View Full Version : C6 Tech/Performance
  1. Intake and Throttle Body Special for $325.00 Shipped
  2. torque specs for sway bar connects
  3. PART # NEEDED ASAP.07 CATS.auto z51
  4. Preload bushings after lowering?
  5. • • • Announcement RPM Motors Expansion • • •
  6. Vac. source for Z06 mufflers???
  7. Check Oil Level in Dic...
  8. Exhaust bolt fell off, two others loose
  9. Had a weird thing happen today...
  10. '09 steering in '08 C6?
  11. 87 octaine
  12. '08 Differential Shop Manual
  13. Slack in Automatic Tranny (HELP)
  14. Why is my Spec clutch sticking to the floor ?
  15. Intake question
  16. Bad Squeak But Not When Turning Right
  17. 402 block question about compatability between C5 and C6
  18. Best $190 spent on Mods! F55 to Z-51
  19. i need a tuner in stuttgart germany
  20. Halogen on low beam
  21. 2008 A6 downshifts with 3/4 and Wot..
  22. 10% ethanol at the pump
  23. 2008 Z06 vs.2008 Z51
  24. Question re: Heads up Display
  25. X pipe question?? Need info!!
  26. New PCM Part # and cost please?
  27. MSD COILS and NO FUEL RAIL COVERS??? Please post pics
  28. Ported intake/heads inquiry
  29. Question on quick shifts with short shifter??
  30. )k guys, im trying to get a day to track meet
  31. Competion setting
  32. Koni fsd review
  33. Want rotors and pads upgrade on Z51 C6
  34. Cat / o2 sensor HELP
  35. Service Tire Monitor message ---- why
  36. Halltech Venom Beehive Installed (Pictures)
  37. I want to run 11.5 in the Summer Heat
  38. zr1 clutch
  39. Motive Brake Bleeder Question
  40. Borla Stinger Install
  41. 05 clutch question
  42. What gearbox oil for my 2008 6 speed manual C6, RED LINE?
  43. Headers -Z06-
  44. Help!...something is wrong.
  45. x pipe worth it on a stock motor?
  46. breaking into the 10s
  47. I need Tire help......
  48. Seatbelt light never goes off?
  49. Best resr end??? Where???
  50. New comp cam sound video...
  51. Need New Throwout at 8K
  52. A&A kit dyno tune.
  53. Need to Vent, while my condensor drains out!!
  54. ***wcc new led tail light sale***
  55. Magnaflow Exhaust
  56. Wheel center cap painting how-to (Pics)
  57. 08 battery & alarm issues
  58. Addatives
  59. New color on Z51
  60. Yeah, another Vararam thread. Pre-cut shroud issue.
  61. Who says PFAST gains are negligible? Dyno Sheet!
  62. 360 Forged TP sensor problem
  63. Good Service around Hollywood CA
  64. to upgrade brake linens or not?
  65. A4 Exhaust Discussion
  66. Michelin PS2 ZP
  67. Will 3" LG pro headers work on a non moded car?
  68. Installed a Progressive Shift Light
  69. R compound tires
  70. 08 LS3 bolt on only 1 3/4" or 1 7/8"?
  71. Head swap cost?
  72. B&B Bullets Alignment?
  73. ?? on drag racing
  74. exh cut outs
  75. Hot New GT2 Rear Diffuser For C6 & C6 Z06 track and Street what do you think
  76. magnetic oil plug
  77. C6 and C6 Z06 Twin Racing Oil Cooler System
  78. H&C Anyone out there running this?
  79. Apsis C6 ZR1 Splitter installed on car, Welcome your opinions, *PIC SHOWN*
  80. 09 LS3 Running hot ?
  81. Just got a C6, going to track, need help
  82. Best Intake To Buy For 2007 Vette?
  83. Gumbys vs Standard rim weights
  84. Rear Caliper Bracket? What am i missing, pic included
  85. TSB for Shifter Rattle
  86. how do I remove the two black plastic cradles...
  87. Z06 Widebody Parts help?
  88. After market valve springs...with two-piece bases
  89. Best cam for stock 05???
  90. Thermostat
  91. Pics of C6 with Z06 rims on front?
  92. 05 to 09 interiors
  93. Got 160 thermostat but??
  94. Head and Cam question?
  95. New best 1/4 Passes!!!!
  96. alignment
  97. Engine Rattle/Ticking on cold startup
  98. Corsa exhaust install diy--please step in if you have
  99. Need a engine..HELP!
  100. More Reasons to choose ForgeLine and LGMotorsports
  101. Possible Head Cam setup.
  102. Drag strip "Driver mod" advice...
  103. HUD install in non-HUD C6
  104. Borla Exhaust for 2008 Z06
  105. Want to Ultimately get a Supercharger - What Mods Should I Do Until Then?
  106. Oil usage problem, help
  107. Apsis C6 ZR1 Splitter Finished Prototype, Like to hear your opinions *PIC SHOWN*
  108. First mods
  109. When is a C6 "warmed up"?
  110. Red line...can it be safely increased with the right mods?
  111. Gear question
  112. Hey You: Interested in a Rear Gear Group Purchase?
  113. Lighter Fuse replacement
  114. New Amsoil fluid for M6 guys
  115. DeWitts gets my A+ rating
  116. disconnect active handling and traction control
  117. is h-pipe functional, structural, both ?
  118. Crossfire in a C6!
  119. brake squealing
  120. My new comp cam dyno...
  121. Compute your valve events - spreadsheet
  122. Where is the COOLANT Air Bleeder SCREW???
  123. Vert Top Sticks
  124. best vendor for Halltech Killerbee ?
