View Full Version : C6 Tech/Performance
  1. jacking pucks??? c6?
  2. Getting some new Lungs !!!
  3. *FREE* WCC new 2007 catalog
  4. ?'s on '08 Driveline
  5. Dyno Numbers
  6. Fair Value Of Wheel/tires
  7. soft clutch pedal after high g" take off heed help!!!
  8. Track Results; Silver Dollar Raceway
  9. '08 C6 A6 trans program for '06/07 A6's
  10. 160 replacement
  11. How to make your LS2 measure up.......
  12. TSB for Service Active Handling System??
  13. Size of oil drain plug and type of socket needed
  14. B&B Bullets: PRT or NO PRT??
  15. 0 - 60 times ???
  16. Spark Plug Wire troubles after Headers install
  17. Dynamic CR and cam selection on a blower car
  18. Drive c6 without hoodliner
  19. Cross drilled rotors
  20. Borla Mufflers
  21. ECM Tuning
  22. 3.90 gear question
  23. Halltech LS7 Killer Bee AAIS now available for the LS2
  24. Another question about Dynamic Comp. Ratio and cam selection
  25. Another question about Dynamic Comp. Ratio and cam selection
  26. Dif Oil Change Question - Royal Purple/GM Friction Modifier
  27. Vararam instalation??
  28. Pilot sport PS2's or Avan Sports
  29. Simple performance upgrade
  30. Bone stock 1/8th mile
  31. Horsepower war keeps going with Mustang GT500 SS
  32. New LS3 Engine Picture
  33. Anyone know if the stock cam has any advance?
  34. No codes with Cam
  35. Nology Wires
  36. WTB Snake Charmer Shroud - C6
  37. Diablosports Predator.
  38. C5Z06 to LS3: Mods for equivalent handling / braking?
  39. 2006 Z06 Calipers/rotors on 2006 base
  40. What's My Gains......
  41. Clutch Replacement
  42. CHEAP ROTORS any good
  43. why only 4.3 sec for LS3 0-60?
  44. Global Warming? Here's a nice option.
  45. New announcement at Bowling Green for 08 C6s
  46. Which Oil and how much?
  47. XX tire pressure reading on the DIC
  48. Spacer For C6 Snake Charmer - Yes Or No
  49. CAT Delete pipe
  50. Any BBK's that will clear the stock rims?
  51. Track rental at BMP
  52. Anyone got any pics of empty engine bays?
  53. More cam tech Qs: help - gurus please step inside
  54. Any torque loss with short duration cam?
  55. Dyno numbers: ARH & Vararam
  56. I think I've beat the DONE!!
  57. Question on rotational mass
  58. Hard wire...manually turning off DTC P250A????
  59. exhaust cut-out question
  60. Best place to buy a Borla Stinger catback?
  61. Breathless Performance Shifter??
  62. LS2 injector ???? s
  63. C05 - HUD (Heads Up Display)
  64. Mods going on tomorrow
  65. First time to track with 06 A6
  66. In Car Video-LG Motorsports, World Challenge C6- Long Beach GP
  67. Who has traction with high Hp?
  68. headers that will fit factory cat location
  69. Dynatech's SuperMaxx Long Tube Headers - $100.00 Off + FREE Shipping!
  70. does this sound right?
  71. Help I Want A Intake
  72. Coat or not to coat (headers)
  73. Toluene for the track
  74. procharger installed. need help
  75. Disable F55 Option?
  76. What's the height difference of Callaway Short Shifter?
  77. Air intake rain shield problem
  78. FAST Intake
  79. Accuracy of tire pressure sensors
  80. Corvettes to race in GT2 category?
  81. Best Cam Only Info Request ???
  82. Extra Seal
  83. Whats Needed To Swap Tires To New Wheels
  84. Whats The Best Tire
  85. a little help with exhaust install
  86. Cartek should be banned
  87. Cost of a Centri SC Kit
  88. Pfadt sway bars
  89. Firestone wide oval ?
  90. Head and Cam For Future FI Apps.....
  91. Z06 exhaust vacuum lines
  92. No hassel tire swap Idea!
  93. Weight of stock(non drilled) rotors
  94. Clutch Engagement
  95. LG Motorsports Header/G5X1 Cam/FAST results! 450RWHP!
  96. What causes cam failure?
  97. How to get at climate control?
  98. Vararam/TBS plus Corsa sports results?
  99. What is considered....
  100. T/C A/H and Competive Drive Mode w/nitious???
  101. mod friendly dealers in DFW??????
  102. how can i adjust the height of my low beams?
  103. This doesn't seem good at all...
  104. Exhuast B & B Bullets or Corsas?
  105. High temps after thermostat change
  106. ls7 clutch and c6 z06 clutch the same?
  107. varam install
  108. GM Performance L92/L76 Here we go!
  109. ForgeLine Model blowout
  110. Rear Spoiler
  111. Best Ss Brake Lines
  112. Z51 Bilstein upgrade
  113. Are Z51 rear brakes bigger than base model front brakes?
  114. How high on the HP, without wider wheels?
  115. Battery acid levels
  116. I Need DIY Instructions to Change Brake Pads
  117. Can anyone confirm what Comp mode does...
  118. Size of the brakelines in C6 ??
  119. c6 A6 going to z51 3.4 gears anyone?
  120. HELP! Tire sensors bugging out!!!
  121. Had to pull fuses to correct....why?
  122. what is reasonable rate for......
  123. Factory HID
  124. removing drivers door panel ?
