- Run without pcv fitting?
- C6 clutch fluid level
- $100 Gift Certificates
- Pictures!!! Back from Lingenfelter
- Good job people!!
- vararam intake
- Houston Folks...HRP tonight? 10-24-08
- info on brake pads
- Dart 225 vs l92
- Bone Stock 08 New Best 12.27@118.66!
- Help, used LG Pros, bent gaskets
- Square box that is connected to the stock air intake on a 2008 C6 LS3 Corvette
- Does a good aggressive alignment cure twitchyness?
- NPP Retrofit system
- Chuck CoW -POSSIBLY- tuning is PHOENIX, Ariz AFTER SEMA
- QA1 adjustable Shocks - What a difference!
- C6zo6 brake pads
- You guys think 12.11 is good stock LS2
- Tires
- ls3 ewp
- Intake Advice
- cammed ls3
- SLP UD pulley bolt specs?
- Sneak Peek Bondurant 40% OFF Specials!!
- Vararam self tune?
- cooling system
- CORSA - Jewelery For Your Vette
- Does anyone have dyno numbers for Lingenfelters C6 Z06 660HP package ?
- Invos or Michelins?
- How tough to install coilovers? Which Coilovers?
- Drag race wheels z06/c6
- Changing a thermostat.. Need help..
- ******ECS Novi 2200 LS2 Results*****
- ABS problems: EBCM and BPMV
- Michelin Pilot Sport Cup
- Help Drivetrain questions?
- Which Shocks
- *** SKF Racing Hubs from LG Motorsports ***
- The A6 Exhaust Poll/Thread...What's Good, What's Bad, and What Drones!
- TPS orientation
- Anybody heard of this cam?
- Dealer suggesting carbon treatement for engine...useful or useless??
- LS2 Cam Swap ..Need Help !!
- airaid intake on ebay
- TRICKFLOW heads ***made in china***
- Chuck CoW TUNING @ SEMA in -V E G A S- Nov 4th-8th
- Cutting open mufflers
- • • • Machine Shop Open & New Short Block Pricing • • •
- ls3 on mustang dyno
- What is transmission fluid capacity ('09 C6 coupe)?
- help with a window rattle on my vert
- Headers and midpipe
- Help on Shift Light Install.....
- Dispelling some Myths: HP and Torque for Stock, Blown and Heads/Cam cars.
- timing chain break on my Lingenfelter 403
- Straight through exhaust
- FREE SHIPPING on Halltech Induction @ Texas Speed
- stat question
- Vibration/wobble after stall converter installation?
- '09 NPP Question??
- HELP !!! ERROR CODE "Reduced Engine Power"
- Trying to enhance stock LS3
- Tune or Chip?
- Oil temp reached 260 during mountain drive
- Wipers
- Black Wing C6 08 Vet
- So tell me, how does a lower thermostat make an engine run cooler?
- "PS2 or Nitto for a Bolt-On Modded C6." from "Tire suggestion on Modded C6 Vert"
- on stock car how much hp will you get from gutting cats?
- How much diff. in sound going from no cats to hi-flow cats?
- Another dead battery victim
- Dual mode exhaust
- "Fall Into Great Savings" Header Sale @ MarylandSpeed - Kooks (Free Coating), SLP, SW
- Mods that will get about 50 horses
- Torque Specs?
- What happens if you run wheels/tires without TPS?
- Help Please, wire hook-up on the starter
- Corvettes of Dallas receives National Attention - TWICE
- which system came on?
- Cam Suggestions?
- procharger or a&a corvette vortech supercharger
- New Best in the 1/4
- Finally made 11's!! 3 Times tonight!!
- ttt
- Looking for a good brake installation write-up
- 07 C6 A6 - New time 10.8!
- o7 c6 zo6 alignment
- BBS RS-GT Wheels.
- Adjusting headlights after lowering
- vararam install 08 pcv fitting question
- Tuning Seems To have Disapeared
- B&B Bullets Question
- KLM Air Filters
- List of tech related "stupid" questions
- Need Clutch Help
- Help! I broke at the track! What to do!?
- what rims
- Cartek........any Header and Tuning specials?
- In Shop Tuning by Cartek look at these #
- Any experience with this Z51 rotor
- Second Gear
- --Fresh Dyno Video-- 471.7 RWHP, 463.4 RWT! **Meth injected Bolt on LS3**
- a question about pfadt
- column lock c6 problems?
- need vendor recomendation brake rotors
- LED light bulbs
- interesting idea....
- Z51 Sway Bars and Pfadt Poly Bushings
- AIRAID Review - WOW!!!!
- This sucks
- Rear bumper construction - Was hit from rear
- Performance Rotor Wear
- trans broke..AGAIN
- Cobra Imola Seat Installed (pics)
- Need help ASAP.. SPACERS
- Where is the B-pillar Left Side Remote Antenna Module
- Wheel Hop
- Idle fluctuation question?
- 92mm TB question
- Help needed, completely baffled
- FAST 92mm sale/port special for 2005-2007 LS2 cars only
- [walk-around video] ECS's LS3 H/C @ idle & vrooom
- My c6 breaks up at 4000 rpms?
- $2500 budget. Best mods to go from 0-55 MPH
- engine idle sound tick tick tick
- We are pretty proud
- Octane
- 110 Octane
- CoW A6 tune update
- *** LG Motorsports World Challenge Blemish Wheel Sale - $995 Per Set! ***
- Looking for feedback on some new DRM packages
- Tec-II Engine Diagnostics
- Help Needed QUICK ... Brake Line Issue
- Are all 823 castings the same???
