- Engine Idle Question
- where can I get my Intake on my 08 vette ported here in TEXAS
- Wierd NOISE??
- BIG Gains from Ported Throttle Body
- 453 rwhp! H&c ls2
- 06 auto trans throwing codes
- Chuck CoW Mail Order Tune
- More horspower
- LMR 08 Automatic Corvette Dyno Vid!!!
- Lost Power
- Apsis' Super Holiday GP Special $668 to upgrade REAL Carbon for 08-09 Center Console
- Intermittent airbag light on my 08
- New HRE specials at LG Motorsports!
- 2009 Z06 with RR-Stage5
- Hawaii Corvette Owners
- turning front brake air scoops into intake?
- Clutch Clarification
- Need some advise from Z06 racers..
- How to fix exhaust leak where header meets mid pipe?
- I think we have the best product GM has ever produced.
- Adjustable Clutch Master Cylinder Suggestions?
- Line Lock Installed with pics
- Ron Fellows at Spring Mountain - Short Notice Special for 11/24-11/26/2008
- quick ? on lowering stock bolts
- Iforged rev : Used wheel / tire package blowout!
- Can electric cutouts on an a6 vette (stock exhaust) be done?
- LS3 timing chain
- It's 47 degrees... why can't i drive my car?
- Caliper Piston Dust Boots Destroyed
- header question
- Skid plate Help
- A4 vs. A6 drivetrain loss...
- Can Magnetic Ride Control be Added After Initial Buy
- Headers - What type?
- *** Last minute track rental at Atco , NJ 11/18 ***
- Vararam track results GM Hitech
- C6 Headlight clear covers
- FAST Fuel Rail Adapter Kit for LS2 ???
- barometric pressure
- CHUCK CoW Tuning - CHICAGO - THIS WEEKEND - on VERY SHORT NOTICE
- Vette at Dealership-Seeping Fluid on Oil Pan
- Clutch Oil Breakdown
- How long are drag radials good for?
- Plug question
- Lingenfelter CNC Cylinder Head Porting LS6, LS3, LS2, LS1 $1,095.00 a pair!!!
- Noise from transimssion/rear
- Surging at low rpm
- Help With CEL...Cold Front Causes P0171?
- Custom Headers?
- Pushrod length (why it matters)
- Procharger questions
- LG pro long tube, front O2 extensions, how long are they?
- Results of Modified LS2 Injectors Flowing 60#/Hr
- How much hp to run 9's
- Seat material wear spot
- converter failure
- clutch fluid exchange
- C6 Coupe - Noise at Trunk-Lid closing mechanism
- super charger
- C6 and Z06 bellhousing and shaft tubing
- running without any O2 sensors (and no tune)?
- dyno day at oc gm preformance
- big oil leak???
- transmission problem 2006 c6 A6
- Car pulls left - Active Handling Problem
- New best time!!!
- oil leak
- transmission problem 2005 c6 m6 (please help)
- PCV Catch Can Questions
- Longer oil filter number
- Nitrogen in tires
- New Supercharger installed, tips please.
- LG Pro install...HELP! O2 extensions don't fit the front
- Steering wheel vibration, wtf?
- Borla Stingers On! Finally, wow!
- npp exhaust
- Corsa: Sport (M6) Vs. Sport (A6)
- ROLL OVER C6 - what are these parts worth?
- stock C6 front & Rear ZO6 Quarter Panel Conversion
- Quick Mods
- Ls2&ls3 air intakes?
- where is the XM harness in the back of the car ?
- FAST mods with Photos - - -
- bolton 02 z06 Vs. stock 08 ls3?
- need an opinion on mods
- Problems with exhaust open/close
- C6 window problem
- Compression ratio bump on LS3
- C6 wheel alignment
- intake question.
- Build week 11/17
- HUD Installed & MGW Shifter
- Borla Looking For Exhaust Partner
- explain how the a6 programming and converter works - is my lockup jacked?
- 07 C6 will not stop dinging.
- torque converter risk?
- HELP, question on ceramic pad change.
- 2008 Convertible Top Problems
- halltech venom/ beehive RAI shroud
- RK Hood
- APS or TTi with rebuild
- LS3 A6 LG Pro/G6X3 combo **465 RWHP!!**
- C6 Hub Diameter
- need to switch tires & wheels
- NPP Retrofit Kit
- Z06 injectors vs. C5 injectors ?
- Corsa
- Pics&vids. Bassani catback with kooks headers installed
- How much do these aftermarket air intakes really help?
- Z51 brake swap SAFE?
- Gear change in 08 C6 Z06
- Skip Shift Eliminator
- Questions about lubricant that stops brake squeaks
- RWHP amount?
- has anybody out there dynoed before and after an intake upgrade?
- Race Proven Motorsports Header & Cam Specials!!
- Will 345s fit on C6 w/ZO6 wheels & rear fenders?
- '06 Z06 brake bleeder valve
- 160 thermostate installed
- need some serious advice
- 02 sensors
- Disable FOB functions
- Sound clip of engine tick. What is it?
