View Full Version : C6 Tech/Performance
  1. 4.10's or fast for 10's
  2. Ace Slick wheels & C6 Z51 brakes
  3. Battery out During Storage
  4. Going nuts need help
  5. New Product what do you think GT2 Style Side Skirts for C6 and Z06
  6. Console question - Please help!
  7. Want to Replace Stock Rotors.
  8. Are LG coil overs...
  9. What clutch should I get? LS2 Twin Turbo.
  10. Got "Active Handling recalibrating"
  11. Does anybody have speakerbox carpeting experience?
  12. Anyone using the PFADT C6 Seat Wiring Harness...?
  13. Is Advanced Dyno Inc. still in business?
  14. 06 TO 09 Exhaust Question
  15. C6 APS Twin turbo installed package
  16. Apsis' C6 Side Air Vent Now Ready To Ship, Carbon & Stainless *PIC SHOWN*
  17. What is the facotry headlight intensity?
  18. Whats the point of picking up x-pipes without cats vs with cats?
  19. Help me decide next mod
  20. Traction Problem Need Help
  21. putting on my procharger, do i need a new balancer?
  22. budget intake - which one for 08/LS3 specifically?
  23. Hurst shifter
  24. Rear hatch opens
  25. Another oil leak question
  26. Throttle body spacer on Vararam
  27. Drag Wheel Setup
  28. dynolious 1/4 mile
  29. Any sugestions on source for "in-dash/console" Exhasut Control Switch (no remote)
  30. New LG's now rattle/ HELP
  31. disabling traction control
  32. Difference between just changing shocks vs complete C/O??
  33. shock recommendation
  34. Slave cylinder needed for a new clutch?
  35. Empty C6 cats. Gains?
  36. M6 gear speeds
  37. New to the forum
  38. oil cooler question
  39. Can headlights/driving lamps be polished?
  40. do the engine covers keep heat in?
  41. Dyno Results *Video*
  42. TPE is Now a Pfadt Dist..HUGE Sale
  43. HUD unit now vibrates in my C6
  44. C 6 Grill Screen purchase
  45. Help me decide: Callaway or MGW shifter?
  46. Thanks to Ragin Racing and LG
  47. Adding a harness
  48. Put your thinking caps on
  49. 1.8 roller rockers on LS3?
  50. Fluids for Stage V a4?
  51. C6 to Z06 aftermarket body panel kit
  52. less traction w/ wider tires? is it the tire type or no sensors?
  53. Help tps wire?
  54. Which heads to drop compression ratio on LS2?
  55. ZR1 rear spoiler
  56. Service Charging System
  57. Trick Flow 225 vs. L92/L76 Dyno Graph
  58. C6 HI/LOW fan controller
  59. New Vette Owner
  60. I want to hear exhausts in person...
  61. My window quit working!!!
  62. Were did u order your
  63. Headers
  64. Top speeds of each gear with 4.10
  65. Where to get a pillar pod?
  66. Help with Baer brake rotor detailing
  67. Clutch and brake fluid upgrades?
  68. Valve covers
  69. AC Compressor running, but I'm getting hot air?
  70. Next step
  71. heyper tech for the ls3
  72. Removing the Cat Question?
  73. ***Bolt on LS3 Hits the Roadcourse with some Z06s!!!*** (VIDEO)
