3 intake.help.
  54. Turning TPMS "OFF"
  55. Exhaust?!?!
  56. Mike Norris Motorsports Cam Swap Installed & Tuned Packages Starting @ $1795
  57. Fastbird Line Lock Price Reduction!!!!
  58. Car won't start. :-(
  59. 92mm Fast Intake, LS2 TB & Harness $1100!!
  60. Ls7 / Ls3 Pull Timing
  61. FAST or Cam, which first?
  62. Stock Exhaust Manifold w/ Exhaust Cutouts?
  63. Best Dyno Proven Aftermarket Air Filter Set-up
  64. Clicking from front driver side wheel when turning?
  65. Unacceptably high interior noise/whine
  66. why change size of exhaust
  67. ls2 build-up question
  68. Formato Tuning in Gettysburgh Same Time as Carlisle 8/22 -8/25
  69. race mesh grill
  70. Lets talk clutches....
  71. belair
  72. ZO6 Brake kit on 2008 C6
  73. Hood insulation
  74. Newbie about to modify 2005 c6. Got questions.Please help!
  75. Gen III Hot Cam experiences
  76. GM Parts House August 2008 C6 Specials!
  77. Head Castings
  78. Non-GM Engine Calibrations Void Warranty!
  79. c6 Z51 calliper and regular c6 calliper
  80. Help with steering column wire coil
  81. Slamming On Bolts????
  82. Drivers seat is turning into a rocking chair!!
  83. plz come in I need help
  84. COD Special - Week of August 4, 2008
  85. New 09 on order - a couple of questions.
  86. Those who have Torque Management disabled
  87. Lowering Bolts
  88. SLP Custom Tuned Diablo Sport II should i get it ?
  89. I Need A Rear Right Quarter Panel
  90. u-joint problem
  91. Vararam VS Vortex Rammer
  92. Looking for C6 vette and then the best mods for the money
  93. 8:50's in the 1/8th? I thought the ls3 was faster...
  94. z51 sway bars
  95. adding HP to 2007 convertable
  96. 4:10 rear gearset question
  97. any one with nos?
  98. Weiand Street Warrior LS Intake
  99. Cutouts?
  100. What the H____?!
  101. When To Change Diff. Fluid
  102. Input Needed
  103. 2005 C6 Powering Down Problem
  104. 08 LS3 w/ NPP- factory stock tune questions
  105. Compression ratio question, mo' simple - - -
  106. Question about my HUD display at the track
  107. B&B Bullets on 2006 C6
  108. Increased Compression Ratio - LS2
  109. Oil Dipstick Holder Bolt LOST!!! Help me find a new one!!
  110. 08 z51 mz6 fan setting question.
  111. Strange electrical?
  112. exhaust tips never sooty
  113. Help! What do I need to make 450rwhp/450rwtq
  114. kenne bell for c6
  115. ’08 C6 automatic gear ratios-Too TALL!
  116. B Pillar Frame - Are Coupe and Z06 the same size?
  117. Degreasing/cleaning Aluminium parts?
  118. Going to document HUD install. What do you want to see?
  119. a6 shifting issue???
  120. Anyone have a pic of the tool used to disconnect the fuel line?
  121. Mayhem Motorsports: top notch work
  122. Clutch/6-speed Transmission Problems
  123. Rear View mirror upgrade ..... hmmmm
  124. Anyone NOT running the standard 30 psi in your street tires?
  125. 373 gears
  126. Anyone NOT running the standard 30 psi in your street tires?
  127. What speed at redline in 4th with different gears
  128. What psi to run in drag radials?
  129. 2009 Stock Z51 numbers....WOW!!!!
  130. DOT 3 clutch fluid?
  131. Rear End Clunking In C6 On Sharp Slow Turns
  132. Ls3 Stock Intake Vs. Callaway Vs. Vararam?
  133. Ported FAST vs Ported Intake comparo w/ dyno sheets & details
  134. Need a little help...
  135. Driver side window no longer goes up to seal when I shut the door.
  136. 4000 rpm...pings under load
  137. question for people with Halltech C6 Venom???
