View Full Version : C6 Tech/Performance
  1. Alky Kit
  2. Z51 rotors??
  3. How to mod my vette, if i get it
  4. Battery Replacement Fit for C6
  5. Vararam Template
  6. Electric cutouts npp or qtp screamer ???
  7. Front Guard for Front Wheel, connecting to ZR1 Style Spliter *PIC*
  8. Exhaust Recomendation
  9. ***Load Bearing Dyno Day in Birmingham***
  10. Looking For LS3 Water Pump Dimensions For Restomod
  11. Exhaust advice....
  12. Failed emissions need advice
  13. Minor but Significant
  14. APRIL FOOLS SALE- A&A supercharger systems $4500!
  15. ZO6 Front Bumper Assy?
  16. performance mod yes or no?
  17. spring burst under dash board?????
  18. 3" to 2-1/2" SS Reducer
  19. 2005 Blown Rear End Question
  20. Noob when it comes to Moding..
  21. PowerLabs Wheels/Tires are in... Pictures and Video!
  22. Dynoed my Vette on spray....results
  23. Alternator failure now WILL NOT START
  24. Npp
  25. LS3 and mods (gas milage related)
  26. Speedo Failure
  27. ABS code from disconnecting sensor: how to reset code?
  28. Corsa Exhaust
  29. Will C5Z Calipers fit a C6?
  30. How much do brake rotors weigh
  31. Bolt size for rear shocks ... help needed
  32. Clutch Fluid Problem???
  33. Tires 4 C^ under 450 RWHP
  34. Open Loop
  35. My TexasMile March 27-29 2009 201.43mph results
  36. **L.A.P.D. 5 Clutches** - the perfect clutch for any vette!
  37. Race tune?
  38. replacing clutch ?
  39. 09c6 -vs-09z06
  40. 1/4 track
  41. Ash tray pops open
  42. Door squealing
  43. Instructions to remove convertible speaker panel
  44. Best Extractor Hood for Downforce & Aero?
  45. Halltech killer bee
  46. procharger screaching sound
  47. Tire pressure?
  48. Outside Air Temp Sticking
  49. L92 H/C questions.
  50. Front License Plate
  51. C6 Error Codes Air Bag Light
  52. I think I found my turn key engine, what do y'all think?
  53. 08 Z 'Service Traction System" warning
  54. 3:15 gear swap from 05 C6 to 08 C6
  55. Z06 Exhaust on C6 - best way to control the vacuum actuators?
  56. Oh no, not another "gears" question..
  57. What size wrench or socket do I need?
  58. Question on Z06 brake pads
  59. C6 coupe with Z0 suspension parts
  60. Big Thanks to Spinmonster for FAST intake repair
  61. Put the NAVI system on hold, priorities :)
  62. Do new Z51 rotors need to be turned
  63. Center console question ?
  64. zo6 vs z51
  65. FAST Intake & TB torque requirements.....
  66. Recommendations on a body shop near Austin, TX
  67. Carbon Halo installed *PIC*
  68. stock z06 cam
  69. Texas Front License Plate Law
  70. GTR C6 package
  71. Chime sounds opening driver's door with fob in pocket
  72. replacing AC condensor
  73. Smells?
  74. Proper Fill For Clutch Fluid
  75. Stainless brake lines, Brake upgrades... not common for C6?
  76. Bilstein compared to Pfadt shocks
  77. wanna build the rear end now.
  78. Question about z06 brakes
  79. Any write-ups/pictures on.........
  80. cam only ls3 new PB today..10.73@131.18 video
  81. Installed Yank 3600 with 2.56 gears!
  82. Bolt-on C6 7.33 1/8 at +1757DA???
  83. Popping Top? Lube it Up.
  84. Door Rattle Solved
  85. Door Rattle Solved
  86. Removing Fuel Rail Covers....Tools?
  87. RCDLR Symptoms
  88. Noob with exhaust question
  89. Car cover recomendations???????????
  90. Intermittent "No FOB Detected"
  91. Stuck between the decision of headers or intake manifold and throttle body
  92. Modification = Reliability Issues?
  93. Do Bilstein S's lower or raise
  94. Need Help
  95. factory GPS antenna help please
  96. $%#@& Key Fob!
  97. CVN, Calibration Verification Numbers
  98. Head light adjustment, Up and Down
  99. Help Needed
  100. weiand intake
  101. •• FAST 92 Intakes - Cheapest you will find anywhere!! ••
  102. Corvette Service Manual Sale
  103. Honker install without removing the shroud
  104. Upgrade the drive shaft in the TQ tube?
  105. How much can I sell a complete LS2 for?
  106. how to make A&A blow off valve loud? any info helps! thx.
  107. Yet another Ebay header thread.
  108. Rear Latch Rattle C6 Z06 when accelerating. WTF!!! ANybody have this???
  109. Went to the track ....
  110. F55 and Coilovers ???
  111. Cat back system- Cause for a slow car
  112. Service charging system
  113. skip shift eliminator
  114. LS3...500rwhp with mild cam?
  115. Need help identifying differential
  116. Got car out of storage and...MGW
  117. Need help removing fuel tanks!!!!!!!
  118. Got ahold of a stock z06 exhaust
  119. Jet Hot Coating
  120. onstar red light indicator
  121. How do you change out a steering wheel?
  122. Header Install?
  123. How to change out steering wheel on C6?
  124. C-6 and Z-06 hood differences
  125. 2009 Z06 performance increase?