- can headers only change my c6 sound?
- Need info on forged LS3, possibly stroker, aftermarket heads, etc.
- Just dyno-tuned my '05 C6 @ MTI dyno sheet inside!
- So I need
- DeWitts Stimulus Group Purchase
- Stock 5 spoke wheels
- Heads n Cam
- Hello
- Supercharging C6 Auto Trans
- Watch the BAD BOY run in Texas
- **Vette Doctors-ARH complete Exhaust System $1,895 Installed and Dyno Tuned!!**
- NEW! Ron Fellows Performance Driving School
- Any forum vendors selling Motive Power Bleeders?
- Stock Exhaust - Sell/keep?
- Service in Texas
- MAN6 Manual 6sp Tranny Transmission Fluid - NEVER replace? Other options?
- Installed Ported intake manifold
- CAMs are incredible
- Free Shipping on all LGHeader Systems
- Anyone have diff fluid changed and not work?
- Is Any C6 a "Consistent Winner, in "BRACKET RACING"
- LS2 fuel injectors, FAST manifold
- Oil.... Did I fill it up too much? Or just right?
- "Service Active Handling" on DIC
- With an FI manual trans which is better F55 or Z51
- How activate/deactivate RPO codes?
- Nav / HUD question
- Rear end whine
- IForged Track Series Blowout!
- thermostat question ( kinda unusual)
- 2005 C6 Z51 Manual Transmission Issues
- Trick Flow 225 on a LS2 issues
- Opinions on my fuel cell setup...
- Question?:
- Awesome Diablo Predator Sale (includes 2008's) - Get a Free Interface Kit!
- Halltech Killer Bee Install ?
- Pulling timing at 86*
- carbotech and T1
- Maggie Install - PICS
- *** ECS Novi 2200 Track Tested on LS3-A6***
- 1.00 g? Possible?
- Installed the VMAX Ported Throttle Body tonight
- C6 with 20" 360 forged and extras!!!!!!
- Exhaust question
- Borla Stingers ON!
- Mathematically-based 0-60 mph calculator
- Looking to go 10.70 or better Nat Asp LS2
- Pfadt Coil Over Shocks - How to Adjust?
- transmission intermediate housing
- 15% MGW Shifter makes my '08 Perfect!!
- Comparing Mods LT1 / LS2
- transparent roof creaks
- Bumper cover install?
- Factory Repos and Tire selection???
- Help! Tried Ranger's clutching fluid flush method - still 'spongy'
- LS7 head coolant passage plug
- Vengeance or Chuck COW- HELP!
- Dyno Day at Horsepower Connection, Lacey WA
- Sizes, Drain Plugs
- Mild 2 Wild Exhaust Controller SALE - fits NPP, Z06, ZR1 @ PFYC.com
- 4 to 5 gear shift solution?
- Gm performance parts exhaust
- Considering getting a lift.
- The c6dvl - ECS H/C Package - $5999 - LIMITED TIME ONLY!!!!
- ZR1/CTS-V Rear Into Our C6??
- Max timing on L92/76 setup
- **LG Street Series and LS3 Results! 30+ HP GAINS!!**
- Latest on Street Warrior manifold
- Extra set of Air Pressure Sensors..
- Anyone try the new WCC tranny mounts to stop wheel hop?
- Ram Powergrip HD clutch question
- what is this?
- ? rewiring fog lights
- What kind of LSD is on the C6
- Will someone in the "inside" with FAST PLEASE find out when the LS3 manifold...
- You guys are being used by God
- C6/LS2 owners w/aftermarket fuel rails: Let's see your fuel setup (engine bay)!
- Will these fit C6 stock wheels
- [PRESS RELEASE] Cool down with Katech Performance Gen 4 LS Piston Squirters
- Best Tire???????
- Aftermarket LS2 fuel rails that still allow use of fuel rail covers?
- Fuse Box Question
- Borla Stingers Arrived!
- What does KR stand for ??
- Advice on Nitrous?
- October ForgeLine Specials from LG Motorsports
- audio system
- Can you add F55 option to a base C6
- Info for lowered cars...Damage to front end.
- Passenger airbag seat cushion pressure sensor?
- Vararam Filter
- Anyone Use an X1 in a MN6 LS2
- Aftermarket fuel rails that accept fuel rail covers & quick disconnect fuel line?
- Rear Hatch Release...
- Exhaust question
- Well guys here's my video of exhaust
- drive train strength
- NEED HELP! Just got the INSIDE of my Fuse box wet...
- Check engine after headers and tuning
- Where to buy FAST???
- Is it possible to shut off rear o2 code by simple wiring?
- I got screwed, willing to swap
- Take a look at my ls3 baseline Please!!
- LS2 tuning ... comp products
- high beams
- Radiator fan removal?
- I got SOOOOOO close to hitting the 10's yesterday!
- DTE Brace for 2008 c6, 6 speed differential.
- 18x91/2 fronts and 19x11 rears. Who's running them!!
- Gonna run MT Drag Radial to & From the Track
- Rpm .. How high is too high!
- Stock Clutch on my 07 LS2??? HP limit?
- Drivetrain hesitation
- 3.42 or 3.73 gears in A4
- PS2 pessure
