View Full Version : C6 Tech/Performance
  1. Interesting Gasoline Information
  2. [PICS]New Modular Concept Wheel Shoot[PICS]
  3. FAST gains over ported stock LS2 manifold
  4. NOS-FUEL gauges & pod
  5. Decesions, Decesions
  6. Paddle shift and borla stinger question!
  7. C6 electrical
  8. 2009 Exhaust
  9. does a throttle body spacer make H.P. gains?
  10. Vette chic twins go to the strip
  11. Corsa sport- is X Pipe Critical
  12. help with door panel
  13. HUD Installation Guide now available.
  14. How much wider are ZO6 rear quarter panels than non-Z06?
  15. 05 c6 6spd Whining / Winding Noise at low speeds in 1st/2nd? PT warranty ticking!
  16. Question - Is there a difference between Z51 Brake Pads and Non-Z51 (stock)
  17. Took the 08 to E-Town today for 1st time
  18. head gaskets
  19. Damage do to Jump Start HELP! "service charging system"
  20. Killer deal for Coated Kooks headers installed and TUNED
  21. 2007 zo6 exhaust on my 05 c6
  22. Codes
  23. fast intake question
  24. M2W question
  25. Doing Wide-Body, putting Z06 copies on, offset? Anything I need to know?
  26. Z-06 suspension
  27. High Speed Wobble/Low Speed Jitters
  28. Steering Column Modifications?
  29. Spec Twin disc. I hate it
  30. How do you guys log IAT's ?
  31. Drove in the rain for the first time with my VaraRam yesterday.Guess what happened ?
  32. Lowering IATS With Cold Air
  33. My new motor questions
  34. 3" electric exhaust cut outs
  35. 2005 Automatic Shifter Sticking
  36. Wheels and tires for HPDEs?
  37. 08 clutch question....
  38. Very cool animation of the LS2 being assembled!
  39. 08 M6 Cam, Killer Bee and AR Headers Results
  40. tires
  41. Did 2007 standard brakes ever have drilled rotors?
  42. 2007 Z06 Bi-Mode Exhaust Help
  43. Any Ideas???
  44. Help, my battery died...
  45. Callaway Honker
  46. when installing HUD should i ???
  47. Roof panel squeek
  48. install tires on rims?
  49. shroud for vararam
  50. water meth on non sc car?
  51. Exhaust venting when working in a closed garage...
  52. RPM Track Rental / Dyno Day - Sept. 5
  53. Need seat grommets for harnesses
  54. Rim and Tire help
  55. What gears?
  56. ZO6 H pipe fit LS3 Cats
  57. LS3 Cam Install with LS7 Exhaust and Bolt-ons. (Pics and Dyno)
  58. need c6 drivers side wiring harness diagram
  59. Z51 Brake noise
  60. whats involved in taking off all 4 calipers?
  61. Need help with loud tire noise
  62. E3 spark plugs................................... ......
  63. vararam with no shroud
  64. Heads and Cam Question
  65. Z51 suspension...to be or not to be?
  66. Fuel injector question?
  67. Sway bar turnbuckle adjustment
  68. DIY caliper switch?
  69. Rotating mass
  70. Kooks header & high flow cats w/crossover pipe install
  71. Anyone have the Lingenfelter LS3 525 package?
  72. Service Traction Control & Active Handling
  73. Rear differential swap - DIY guide?
  74. **who makes this rear difuser?**
  75. NPP exhaust from a 2009
  76. Tire Sizes with bigger wheels..PICS PLEASE!
  77. TPMS Tire Sensors 2008 C6
  78. painting fuel rail covers
  79. Head Up Diplay - C6 Competition
  80. HVAC system problem, 05
  81. B&B Retro Fusions In Stock and On Sale - Includes Round Tips w/ Wiring Kit!
  82. Nav factory/back up camera
  83. C6 Air Filter Recommendation
  84. Second annual RPM Track Rental - Sept. 5
  85. What's needed to connect Z06 h-pipe to LS2 borla?
  86. Genuine GM taillights
  87. Questions about using 100 plus octane fuel
  88. Vibration through shifter at 4k rpm
  89. replace fob with switch
  90. NGK TR55 spark plugs
  91. Dealer WTF
  92. LS2 heads or cam only?
  93. New best in the 1/8
  94. Help removing rearview mirror lights
  95. Wheel Size 18" MT DRAG RADIAL
  96. Inefficient Corsa Cats Code
  97. C6 Horn Problem?
  98. mild and wild part 2
  99. Anyone dyno the difference from 2.5" to 3.0" duals?
  100. 2008 LS3 Air Filter
  101. torque tube ?'s
  102. Hardwire V1 in 2009 Z06
  103. AEM Wideband install...
  104. dual mode exhaust 2006 coupe
  105. NPP question on 08
  106. Fuel Door Solenoid Stuck Closed, Fuel Door Won't Stay Shut...
  107. is the 08 diff and gear the same as 05-07
  108. Traction Issue
  109. Facts about HP
  110. question on z06 brake piston sizes and info on the rest
  111. C6 AC Drain?
  112. Road Race guys: Anyone ever try the Kumho V710's?
  113. post pictures of your aftermarket muffler tips
  114. First track day in the 'Vette
  115. any LS3 owners using a catch can?
  116. Help with Battery voltage
  117. slow loading
  118. Question about the EBDM.
  119. Vengenance Cam install
  120. COW A6 mail order tune removal made EASY!
  121. GCA Off Road or NPP?
  122. Who makes LS3 fuel rails?
  123. Airbag readiness warning?
  124. mild and wild
  125. FOR ANYBODY CURIOUS ON 08 AIRRAID/ECS MINI TUNE #'S ON THE DYNO Here are mine.
  126. 357rwhp dyno run Good?
