View Full Version : C6 Tech/Performance
  1. all pfadt products on sale
  2. Has anyone installed the ACS or SLP ZR1 fender knock-offs?
  3. Z51/Z06 Toe Link Boot Replace/Upgrade?
  4. Anyone replace LS3 with LS7 in GS Coupe?
  5. 06 w/ Borla Exhaust and loud harmonic noise
  6. ***RSD Line Loc FS***
  7. October 2011 Aftermarket specials at GMPARTSHOUSE.com
  8. Halltech Ultraleggera Z06
  9. Need closeups of fuel pump assembly connectors anyone?
  10. Do you have to change ANYTHING on an LS2??
  11. ARH 2" headers + 3" catless x-pipe + B&B Bullets... too loud?
  12. Help me resolve a heated "discussion"
  13. Jacking locations?
  14. Whats this we cant answer phone
  15. Will Z51 C6 brake upgrade help me with...?
  16. Cold Air Mod?
  17. Help, I have a problem with my 07's headlights!
  18. Question about replacing heads on LS2
  19. Tire diameter vs gear ratio.
  20. Finding codes ??
  21. Help question about FAST 102 on an LS2
  22. C6 Drag Racing Rims
  23. clutch/transmission problem
  24. Tire Pressure Question
  25. Loud front-end vibration: help with brainstorming (hub?)
  26. Kooks Headers Sale- Free Ceramic Coating or Big Savings this Fall!
  27. Brake Upgrade
  28. Save Big on Catbacks & Cutouts this Fall @ MarylandSpeed- Borla, Corsa, B&B, DMH, etc
  29. C6 Engine Cradles
  30. Important Super Bee initial install maintainence
  31. Cam only LS2 Drag strip Vids
  32. Intake Manifold and t/b and Rear Gear ???
  33. A/C starts blowing warm air?
  34. Help, I got ink pen on the tan leather
  35. After z06 exhaust modificatiom gas smell and lean code
  36. Dragtimes has a new iPhone app to calculate DA
  37. What gear oil to use 2007 c6 3.42 differential ?
  38. flowmaster american thunder exhaust
  39. Need some help with A6! DR's? Launch ? and Set up
  40. New Nav
  41. A4 Brake Transmission Shift Lock Control Solenoid Replacement
  42. Tuning software
  43. Oil Overfill
  44. A&A S/C LS3 with A6 Tranny goes 9s in TX....
  45. 2007 corvette rear end housing
  46. What is the best upgrade for Z51 brakes for least $$.
  47. Sway Bar Links Again
  48. Just installed z06 exhaust on ls3
  49. Halltech Carbon Super Bee CF112/Carbon Beehive Pak
  50. Pic of the day!
  51. LS Series Street Car Shootout Nov 11 & 12 Orlando FL
  52. Another set of Daytona seats and D bottom wheel going to SC
  53. looking for good tuner south florida
  54. Ragin Racin stage 3 Grand Sport completed
  55. New best 1/8 mile only!
  56. Ready to dump my dream car! SCL troubles?
  57. any gp coming on upgraded drivetrain parts?
  58. Still scratching my head
  59. C6 Choppy Dyno
  60. z51 z06 brake question
  61. Ventilation system and A/C compressor
  62. Gas smell coming through a/c
  63. 2011 LS3 M6 w/ NPP
  64. 2007 corvette chassis- scematic drawing
  65. Caravaggio race seats in WI
  66. Caravaggio D bottom wheel going to CA
  67. 2010 GS NPP on 07 C6 m6
  68. Ac help please
  69. Want a Free Tick Performance Shirt? Guess the RWHP of our latest ProCharger Install!
  70. Mis-matched Tires on Road Course: Understeer Fix?
  71. LS2 Boost discussion
  72. Borla Atak Rear Section vs Catback
  73. what kind of hp gain?
  74. car misfires on the top end, any ideas?