  125. Leaking Transaxle
  126. Non Worthy Transmission
  127. 305 invos or 325 supercars
  128. carpet fitment
  129. What are the 2 valves on the passenger side of my car next to the fuse box??
  130. Koni fsd install
  131. My LS3 cam + bolt ons at Vengeance
  132. Please help now koni fsd install
  133. Late Model Racecraft Slayer 630hp Package w/ 360 forged wheels Pics and Vid!!!
  134. Replace PCM
  135. X-Pipe Hits the Tranny
  136. A/C controller
  137. Review: Ported intake vs Fast; LG vs Kooks (Results/Dyno)
  138. CD Player "Mechanical Failure"
  139. LS2 Port Works - Free shipping on intakes until 9/30
  140. SunsetOrangeCreations NPP controller - great customer service!
  141. Traction Control while on Freeway!!!!
  142. 4 Antenna Hat Trick..where are the antennae located?
  143. Tire and Wheel sizes for a track day C6
  144. Comp gray gumbys
  145. Question about synthetic oil in new shortblock.
  146. Aftermarket clutch staying on the floor ?
  147. Brake pad installation Question
  148. priorty start
  149. Estimated power ??
  150. Brake pads for Street?
  151. Base cars Check your rear shocks
  152. CCw Wheels with Z06 tires
  153. Big time trouble!
  154. c6 voltage problem
  155. ls3 valve angle?
  156. GM's Mud guard - problem??
  157. Thinner Jacking puck?
  158. DA Calculator that looks up the weather for you runs..
  159. 60lb and 73lb INJECTORS FOR THE c-6
  160. Callaway “Honker" & Vararam vr sc1 filter question
  161. 2007 corvette LS2 engine tuning questions!
  162. Track allignment
  163. intake truths
  164. B & M shifter bushing problem
  165. Brake issues, what do you think.
  166. RPS Street Twin Lite Installed
  167. part number to fit C5 rotors on Z51?
  168. Installed ready for tuning
  169. Advantages of having x pipe vs h on corso exhaust
  170. C6 newbie
  171. Finished Vararam install couple ???
  172. Bassani Installed
  173. Big mouth
  174. clutch pedal hangs up....
  175. Z06 rotor coolers
  176. Seat back unzipping.
  177. Corvette C6 Granatelli MAF Sensor
  178. Racing seat recommendations
  179. Kumho Ecsta SPT
  180. LSX Shootout, Memphis, Oct 9-12, 2008
  181. Manual to Auto Conversion Possible?
  182. Dyno results from revised 403 stroker....long, but a good read
  183. 08 dead gas pedal
  184. 427 overheating issue
  185. Who has put 305's on cray scorpions?
  186. Rim Question
  187. interior cleaning question
  188. OE replacement front rotor Z51 made by Brembo
  189. WCTA needs Vettes for testing new surface!
  190. Service ABS/Handling System warning light
  191. brake pads
  192. Another....2009 stock dyno results....
  193. Halltech Beehive Venom™ RAIS
  194. Need advice '09 clutch/trans/diff issues
  195. Additional Oil Pressure Sensor on LS7
  196. Help est. HP: Dyno on Mon.
  197. Performance shop around Houston?
  198. C6 z06 seat q.
  199. 4.10s in 08 ?
  200. headers with B&B bullet exhaust?
  201. Ethanol WTF
  202. Chuck CoW Tuning In Wichita, KS
  203. GM Parts House September 2008 C6 Specials!
  204. Drivers Door just blew open
  205. 4 out 6 ZR1 Carbon Halo already have MILKY Spots, Can you believe it? *PIC SHOWN*
  206. Brake Upgrades
  207. Koni fsd and ride height adjustment
  208. Apsis C6 ZR1 Style Front Splitter Prototype, Like to hear your opinions *PIC SHOWN*
  209. Front fender not staying in place??
  210. Suspension advice?
  211. Bolt on advice for a 2005
  212. 08 Center Caps Plastic or Aluminum?
  213. Livernois Motorsports LS2 Head/Cam Packages
  214. New meat hooks
  215. anyone gut the stock mufflers ?
  216. Lowering IAT with Heat Extractor Hoods?
  217. IPS CNC Cylinder heads CLEARANCE SALE!
  218. Nav Wiring Diagram
  219. NPP Exhaust Filler Panel Installation
  220. Does it exist?
  221. 2008 Air Intake Question
  222. cam in a a4
  223. Storing Injectors?
  224. What is the lightest make model wheel?
  225. aftermarket navigation with oem bose speakers, HELP Please
  226. Latest on tires?
  227. Brake pads
  228. z06 exhaust?
  229. Vette Died, No Fuel to the Engine
  230. My Gas Cap Won't Tighten!
  231. trans blown up??
  232. DIY K&N Filter Housing
  233. Brake Question
  234. drag race and street
  235. **LG C6 Street Series Header SPECIALS!!!**
  236. **Last change on Forgeline Specials from Carlisle....until SEPTEMBER 6th**
  237. Will a Borla S-type Exhaust made in 05 fit an 08?
  238. Reset Transmission code?
  239. Floor jack question
  240. Aux oil cooler
  241. Need new tires...need some advice
  242. 09 Issues?
  243. Shift update for 2007 Paddle Shift?
  244. Will '09 NPPs fit on '05-'07 C6s?
  245. Installing headlamp washer
  246. Why does the z06 sit lower than c6 coupe
  247. so since i cant fit 16s on my car`
  248. New Wheels (lightweight) For My Autocrosser
  249. Running with out TPS
  250. External Oil Cooler ---Help!!!