  127. New Best Time 12.07 @ 115.30
  128. Callaway honker
  129. A Great Big Thanks From A.R. Headers
  130. Is there a poly bushing set for BASE rear swaybar?
  131. NGK TR6 Spark plug cap ?
  132. Tip: Map Light Bulb Removal
  133. Service Active Handling Message
  134. Odd noise coming from engine & I can feel it in the pedal.
  135. Widening Stock 19" wheels to use Z06 Rubber
  136. C6 Z06 Ceramic Brake Pad info??
  137. hats off to Cartek!
  138. CEL FIXED AT ECS.Now an occasional rpm surge to 1500...
  139. Questions about removing battery and sensor
  140. Steering hub?
  141. 2009 exhaust change
  142. Can the '09 LS3 gain power from tuning?
  143. Wiring diagram for the seats
  144. Cags disconnect access question
  145. C6 automatic trans cooler
  146. Tranny temps,,,
  147. Wrapping fender under hot weather?
  148. Nitto Invo problem
  149. 2008 transmission problem
  150. drag car
  151. Anyone got instructions for a front wide body conversion?
  152. GM performance off road exhaust
  153. It's a PASSION
  154. Tire Pressure Sensors
  155. procharger, and m.mt drag
  156. C6 sreeching sound shifting to 2nd
  157. Battery change......
  158. iliveingermany and need new speedo
  159. Crank Pulley
  160. Oil cooler removal
  161. B&B Bullets don't fit question
  162. surging/missing
  163. Does any body know how much torque?
  164. Will it reduce heat to ceeramic coat exhaust in the tunnel area?
  165. Need part number please!
  166. Does the c-6 steering wheel lock?
  167. Fast 92
  168. Can I get better handeling?
  169. Any pic's of CCW T10's on C6
  170. Z51 with Z06 rear swaybar?
  171. I want more power!!..Use more mods or buy Lingenfelter
  172. A short Video of the MGW shifter in action!!!
  173. They finally broke me ! Bought a Vararam today at Carlisle
  174. z51 vs. f55
  175. Any CAI add more than 10 hp without cutting?
  176. Converter question - Single or Multi Disc
  177. Any Tips/Hints in Rocker Arm install
  178. Kooks Headers Special!
  179. Final touches on LS3 Bolt on package completed!!!
  180. LS7 Carbon Fiber Intake Manifold
  181. What oil do you use in your TR6060?
  182. 0.040 Cometic Gasket for L92 Heads
  183. Tire Pressure
  184. !Please help me find my mis-fire!
  185. I pulled the trigger. Thanks Vengace racing!
  186. torque tube coupler
  187. Clutch
  188. targa roof
  189. Getting z06 wheels, is switching tire sensors from current wheels tough?
  190. Power window motor from wrecker
  191. tire size??
  192. Convertible question
  193. Leaking weather stripping 2008 Z06
  194. Vararam Help
  195. Anyone tried a "Mufflers Only" on the C6 yet?!
  196. can hp tuner and predator tuner work together
  197. SpinMonster and AintQik FAST 92 Install
  198. Hot Engine A/C OFF. Help !!
  199. Jammed Roof Panel
  200. Stock Z51 Rotors
  201. Sharing exhaust experience
  202. Clutch Pedal to the Floor
  203. Calling all LS2 A6 Dyno Sheet holders...
  204. MGW 15% Shifter Quiet Nice
  205. 2009 GM Accessory Splash Guards Now Available!
  206. Pfadt Racing, Brand P, and an actual Shock Dyno
  207. To Sipe or not to Sipe...Thats is my question to all of you!
  208. What non run flats will fit a Z06?
  209. What size allen wrench for rear diff drain plug?
  210. Clutch Problems
  211. ethos gas saver
  212. bogart to try to make us a 16" drag wheel - need help with measurements
  213. O2 sensor wire routing help
  214. Radio changes channels when turn wheel?
  215. Who makes the better C6 drag radial - Mickey Thompson or BFG?
  216. 60 lb. injectors: Correct length & connector (USCAR/EV6) for LS2?
  217. stock LS3 cam in a ls2
  218. Vararam and Kooks with Catted X Package (LS2/LS3)- Save for a VERY Limited Time!
  219. Chuck CoW TUNING @ CORVETTES @ CARLISLE
  220. How to change the Signal bulb ??
  221. Anyone experience: Navigation "unable to calculate route" for all destinations?
  222. Indexing spark plugs
  223. 2008 MN6 Coupe - Baseline Dyno / Dyno with Veraram and Headers
  224. New setup - 07 A6
  225. Gas Mileage MPG on YOUR MN6 w/ 4.10 Gears?
  226. SLP C6 Long-Tube Headers
  227. Alignment & Corner Weight '08 C6
  228. c6 sub box
  229. DeWitts Radiator
  230. Pictures of my c6 'lowered'
  231. lets see your drag packs
  232. Battery Relocation kit or DIY
  233. There Is A Good Corvette Tuner In Kentucky!
  234. Situation with defective part
  235. Vararam question?
  236. Need Help: Switched 12v power source
  237. A6 paddle question
  238. F55 Magnetic Selective Ride Retrofit?
  239. C6 oil capacity
  240. Weird Engine Symptoms
  241. AUTO conversion
  242. Anyone sell a Brake duct kit for the c6?
  243. How can you tell if a vette's been tuned?
  244. DTE Differential Shipments (info & pics)
  245. My output shaft update
  246. Lowering, removing bolts all together???
  247. Weird clunking noise when shifting???????
  248. Z06 muffler question-did a search already!
  249. Wanted: Wiring diagram ls2 and 6l80e
  250. Gauge Lighting Part Duex!