  75. C6 Corvette Shifter Housing Bushing Kit
  76. Should Vendors Be Held to Quoted Prices?
  77. "Buckle passenger" message on DIC & get a audio tone
  78. TF 225's on LS3?
  79. Underdrive Harmonic Balancer Question
  80. C6 exhaust question
  81. Z06 differential swap into '08 C6 (oil cooler)
  82. Would this concern you: car fax report air bag
  83. Removing Fuel Pump From Tank-Help
  84. GTO Drag Pack drops ET and gains MPH...
  85. Updated shift box 25823572 question
  86. Radio Controls - can I add to 2007 2lt??
  87. Brake Rotor Stuck
  88. Exhaust tips for 2007 Corvette
  89. Just bought new wheel for my c6.... Used zo6 ones...
  90. Happy 65th Birthday to Jim Hall means a huge sale through September!!!!!!!
  91. c5z diff in 05 swap DIY please
  92. American Racing Header Question
  93. Bolt On 500HP Package, C6 LS3 less than $2500
  94. Replacing tires 2 questions
  95. •► ► Eric Linder's AWESOME E-FORCE ATTACK PACKAGE ◄ ◄•
  96. ***RSD NHRA Legal Bolt in Roll Bar***
  97. C5 Heated O2 on a C6. ASAP!!!!
  98. Anyone see or install new zr1 steering wheel from ecklers yet?
  99. Cylinder head experts step in and assess this damage. Lots of pictures (warning)
  100. Auto transmission shift to drive when cold...
  101. So I made a vac source for my non NPP GS ZO6 exhaust install.
  102. Anyone own a GS with MSRC?
  103. Another MGW Shifter Question
  104. Installing a new custom grind Comp cam-necessary to degree it? If so, tips/tricks?
  105. LS3 Problem
  106. Wow...Corvette General is a different group than Tech!
  107. Electrical radio problem
  108. LS3 High Oil Pressure Question
  109. installing my cage
  110. Engine light w/ code : camshaft position sensor
  111. 2011 rear hatch
  112. My Narrow Body C6 with Z06 Front Wheels (Pics)
  113. Key FOB interchange ?
  114. Electronic Ignition Switch
  115. Whats needed to switch to manual trans??
  116. Please help my find this turbo stud
  117. So, everything driven by a belt has died...
  118. LS2 Z06 Exhaust Install and Review
  119. Outside Temp.?
  120. Window stuck open-help!
  121. LS2/LS3 failures
  122. Staying cool...
  123. So I picked up a ZO6 NPP exhaust for my GS
  124. Which sway bars?
  125. Autometer Cobalt Boost Gauge owners or vendor help needed
  126. Are all c6 fobs interchangeable?
  127. Clutch replacement
  128. Shifter Vibration normal??
  129. Noise in drivetrain help please
  130. Emergency!! I'm an idiot and need your help
  131. LG Suspension Upgrades @ JWM- Sways, Coilovers, and Endlinks
  132. For those of you that have cut your stock bushings...
  133. New LS2 H/C numbers 518whp 468wtq
  134. Need Help! Cammed LS2
  135. Would this exhaust fit?
  136. Caliper bolt size?
  137. Recommendations for a subwoofer box
  138. new personal best
  139. Bilstein shocks not yellow?
  140. 2008 A6 slipping 3rd gear
  141. Repairshop recommendation in Katy Texas
  142. ========> IS CHUCK CoW COMPLETELY %@&#ING INSANE ?!?!?!