  126. Genuine Corvette WO Extensions/Splash Guard Sale
  127. what i need to run a 11.9
  128. Torque spec's for a Header install
  129. Restoring Some Clutch Pedal Pressure
  130. Anyone using the LG Sport Shocks
  131. Tire Pressure Sensor Question
  132. Nearly 400 rwhp off simple mods... what next?
  133. new vette and verraram air intake
  134. "Pfadt inverted shocks",,
  135. Tough question
  136. Coilovers and alignment specs?
  137. Bolt on Performance
  138. Fichtner march madness specials
  139. Stripped Threads on Front Crossmember
  140. Active Handling Calibration
  141. Would this be a "500rwhp" cam for the LS3?
  142. 06-08 z06/ 09 zr-1 powercore air filter
  143. Cam selection for 418 LS3 Stroker?
  144. Cut bushings on stock bolts?
  145. •• Purchase HP Tuners Pro and get an Innovate LC1 for $139 or NGK AFX for $239!!! ••
  146. Looking for a good set of slicks
  147. stock car dyno numbers! is this high numbers?
  148. 6speed or Automatic??????????/
  149. 12v Accessory Outlet?
  150. Looking to gain 500 RWHP
  151. HiTech Vented Hood references and advice please
  152. Can I put the differential from an M6 in my A6?
  153. Suspension Bushings?
  154. drivetrain loss question
  155. 05 C6 going under the knife
  156. Torco SGO
  157. can 325 runflats fit on the 19x10 rim?
  158. Header install questions
  159. Start button does nothing
  160. Brake Pad Rotor Combo Z51?
  161. Hello from a New Southeast Sponsor
  162. C6 Side Air Vent in LMB & MS *PIC*
  163. Z06 exh manifold on C6 help needed
  164. mods for my 07 A6 - any thoughts?
  165. Upgrading Air Intake?
  166. Aftermarket CAI Thought / Help
  167. retrieving my past threads
  168. Automatic Shift Knob
  169. Hard time with Gas Cap???
  170. LS2 head comparision
  171. South Florida Corvette/Mustang/GM/Truck/Mopar Challenge 3/28/09
  172. Hurricane CAI
  173. Service Charging system light...
  174. What next...
  175. Why not Rotors out of Stainless Steel
  176. Racing Tire Questions
  177. New Tune on My Basic Bolt-on LS2
  178. Vararam,Kooks headers(1 3/4), 3x3 Xpipe, Corsa Z06 Sport, and a Tune
  179. Bolt on only LS3 1 3/4" or 1 7/8"..bottom line
  180. Methanol spacer?
  181. Best rim and tire combo for rear only widebody c6
  182. Pfadt Competition sways Arm Assembly ?
  183. 08' exhaust fuse jump?
  184. Underdrive Pulley install...$750?!?!
  185. What are the part numbers for....
  186. HallTech Killer Bee & Bee Hive Install Questions
  187. Maybe buying 2005 Z 51
  188. Converter guys
  189. C6 ls2 vacume tap
  190. C6 front end clicking noise
  191. Zo6 rims and tires on a c6 ???
  192. What's the best way to install DRs?
  193. * * * dennis50nj/CARTEK 'bolt ons only' C6 LS2 runs new best! * * *
  194. ferrari inspired bodykit.
  195. Motor HP verses RWHP
  196. Lowest price for Corsa Sport Exhaust !!
  197. Rocker Arm Upgrade Procedure
  198. NEW SERVICE: Performance Ceramic Coatings
  199. New corvette owners observations, is this normal?
  200. Need New Tires
  201. Cruise Control
  202. Wider tires better?
  203. any info on a bbk 1735 air intake
  204. Anyone use an engine oil extractor?
  205. expectations from mods
  206. Part # for the little snaps for the wheel liner
  207. Help! TCM removal
  208. Introducing our Carbon Fiber Driveshafts
  209. black smoke z06
  210. Does TM cause "grainy" feel to accelleration?
  211. silly question, is there a trick to get the spark plug wires off?
  212. Where do you buy fluids online?
  213. 1/4 mile DA
  214. Cure my Wheelhop: General Exclaims or Pfadt Coilovers
  215. Harmonic Balancer
  216. cam question
  217. Low RPM surging with the addition of a Honker...
  218. Racing Seats in Z06
  219. Z51??
  220. C6 Muffler Change
  221. new c6 NA and power adder record holder
  222. vararam vs. Hurricane
  223. Changing out stock pieces for Lighter weight Parts...
  224. The dreaded "CD MECH ERROR"
  225. Wheel Lug?
  226. G5X3 cam - trying this again
  227. Rim and tires
  228. Pfadt alignment settings
  229. Can I get engine error codes from DIC on C6
  230. HELP!! Charging system problem
  231. For those of you who ported their own Throttle Body...
  232. Cleaning the Glass
  233. 08 Base Coupe Suspension Swap
  234. Pulling the exhaust controller fuse
  235. Can 3" over axle pipes on Z06 mufflers be changed to 2.5"
  236. 05 A4 Rear Weak?
  237. Stripe or No Stripe?
  238. Exhaust
  239. o2 Harness
  240. Lets see your non-booty big brakes
  241. Kooks header question.
  242. Cam advice
  243. Rip that POS clutch spring out of your car!
  244. Help a newb
  245. Catless Mid pipe
  246. Shifter Buzz
  247. Clutch Problems at dragstrip
  248. Headers - what to buy?
  249. Time To Replace Air Filter
  250. Which setup is correct?
