View Full Version : C6 Tech/Performance
  1. What is the pitch of the lug threads on a C6 Z06?
  2. Not Real Techie but I can't figure out how to get rid of the 24 hr clock!
  3. Wires and Plugs
  4. MT Tire Question
  5. 6M or A6 and why?
  6. GCA Splash Guards Available
  7. UPF48R Ultra Guard Oil Filters Available
  8. 2nd Shipment Of ZR1 Spoilers Available
  9. GM Parts House November 2008 C6 Specials
  10. What injectors do I have ? ? ?
  11. stall converter install diy help
  12. Powdercoat Vendor
  13. MGW short shifter: gasket or silicone?
  14. Rim/Tire Install in Georgia
  15. wheel hop
  16. Vararam Sale Extended Through November!
  17. Who Wants Gears?
  18. 2008 C6 SLP ZL465 Package
  19. Katech Delphi to Bosch MAP sensor adapter now available
  20. CAI Preference
  21. Exhaust help!
  22. Need some help for geting ready for a race with viper
  23. Need some help
  24. Looking for best short shifter
  25. getting traction
  26. Cams with Rage@RaginRacin
  27. What have I been up to ...
  28. What does an exhaust leak sound like?
  29. 2007 Corvette LG Street Series with G6X3 **456RWHP**
  30. Brake pads recommendation?
  31. Beefing up 05 Rear
  32. FAST manifold news for the LS3
  33. Long Tube Headers on C6
  34. B&B Fusion with LG Pro LT's
  35. Help,what's the best way to lower my 08 Z51 C6 LS3 ?
  36. Advice – buff or repaint?
  37. anybody have pics of how/where to cut rear bushings?
  38. Can someone please help? 5 spoke polished stock wheel weight?
  39. >>DTE Powertrain HD 4340-300M Output Shaft Sale<<
  40. sensor bung/dyno Q's
  41. Question on lightweight brake rotors
  42. Wideband Gauge Tip
  43. Transparent Roof Panel Question
  44. jacking pucks
  45. Adhesive for the VR
  46. need info on BFGoodrich g-Force T/A KDW
  47. Here's a little engine eye candy
  48. 100 reliable hp in a stock c6
  49. Is my car running ok or not??at track
  50. Will Z06 fuel pump be enough? And where to get one?
  51. Does Taking Off the C6 Roof Panel Disrupt Handling and Performance?
  52. Transmission Questions?
  53. Textrailia Exo-Skel Multi-disk in stock
  54. How do I remove the speaker screen?
  55. -=-Tunes from ECS!!! Dougs Birthday Special!!! -=-
  56. C6 vs C5Z06
  57. C6 vs Challenger R/T
  58. What rockers with etp heads?
  59. Tubbing a C6?
  60. C6 && Z06 bellhousing and shaft tubing??
  61. Clutch Question
  62. Can anyone tell if any Recall has been done on my car..
  63. LS7 manifold 1/4 times (Polished pics)
  64. Dissect my dyno graph please...
  65. 05 A4 downshifting
  66. Is Creaking of the C6 Coupe Roof Panel OK and Normal
  67. Will 285 tire fit 8.5" wheel?
  68. Cleaning VR filter Help
  69. Help Diagnosing Vibration / Noise
  70. Best protection for polished wheels
  71. Garmin nuvi 350 install location
  72. Tire pressure sensors
  73. odd balancer installation issue
  74. I guess it will be a maggie
  75. • • • Before & After LS3 Cam Only • • •
  76. LS magic
  77. Reprogramming the Traction Control System...
  78. Putting in 5 point harness, seat belt light
  79. C6 Cam Media Gallery
  80. Module
  81. Exhaust Sound
  82. Programming a new BCM
  83. Need GM Bulletin # for convertible top liner wear
  84. Will a 16' wheel fit over rear Z51 brakes?
  85. please help with stock thermostat
  86. C6 Harness Bar and Belts?? (Recommendations)
  87. clutch questions
  88. Bone stock ZR1 at Memphis motorsports park!
  89. Catback and aftermarket exhaust..
  90. Reset Airbag Light?
  91. New SLP Blackwing for LS3/LS7 In Stock and Shipping (well under $400!)
  92. APSIS Long wheel well flares/flaps
  93. Coolant Sensor location
  94. How to crank the engine without starting?
  95. Activating RPO
  96. MT 275/40/17 - Advice please
  97. Service Active Handling Warning
  98. C6 Electrical Gremlins for Halloween
  99. kenne bell
  100. What is too much? (cam)
  101. want to install 410's
  102. 08 LS3 6Spd Manual w/ Boltons
  103. Tire monitor problem
  104. 05 rear question
  105. Help please
  106. Vette is Dead with electrical issue ...help please.
  107. Automatic with shift problems
  108. HP Tuner users
  109. Non-OEM Bolts...
  110. Back together
  111. cold weather and tyre inflation
  112. I Swapped out my 05 diff with an 06 Diff Pics inside
  113. Lower F55 Suspension?
  114. c6 z51 procharger went boom!!!!
  115. blackwing install question
  116. torque value for sway bar bolts
  117. Those who have changed gear ratios. What are the good/bad results ?
  118. 1978 corvette swap ls6
  119. Bilsteins Bleed out?
  120. Z51 Sway Bars & Z06 Shocks?
  121. Hey Kooks guys..
  122. EBM Failure
  123. Window stuck all the way down
  124. Special One Time Only Pricing on Kooks & Stainless Works!!!
  125. next step
  126. Question for those that leave the NPP valves open
  127. correct clutch size for 68' 427????
