View Full Version : C6 Tech/Performance
  1. **800 Naturally Aspirated HP from LG Motorsports**
  2. O2 Simulators
  3. Best All-Around Rotors for Z06 calipers
  4. How much does the C6 Z06 engine cradle weigh?
  5. Where to start????
  6. MAF location
  7. Anyone have Pfadt coil-overs on a dialy driver?
  8. Battery Relocation complete! Here's a few helpful hints...
  9. Cat delete
  10. ready to get back to the track ls3
  11. Power steering fluid?????
  12. unlocking -car is "asleep" syndrom
  13. Seat Moving?
  14. Tune, Headers, Cats, Intake..what next
  15. Mods On Budget
  16. Caliper Question
  17. No microphone wire?
  18. alignment experts - ??? - increased neg camber
  19. Low Freq Acoustic Resonance
  20. LG motorsport header o2 sensor cable length
  21. ls3 in a f-body
  22. Help - Stuck - Rear Hatch Glass removal
  23. A Pillar Gauge Pods
  24. Will ceramic coating on cat's........
  25. VIN , Vis report
  26. c6 rear diff cover broken help plz
  27. z06 muffler mod sound clip with G6X3
  28. Best Street Tire for Strip Use?
  29. *** Shop Specials at LG Motorsports ***
  30. short shifter install
  31. question for you tech guys - C6 Clutch Stop / Bumper
  32. **May Suspension Install Packages from LG Motorsports**
  33. quick question - alignment - C6 or Z06
  34. Is 1&1/2 ton jack good for C6
  35. Is Dot 4 Bad for C6 brakes?
  36. where do i find these valave covers!!!
  37. *** Forgeline Wheel & Tire Special at LG Motorsports ***
  38. *** Incredible Deal on ProCharger Installations at LG Motorsports! ***
  39. What Transmission do I have?
  40. Best Header for 09 Vette C6
  41. Need "heat sheild tape" alternative
  42. What's it worth....
  43. anyone on heres car?
  44. Code Scanner for BCM/TCM/etc?
  45. Need Help: NPP Exhaust
  46. A different way to get fresh air to the intake
  47. click when turning
  48. I love Royal Purple Synchromax!
  49. >> NEW MONSTER CLUTCHES Available NOW !!
  50. Harmonic Balancer Issues
  51. Strange steering Variable Effort Steering
  52. Rear Gear Mod Question
  53. zo6 exhaust gains on ls3
  54. "Another" brake bleeding question (!)
  55. Airaid 250-230 installed
  56. nut inserts on lower radiator support?
  57. anyone know where the horn mounts on C6?