  125. Toggle Switches
  126. 2005 rear diff case option
  127. [PICS] What a day for a cruise w/top off! -- DELETED
  128. Vararam install.. Please help
  129. Fuel Injectors
  130. ProCharger Installed
  131. 2006 C6 exhaust
  132. Anyone have the rear clutch discs replaced?
  133. Portenza RE050A opinion????
  134. Best C6 Street Clutch?
  135. Back from the track not as happy-what do you think?
  136. Header Install Question
  137. One way to support O2 sensor wiring on header install
  138. Clutch STILL sticking after slave cylinder replacement!
  139. Clutch STILL sticking after slave cylinder replacement!
  140. Radiator flush with drain and change of coolant
  141. C6 Caliper (FYI ~ C5 Install)
  142. Seat has lost it's memory
  143. Got to run the 07 c6z51 mn6 with...
  144. No Competative Driving Mode, Why?
  145. LG Forza Front and rear Carbon fiber splitter and spoilers
  146. C6 rearends.....
  147. convertible deck lid
  148. Would very much like this sound...
  149. I Ran the 1/4 Today,Times inside!
  150. Just got my C6 not even a week ago and look...
  151. Looking for an exploded view
  152. Should I Advance The Timing?
  153. Cheapest place to buy American Racing Headers?
  154. More promblems, now what?
  155. New Wheel Design from ForgeLine!
  156. Why does the car "feel" slower with TC/AH off?(Comp. Mode)
  157. Anyone have an exploded view of the rear housing?
  158. These valve covers are Nasty......
  159. Off to the track today after some changes
  160. URGENT question for those who installed the FAST 90 WITH the MAP relocation kit??
  161. Charlie Williams Tune
  162. Just saw A Mint Yellow C5 smashed up.
  163. Mods are complete for now..
  164. C6 Shifters
  165. Help Please With Tire Sizes
  166. A6 owners who heavily mod..step in...
  167. Procharger Installation Question - Crankshaft Bolt
  168. Exhaust System Fuse Location
  169. Thinking about trading Z51 for selective ride Help!!
  170. Tires again!
  171. Hardend Shafts -- Needed or Not?
  172. ** $150 Mail Order Tuning & New Shop Announcement **
  173. Headers and Excessive Exhaust Smell??
  174. Location of A6 Transmission?
  175. Squeaky brakes
  176. Any update on new sport konis for c6 ?
  177. 1st Time at Drag Strip....Need Advice
  178. Kooks Or Melrose Headers System?
  179. Brake education ... Z51 Vs Z06
  180. Wheel Spacer Question
  181. tubs for vert
  182. Who in Midwest installs 4:10 rear ends
  183. Numbers of new mods on 06 A6
  184. power programers
  185. Question about callaway short shifter
  186. Insalation of rear fenders?
  187. anybody know of a good window tint co. in Los Angeles who
  188. Help with fan settings?
  189. Any issues on headers/exhaust on new C6
  190. Climate control 05 C6
  191. Any Vegas Tuners?
  192. creaking noise coming from rear
  193. Electrical tech question???
  194. B&M shifter install trouble
  195. Directions, please, 2005-2007 differences.
  196. Instructions for replacing the thermostat?
  197. Tires and wheels
  198. video: C6 smacks the wall at the strip
  199. Roller Rocker Install Query
  200. Changing tires? Special mounting/dismounting equipment needed?
  201. Firestone Wide Oval Tires
  202. C6 vs. C6Z mufflers; whats the difference?
  203. Anyone installed Corsa's with LG LT's on an A6?
  204. Synthetic Brake Fluid for the Clutch
  205. 2007 C6 Leans To The Left
  206. Where to get G.M. Racing Spoiler
  207. Can i put the same calipers that are on the front on the rear
  208. 2007-C6, Z51 6spd M 1/4 mile & Top Speeds
  209. B&m ?
  210. Check Engine Light in Newark, DE
  211. Best Headers
  212. Next possible mod question...
  213. Tuned by Cartek, 799 head car
  214. Which gears?
  215. p2066 low fuel sensor code?
  216. Z-51 sway bar conversion question
  217. Help Needed to Relocate Evap Purge Valve
  218. What are your torque numbers with bolt-ons + cam only?
  219. LPE Mini Tub Kit
  220. Billet V8 block with a 5 axis mill
  221. ProCharger oil change simplified
  222. LSx engine forum members...
  223. Blue Red or Green display?
  224. '07 Z51 A6 HP Suggestions
  225. Comp Cams 226/230, lift 569/574 117 lsa
  226. Brake Fluid
  227. Vararam + Blower?
  228. Trailering a C6
  229. opinions on this set up
  230. Got my 2007 Tuned by Charlie @ RPM
  231. Diablo Sport Tuner
  232. Factory Alignment Specs
  233. headers?
  234. how important is the differential strut
  235. Is This Ok?
  236. Lower car= bad launch? Input?
  237. Z06 Exhaust install in C6 Vert
  238. Acceptable quality from Kooks?
  239. Help with Radiator Upgrade - quick question
  240. Which Tires for event?
  241. c-6 rear diff
  242. best et non drag tire
  243. Vibration noise from shifter
  244. A Corvette funny for You! The end is near!
  245. Need Mufflers!!!!!
  246. Question about GM brake pads....
  247. Vararam reducer size?
  248. Couple Videos of MTI G1 Cam 228/232 113,AFR Heads, Kooks 1 7/8, Corsa Sport
  249. Kooks And Callaway
  250. help, diff fluid change