  74. Slave cylinder for Z06 fit a c6?
  75. So pf46 and pf 48 delco filters...
  76. How Expensive to change from perf axle to stock
  77. Anyone using the Textrailia X-Grip?
  78. ZR1 and MILD2WILD = WOW (video)
  79. Engine Missing After Prolonged Downtime
  80. Need advice on tire pressure
  81. ls3 cam advise
  82. Headers and O2 sensor code sollution.
  83. VSS/Open circuit when the car is moving. Ideas?
  84. Torco- shelf life?
  85. Mag ride switch controls DME
  86. Question On Replacing Stock Rotors With Drilled And Slotted Rotors on C6
  87. 2006 C6 Lloyds Mats Installation
  88. best rear end parts where.. vendors welcome
  89. Engine Drag Contron
  90. New Best Times 08 A6
  91. Service Active Handling
  92. New Best: 10.9091 @ 127.51
  93. Help with 2 codes
  94. TPE's NEW 6 & 8 Rib Heavy Duty Tensioner Assembly!!
  95. Kooks Header Question
  96. Fast MPH, same old ETs...
  97. Center Console Heat??
  98. 2nd time at track with 08
  99. TPS info
  100. Update: GCA C6 Accessory Splash Guards Now In Stock!
  101. New To Internal Engine Mods and I need INFO/HELP
  102. Voltage Problem?
  103. Need help on cleaning my Vararam filter...
  104. Thanks to Southern Car Parts!
  105. 08 A6 trans software in a 06 A6?
  106. Great race weather,new best times,and more broken stuff
  107. Another clutch question
  108. 2 questions please.
  109. Hit the Dyno with My LS3 Today! {458 RWHP} Fresh Graph:
  110. Need suggestion on what Mode to run
  111. Need a little advice on track day tires
  112. Employee pricing on all parts + read on
  113. Spare fuses?? HELP ASAP
  114. Putting in motor this weekend - new fluids too?
  115. 05 C6 replacing the alternator/generator ?'s
  116. *Group Buy* Apsis Z06 Mesh Side Air Vents & Hood Vent
  117. **AFR 205 and 225 cylinder heads in stock!**
  118. 3M Invisable Mask Paint Protection
  119. Injector resizing for ls1,2,3,6,7
  120. Late Model Racecraft's Magnacharged C6 Dyno Vid!!!
  121. Injector install ?
  122. Late Model Racecraft's 05-07 C6500hp Package Dyno Vid!
  123. Dealer Story
  124. Rattling caliper
  125. halltech venom question
  126. HELP: Quick replacement roof question
  127. Dyno Results
  128. Dyno'd my 09 LS3
  129. Pressure Release Noise - A/C Problem?
  130. just bought new clutch. do i need new slave? need help cuz clutch goes in tomorrow
  131. Cartek Procharged LS3 and CAM 684RWH (in 4 days!!!)
  132. Cartek Procharged LS3 and CAM 684RWH (in 4 days!!!)
  133. Is This About Average...Better or Worse..
  134. ZR1 in-car video at 180 mph... Wow!
  135. LG header install and tune $2200.00
  136. L92/L76 Dyno Results
  137. Halltech Beehive Ram Air Induction for the Venom and Stinger
  138. IPS C6Z06 9 second videos!!! MPH and ET records
  139. **LG World Challenge Hoods in stock and on special**
  140. Altitude and compression discussion
  141. 08 C6 Wheel Problem
  142. $3000 L92/LS3 conversion
  143. OnStar module location on an '08 C6??
  144. **$229 LG Motorsports Silicone coolant hose kit special**
  145. Connecting My LM-1 Output to a NB Sensor
  146. What is the best spark plug to use?
  147. tire wear?
  148. Part# for .036" thick Cometics
  149. Who here has used the Odyssey batteries...how did you mount it?
  150. Zr1 Tire Sizes
  151. Tinting question...painting black dots?
  152. New personal best in the quarter mile - 11.155@121.432
  153. FAST manifold mod/port special INCLUDES porting the Throttle Body
  154. Chuck CoW Tunig In Eureka Springs,AR
  155. drag wheel/tire setup
  156. Clunking differential when cold
  157. DEXRON-Grinding worse now than before
  158. Anybody get this wacky Climate Control display?
  159. Can't get any sound out of aftermarket navi
  160. Wheel Spoke Install???
  161. Replaced A6 trans, now car will not start
  162. **FREE GT-2 Hat with any LGMotorsport order!!**
  163. 400+ RWHP on LS3 for 09 ???
