View Full Version : C6 Tech/Performance
  1. Steering Upgrades?
  2. Ram street dual clutch install help
  3. Air Conditioning
  4. CEL, Code P0171
  5. Exhaust Hanger Question
  6. help with Z06 front fenders on regular C6
  7. Predictions on modding the new LS3?
  8. Black Chrome?
  9. Somewhat conserned - Check oil level light came on
  10. After LG Long tube install should there be a noticable HP Gain??
  11. Suspension mounting points?
  12. What headers are the best fitting?
  13. Wheel Hop
  14. Z51 zinc rotor ???
  15. Which wheels work best for drag radials
  16. EG Install : 2007 C6 AR Headers + Blackwing [Dialup; serious hurting]
  17. welding on c6 and computers
  18. need advice
  19. 07C6A6 Running slugish in the morning
  20. Dynatech / Kooks Long Tube Packages Installed From $1669.99!
  21. zo6 wheels
  22. All 400+ci guys step inside........
  23. TB Porting?
  24. LS2 Port Works - expanded "bolt-on" product line
  25. l967 vette
  26. 1st to 4th shifting
  27. Z06 Front Facia
  28. C6 & C5, front rotors the same?
  29. Is there any way to make the seat go back further?
  30. Hurricane CAI
  31. Halltech intake question...
  32. HALLTECH KILLER BEE AAIS C6 Conversion Package
  33. This Sat in Tampa, Formato tuning and porting
  34. B.B. HEADERS anyone?!?
  35. Need Your Xm Help Now!!
  36. Squeek when shifting at high RPMS
  37. Question about predator
  38. Aftermarket Exhaust Question?
  39. Rear-end oil overflow - 2005
  40. wires thru firewall of a C6
  41. Need help with tire sensors in NJ
  42. Instrument Cluster Panel Removal
  43. Where to get ball joint boots?
  44. Will a 2005 3.15 differential (option code G90) fit in a 2007 A6?
  45. Y'all see the new 2008 #s?
  46. Help! Tire Sizes
  47. help
  48. Any problems with the twins?
  49. HUD Install on 1LT and 2LT In Miami. $1500.00 Installed
  50. Where to buy cleaner/oil for Vararam?
  51. No nuts on the rear leaf spring bolts???
  52. REAR end Talk
  53. Gm Offroad Vs Flowmaster
  54. Cause of loose axle nuts?
  55. Cause of loose axle nuts
  56. Converter for A6
  57. 2007 vs 2008
  58. Questions for those who have converted to Z06 brakes:
  59. C6 "Primary" steering shaft replacement NOT available.
  60. Car backed into my C6 on Parking Lot
  61. 11-second recipies
  62. Vararam: What Was I Thinking? This Thing is Going Back
  63. Dyno Sheet from G5X3 Cam only?
  64. How to: gain extra 35rwhp?
  65. Oil Leaking From My CAI!! :(
  66. Tire Pressure Monitoring Sensors urgent need help
  67. K&N FIPK question
  68. Lingenfelter CAI install
  69. Ever heard of a engine builder called Schwanke?
  70. Z06
  71. Performance questions............
  72. mp3 question
  73. Cost of a new ECM?
  74. C6 Coupe w/Z51 for Track Day and Autocross
  75. Quick Question: How much oil?
  76. Coolant Temperature Reading on DIC
  77. DO you have to remove the engine
  78. Gears ?
  79. Clutch Questions and Recommendations
  80. Rear gear question #2 C6
  81. Finally worked on my own c6 last night-nitrous dyno results..
  82. Anyone try resonators to lessen drone?
  83. squealing please help
  84. How to remove fuel line?
  85. Pipe Diameter?
  86. Where are all the Fast C6's ???
  87. Removing the "GM" badges behind the doors?
  88. On the topic of Warranties
  89. 81 No rubber plug hood latch access, passenger side?
  90. Callaway DD Exhaust
  91. Tune by Chuck Cow at Bloomington Gold
  92. 918 springs and troubles
  93. Bilstein vs. Z06 shocks
  94. post complete GM rear gear list for c6 at please
  95. 427 Emblems Available (Pic)
  96. Start Button Issues
  97. A few dry sump questions
  98. Why not an ELECTRIC Supercharger?
  99. Z06 mufflers??????
  100. willwood brakes... any venders
  101. Benefit to coating headers?
  102. More FAST questions
  103. Adding LG headers and CAI
  104. 3" Corsa Sport
  105. Tell me more about the gas pedal...
  106. QTP Quick Cam Cover
  107. Will Z06 brakes fit stock Chrome C6 wheels
  108. RevXtreme Dyno Tune Special: $399!!!
  109. C6 central lock wheel hubs
  110. K&N Air Charger Install and Battery
  111. where to buy the melrose offroad midpipe??
  112. Fuel Gauge Problem - Help Please
  113. Back vette w/ RPM tranny and rearend
  114. Brembo's / 21st Century Muscle Cars
  115. 2005 Corvette iPod Interface
  116. Question for those with spindle ducts...
  117. Elec Water Pump?
  118. how hard is it to install kooks headers
  119. 411's are finally in!!