  58. Vararam removal for cleaning
  59. PCM is tuner locked what can I do.
  60. I hate mods!
  61. General Exclaim UHP First Impressions
  62. 09 C6 Reduced Engine Power message followed by a Service Traction system
  63. ***Please help with battery relocation***
  64. A6 speed sensors?
  65. GMPP 19156429 Valve Cover ??
  66. New dragstrip times
  67. Callaway or Lingenfelter-which way to go ?
  68. Any down side to pulling the fuse on my npp
  69. Newest Stock GM Tune for 08 C6 MN6 LS3
  70. Drag Launch Techniques for 512whp C6 M6
  71. Cooling Issue
  72. Upgrade lights
  73. GM Parts House May 2009 C6 Specials.
  74. Genuine Corvette Accessory Splash Guards Available.
  75. Genuine GM Console Lid W/Jake Skulls In Stock!
  76. Track handling with 9.5" fronts and 13" rears
  77. Coupe wide body kits
  78. Coupes get loose with top off at high speed
  79. Drag launch techniques for 09 A6
  80. swaybars
  81. Anyone try the E3 spark plugs?
  82. Vbp pre-summer sale 15% off through may
  83. Jack Stands?
  84. Is c6 coupe rear pass compart. strong enough for a 43lb Optima Bat
  85. 2009 Z51 A6 Transmission -Radiator Connections
  86. need an ebcm for 2003
  87. Suspension options
  88. To Match A Tansmistter...or to unmactch - Please help!
  89. Bridgestone RE-11 tires FTW! (for the win)
  90. Pioneer Avic F900BT - Just bought one, have a few questions
  91. 345 tires on stock z51 c6 couupe
  92. Additional Oil Pressure Sensor?
  93. Doors won't lock/unlock with FOB
  94. LS3 Stock Exhaust Vs NPP
  95. Garage Floors
  96. P0442 Code Problems
  97. What's Next?
  98. rough idle 08 c6
  99. GM auto trans fluid vs. Amsoil auto trans fluid
  100. I want to relocate battery to the trunk but have a question
  101. Question... drag radial set up
  102. Factory Exhaust?
  103. Alignment camber gauge
  104. LS3 and 160 Motorad Thermostat Fitment?
  105. What i need to install LS7 exhaust manifold on LS3 engine
  106. May Group Special Z06 Front Wide Body Kit www.PartsTaxi.com
  107. LS3 Timing chain -CLOSE CALL - heads up
  108. Another Check engine light (no codes)
  109. Any tips/tricks for removing exhaust from axle back
  110. GHL bullet vs GT4 cat back mufflers from LG
  111. >>> Chuck CoW TUNING @ the Corvette Museum -CF Cruise-In Event<<<
  112. Can anyone post pics of the Corsa Mufflers/exhaust Please for c6 ?
  113. Anyone tried b&m transmission fluid consistency system?
  114. Just got my car out of the shop, now I can't put it in Comp Mode
  115. **Vette Doctors-ARH complete Exhaust System $1,895 Installed and Dyno Tuned!!**
  116. **Vette Doctors A&A Vortech Supercharger with Ram Air Intercooler $6,599 Installed!**
  117. here is a hard ??????????
  118. Question
  119. Veering Z51 Since New
  120. Any suggestions for type of ramps to buy
  121. And there she blows...........
  122. C6 - Turbo vs Supercharger
  123. Thanks for a great motor, Spin!
  124. Heat shield rattle ?
  125. LS7 manifolds on an LS3, do they bolt on or not?
  126. LG header install
  127. Vararam intake for 09 c6
  128. B&B Fusion 3in with A6?
  129. Question for the C6 Guys: *MAX* Tire Widths
  130. Quiter Exhaust
  131. WTB: 2005 C6 Shop Manual
  132. Speaker problem
  133. toe "out" front tires
  134. Power Capabilities?
  135. "service vehicle soon" on a 2008 z06
  136. Help with cam decision
  137. What kind of headers are "JJ" headers?
  138. Flowmaster and drone?
  139. Searched but cant find a DIY rear fender install
  140. Texas Motorplex This Friday
  141. C6 brake line change
  142. LS7 Heads....? Which ones?
  143. GM Bulletin 08-06-04-033C
  144. Does anyone make Cat eliminator test pipes?
  145. Lexan(?) / clear roof
  146. 265/35/18 & 305/30/19 on stock wheels?
  147. normaly asp, or forced induction?
  148. Special Price for CF ONLY - 2007 Official CVT PACE CAR WITH TWIN TURBOS - $44,000
  149. Grinding going into 2nd Gear... ugh oh?
  150. Michelin PS2 ZPs
  151. [new mod]Can the DVL get anymore EVIL?
  152. Replacing Coolant
  153. rim 19x11 +64mm size only will it fit
  154. rim choice +64mm with 305 will it rub?
  155. What's the strongest Battery that will fit in rear Passanger compartment????
  156. LS2 Cam only guys come in
  157. Lettering on windows
  158. Popping noise
  159. HRE Comp 20 Wheels on C6
  160. New Toyo tire?
  161. HELP!!! Pushing the start button does nothing
  162. MT ET Street Radial II vs ET Street which hook better?
  163. 700rwhp vs 305 street drag radial
  164. it's 90 here today and I got the codes again!!