  164. OEM HUD Install
  165. where can I buy this part
  166. Interesting WB Findings w/ NPP
  167. HELP!!! 05 Horror story purchase!
  168. I Have To Go Post CAT for a WB Bung?!
  169. Apsis Z06 Front Splash Guard Fitting Report *PIC SHOWN*
  170. Switching to Z06 Rear Quarters
  171. Finally got the Split Spokes
  172. L92 Valvetrain Questions??????
  173. 2007 Z06 Exhaust on Regular 2008?
  174. header install on LS3
  175. Need Recomendations on how to deal w/ GM about 08 A6 Trans issue
  176. VARARAM survives Hurricane Ike - Please read!!!
  177. 12.12 @118 tonight @atco
  178. Tire Sensors Need Help
  179. Spring Mountain Instructor Jordan Yost Drives New ZR1
  180. new aps turbo kit and exhaust for c6. 8500 firm.
  181. A6"paddle shift"......what's best B&B bullet or PRT
  182. Norris Motorpsorts - VMax CNC Ported Throttle Body Available - $139 Shipped
  183. some injector deals from Fuel Injector Connection
  184. LUK "Gold" clutch question
  185. need help in deciding
  186. cooling fan controller module question
  187. Anyone a 'sparky' ? Paddle shift 'mod'
  188. Air Condition noise
  189. B&B Retro Fusions In Stock and On Sale - Round Tips w/ Wiring Kit! (One Kit Only!)
  190. Call from cartek.
  191. **Straightline & LG working together**
  192. best performing exhaust
  193. How long to change shocks?
  194. power gains question
  195. New Rims for Drag Racing
  196. Woooosh Sound after I turn off car????
  197. air temps/water temps and timing ???
  198. How to get to the condesser to clear radiator
  199. Nail in a run-flat tire
  200. NPP on a 2005 C6??
  201. shaving weight
  202. LG headers are built by Borla ?
  203. Jacking up 2008 Z06 with floor jack
  204. zo6 catback in c6
  205. Tranny seamed to "slip" today???
  206. Bowling Green slowdown
  207. We Want To Stamp Out - Column Lockup
  208. Service Charging system light
  209. Check if the frame got damaged?
  210. C6 Seat Belt Question
  211. Magnetic selective ride control is really rough. Help!
  212. battery dead need help to open the car
  213. "service electrical system"
  214. Intake and Throttle Body Special for $325.00 Shipped
  215. torque specs for sway bar connects
  216. PART # NEEDED ASAP.07 CATS.auto z51
  217. Preload bushings after lowering?
  218. • • • Announcement RPM Motors Expansion • • •
  219. Vac. source for Z06 mufflers???
  220. Check Oil Level in Dic...
  221. Exhaust bolt fell off, two others loose
  222. Had a weird thing happen today...
  223. '09 steering in '08 C6?
  224. 87 octaine
  225. '08 Differential Shop Manual
  226. Slack in Automatic Tranny (HELP)
  227. Why is my Spec clutch sticking to the floor ?
  228. Intake question
  229. Bad Squeak But Not When Turning Right
  230. 402 block question about compatability between C5 and C6
  231. Best $190 spent on Mods! F55 to Z-51
  232. i need a tuner in stuttgart germany
  233. Halogen on low beam
  234. 2008 A6 downshifts with 3/4 and Wot..
  235. 10% ethanol at the pump
  236. 2008 Z06 vs.2008 Z51
  237. Question re: Heads up Display
  238. X pipe question?? Need info!!
  239. New PCM Part # and cost please?
  240. MSD COILS and NO FUEL RAIL COVERS??? Please post pics
  241. Ported intake/heads inquiry
  242. Question on quick shifts with short shifter??
  243. )k guys, im trying to get a day to track meet
  244. Competion setting
  245. Koni fsd review
  246. Want rotors and pads upgrade on Z51 C6
  247. Cat / o2 sensor HELP
  248. Service Tire Monitor message ---- why
  249. Halltech Venom Beehive Installed (Pictures)
  250. I want to run 11.5 in the Summer Heat