  143. Catch can or not?
  144. c6 clutch
  145. ***09 C6 with Twisted Slayer Package from Late Model Racecraft***
  146. **C6 Z06 Slayer Package By Late Model Racecraft**
  147. **C6 with 408ci makes 582rwhp by Late Model Racecraft**
  148. -103 RWHP Gain- LS3 Corvette G6X3 Cam package at LG Motorsports
  149. New Product - Carbon Fiber Gauge pod with matching passenger side
  150. 2008 A6 Shifter Issue
  151. FS: 509hp Katech Torquer LS2 with Katech valve covers
  152. How fuel is drawn from both tanks?
  153. BORLA 11744 '05-'08 sport exhaust $1250
  154. Any Drag Raidals for stock size rims 19x10?
  155. Qtp electric cutouts low profile $325 obo
  156. Another oil temp question...
  157. I need racing alignment in South Florida....PLEASE POINT ME IN THE RIGHT DIRECTION
  158. Halltech MF103 impressions
  159. •► ► INCREDIBLE VARARAM DEAL at CoW!!! ◄ ◄•
  160. Clutch Usage
  161. P0135, time to replace that o2 sensor?
  162. You Asked, We Listened! A&A SuperChargers INSTALLED & TUNED for under $6200 at Tick!
  163. Inner CV Joints leaking again--4th time
  164. Cleaning Intake out after Catch Can
  165. I need a new LS2, high performance
  166. Another set of Daytona seats going to TX
  167. 19x10 Rear Wheel with 65mm offset
  168. How It's Made: COMP Cams® Hydraulic Roller Lifters
  169. MP3 help please.
  170. NAV. Screen, Navigation and Audio
  171. Front tire PSI for 1/4 mile et?
  172. Anyone? 102mm Tb and stock intake Question?
  173. Differences in shifters?
  174. 05 c6 harmonic damper wobble - ATI fix?
  175. Cam help
  176. Special Torx Bit for MAF Sensor?
  177. how accurate is the fuel gauge?
  178. Pfadt Race Engineering and the Johnny O'Connell Package Vs. Nürburgring
  179. DIY Write-Up on Replacing Brake Fluid
  180. Rear End
  181. 2011 GS A6 transmission flaring
  182. ** C6 Super Pro Headers & Vararam Intake Package- SAVE!!!!!!
  183. Lower cost HP add-ons
  184. ATI damper On previously pinned crank??
  185. Service Charging System
  186. Vengeance Racing STREET 427 In action... Pics/Dyno/Videos Inside
  187. Corbeau Seat Rails
  188. C6Z06 Stainless Works headers/x-pipes on LS2?
  189. Nick Williams throttle body info
  190. Pissed...OEM crank pulley went bad AGAIN...in 2000 miles
  191. HD Z06 pilot bearing????
  192. MSD 2-Step
  193. E brake question
  194. Anyone with Johnny O'Connell bars & F55
  195. *** NEW RELEASE: Polished Flat Top Billet Valve Covers ***
  196. 2005 conv. radio software upgrade
  197. Battery connected backwards on C6. Where to start?
  198. E-brake cable
  199. Anyone in Houston area...
  200. Installing Z06 exhst on C6, little things I'll need?
  201. Oil filters
  202. Lightweight Rotors GS/Z06 Size
  203. Flowmasters cat back- any good?
  204. Weak Brakes w/ New Bobcat 1521
  205. Trans cooler oil line rubbing on header
  206. Help please! Installing a Z06 differential in a '05 Z51 corvette
  207. Brake Squeal!!!
  208. Which Sway Bars for 2008 C6
  209. Window tinting in Atlanta area.
  210. C6 paddle shifters
  211. Z06 front brake caliper rebuild
  212. Window Height/Alignment Adjustment?
  213. Upgrade to Z51....worth it?
  214. What did I do to my clutch?
  215. Cryo rotors for C6 Z06?
  216. Reuse exhaust manifold gaskets?????
  217. Kooks stepped headers
  218. Just Bought a Vette, now want a turbo
  219. Snug seat belts in new GS
  220. How fast how long?
  221. Will the new 2012 Centennial Caliper fit C5s like previous year C6 Calipers?
  222. headers
  223. Service active handling message.....
  224. Msd coils packs
  225. 09 A6 torque converter
  226. A/C belt size
  227. How to drain coolant on a C6?
  228. Stainless Works Chambered Exhaust on C6 LS3
  229. A6 LS3 11.8 @119! Headers, tune, and runflats!
  230. Thoughts on Schroth Clubman?
  231. Are all c6 torque tubes the same?
  232. Halltech MAF Screen C6
  233. Removing rear bumper panel
  234. Tire question, different front vs rear brands
  235. Getting a Complete Kooks system...but ?
  236. User Experience With Tire Rack Tpms Tool needed
  237. Latest Oil Sample
  238. Katech's Color Matched Super Bee MF103
  239. LS2/LS3 fuel rail difference?
  240. Tpms Inop W/Michelin Pilot Sport A/S P Zero
  241. Looking for BB Fusion installer in Philadelphia area
  242. low beam headlight issue
  243. Finally found someone local I can trust....
  244. DTEP Differential Sale 15% Off
  245. Quick brake bleed question
  246. LS3/LS7 airbox mounted on an LS2?
  247. Cheap Tracktime Available THIS WEEKEND! - Roebling Savannah, GA - $125/day
  248. HELP Z needs clutch
  249. NEW Katech splitter and side skirts for C6
  250. Wiring help