  128. DFW Vettes: Where should I get my Z06/NPP retro done?
  129. procharger
  130. Short throw shifter question
  131. I have An 08 Corvette with kooks and CAI and everything else pretty much stock
  132. 2008 z06 aps twin turbo
  133. 4" CAI Couplers look great
  134. Stock z06 manifold??
  135. What is the highest RWTQ achieved with a N/A 6.0 Liter LS2 without nitrous?
  136. Brake Bleeding
  137. Billy Boat exhaust system
  138. Fidanza making a LS flywheel to fit LS9 clutch set up ?
  139. Need Advise on Exhaust System
  140. all xo-pipes the same?
  141. FREE Parts & Specials from AFR, Trickflow, Patriot, Comp Cams
  142. Paddle shift problems
  143. Lifter noise?
  144. Z-51 BRAKES W/19x12 wheels
  145. Changing CAI Question…
  146. ICON Autosports of Houston Texas now Sponsors!!
  147. Wrong tires ordered!!!
  148. Pfadt C6 Transmission Mounts............are they worth it? do they work?
  149. Automatic down shifting question on a 2009
  150. -- The Tina Caronna Memorial Fund --
  151. Estimated Power?
  152. **New Round Delrin shift knob from LG Motorsports**
  153. stall conveter bolts?
  154. STATIC compression ratio chart
  155. New Wheel/Trire combo... Good?
  156. 2005 corvette z51 Active control problem
  157. Is 500rwtq possible with LS2 ???? Experts please..
  158. New Head Gasket Blown after mods, vendor issues or experiences?
  159. Need a part #
  160. New wheels, traction control issue
  161. Wheel Repair
  162. Crown Chevy in Dublin, CA closed - now what?
  163. I have #s before Spin!!
  164. Brake bleeding -- need to remove wheels?
  165. Chuck Cow, comes thru Again!!!!!
  166. LG Headers + Vararam + Tune (LS2)...
  167. z06 fenders and quarter panel swap
  168. 06-07 Z06 mass air flow sensor..question
  169. Wrecked 2008 C6 vert wont start!?
  170. Advice About Front End Alignment Please
  171. OEM C6 ZO6 wheels on C6: What else besides rear fenders?
  172. DIY on clutch replacement
  173. Body Repair advise needed
  174. Carbon flappy paddle gear extensions!
  175. 638 HP LS9 Crate Engine WILL BE AVAILABLE
  176. Heads up display C6
  177. question about varram intake
  178. texas Mile Corvette 210mph Video inside :)
  179. Fire Ext needed???
  180. Larger replacement tires for '07 Z51
  181. porting ls3 intake
  182. Master brake cylinder?
  183. Am I reading this right
  184. Tips to accomplish 200mph in a M6 coupe?
  185. Help needed for No Start condition.
  186. forged bottom end
  187. Winter specials on Ron Fellows Performance Driving School at Spring Mountain
  188. 09 A6 12.010@118.30 showroom stock
  189. What should a dual exhaust sound like normally
  190. A great testimonial
  191. Question to Widebody rear only tire size?
  192. Any news availability LSx crate motors?
  193. Intakes and exhausts
  194. Vararam leaking and warped?
  195. Info on the C6
  196. Jeremy Formato tuning and porting 10/29-30 in S FL
  197. 08 a6 trans wont shift right
  198. How can this be?
  199. 2007 C6 vs 2008 C6 wheel sizes
  200. Fuel in my LS3 Intake manifold?
  201. Wide body kit?'s
  202. Goal: 500 RWHP
  203. I fixed my aftermarket exhaust drone
  204. Finally got the new motor in!!! LS3 427 aka El Torro Grande
  205. Lgmotorsports runs 210 mph in standing mile
  206. where to buy koni fsd's?
  207. Differential clutch packs
  208. what kind of Front runners should I use on my 08 Z51 Vette?
  209. need help with vararam
  210. do it yourself lowering stock bolts?
  211. Orange County (CA) Shop?
  212. Shock Replacement
  213. Late Model Racecraft's Procharged C6 Dyno Vid!!
  214. rims for my 08 c6 z51.....whats out there??
  215. P1SC or D1 procharger?
  216. Need a lttle help on shift knob removal
  217. need help with shocks asap!
  218. Power Steering Lines Z51
  219. c6 knocking ?
  220. Mixing Firehawks and F1 Supercars on a Z51 Car
  221. 1993 Will not turn over
  222. Did I get slower?
  223. Best price for ARH 17/8"?
  224. Finally beat my stock time!
  225. center speaker
  226. question for california owners
  227. Oxy tane
  228. Texas Mile Report
  229. Supercars vs. Wide oval vs. Non-rft
  230. How To Remove A4 Transmission Pan?
  231. C6 vibration/roughness reduced
  232. new best 11.32@126mph
  233. C6 Air filter help, please
  234. Late Model Racecraft's Procharged C6 Dyno Vid!!
  235. Help on a dented NPP muffler tip.
  236. Oil usage?
  237. ***Cartek/Dennis50nj breaks C6 bolt-on record***
  238. *** LG Motorsports at the Texas Mile ***
  239. K&N Z06/LS3 intake MAF slot cartridge fit
  240. Dynamic Compression Ratio CHART
  241. reset oil light
  242. tuner on long island
  243. Aftermarket DBW LS2 throttle bodies? Room for improvement on stock?
  244. have you seen these?
  245. tranny help
  246. Thanks Chuck COW!
  247. just ran a 2002 viper
  248. How does the oil filler ext neck come off
  249. **ECS Novi 2200/blower cam tops the C6 go fast list on a STOCK LS2**
  250. 2005 Stock Exhaust - Two Types?