  165. Where to PORT TB for my c6Z06?
  166. Pfadt Pfatty Sway Bars Truly Are FAT! Pics Inside :)
  167. Launch control
  168. Short shifter question
  169. TSB for 05 Fuel Gauge Flash
  170. Best 1/4 mile slick for C6 MN6
  171. Headers Dyno Numbers
  172. How to identify break rotors on my C6
  173. Reason for '09 LS3's dynoing better than '08 LS3's?
  174. F.A.S.T. LSX-R.. ANyone have one?
  175. Thinking ahead.. 243's, how much hp will they support?
  176. Do peel-and-stick side cove screens work?
  177. Installing a bunch of mods today
  178. Long Tube headers...what else do I need
  179. Speedometer not working
  180. RPM Signal and O2 signal
  181. Oil Control - Cartek Breather can installed
  182. Best tire for 19" rear wheel for traction
  183. "Traction system active" at high rpm
  184. Water pump pulley removal
  185. I should have done this from the get go….
  186. Z06 dust pads
  187. Head swap??
  188. Suspension Setup
  189. Advice on Tranny and Oil Cooler upgrade
  190. What is Your Oil Temp ?
  191. CEL (02 sensors throwing codes and blowing fuses.)
  192. New Wheel Set For Race Tires
  193. Safe to run without cats
  194. Air intake coupler size?
  195. Removing stuck wheels???
  196. best oil cooler for LS3
  197. COW 3:42 Attack Package …. WOW !!!!
  198. WTB HP Tuners Beginners at Home Course
  199. HELP:Service fuel system warning...
  200. Radio Noise
  201. C6 Exhaust Replacement
  202. Has anyone, or is it worth cutting the Radiator shroud on a LS3?
  203. Need opinions, heads??
  204. Downsides of UD pulleys
  205. Fuel rail covers - Yuck !!!
  206. Invo's in the wet and cold
  207. Looking for MILD CAM for LS3 Engine.....
  208. FAST 102mm and Larger Throttle Body
  209. Front Wheel Size
  210. Tire Selection
  211. Z06 middle pipe hits the heat plate. Please help
  212. High Tire Pressure?
  213. Do they make 28 inch slicks for 17 inch rim?
  214. Door Sill Replacement
  215. Short throw shifter info needed
  216. What Drag Class?
  217. Help
  218. •• LS3 Cam & Heads - results inside ••
  219. How do you delete the Tire Pressure Monitoring System (TPMS)??
  220. I Need Help!
  221. Water Pump
  222. Borla exhaust vs. American Thunder Flowmasters
  223. I'm punching myself 12v switch?????
  224. Do the C6 fogs fit a ZO6?
  225. Gaining 60 rwhp and 46 rwtq from bolt-on's in A6 LS3?
  226. SELLING for an especial price: 8% to 10% additional RWHP with FREE shipping!!!
  227. Generator/sound
  228. Twin-screw superchargers
  229. C6 automatic top
  230. vibration
  231. PFADT competition bar: please help
  232. Black chroming
  233. ZO6 mid pipe on a 08 C6?
  234. C6 HVAC heating system display LCD flashing
  235. C6 Unknown issue....HELP
  236. track run after gears/ line lock.
  237. Info: Ever part needed for an M6 swap?
  238. Are c6 foglights interchangeable on ZO6?
  239. *NEW* Beautiful 2005 D-Type Sport Steering Wheel *PIC*
  240. New CCW C14 corsair wheel color POLL
  241. Rt side muffler removel trick
  242. Got another tough question
  243. steering hose conversion to AN fittings/hose
  244. Hinson Motorsports now stocking Trickflow Cylinder Heads!! (Lots of Eye Candy Inside)
  245. Any tall guys relocate their inside rear view
  246. Torque Wrench Question
  247. Pacesetter headers?
  248. It's official - GM killed the Z51
  249. Non Runflat Street Tire Experiences
  250. Changing fan settings