  138. INSTALLATION, new MGW low effort 15% shifter
  139. Carlisle Parking - Spots Available With Us in the Fun Display Field
  140. Buying first Chevy (Corvette)
  141. My FAN KEPT RUNNING
  142. Alternater differences???
  143. APSIS Corvette Forum Group Purchase "august Summer Sizzler Special"
  144. squeaky brakes on C6
  145. P0106 Code
  146. Has anyone done bussiness with Texas Direct Auto in Houston ?
  147. Calling Blue C6 Verts - new desktop wallpaper from the Corvette Museum
  148. Those looking for fuel rails
  149. Got a Four Wheel Alignment Today - Toe Was Out of Spec On All 4 Wheels
  150. 08 C6 LS3 STOCK Vs American Racing Longtubes/MagnaFlow Catback
  151. Abear Motosports now shipping Custom Fuel Rails!
  152. Front tire advice
  153. LS7 headers
  154. Cool iPHone app - Dynolicious
  155. Factory Nav/Radio is not opening
  156. [PICS]First C6 With a Modular-Concept Carbon Series Wheel! [PICS]
  157. "Oil Life Monitor"??? Right! More like "Oil Life Guess-ometer"
  158. Alignment problem...I think!(kinda long - sorry!)
  159. Passenger rear creak
  160. GM C6 Parts List
  161. car wont start
  162. Cam
  163. OBD code - P1825
  164. Installing Z51 Sway bars (mechanics step in)
  165. Z06 wheels on C6 ayone do that? photos?
  166. L76 aftermarket intake? WHEN?!?!?!
  167. Jacking up my vehicle
  168. ECS LS3 CAM ONLY hits a dyno jet 498.68/457.53 vid
  169. LS2 - more TORQUE needed at 4000 rpm !
  170. Breathless Performance Vortex Ram Air System 15% Discount
  171. Baldwin oil filters
  172. Wheel Swap
  173. headlight moisture
  174. 265 & 295 fitment
  175. Anyone Changing out Foglights?
  176. traction control
  177. Anyone running a .027 head gasket?
  178. X-pipe install helps what?
  179. c6 stock heigth
  180. How many have installed headers by DIY at home?
  181. window tinting and Nav and dot matrix
  182. 2008 LS3 Diablosport Predator Released
  183. Diablo Tuner???
  184. performance chip??
  185. CAI question
  186. Fastbird Performance Line Locks are Released!!!!
  187. Halltech's Beehive fits the LS3 Perfectly
  188. Key FOB
  189. Ecs Blower Cam...
  190. Cam only LS3 485hp/460rwtq
  191. 418 LS3 stroker
  192. Which Lowering Bolts?
  193. Bosch Platinum IR Fusion Spark Plugs
  194. Polished Hose Clamp Suggestions?
  195. fast manifold question
  196. A6 no shift 3 to 4
  197. GM Close Ratio T56 transmissions at LGMotorsports
  198. Some more ported intakes and tuning results, FAST, LS7
  199. quick MGW shifter question
  200. MTI Racing's(Marietta,Ga.) Annual Dyno Day and Open House on Saturday, August 16th
  201. 08 LS3 with Vengeance Racing Stage II Cam Dyno Results/Idle Clip
  202. Pioneer avic-f700bt
  203. Apsis' C6 Carbon Rear Roof Panel (Halo) Group Purchase Special, *PIC SHOWN*
  204. LGMotorsport Transport rides again.....Dallas to D.C. area
  205. SpinMonster Arrives Safely - the Future BoostMonster Departs
  206. Need Help With New Key Fob
  207. Apsis' C6 Side Air Vent Final Sample Installed, *PIC SHOWN*
  208. Need Advise, Please help!
  209. what parts should i replace? broke something doing a burnout
  210. Drag Tires For C6
  211. ### St Jude auction #54 ** C6 2005 - 2007 Corvette High Flow Air Intake System
  212. MGW daily driver shifter option now available>>>
  213. What tires should I get for my C6?
  214. Spare Tire for 2008 C6?
  215. Houston Performance Shop
  216. What do you think of the following.........?
  217. Test Driving My New Engine Stands
  218. Need engine shipping HELP!!!!!!!!!!!!!!
  219. Engine Shipping Help
  220. LS2 engine covers how?
  221. 06 C6 Air Conditoning Question
  222. A6 Trans Engine Tune at ECS WOW!!!
  223. Had my 06 A6 C6 Dyno'd this weekend...
  224. C6 LS3 535 BHP Package
  225. Apsis' C6 Carbon Rear Roof Panel (HALO), *PIC SHOWN*
  226. Code P2135 anybody ever get this one?
  227. Help Side View Mirror
  228. For new cam, should I have Harland Sharp rebuild stock rockers?
  229. Smugglers Hatch Things
  230. Help Wheel and Tire Sizes?
  231. I Just Noticed My 09 LS3 Does Not Have A Mobil 1 Oil Cap!
  232. Formato Tuning and Porting in Gettysburgh - Same Time as Carlisle 8/22 -8/25
  233. Car Malfunction ???
  234. A6 shifting issues and rough idle
  235. CSL wheels ?
  236. Spec Clutches on Sale at MarylandSpeed!
  237. Strange sound when A/C compressor is on...
  238. Strange sound when A/C compressor is on...
  239. Body Control Module
  240. Show me your Pods
  241. C6 Performance Improvement!
  242. callaway or ligenfelter
  243. AirAID cold air intake ??
  244. Any Help Appreciated
  245. Attention A6 Owners!!! Finally, The Wait Is Over!!! @ C.o.w.
  246. Funny Electrical Buzzing Sound
  247. When to do first trans/diff oil change on new C6?
  248. z06 and ls3 top speed
  249. Show me your catch can set ups...
  250. slave issues