- Tire pressure sensor nut torque
- Front driver side blinker is out
- Dyno results after heads and cam
- Brake pads ...
- Brake Pads for Street and Track
- Ron Fellows to make appearance at Spring Mountain
- Fuel Choice
- Livernois C6 Z06 Cam Package - Installed
- Livernois C6 Head/Cam Packages - Installed or Mail Order
- 2005 Specific ECU problems and weaknesses?
- Brake Pad Recommendation
- Corvette GT-2 InCar Video Petit Lemans Atlanta-LG Motorsports
- can someone explain cams to me
- My dyno chart
- C5 Z06 wheels on C6?
- Pulstar Sparkplugs....
- Does VHT tire treatment really work??????
- Mobil 1 Sales Restiction!!!
- Diablosport Predator
- Ticking valvetrain?
- ? P/N's for Z06 L/R Hand Gurney/Winglet Flaps
- 2008 z06 diff/trans
- Best tires besides Michelins ps2??
- Apsis' New D-Type Carbon Steering Wheel (Carravagio Style), Group Buy Special
- Apsis' SEMA Special for forum members, All Lamination Carbon & Carbon Look Parts
- wide body front
- questions about LS3
- Race Proven Motorsports Discount Time!!!
- Katech Tensioner group purchase from SDPC
- Need help with cam decision
- ddd
- 295/30ZR/19s on the rear of C6?
- Heads and Cam Are in!!
- Cracked bellhousing
- Who makes the Z06 Shocks for GM?
- C6 Shocks - ZO6 or Bilstein sports
- Stall or Gears?
- Active Handling needs the TPS
- Formato is the greatest
- 05' LS2 sounds like a Diesel?
- Pressure pad door handle
- Crank reluctor wheel 24 tooth(LS1) ->> 48 tooth(LS2) ??
- c6 rear calipers
- First trip to 1/4
- Hertz rental car wiring
- H/C C6 5th gear top speed
- can i tell if my tb&intake was ported?
- any custom gauges for the c6?
- Opinion on HPE Megadeath cam?
- Passing Emissions
- Pulstar spark plugs ?
- 1st trip to the 1/4 mile - C6 A6 Z51
- Does your Textralia clutch rattle?
- State inspection test fail
- What do I need to make my base C6 stay flat when cornering?
- Coming soon to a C6 near you...900+ HP and Torque
- What would I need to upgrade to Z51 Brakes?
- C6 Alignment
- After Market Wheel Problems
- torque management
- C5/C6 suspension parts interchangable?
- 08 LS3 Clutch Problems??
- HELP! Are these CAM dots aligned correctly??
- Tire Fitment
- The 2009 Gumbys on a 2005
- NPP w/M2W best mod ever!!!
- Hp tuners
- Gears: just ring/pinion vs entire differential?
- Great Weather = Fast Times....New Best Runs
- C6 bolton + fast + 4.10 = wheel hop
- Engine removal tips/help?
- SPINFAST install with pics
- Thanks Subfloor and Corvette Don
- anyone running .224/.232 114 lsa cam on their ls3? results?
- Improve my 60'
- Guys with AR 1 7/8 step in
- CAGS by-pass
- Cool Vette Parts at SEMA this year - pics
- New calipers, bled brakes, no pressure?
- I made it in the 10s with my 06!
- LS3 Bolt-On...My personal best 1/4 mile
- What is this unused connector behind vents?
- Swapped front tires - How do I Program DIC?
- Weiand Intake for LS2
- 2009 ZR1 Dyno Video...
- 1 3/4 vs 1 7/8
- How to add/check auto tranny fluid level????
- Fichtner veterans day employee pricing sale!
- Door Speaker Cover
- Does anyone offer a ported/polished LS2 90mm DBW throttle w/a polished exterior?
- tire help
- Upper Control Arm Studs
- Trouble with injectors?
- Callaway-Eibach coilover shock broke - pic
- New pads on existing rotor - Good or Bad idea?
- Water pump issue...
- Noisy belt?
- No power then a surge of power on cold start.
- Injector Size
- Replacement tires
- RIDE height Adjustment limits
- POP Question for you engineers/alignment experts. Time sensitive
- Where should my rev limiter be with a g6x3?
- Problem with Vararam New Upper
- New Rims... Tire Question
- Clutch suggestions?
- OEM brake pads
- engine mods and emissions?
- 08 Z51 Rearend Noise
- can someone PLEASE post before and after hp/tq from only headers alone? honest please
- Got to put her away :(
- New guy here - old issue DBS
- ZR1 LS9 crate motor.
- Corvette Track Days Update - Major Changes & Additions!!
- Tire pressure for Drag Radials to start?
- Rear O2 sensors
- Clutch Help
- Pic's of carbon fibre 'flapy paddles' fitted!
- Questions about 2009 Z-51/F55 brakes
- Any LS3 guys looking for a Honker & trimmed shroud?
- Cam Install Question
- Valve spring kit suggestions
- Crane lifter question
- for those who have gone without cats/tune
- Kooks Headers and Cross-over x pipe
- Hardened output shaft installation question.