  120. Help with !
  121. Sound clips - flowmasters with LT headers
  122. Dynoed my car today before the cam swap.
  123. Pics of Maggie's installed - silver vs. polished
  124. Flowtech Terminators on a C6?
  125. Cam gear compatibility
  126. Part numbers wanted
  127. A Few Newbie Test & Tune Drag Questions
  128. Fuel Injectors
  129. Non-GM replacement AXLE nuts - Size? Source?
  130. Gear change, why is it so hard to do?
  131. darkened brake light lenses
  132. MDMC $300.00 Text Gift Card Give Away step inside!
  133. Installing a t-stat...
  134. 07 c6 a6
  135. Rear Suspension width.
  136. Converter on A4 question
  137. FAST + FRC's
  138. Optimal Rpm's For Shifting
  139. C6 Coupe removable top creeks
  140. So has anyone dyno tested or run a 1/4 mile yet with an LS3 C6?
  141. Anybody using the 39 LED Third Brake Light?
  142. Who got the best price for this hood
  143. Thinking of 1 of 3 mods help
  144. What Is My Procharger Worth?
  145. Flowmasters Anyone?
  146. Koni FSB Shocks
  147. Halltech C6 Stinger Blowout Sale!
  148. How to install aftermarket catback, please
  149. Halltech Kill Bee – here is my input!
  150. Mild 402 or H&C?
  151. Vararam....any codes?
  152. Turbo vs. Blower?????
  153. Tire Pressure
  154. Parts catalog for C6?
  155. Twin Turbo Conversion In Progress :)
  156. First time with the Z51 at the 1/4 strip.. Interesting night..
  157. snake charmer vs. honker
  158. Tires
  159. Brake help needed "makes pufffffffff" sound
  160. Question for Audio Geeks-XM in Base 2007 Radio?
  161. Does Anyone Like the Corsa Sports?
  162. any c6 vetts in the 11's with cam only?
  163. Corsa/Kooks question
  164. 2007 Coupe "Run on"
  165. Drag strip enthusiasts, please read...
  166. Whats the most power 1 can make /wo worrying about reliability on everyday use for C6
  167. Brake caliper rebuild
  168. Need Suggestions for a Supercharger
  169. exhaust plate above mufflers.....
  170. Which exterior colors are most common?
  171. Anyone have the link/Pics/details 18x10.5's fronts?
  172. Widest tire that fit on the non-Z06 body
  173. C6 w/Z51 vs. MSR vs C6 Basic Suspension
  174. B&B bullits fit the 2008?
  175. C6 w/Z51 vs. MSR vs C6
  176. Need Help!
  177. Exhaust Rating Chart
  178. EnglandGreen Shop - Supercharger Mania
  179. Will entire Z06 Exhaust Fit A4 coupe?
  180. Halltech Killer Bee-2008 LS3
  181. New Corvette Forum sponsor Jeremy Formato and Fasterproms
  182. Codes
  183. exhaust
  184. Radio Volume
  185. Heads with S\C?
  186. Where is SpinMonster?
  187. question on lightweight flywheel
  188. C6 vs. C5 drivelines?
  189. Do we need a sticky sticky tire thread?
  190. gears
  191. DIY Door Speaker Replacement w/PICS
  192. Ranger, others, need comments on this run...
  193. potential mods. what does everyone think?
  194. Jacking question
  195. Driving stock street tires c6 what is a reasonable estimate of ........
  196. Procharger...What can I expect??
  197. stripping smc panels
  198. Camshaft Sensor
  199. Best place to buy O2 sensor?
  200. Can I put the 454 LSX in a C6?
  201. Any one bought an Omega Lift Jack?
  202. Nitto Invo 345/30/19 Pic!
  203. Drag Slicks
  204. Brake Rotors
  205. Optima RedTop Installed
  206. Another Raceramp Question
  207. Need help reducing oil and coolant temps
  208. ls2 camshaft
  209. Pro-Charger installer and tuner
  210. First Time 1/4 Mile Results...
  211. CV joint boot tear
  212. CAM specs in your A6
  213. Expensive Lesson - Don't Lift Your Car Like I Did!
  214. remote wire for Stereo
  215. Valentine One / Escort Compatability
  216. Anyone use Bosh universal 02?
  217. Looking for 12V switched power
  218. Starting a Project - Best way to 700 HP
  219. new flowmasters installed
  220. Ticking/clunking from front wheel.
  221. Pulstar Spark Plugs
  222. PCV Barb in Bellows - Where to get?
  223. What kind of performance can I get for $5000?
  224. FAST Install Help
  225. Cam, before/after Dyno graphs
  226. Re: "Check Engine Light"
  227. Tunnel Plate Install Problems
  228. Invisacord Install Questions
  229. Ok Guys, Kept All My Time Slips.....
  230. Ported intake, Throttle body, and catch can sale
  231. Transmission
  232. 427 Hood Emblems Now Available!
  233. B & B Prt System
  234. Dry NOS system ?
  235. how does getting warranty VOID work?
  236. Stealth cam for an '08 MN6.
  237. C6 Procharger Install in Maryland area
  238. Those w/ experience swapping heads
  239. GM Parts House June 2007 C6 Specials (Important Pricing Update)
  240. What shock setting for Pfadt coilovers on street?
  241. Just Installed C5 Clutch Spring
  242. CHUCK CoW TUNING @ BLOOMINGTON GOLD - CHICAGO AREA - JUNE 14 - 17
  243. Tire Pressure Sensors and TPMS - Videos
  244. easiest way to remove glue
  245. bluetooth car kit
  246. Cheap wheels to clear Brembo 4 piston fronts?
  247. Give me a brake...................I mean brakes
  248. Transparent top question
  249. any "vette techs" in memphis tn?
  250. CARTEK 2X - The Die is Cast
